Results 36 to 70 of 73
Thread: BFI - Clean Catch Crankcase Oil Separator - for 2.0T FSI!
    Apr 2nd, 2011
    Grand Forks, ND
    02-22-2012 03:29 PM #36
    Quote Originally Posted by pete@blackforest View Post
    A catch can that empties to your oil pan is not ideal for a street driven vehicles.
    The can not only catches oil vapors, but as a consequence of the design water vapor will accumulate in the catch can as well.
    If this water was recirculated back into your oil pan, it would pollute the oil and reduce its ability to properly lubricate your engine.
    Routine emptying of our Clean Catch products is required in order for the product to work correctly...
    Is the Air/Oil Separator suitable for a stock/daily driver?- Yes... You can pull the intercooler off your new car with only 500 miles on it and find oil inside of it. The purpose of the AOS is to remove this oil from the intake system to lessen the possibility of detonation which is the main cause of broken ring lands on the stock pistons. As you increase your HP, the amount of blow by passing through your breather system increases as well. This scenario also increases the need for our AOS.
    A catch can needs to be emptied of its hazardous waste on a regular basis. Our AOS needs ZERO maintenance. A catch can emits the unpleasant smell of the crankcase fumes. Our AOS doesn't smell and is emissions friendly. Most catch can systems end up leaking or spewing oil in/on your engine bay while our AOS keeps everything clean and tidy.
    Also with oil not being removed from the pan, there is no worry of running low on oil whatsoever...also I don't personally know about the smell issue and maybe its more directed at VTA cans, but it's a good point nonetheless.
    An regarding the moisture theory there is this:
    3. What causes the yellow gunk? This is a mixture of oil and water. Usually when the water in the engine heats up it vaporizes and makes its way out the breather system. If it stays in vapor form it will make its way out the top of the AOS and into the intake. We have found from our cold weather customers that condensation is occurring inside our AOS as it is colder than the engine. This condensation is mixing with the oil in the AOS causing the yellow gunk. To fix this issue we have made a cold weather version that incorporates a heater inside the AOS to keep the AOS at the same temperature as the engine. With them being the same temperature, condensation will not occur leaving the water vapor to flow out the top of the AOS and into the intake system.
    Now these replies are from a STi forum, but the physics and functionality are the same
  2. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    03-12-2012 12:32 PM #37
    No more koozies!
    Black Forest Industries /// 919.468.5400 ext. 7014
    PM, Facebook, E-mail, or call us with any questions
  3. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    03-12-2012 02:44 PM #38
    Quote Originally Posted by Kelion View Post
    thought you contacted them, now it sounds like you ARE "them"...
    cool pic, terrible beer!
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
  4. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    03-14-2012 05:10 PM #39
    Quote Originally Posted by Krieger View Post
    The Koozies fit all makes and models.
  5. 03-15-2012 10:18 PM #40
    excuse my ignorance but this is the same as a traditional catch can yes?
  6. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    04-18-2012 01:42 PM #41
  7. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    04-26-2012 12:58 PM #42
  8. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    05-17-2012 03:24 PM #43
    Our Show Season Kick-Off Promotion has ended.
  9. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    05-24-2012 04:53 PM #44
  10. Member BETOGLI's Avatar
    Jul 15th, 2010
    MEXICO CITY
    2007 JETTA GLI, 2012 GOLF GTI 35TH ANNIVERSARY
    05-24-2012 08:10 PM #45
    I would love to buy this Clean Catch Can since IMO it's the best looking on all the market!... The bad thing is that my car came with a Charcoal Canister! Do you have any application or solution for this?
  11. Member BETOGLI's Avatar
    Jul 15th, 2010
    MEXICO CITY
    05-25-2012 05:37 PM #46
    Bump!
  12. 05-29-2012 10:57 AM #47
    Quote Originally Posted by BETOGLI View Post
    We are working on it, but its going to be some time before we expect it to be available. While this is for the rest of world cars everything outside the U.S. has a canister.
  13. Member BETOGLI's Avatar
    Jul 15th, 2010
    MEXICO CITY
    05-29-2012 12:24 PM #48
    Quote Originally Posted by black forest ind View Post
    Thanks for letting me know this! And for sure I'll buy two of them once they're realized!
  14. Member
    Oct 23rd, 2006
    2012 Golf R
    06-02-2012 09:58 PM #49
    For the "average" customer what do you expect drain intervals to be?
  15. 06-04-2012 10:09 AM #50
    Quote Originally Posted by webcrawlr View Post
    Unfortunately it varies a lot depending on the driver and their surrounding climate. At the very least you should check it at every oil change if not sooner. If the dipstick reads full, dump it.
  16. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    '08 GTI, '12 Beetle, '91 Passat
    06-30-2012 11:05 AM #51
    Call me a noob, but I have a question.
    On the stock pcv it dumps the crank case pressure into the intake manifold, correct? With the catch can setup the intake manifold is capped off. After the oil is seperated the pressure looks to go back into the valve cover. Where does it go after that? Why cap the intake manifold? My main question is, where does the crankcase pressure go after the oil is seperated?
    Total catch can noob and trying to wrap my head around it. Thanks
    // DROP // DRAG // DESTROY // beer
    // Open Road Tuning
    Instagram: @bryangb
    bags and wheels = build thread
  17. 07-02-2012 10:56 AM #52
    Quote Originally Posted by bryangb View Post
    The 2.0T FSI has two pcv ports - that alternate direction depending on load and vacuum/boost level. Our system blocks off the pcv port to the manifold - or in reality - redirects it back through the port in the valve cover to the rear pcv port. That way all pcv gasses pass through the catch can before entering the intake tract. It also allows the pcv to maintain constant draw.
  18. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    07-02-2012 10:19 PM #53
    Where does the rear pcv port dump?
    // Open Road Tuning
    Instagram: @bryangb
  19. 07-03-2012 10:18 AM #54
    The rear port attaches to the intake plumbing just above the turbo.
  20. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    07-12-2012 10:20 AM #55
  21. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    07-17-2012 03:09 PM #56
    Our Waterfest Promotion has ended. Thanks for all the orders.
  22. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    08-14-2012 11:14 AM #57
  23. 08-22-2012 01:47 PM #58
    What are you guys doing with the rear hose off the valve cover. Doesn't that go right to the intake?
  24. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    08-30-2012 03:20 PM #59
    No more sunglasses. Thanks for all the orders!
  25. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    09-26-2012 03:53 PM #60
    Our H2O Promotion has ended!
  26. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    10-04-2012 11:53 PM #61
    wheres your mk4 / 1.8t catch can setups...
    the car is on an inclined driveway and up on jack stands in the front only
    VW's don't leak oil, they just mark their territory!
    Master L1 ASE certified
  27. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    10-05-2012 10:36 AM #62
    Quote Originally Posted by Slimjimmn View Post
    Soon. We have a prototype coming and we'll have it installed on my 1.8t GLI.
  28. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    10-05-2012 09:41 PM #63
    I can install a prototype on my car ;-)
  29. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    11-12-2012 02:22 PM #64
  30. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    11-19-2012 02:15 PM #65
  31. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    11-20-2012 10:39 AM #66
    Our Black Friday Sale was a huge hit! Thanks everyone!
    Last edited by pete@blackforest; 11-29-2012 at 03:44 PM. Reason: Black Friday Sale has ended
  32. Member BETOGLI's Avatar
    Jul 15th, 2010
    MEXICO CITY
    11-30-2012 10:12 PM #67
    ... I need one... But my car has a Charcoal Canister!
  33. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    12-06-2012 10:41 AM #69
    Quote Originally Posted by crew219 View Post
    Two weeks and it still hasn't shipped
    We have been communicating with customers that were impacted by component delay and now, to the best of my knowledge, all Clean Catch orders have already shipped.
    If you have not received your tracking number via e-mail, please send me a PM with your information and I will investigate the whereabouts of your order.
  34. 12-07-2012 08:52 AM #70
    I was sent tracking info on the 3rd which didn't move until you delivered it to USPS on the 5th.
    Placed the order at 12:06AM on black friday. Should have been one of the first ones sent out. I received no such communication until I called in after a week of not receiving a tracking number. Was promised that my order would ship within the next two days. Took a week from that call for it to ship.
    Dave
