VWVortex.com - CB Performance Hide Away Turbo Kit
    Results 1 to 2 of 2
    Thread: CB Performance Hide Away Turbo Kit
    1. Junior Member wicked1lbc's Avatar
      Jan 13th, 2011
      Suffolk, VA.
      1964 VW Bug
      08-05-2011 10:17 PM #1
      I got 2 CB performance turbo kits, one that Ill keep and the other to sell. The one I'm gonna sell comes with a single turbo prepped Dellorto 45 and the ducting for it that also doubles as the ducting for the Dual carburetor set up plus the manifolds for the duals. So basically its the hide away blow through kit for with a single carb + the gear to expand to the dual carb set up if you choose to do so in the future(all you will need is another turbo prepped Dellorto 45, or another set of turbo prepped carb's + linkage). It comes with the supply/drainage lines and the modified tins you'll need to run.... The turbo is a RayJay, as is the waste gate, and has virtually no end play with minimal side to side action. Turbo is tight and spins smoothly. I may break down the header to clean it up and hit it with Hi Temp header Paint and post better pictures. The Dual Carburetor's DO NOT come with the kit they are just mocked up for an Idea of what you'll be looking at with that set up.
      parts list:
      Rayjay Turbo
      Rayjay Waste Gate
      CB Performance Hide Away Header & J-tubes
      CB Performance Hide Away pressure ducting
      CB Performance Hide Away carburetor hats
      Single Turbo Prepped Dellorto 45 DRLA
      Custom Aluminum "box style" hat
      Tapped Dual carburetor manifolds **NOT THE EMPI ONES THAT I ORIGINALLY POSTED**
      Single carburetor manifold
      Turbo oil supply/drainage lines
      Should bolt right up and that's it. Tuning required of course. Best offer takes the lot. I'm building a fresh 2276cc turbo and may take trades or trades + cash. Crank, Heads, Pistons, Barrels ... let me know what you got. Buyer Pay's Shipping.
      Thanks for looking. Matt
    2. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      1971 Super Beetle, 2014 Golf TDI Manual, 2015 Silverado 1500 LT 4x4 Crew Cab
      08-07-2011 12:29 PM #2
      Price ?
