Page 8 of 20 FirstFirst ... 4 5 6 7 8 9 10 11 12 18 ... LastLast
Results 246 to 280 of 693
Thread: Bariman82's 1998 Jetta restoration
  1. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    windsor 2.0, ginster 1.8t
    04-17-2012 02:12 AM #246
    nice. wish i could pick up another car so i could do this to my car
    Quote Originally Posted by ZACHER3tuning View Post
    only on vortex, could this turn into a argument.
    http://forums.vwvortex.com/showthrea...Project-molest
  2. Member Juggy's Avatar
    Nov 21st, 2005
    97 VR6 DE, '04 Passat GLS 1.8T
    04-17-2012 11:09 PM #247
    Out of all the rusty areas I got you beat, this one is where I'm ok, but the area where I have to repair is where the inner wheel well meets thefiller hole. I'll be cutting that area out a replacing it, but was thinking of fiber glass. Not sure yet but I too have been putting this off due to it being the trickiest bit.
  3. Member Juggy's Avatar
    Nov 21st, 2005
    04-17-2012 11:10 PM #248
    Did you disconnect your fuel lines when u dropped ur tank, someone said you can drop the tank without unhooking the lines.
  4. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    1998 Jetta 2.0, 1966 Beetle 1915cc
    04-18-2012 03:10 PM #249
    No, you don't have to disconnect the lines from the tank when you remove it. I disconnected them from the fuel rail, pulled them through and out it all came.
    Quote Originally Posted by mhjett View Post
    I'm convinced you commuted through a salt mine.
    Quote Originally Posted by Mk3_Addicted View Post
    Bariman82 is the king of rust patching...He is the guy you want to talk to.
    My take on fixing a rotten mk3.
  5. Member Juggy's Avatar
    Nov 21st, 2005
    04-18-2012 03:50 PM #250
    Quote Originally Posted by Bariman82 View Post
    Fuel Rail? Meaning from the engine bay you pulled them all the way through?
    Wasn't planning on doing all that.
  6. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-18-2012 04:01 PM #251
    Yes. You can drop the tank and push it over to the side, though. Just be careful with the lines. You either disconnect them at the tank or the fuel rail.
  7. Junior Member
    Apr 11th, 2012
    Sweden
    1999 Golf IV 1.6SR
    04-18-2012 04:46 PM #252
    Well, since posting my question I've been under my car and had a real good look at the fuel tank so now I don't need a picture of that, the picture of the wheel well and the hole in it gives me an idea of what mine looks like, the metal around the filler neck is completely rusted away and it's just a small part where the screws for the flap hinge that's not completely gone yet... This will become most interesting indeed...
    A small advice on welding the outer sheet back in(rear wing of car), make a strip of sheet steel and weld it to the body of the car and then put the outer pieces of the filler cap back onto that, tack it in and then fill up the space between the body of the car and the newly welded filler cap/flap piece with filler(sorry, don't have the correct vocabulary for everything technical in english since I'm swedish)... If I beat you to it, I'll make sure to post you some pictures, ok?
    Thanks for the pictures you've shared, they help a lot!
    VW is the next best thing to the Kässbohrer Setra!
  8. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-18-2012 05:19 PM #253
    Your English is fine. I understand what you mean.
    I like your idea with the strip of metal behind the body. The extra metal might prevent burning through, which is something I've struggled with. My repair won't be pretty, but it will be rust free.
  9. Member Slayer's Avatar
    Aug 8th, 2000
    Windham CT
    2008.5 GTI w/TSI motor, 1995 GTI Vr6
    04-18-2012 07:03 PM #254
    Hah, cool thread.. going to be doing this on my 95 Gti at some point
    Check out my Garage build thread - 08.5 GTI 2.0T TSI, APR stage2, APR intercooler, 42DD 3" Catless Downpipe, Autotech 3" Exhaust, Full Carbonio intake, AWE DV relocation, BSH Motormounts, Coolingmist CMGS stage2 Meth injection, Dieselgeek Shortshifter, Southbend Stage2 Endurance clutch, Forge Shift knob, Euro LED tails, Koni Coilovers, Miro STP3 19x8.5 rims, General Exclaim 225/35/19 Tires
  10. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-18-2012 07:11 PM #255
    Quote Originally Posted by Slayer View Post
  11. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-20-2012 06:13 PM #256
    Busy busy. I have the rear beam and backing plates blasted, POR'd and assembled with new stub axles. New bushings going in this weekend. I just did them 15,000 miles ago, but they're cracked already.
    Floor, trunk and backseat etched.
    Paint!
    Pedal cluster, booster and new master cylinder are in too.
    I still have to POR the rear wheelwells in order to get the suspension on. The Metal Ready is really making a mess in my garage on these larger areas. I'd like to get the car in the driveway so I can do the underside. Which brings me to suspension. A top-to-bottom suspension replacement is around $600 from GAP. Man, if anything gets you thinking about coils, THAT would be it. Let's see what my next paycheck brings. I've got one lowered car already...I'm not sure I want another. I know the answer is always to lower it, but what do you think? I would only consider good coils (H&R, B&G) because ride is more important.
  12. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    98 GTI Vr6-T (Project) | 96 GTI Vr6 (SOLD) | 97 Passat Wagon Vr6 (Daily)
    04-20-2012 07:47 PM #257
    Nice. I like checking this thread every once and awhile. Still doing good work
    As far as suspension. You don't HAVE to get coilovers to have a good ride. If you aren't really in to having another lowered car, I would suggest a good cupkit. Ride height is lower, obviously, but not to where most people spin their coils down, and the ride isn't the bouncy mess that cheap coils are.
    For the record, my other GTI with a full Weitec 60/40 rode SO much nicer than my current JOM coils. Ride height was nice looking, and I really didn't have to worry about swerving all over the road to avoid the smallest crap. Just my experience.
    All depends on what you really want for the car and of course, how much $$ in your pockets
  13. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-20-2012 07:59 PM #258
    I want it to be comfortable to drive and ride in for my passengers, as close to stock as possible. I'm not into having it look a certain way or scoring internet points with it. I think I just answered my own question.
  14. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-20-2012 09:05 PM #259
    Sounds like it to me. Get some fresh OEM's on there and call it a day
  15. Member leecatd8209's Avatar
    Jul 13th, 2010
    Sullivan County, PA
    1995 Cabrio, 1989 Jetta 4dr, 1982 Pontiac Trans Am, 1961 Fiat 500, 1969 Z/28 Camaro
    04-20-2012 09:06 PM #260
    This is just insane, but I love it. I've restored quite a few legitimately collectible vehicles before, but I've never gotten this wrapped up in a "daily".
    Your welds are really progressing, I still run into some of my old work every once in awhile and sometimes it's enough to make me cringe.
  16. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-20-2012 09:13 PM #261
    Quote Originally Posted by leecatd8209 View Post
    Believe me, I think about that all the time. Next time, if there is one, I'll do this to a vehicle that will actually have some value when I get done. Nonetheless, it's been fun. I wasn't ready to junk it.
    I was so ashamed of one particular patch that I went back months later and redid it. The welding is almost done...I think.
  17. Member heerschap's Avatar
    Mar 18th, 2009
    ontario
    97 Ginster DE/95 Jetta GLX (RIP)
    04-26-2012 02:09 PM #262
    awesome work! you will pretty much have a brand new car when your done. lots of valuable info here too.
  18. Member mhjett's Avatar
    Oct 16th, 2000
    Northern Virginia
    2008 VW Jetta SE
    04-26-2012 02:14 PM #263
    Just an FYI, but if you ordered your rear beam bushings from GAP - I've had bad luck with getting some non-OEM parts from GAP that didn't last worth a damn. For example, tie rod ends where boots cracked prematurely, parking brake cable boots that rotted in 9 months, etc. GAP used to be my go-to place, but I've now put more effort into making sure the stuff I buy is genuine OEM and not Chinese-made or some other crap.
    1995 VW Jetta GLX VR6 [07.2003 - 03.2012]
  19. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-26-2012 02:43 PM #264
    The new rear axle bushings are from AutohausAZ, as is most of my recent round of parts. Rear strut bearings, rear springs, front spring perches are from GAP this time, and the rubber parts all say 'Made in Germany.' I've read complaints about GAP from people, but my experience has been great with them. Nonetheless, I am shifting my purchases to AZ when I can.
    Meanwhile, work continues. I'll try to get something worth updating this weekend.
  20. Junior Member
    Apr 11th, 2012
    Sweden
    1999 Golf IV 1.6SR
    04-26-2012 04:18 PM #265
    Nice seeing your progress Bariman!
    I took a few steps towards mine today by visiting the junkyard with my friends Mr Sawsall and Mr Ratchet. This netted me two much better looking rear fender liners(dunno the correct word, I'm sure you get what I mean anyway) of which the right one included the oh-so feared gas filler mayhem in quite good condition compared to mine(which is now see-through to the ground!) and three better-than-mine tank bands... Next week will be devoted to this "cheapo-restoration" of my car... I can't say I'm looking forward to it but it has to be done so I'll suck it up and fix the thing.
    Thanks for the inspiration from your restoration!
  21. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-26-2012 06:34 PM #266
    You are more than welcome. I just got back from the junkyard myself. I took Mr. Cutoff Wheel. Also, my car is pristine compared to some of those hulks in there. Sheesh. Rusty piles...
  22. 04-26-2012 06:42 PM #267
    This is a serious restoration job.
    I wish I lived close by so I can come over and check that car out...
    Great job.
  23. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-26-2012 06:43 PM #268
    Where you at? I have burgers and homebrew.
  24. Junior Member
    Apr 11th, 2012
    Sweden
    1999 Golf IV 1.6SR
    04-28-2012 04:29 PM #269
    I've started stripping things off from my car today... Let's keep it simple by saying "OUCHIES!", both whole sides where the rear skirt mounts to(the sheet wings pointing downwards) are goners and I won't rebuild them, I'll cut them off and improvise new mounts from threaded rod or something similar... ugh I say, this will be one hell of a week... Your car is in mint condition compared to mine.
  25. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-29-2012 12:01 AM #270
    I'm confused. Which location are you referring to?
  26. 04-29-2012 12:31 AM #271
    I'm in California and I'm impressed for all the work you've done to your almost junk-rusted car. You're going to have an almost brand new car there when you're done.
    CHeers
  27. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-29-2012 01:28 AM #272
    Thanks for the thoughts. That's the plan and I'm stickin to it.
  28. Member Mk3vr97's Avatar
    May 7th, 2010
    The Empire State
    96 2.turtle (R.I.P), 97 4door Slut
    04-29-2012 02:22 AM #273
    Awesome progress man
    Tim..Michelle|GarageQueen..CORNSTATUS
    Quote Originally Posted by JohnStamos View Post
    Everytime I come in the Mk3 forum, I want to send my car to the crusher due to embarrassment.
  29. Member LucidDisarray's Avatar
    Dec 26th, 2008
    Chicago Northside
    VR6
    04-29-2012 10:21 AM #274
    God Damn!
    I have some serious catching up to do
    Looks great
    WOTFilms
    My "Stock" build.
  30. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    04-29-2012 12:47 PM #275
    Hey, nice to see you again! Yes, you do. I've been busy.
  31. Junior Member
    Apr 11th, 2012
    Sweden
    1999 Golf IV 1.6SR
    04-29-2012 04:09 PM #276
    The sheet/pinch welded thingies that run from the rear wheel wells all the way back to the rear end of the car, inside the plastic rear bumper/skirt. The ones that facilitate mounts for the skirt/bumper... They are completely rusted away on my car.
    I'll fire up a thread of my own right next to yours I think, just gonna get todays worth of pictures onto my computer... I've fixed that dang fuel filler cap first of all, now all I need to do is find a **** oscillating sander, sanding it all by hand is... awful at best.
    Here's my thread: http://forums.vwvortex.com/showthrea...vier-than-rust...
  32. Member bherman13's Avatar
    Sep 9th, 2010
    The Village of 7,400 Location:___ and the City of 3,100
    MK3 VR6 Jetta Vehicles:___ B4S TDI Passat
    05-03-2012 01:10 AM #277
    Well holy crap. In the time it took me to read through this thread, it has scared me about what my lurk in my car ('99 mk3 GLX), taught me a few things about my own, inspired me to make plans to do this once I graduate, then lose faith in the fact that it doesn't seem worth it to me personally, only to wish/hope I someday have the shop and tools to do this to a car I love just for the fun of it. Overall though, I have gained much respect for you and I cannot wait to watch it all come back together. I hope you enjoy your nearly brand-new mk3 that can last for decades more now.
    Also, I'm glad the part of Illinois I live in is much farther south than you and there is much much less snow here during the winter (comparatively).
    "Artificial Intelligence usually beats natural stupidity." <---- If we apply that logic to driverless cars, the future of commuting should be just fine.
  33. 05-03-2012 03:16 AM #278
    I feel ashamed i can´t even give my car a tune-up. Fantastic work, keep it up!
  34. 05-03-2012 03:27 AM #279
    I'll bet that those rear bearings weren't tightened in correctly, or weren't packed well if at all with good grease. Get some coastal moly or some mobil1 synthetic grease and hand pack them even if they come greased. Then you want to follow the bentley install instructions because there is a process to install the nut before putting in the cotter pin. Then check the free play of the bearing every so often by grabbing top and bottom of jacked up tire and pushing and pulling it towards and away from you. There should be ***slight*** play.
    LUK VR6 CLUTCH AND PRESSURE PLATE FOR SALE PLUS MORE!!!>>>
    http://forums.vwvortex.com/showthrea...t-inserts-9346!
  35. Member Bariman82's Avatar
    Jan 26th, 2004
    Rockford, IL
    05-03-2012 03:29 PM #280
    Quote Originally Posted by bherman13 View Post
    Thanks. It's been fun, actually. It depends on how bad it is and how bad you want to keep it. I take my notes from the mk1 guys, some of who have rotted out rear beam bracket mounts. I would scrap a car over that, but some like to fix it. Some would scrap my car here, but I like to fix it.
    Quote Originally Posted by Mex gti View Post
    Well, start with little things. Oil and filter is a great place to begin. Then try the spark plugs. Before long, you'll move up to brakes and maybe rear wheel bearings. It won't happen overnight, but start with easy things to build your confidence up.
    Quote Originally Posted by 'dubber View Post
    The problem I had was with the rear beam rubber bushings, not the wheel bearings. And yes, I screwed up the install of them. I did trash a rear wheel bearing (and almost the stub axle) last year when I thought it would be safe to leave the dust cap off. Oops.
