VWVortex.com - Flashing CAN Gateway
    Results 1 to 3 of 3
    Thread: Flashing CAN Gateway
    1. Member Tanqueray's Avatar
      Feb 19th, 2011
      Washington D.C.
      08-08-2011 12:06 PM #1
      So I've read over this instruction to flash a new CAN gateway.
      Correct me if i'm wrong.
      1) Open VCD with your old CAN pluged in, and enter 19. Can Gateway and click 07. Coding to acess Long Coding Helper.
      2) With your old CAN still pluged in, write down everything that's checked or highlighted in blue in each of these menus (red arrows)
      3) Install the new CAN and check or highlight everything written down from the old CAN.
      4) Enjoy your new CAN gateway.
      Did I understand this instruction correctly?
    2. Member Tanqueray's Avatar
      Feb 19th, 2011
      Washington D.C.
      08-11-2011 05:09 AM #2
      40 views and nobody?
    3. Member najel's Avatar
      Apr 10th, 2008
      Mankato MN & Bielefeld Germany
      66 Mustang & 03 Jetta GL & 09 JSW TDI
      08-11-2011 09:16 AM #3
      It would not be considered flashing, just recoding.Your description sounds right to me. This means that when you first plug in the new module, you will probably not be able to access anything else in your car. Once you recode the CAN module to tell it which other modules are installed, everything should work as expected.
      I think the VCDS forum may be the better place for specific questions like this.
