VWVortex.com - 1982 Rabbit S- progress report (slight build thread begins)
    Page 3 of 5 FirstFirst 12345 LastLast
    Results 51 to 75 of 114
    Thread: 1982 Rabbit S- progress report (slight build thread begins)
    1. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      1982 Rabbit S, 91 cabby (blew up), 1984 rabbit gl 4dr that my ex (the devil) wont give back
      08-20-2011 08:33 PM #51
      i figured out when i had my dash apart that there was no glovebox light,
      so while at the yard pulling the 944 door handles i also grabbed the glovebox light, did some mods, and mounted it on the side in my glovebox, i think it is a small, but possibly a pretty unique touch
      friends dont let friends have dirty door jams
    2. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      08-20-2011 08:34 PM #52
      ^sorry for the crappy cell phone pics^
    3. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      08-21-2011 07:49 PM #53
      my porsche glovebox light WORKS!!!!!
    4. Member rallydiesel's Avatar
      May 10th, 2006
      SK
      2006 Jetta TDI, 1981 Rabbit, 1991 Jetta TD (sold)
      08-21-2011 11:52 PM #54
      Nice build!
      Once you go "clack", you never go back.
    5. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      08-24-2011 05:11 PM #55
      intake is ported, just need to get this dang T/B together
    6. Member jpawl's Avatar
      Apr 12th, 2000
      Lynn, MA
      '83 Rabbit Gti Callaway Stage I, '81 Scirocco, '83 Scirocco Callaway Stage II
      08-28-2011 09:40 AM #56
      Quote Originally Posted by thumper82 View Post
      could be. i have no clue, there really isnt much info on the S's. i'm sure someone on vtex has some sort of answer.
      I have a few 1982 Rabbit brochures up for grabs.
      It includes specs on the Rabbit S, colors, and options available for each model of the year.
      Nice duckbill, eh? This was certainly the bunny to get just before the GTI was available.
      http://forums.vwvortex.com/showthrea...ure&p=73140984
      Thanks,
      Jim
      Jim
      1983 Rabbit Gti Callaway Stage I, 83 Scirocco Callaway Stage II, 81 Scirocco
      1979 Scirocco Limited Edition - back from the dead
      Callaway Rabbit GTI build
    7. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      08-28-2011 09:58 PM #57
      thanks jim. pm sent
    8. Member rabbitnothopper's Avatar
      Oct 19th, 2009
      D-Town REPRESENT : Texas
      RIP81. 78 VW Rabbit 1.5L EH 4speed 020 GC->GP, 82 Rabbit Pickup 1.6D
      08-29-2011 12:42 AM #58
      this is the cap that came on my car
      it looks stock and legit to me
      i replaced it with one of those metal locking caps
      nice ride
      sorry you sold all those other awesome ones...
      -edit-
      actually about the gas cap
      i have mine here in my hand
      mine has words on it
      "warning fuel may be under pressure spray may cause injury remove slowly"
      and it does not have VW-Audi on it anywhere
      thus, my suspicion is it was an aftermarket part in the late 80's early 90's because someone lost theirs
      i typically set mine on the rear bumper... so not surprising someone would drive off with it still there like an idiot
    9. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      08-29-2011 06:02 PM #59
      Quote Originally Posted by rabbitnothopper View Post
      nice ride
      -edit-
      i inquired about the cap a while back and learned that they are VW...just not a common one. and from what i learned is that not too many people are fond of them so they seem to be tossed for the traditional "star" caps, or the metal locking caps. i kept mine, but currently have the later cabriolet star cap with the lock under the flap.
    10. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      09-20-2011 05:52 PM #60
      I only need a filler neck now. Anyone have one?
    11. Member brad131a4's Avatar
      May 21st, 2003
      Sammamish
      01 S8 ( totalled) 09 Jetta S, 11 Golf TDI, 90 vanagon
      09-20-2011 06:39 PM #61
      Looking at the pics and notes. I see you used stainless steel nuts and studs. If you haven't started the car I'd recommend that you change them to just the brass nut and regular studs.
      Reason is you will not be able to remove them after they've heated up.
      Worked on a vanagon which the owner used ss bolts and nuts. I think only one didn't break or that I had to grind the nut off.
      Thats after letting them soak in PB Blaster over night.
    12. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      09-21-2011 04:03 PM #62
      Quote Originally Posted by brad131a4 View Post
      Thanks for that info. I haven't started the car yet, but I dont plan on keeping the motor in, I'll eventually swap it. But from what you're sayin it be a goodthing to change since I'd have to unbolt the header to pull the motor
    13. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      09-29-2011 07:41 PM #63
      finally started the lil feller up, i dont know how to just post the vid up so if someone knows an easy way to do it let me know
    14. Member
      May 17th, 2011
      Nebraska
      82 quantaum
      10-02-2011 11:00 AM #64
      hey man, i Replaced all the gaskets on my S and new timing belt. got those studs out and installed the header.
    15. Member
      May 17th, 2011
      Nebraska
      82 quantaum
      10-02-2011 11:15 AM #65
      this is the day i picked it up, shes a little more banged up as you can see. And you can see how our harsh weather here in maryland has taken a tole on her paint job over the years.
    16. Member
      May 17th, 2011
      Nebraska
      82 quantaum
      10-02-2011 11:25 AM #66
      machined the head is all nice and shiny, had to weld onto the broken stud to get it out, let me know what you think also after 2 an a half months i got my diamond steelies. ill be sure to post a pic as soon as i get em on!
    17. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      10-02-2011 06:07 PM #67
      Quote Originally Posted by Llcoolchris View Post
      yes, hurry up and get them rims on still have that roof rack?? my lil bro wants one for his mk2... i want to hear your isht on straight header
    18. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      10-02-2011 06:11 PM #68
      chris, i also noticed that you dont have openinig vent widows. i was thinking on swaping the solid ones out for the opening wings but i cant seem to find any bolt thrus in good shape oh well some day, not on my list of "NeeD" to have yet
    19. Member nnamssorxela's Avatar
      Jul 19th, 2009
      Colorado
      '97 E350 Powerstroke, '09 Ninja 650R, '06 WR450
      10-02-2011 06:52 PM #69
      I'd like to know the specs on those diamond wheels. Are they pretty well balanced from the factory? What's the actual weight of them?
    20. Member
      May 17th, 2011
      Nebraska
      82 quantaum
      10-05-2011 06:26 PM #70
      The specs are 15x8 w/ zero offset. the front is 5inch backspace and rear 4 1/2 in the rear. They are VERY WELL made. the only downfall was i waited 2 1/2 months for them. But very much worth it. i think there like 18 pounds each?(could be wrong i will weigh them tonight and give you the correct weight)
    21. 10-06-2011 11:49 PM #71
      awesome build! keep it up mate
    22. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      10-07-2011 11:59 PM #72
      thank you sir
      its been a fun build for sure, but i am FAAAR from done
    23. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      10-28-2011 01:06 AM #73
      a few new pics, but havent really done much on the lil feller lately. but got lots done on my lil bro's 86 wolfy
    24. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      10-28-2011 01:30 AM #74
      and a few more
      before the bottle caps and H&R suspension (on the jetta)
      finally got my ////Alpine 3 shuffle in and brain mounted in the dash
      and some rims i picked up dirt cheap (from an old school alpina bmw) 4x100, better offset and they have all 4 beauty rings.
      plus my VW center caps will work nicely
      more to come
    25. Member thumper82's Avatar
      Dec 15th, 2010
      colorado
      10-28-2011 01:52 AM #75
      one for ishts a giggles
      my other lil bros mk3
