#71
Ok, so I'm going to bring this thread back some, so hopefully we can get some clear cut answers for others out there.
Update: I sent back the first switch I ordered and get a replacement one from ECS trouble free. Installed the new one, and front fogs work as designed, sorta. When the front fogs are turned on, the cornering lights also come on as well. Any idea as to what coding has to be changed for this to stop. I don't really want to burn the cornering lights out prematurely. This is on a 2012 CC R-Line.
- Robert
#72
#73
Yes, here's the website:
http://www.dbcperformance.com/3C8941...941431axsh.htm
I haven't attempted the rear fogs wiring yet since no one else more daring has been able to figure out the 2012 DIY yet.
~ 2012 VW CC Luxury Plus ~
Light Brown Metallic | 35% Tint all around | WeatherTech Digital Fit floor mats | Infinity Basslink | Euro Switch | K&N Drop-in | H&R 24mm RSB
#74
Looking to get the Euro Switch for my 2012 6MT R-Line...and save some money. So, this one won't work right for "fogs as DRL" and some other functions (with or without VAGCOM programming)? http://www.ebay.com/itm/120797526526...84.m1423.l2649
2012 CC R-Line, 6MT, Night Blue - LED Turns, Euro Switch, GIAC Tune, RLine Pedals
Mods to Come: SSK???
2006 Subaru Baja Turbo, AT - Open Source Tuned (Florida)
1997 Mazda Miata, 5MT (Fair Weather ONLY)
2005 Lotus Elise, 6MT (Sold 2009)
#75
Ready to order the Euro Switch. Which was the first switch that you ordered and from where? Problem with the front fogs?
Still looking to purchase this one - http://cgi.ebay.com/ws/eBayISAPI.dll...m=190627134988 . Part #5ND941431B XSH
SlavaKM - yours is working OK? Rear Fogs with trigger?
#76
#77
i have installed euro switch on my 2010 sport
but i noticed that when it was stock even i left switch on and take key out all lights were turned off automatically
not when i take key out while leaving switch on, parking light stays on
is this normal for even euro cc?
most of time i just leave the switch on auto but sometimes i use fog light and forgot to turn it off
#78
If you leave the switch on ON with Fogs on, after turning the car off. Your parking lights will stay on.
The car will "beep" to alert of lights on, if that isn't enough for you - i dunno what to tell you.
I dont know if they turn off after a few minutes however, i never tried to see what would happen.
Maybe manual has something about it listed.
#79
So I am having trouble taking my old switch out. I popped both panels off, turned it to off, and pushed the knob in. I can't get it to pop out. Is there a trick?
#81
#82
Right but if he's having a hard time and has the panels already off....it doesn't hurt to push it from behind to make sure it'll pop out
2013 VW
#84
The ebay one works perfect on my 12 R line.. Does everything but rear fogs. I did open the cubby and give a push from behind to help out the stock switch. took 3 min to do the entire thing..
13 R stage 1
Philthy PA
EUROFINE
#85
MODS: APR Stage 1 Flash | APR Carbonio Stage 1 CAI | 35% Tint All Around | EuroSwitch | 4,550K Hi/Lo Beams | Nokya Hyper Yellow Fog Bulbs | Blacked Out Front Turns | H&K 24MM RSB | BFI Torque Arm Insert Stage 1
FUTURE MODS: Rear Fog | Lots of Vag-Com Work (DRL, FOB Windows, Auto Rain Up) | Forge Short Shift Kit | Coil Overs | Stage III or K04
#86
I know this is an old thread but I just received and installed my euro switch in my 2010 CC, it came with fogs.
Everything is working but when I turn the switch to the position right past auto (which I would think is for "city/parking" lights) the only lights that come on are the headlights.
Is this how it is made to work?
#87
#88
I have not done any VAG-COM programming as of yet. My understanding was VAG-COM was only needed if you wanted rear fogs or to turn off the DRL's.
It almost seems like the switch is wired backwards because in the position right past auto the only lights that work are the main headlights, with the switch in this position it turns off all dash-parking-tail lights and only leaves on the headlights which is basically useless.
If I pull the switch out while in this position then the fogs come on with the main headlights.
#90
I was curiousif anyone has installed a Euro switch on a 2013 CC.
Since the DRL's are now a separate light from the headlights how would the switch function without programming?
Thanks for your input
#91
Curious as well. I have a 13.
#92
2009 CC sport auto , black on black, %20 tint all around, euro switch, rear fog, DRL delete, Hoën fogs, Clear turn signals, LED plate lights, RCD-510 AE, 9W7 Bluetooth, LED strip lights in the trunk, lots of VAGCOM fiddling, APR Carbonio stage 1(for sale) , Magnaflow 3" cat back exhuast, 3 watt Cree LED interior lighting (from DDM Tunning)
#93
Yup...I did it
It's just plug & play with the switch.
The DRL's (LED's) don't turn off though....so when you go to the "parking light" mode....the LED's go to 50% brightness.
Then you can pull out the switch to turn on the fogs & run the fogs with the 50% LED's.
I'm sure you could maybe turn off the DRL's thru VagCom (?), but I like the DRL's on.....so I left them on
2013 VW
#94
Thanks snowbrdrdan!
What about when the switch is in the Off position, do the DLR's go back to 100% brightness or do they shut off?
Also do you get any function out of rear fogs?
Mike
2013 VW CC LUX / 1999 VW Passat GLX
#95
#96
Thanks for the 13 info, Sno. I asked this too in another thread a few weeks back but it went dead and unanswered. I was hoping the Euroswitch would just be plug-and-play, and allow running with fogs & DRL LEDs only. I don't mind if they reduce to 50% brightness, and I do prefer that they stay on in this mode. I mostly use this middle mode in rain, daytime fog, etc where I want a little extra visibility of the front fogs and the taillights, but don't need actual headlight illumination...I like the way the LED DRLs look so I like them to stay on.
_____
Justin
#98
Just installed Euro-Switch in my 2013. Love the option of 50% power LED and fogs on without HIDs. Also put in my Hoen Xenonmatch fog bulbs. Looked really bad stock.
2013 Sport Plus CC (James Bond Edition) -- Debadged, 35% Tint, EZ-Lip, K&N filter, Blacked out Grille slats, Euro-Switch, Hoen-Xenonmatch Fogs
#99
Did you get it from bold-sport, or ecs? I am going to buy one this week for mine.
Anyone ever looked into enabling the amber turn signals in the back of the '13s?
#100
Sorry for the double post.
#101
#102
The Tiguan, Touareg, & Passat have provisions for amber turns also, may not meet the FMVSS requirements for the turn signal area for amber turn signals.
Sometimes it's a stupid style thing the Germans can do and have done in the past, giving us red turn signals, when they obviously and/or have offered amber turns in a pre-existing housing already sold in our market...
2008 Passat wagon, 2.0T 6MT with mods
Other Rides:
- 2013 Cannondale CAADX-6
- 2010 Specialized Secteur Elite
- 2009 Specialized Rockhopper Comp 29-er
#103
How did you get the original one out? I looked at all the vids and still am having trouble.
Sent from my ADR6425LVW using Tapatalk 2
#104
Turn to Off position, push in and turn clockwise. Knob should stay in releasing the catches on the back end of the housing, pull straight out. If you cannot grasp it to pull out, open the cubby under steering wheel and reach up to the switch and push it out from behind.
#105
