VWVortex.com - Coil packs keep blowing up? Don't know what to do?
    Results 1 to 9 of 9
    Thread: Coil packs keep blowing up? Don't know what to do?
    1. Member tigger1976's Avatar
      Sep 5th, 2009
      Portland, Oregon
      MK3 Jetta Coupe!!!!!
      08-12-2011 12:40 AM #1
      So I have a 1999.5 mk3 vr6 that my coil pack blew out, so I replaced it and it drove for a day then went bad again. So I replaced it again and it now has done the very same thing? I really don't know what to do and it is starting to concern me a little. I could use any help. Thank you.
      "Did phil eat yet?"
    2. Member ogvr6's Avatar
      Nov 3rd, 2004
      fl
      a gas guzzler and a econobox
      08-12-2011 12:55 AM #2
      I thought all 99.5 were mk4's
      did you buy a new coil pack or used ...
      indoctrinate through academia and media.
      why is that the ones that seek tolerance are the most intolerant.
      They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety. -Benjamin Franklin
    3. Member tigger1976's Avatar
      Sep 5th, 2009
      Portland, Oregon
      08-12-2011 01:00 AM #3
      1999 was the half year where they built mk3 for half then changed to mk4 style. All the coil packs were brand new.
      "Did phil eat yet?"
    4. Member
      Sep 18th, 2004
      Marion, Iowa
      2001 Jetta 1.8t, 90 Jetta GLI (E85), 04 Jetta GLI
      08-12-2011 07:48 AM #4
      Are they OEM, or aftermarket? This isn't the normal cracking and arcing that they get with age, this is different. Got a bentley? Look and see what is driving the pack. I just replaced my coilpack a week or so ago, but it was falling apart, had cracks all over it, and most of the spark was shooting out of it, very little was making it to the plugs.
    5. Member tigger1976's Avatar
      Sep 5th, 2009
      Portland, Oregon
      08-12-2011 04:38 PM #5
      The first pack actually had a hole plug crack off so that was the reason for replacement the first time. the next 2 are all oem replacements from the Halsey Imports. So I am just confused now.
      "Did phil eat yet?"
    6. Member 02GTIFREESKIER's Avatar
      Oct 3rd, 2006
      Alta, UT
      Nissan Pathfinder 4.0l. KTM 250 XC
      08-12-2011 11:07 PM #6
      Do you have a wiring diag? i know nothing about the coil pack setup(my distributor is doing amazing btw). But check a wiring diag and see if there is a voltage regulator or resistor associated with the coil pack. Or maybe its a grounding issue?
      Corrado: because I always wanted to get heckled by elitist pricks over the internet.
    7. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      1943 Flugkreisel, 1945 VRIL-7
      08-14-2011 01:25 AM #7
      The original Dub and Dubber.
      Manche VWs sind einfach schneller als andere.
    8. Member tigger1976's Avatar
      Sep 5th, 2009
      Portland, Oregon
      08-14-2011 01:36 PM #8
      I dont see anything burned out on my harness in any way. Its just really weird that I am burning out 2 coils on every pack and the new packs dont last more than a couple hours? The wiring harness ends look good and the coil pack has no blemishes even.
      "Did phil eat yet?"
    9. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      08-14-2011 02:55 PM #9
      Then it is time you bust out your Bentley manual, DMM and troubleshoot.
      You can look at the recent post about testing the ICM, I posted info in there.
