Page 2 of 2 FirstFirst 1 2
Results 36 to 69 of 69
Thread: TT RS Rear Sway Bar...
    Jul 14th, 2000
    Bay area, California
    2012 TT-RS
    01-24-2012 01:38 PM #36
    Quote Originally Posted by DesertTTRS View Post
    includes the 24mm frt and 22 mm rear. Both are 2 hole adjustable. Going on my TT RS with H&R lowering springs P/N 29102-2 - .7 inch drop.Also have the adjustable drop links from 034 Motorsport. These will allow the install w/o any preload on the rear bar.I you preload the rear bar your car will be bouncy!
    Have any pics of the rear bar? As for the front bar, this car doesn't need any more under steer.
    2012 TT-RS in Suzuka Gray
  2. Junior Member
    Dec 17th, 2011
    Las Vegas
    2012 TTRS
    01-24-2012 10:03 PM #37
    that 5 mm differential. Actually playing with the adjustments - stiffer rear vs soft frt will yield less understeer than non-adjustable stock bars. One key here is not preloading the sway bars. I've set up suspension on V8 S4's,Porsches,RS4 etc and find that a properly set up set of bars is always better than a single bar.Bars are still in package .
  3. Member GaBoYnFla's Avatar
    Oct 2nd, 2005
    Florida
    2011 Audi TTS
    01-25-2012 08:46 AM #38
    Quote Originally Posted by Marty View Post
    Do them both for balance with larger or equal in rear. I have the Neuspeed setup in the TTS....it's balanced not understeer....and flat. How much heavier is the 5 cyl than the 4 cyl? You might want a bigger rear if the weight difference is significant?
    It's me, it's Earnest T!
    2011 Audi TT S
    Black on Black
    Clear bra, H&R Sport Springs, Magride, Neuspeed 25mm front and rear sway bars
  4. Member
    Jul 14th, 2000
    2012 TT-RS
    01-25-2012 06:39 PM #39
    Keep in mind that the torsional stiffness of a bar is proportional to the 4th power of its diameter. So a bar that is twice the diameter is actually 16 times stiffer in torsion.
    Assuming the stock bars are 19mm front / 17mm rear, then the ratio of REAR bar stiffness to front bar stiffness is (17/19)^4 = 64%.
    For the H&R bars of 24mm front / 22mm rear, the ratio of rear bar stiffness to front bar stiffness is (22/24)^4 = 71%.
    So swapping in the H&R bars makes the rear bar to front bar stiffness ratio a little bit larger, but not dramatically so.
    However, if you keep the stock 19mm front bar and just add a 22mm rear bar, then the stiffness ratio is (22/19)^4 = 180%, which is a huge increase in ratio.
    These calculations neglect adjustable moment arm lengths on the adjustable bars, but you get the point.
    If only the rear bar is being changed, then I have a feeling that jumping up to 22mm might be too much.
    Sep 1st, 2004
    Orange County, CA
    02-07-2012 03:43 PM #40
    Desert,
    Do you find a big benefit of the aftermarket end links with aftermarket bars? Some questions about the end links:
    - How are they adjustable? I presume it's the end socket which appears threaded in the pics.
    - What is your set point? Do you just drop it until there is no tension on the bar, or do you have to drive it around and play with different settings?
    Hanging around this board is not good for my wallet. ARB was a given, but now I'm thinking about torque inserts and end links and all kinds of crazy talk!
    - Deep Black Pearl '12 GTI 2.0T DSG
    - Phantom black '12 TT-RS 2.5TQMS
    - Brilliant black '08 A5 3.2QMS
    - Volcano black '99.5 A4 1.8TQM
    - Black '89 80 manual
  6. Member
    Feb 16th, 2003
    Binghamton, NY
    2011 OB Q7 S, 2012 PB TTRS
    02-07-2012 06:35 PM #41
    Most of us did just the Neuspeed RSB on the TTS. That was 25mm. No matter what size rear bar, this thing will still have some understeer...which is fine.
    2011 Orca Black Q7 S-Line
    2012 Phantom Black TTRS (Tech Pack, Sport Exhaust Titanium Pack, Heated Seats)
    1999 Spec Miata #46
  7. 05-04-2012 07:45 PM #42
    Sorry to bump this up, but we have a little something in the works for you guys...
    034Motorsport Audi TT RS & Audi RS3 Adjustable Solid Rear Sway Bar
    • 362% Increased Sway Bar Rate
    • 22.25mm Diameter
    • Solid Spring Steel Construction
    • 3-Way Adjustable
    • Easy-to-Lubricate Sway Bar Bushings
    Clicky!
  8. Junior Member
    Dec 3rd, 2011
    Australia
    2010 Audi TTRS - 343awhp.
    05-04-2012 11:30 PM #43
    Awesome.
    Have already got your end links - will go pre-order this now!
    2010 Audi TTRS (6spd)
    Options - 19's titanium blades, Mag Ride, RS Seats, Bose, Extended Leather, AMI, SatNav, Xenons
    Mods - Catback Milltek Exhaust, Wagner Intercooler, Self tuned - 343awhp
  9. Junior Member
    Dec 3rd, 2011
    Australia
    05-04-2012 11:39 PM #44
    Nuts... Quoting $600 for shipping to .AU via USPS
    Have pinged you via your contact me form on your website. If you could get back to me that would be great!
  10. Member
    Feb 16th, 2003
    Binghamton, NY
    05-05-2012 01:40 PM #45
    Pretty awesome! Why not do 25mm, as the TTS Neuspeed bar? Just curious.
    1999 Spec Miata #46
  11. Member
    Jul 14th, 2000
    2012 TT-RS
    05-06-2012 02:51 AM #46
    Quote Originally Posted by DrDomm View Post
    362% not enough of a stiffness increase?
  12. Member GaBoYnFla's Avatar
    Oct 2nd, 2005
    Florida
    2011 Audi TTS
    05-06-2012 07:38 AM #47
    I thought someone tried one here and it hit a transfer case?
    2011 Audi TT S
    Black on Black
  13. Member
    Feb 16th, 2003
    Binghamton, NY
    05-06-2012 08:48 AM #48
    Well what's the increase on the 25mm Neuspeed bar? I don't know. If it's 400%, then based on my impressions on the TTS, 362% might not be enough.
    Anyway, I think there is already another 22mm bar on the market. H&R?
    1999 Spec Miata #46
  14. Member
    Feb 16th, 2003
    Binghamton, NY
    05-06-2012 08:49 AM #49
    Quote Originally Posted by GaBoYnFla View Post
    That was me. A slight modification in the bend, and 25mm would work fine.
    1999 Spec Miata #46
  15. 05-07-2012 04:06 PM #50
    The 362% is not a typo. The 034Motorsport Audi TT RS & Audi RS3 Adjustable Solid Rear Sway Bar is solid, not tubular, like some other bars on the market.
    The Neuspeed TTS bar, while 25mm in diameter, is hollow, and about half as stiff as our solid rear bar is: http://www.neuspeed.com/131/2/0/1649...-bar-25mm.html
    It also does not fit the TT RS.
    Our bar was designed specifically for the Audi TT RS, and to be used without any need to replace the front sway bar. It virtually eliminates body roll, and allows the car to rotate if desired.
    It drastically changed the handling characteristics of our TT RS for the better, and has seen street and track testing.
  16. Member
    Jul 14th, 2000
    2012 TT-RS
    05-07-2012 04:33 PM #51
    Has anybody had any issues with their rear swaybar endlinks on their TT? I have a hard time believing that these generally need to be upgraded with the stiffer bar.
  17. 05-07-2012 05:47 PM #52
    The stock sway bar end links won't break, even with an upgraded bar as stiff as ours.
    We recommend our Sway Bar End Link Pair for two reasons:
    • First and foremost, they are adjustable, allowing you to adjust preload on the sway bar. Even factory Audi/Volkswagen sway bars will vary in preload, and the use of an adjustable end link will allow you to compensate for that.
    • They eliminate the rubber found on the stock sway bar end links in favor of sphericals. Rubber deflects, making to sway bar less effective.
  18. Member
    Jul 14th, 2000
    2012 TT-RS
    05-07-2012 06:27 PM #53
    Quote Originally Posted by TallaiMan View Post
    Could you talk more about the "preload" concern? The preload can't be very much, otherwise you wouldn't be able to assemble the stock endlinks on to the aftermarket bar by hand in the first place.
  19. 05-07-2012 06:44 PM #54
    Preload will not necessarily make it harder to install the stock endlinks onto an aftermarket bar, as most of the time the suspension is put under load to install the end links anyway.
    The preload can vary from bar to bar, and usually isn't drastic. Again, even factory bars can vary in this respect.
    Once you cornerweight the car, (usually resulting in the car being lowered unevenly) you will inevitably have preload that you want to remove through the use of an adjustable end link.
    Hope that helps answer your question!
  20. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    05-07-2012 07:28 PM #55
    This one has me interested. I found the upgraded RSB made a nice difference on the mkI, I suspect the same will be true on the RS.
    2012 TTRS: Daytona Gray, Tech Pack, Heated Alcantara, CF Mirrors, Nexon CF Steering Wheel, DG Rear Valence
    GIAC Stage 2+, AWE SwitchPath + cat-deletes, AWE FMIC, H&R RSB, MSS Sport Springs, HRE P40, AWE Boost Gauge, Tinted Tails and Reflectors, OSIR Coolant Tank CF Shield
    Winter/Track Wheels: Borbet LV5
  21. Member
    Jul 14th, 2000
    2012 TT-RS
    05-08-2012 01:11 AM #56
    I definitely felt a lot of understeer at the track that I assume could be reduced in exchange for a bit of stability with a stiffer RSB like this. Definitely interested, but I'll probably wait for a few Guinea pigs to test fit these bars first so there aren't any headaches.
  22. Member
    Sep 1st, 2004
    Orange County, CA
    05-08-2012 01:26 AM #57
    H&R 22mm rear bar works great without any rubbing. Gonna post a writeup when I have the time.
  23. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    05-08-2012 01:16 PM #58
    Thanks. Will be anxious to hear your thoughts.
  24. Member
    Feb 16th, 2003
    Binghamton, NY
    05-08-2012 04:02 PM #59
    Quote Originally Posted by mageus View Post
    Is that bar solid? I'm impressed this 034 bar is solid.
    Back to preload and adjustable end links...my (limited) understanding is that preloading the bar will affect corner weights when setting up a "racecar". To set up the racecar suspension, you'll be adjusting ride heights. If you don't have "coilovers", you aren't going to adjust ride height on the TT RS.
    So...the stock end links should be "close" to the right length to install a bar that is the same shape/size as the stock bar...to have whatever amount (hopefully negligible) of preload Audi thought was appropriate. Likewise, I'm assuming the Neuspeed endlinks would be fine also.
    1999 Spec Miata #46
  25. Member
    Jul 14th, 2000
    2012 TT-RS
    05-08-2012 05:41 PM #60
    Endlinks really shouldn't make any difference for you unless you are trying to do precise corner balancing for a track-only car, or if the stock endlinks break with the stiffer bar.
  26. Junior Member
    Dec 3rd, 2011
    Australia
    05-08-2012 06:27 PM #61
    Just ordered it guys (also have the sway bar end links which I haven't yet fitted).
    Will post a review after it arrives.
  27. Member
    Feb 16th, 2003
    Binghamton, NY
    05-09-2012 05:26 PM #62
    That's what I was saying.
    1999 Spec Miata #46
  28. Member
    Jul 14th, 2000
    2012 TT-RS
    05-09-2012 05:49 PM #63
    Maybe thay's where I learned it!
  29. Member
    Sep 1st, 2004
    Orange County, CA
    05-12-2012 02:34 AM #64
    Posted a write-up on the H&R bar.
    http://forums.fourtitude.com/showthr...ar-ARB-install
  30. Junior Member
    Dec 3rd, 2011
    Australia
    07-05-2012 07:39 PM #65
    Excited... Just found out my 034 swaybar just shipped.
    Will have it fitted in the next few weeks and report back on results!
  31. Member
    Jul 14th, 2000
    2012 TT-RS
    07-05-2012 10:16 PM #66
    Looks like the H&R bar is 21mm, while the 034 bar is 22.25mm. Assuming they're both solid bars, then the 034 bar is (22.25/21)^4 = 126% as stiff as the H&R bar (26% stiffer). Given that the 034 is already "362% stiffer than stock", I bet either bar would perform similarly.
    One thing I like about the H&R bar is that it includes urethane / teflon bushings that supposedly never need to be lubricated... the last thing I want to worry about is lubricating a squeaky sway bar bushing. And at ~$225 (H&R through ECS) vs. $325 (034 through 034), it seems like a bit of a no-brainer...
  32. Member
    Aug 13th, 2011
    London and Hampshire. UK
    07-06-2012 04:45 AM #67
    OEM sizes...
    fronts = 22mm
    rears - 18.5mm
    The H&R ARBs I got fitted some 2.5 years ago are as follows...;
    fronts = 24mm
    rears - 22mm
    @Marty,
    good point ref H&R bushings...been quiet from day one...ZERO maintenance. I did ask my tuner to swap the bushings for SuperPro items and he asked me why...we left things as that as I could not give him a reason worth noting...he could have easily taken my money...!!!
  33. Member
    Mar 4th, 2004
    Canada EH !
    2010 TTS Coupe, 2011 Q5
    07-06-2012 09:17 AM #68
    Avoiding some squeaking can be meaningless to some; however, I personally hate it. I've had a few different manufacturers bars on my cars over the years and my current Neuspeed has squeaked in the cold weather. Not difficult to remedy with some lube or wrapping the bushings with teflon tape but given a lower price and mice free design, I'd say the H&R gets the
    2010 Ibis TTS - PODI in OSIR mono/ MTM 330 flash/ Milltek DP and exhaust/ HPA DSG Stage II + Haldex/ 2011 RNSe w/Dension Gateway 100/ R8 V10 steering wheel/ BC Forged RS31 wrapped with PSS
  34. Member
    Jul 14th, 2000
    2012 TT-RS
    07-07-2012 01:38 PM #69
    Quote Originally Posted by Stevelev View Post
    Agreed. Just ordered an H&R!
