Page 10 of 14 FirstFirst ... 6 7 8 9 10 11 12 13 14 LastLast
Results 316 to 350 of 467
Thread: Yes another Corrado Build.
  1. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    91 Corrado 2.0l 16v on MS3X, Parked like Jurassic... 83 Cabby 1.8l 16v... 88 Powerplay XLT-185
    05-02-2012 05:22 PM #316
    Quote Originally Posted by vwflygti View Post
    Little disheartening! Guess we'll have to see...
    will the vr6 speed sensor screw right ontop of the g60 sensor? Looks like it's threaded speed sensor...
    I do have a designated output. using channel 0 as a p259 tach output. I ordered channel 0 with a built in 1k resistor to ground the tach. its grounded and rated at 0.3a I have tried attaching it directly to the green wire on G1/12 with no luck. The divider is what I may need to play with. The tach used to work, not to say it still does though. I have another gauge cluster that maybe i'll try... Thanks Chad.
    I did a group buy with a few Corrado buddies on the RSD hoodlift, HOOOOORRRRIIIIBBBBLLLLEEEEEEEEEEEEE!!! First off, the hardware rusted in like a day & fitment was a joke! I sent them all back for a full refund from TM
    I do believe so, but ask in the experts thread
    I do not know why you need the resistor, possibly like something I have built on my board, but I did not solder anything on my MSExtra card, dunno with VEMS, what did the rep (Kevin?) say?
    Quote Originally Posted by crazynorweegian View Post
    Good luck, might want to get vaccinated for "while-I-am-in-there" syndrome.
    tek-euro.com SpoonFedTuning
    my Corrado's specs on corrado-database / My Corrado Build Thread / My Cabby Build Thread / My Boat Build: 18' Powerplay w/5.7l V8
  2. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    2000 audi s4, 1990 corrado aba/16vt, 2004 audi A6, 2008 Aprillia 450svx, 2003 Kawasaki Z1000
    05-02-2012 08:43 PM #317
    Didn't talk to Kevin. I used a different dealer but will try to get in touch with Kevin. Sucks on the hood lifts.
    CHECK OUT MY BUILDS AT WWW.BUILDMYS4.COM
    2000 AUDI S4 RS6/54MM BILLET WHEELS
    1990 VW CORRADO ABA/16VT PRECISION 5857 .63 A/RCORRADO BUILD THREAD
  3. Member 1broknrado's Avatar
    Jul 6th, 2005
    Wilmington NC/Stratford CT
    24v Corrado
    05-02-2012 09:04 PM #318
    post up when you find out because i have the same issue. Connected the VEMS right to g1/ something i forgot right now but when is started car up, i had to no tach signal either.
  4. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-02-2012 09:10 PM #319
    Quote Originally Posted by 1broknrado View Post
    May be a stupid question, but here goes... Could the issue lie in your tach settings? I personally forget how many volts the tach needs to operate, IIRC 0-5v
  5. Member 1broknrado's Avatar
    Jul 6th, 2005
    24v Corrado
    05-02-2012 09:25 PM #320
    its possible...and yes it is a 0.5v
    Just looked at the wiring spreadsheet i have and my VEMS is channel 0 as well and goes to g1/12. But it does not say if its a ground trigger or a .5v, so i couldn't verify that for you. sorry.
  6. Member DWI_gti's Avatar
    Jan 11th, 2004
    NJ
    05-04-2012 09:51 AM #321
    Why didn’t you get one from Kevin, yeah you probably got it a few bucks cheaper but his support and basemaps he supplies are well worth it. Should go back to your VEMS dealer and ask questions.
    update: I let Ben (someone he works with offten) know about this see if he can get the time to pop on give you a answer
  7. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-04-2012 10:47 AM #322
    Quote Originally Posted by DWI_gti View Post
    Thank you, I don't doubt kevin's support is great. My good friend @ EP Racing is a VEMS distributer with basemaps as well. Who got me everything, yes for a great price, less than most pay for MS and made my whole wire harness for me for next to nothing.... VEMS does offer great support in there forums. I am waiting from Rob @ VEMS for confirmation to sign up as they closed open registration. My friend said he is sure he can figure it out, just thought I'd ask here first incase someone ran into this problem already.
  8. Member DWI_gti's Avatar
    Jan 11th, 2004
    NJ
    05-04-2012 11:15 AM #323
    im sure the vmes fourms will get your the answer you need.
  9. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-04-2012 11:21 AM #324
    Thanks again...
  10. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-04-2012 11:25 AM #325
    I assume they are not like the MS forums ........
  11. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-04-2012 02:08 PM #326
    Quote Originally Posted by Sr. Karmann View Post
    no! Lol
  12. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-04-2012 02:26 PM #327
    no! Lol
    thank God!!!
  13. Member 1broknrado's Avatar
    Jul 6th, 2005
    24v Corrado
    05-04-2012 07:36 PM #328
    VEMS forum!? I didnt know such a thing existed.
    Nvm. I remembered forum rules and used the search button
  14. Member jettalvr41's Avatar
    Oct 26th, 2006
    Lincoln, Nebraska
    04 jet 92 SLC
    05-04-2012 07:42 PM #329
    Me either. Point me towards?!
    8v mkiv 12vt slc
    Nebraska Corrado VR build
    The Depot Build
    Quote Originally Posted by cstanley19 View Post
    . Learn the car first.. then modify it...
  15. Member 1broknrado's Avatar
    Jul 6th, 2005
    24v Corrado
    05-04-2012 08:01 PM #330
  16. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-04-2012 09:54 PM #331
    Yup, that be the one...
  17. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    92 Corrado VRT, B5 A4 1.8TQ
    05-04-2012 11:22 PM #332
    Im having the same problem Fred. Curious to know what everyone finds out.
    Do Werk!
    EEMILITIA PA CHAPTER
    WTB Passat Syncro Rear beam
  18. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-06-2012 09:22 PM #333
    Quote Originally Posted by ItsNotaScirocco View Post
    Ok. Cool. Well maybe with both of us playing with it we'll get it figured out a little quicker. Keep in touch.
  19. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-07-2012 09:05 PM #334
    Ka Boom!
  20. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-07-2012 09:26 PM #335
    Ka Boom!
    Freakin sux man
    Do you know what happened?
  21. Member 1broknrado's Avatar
    Jul 6th, 2005
    24v Corrado
    05-07-2012 09:32 PM #336
    Thats an unusual sight
  22. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-07-2012 09:41 PM #337
    Freakin sux man
    Some rattling and loss of oil pressure, I'm gonna guess rod bearing spun... Will know more tomorrow....
  23. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-07-2012 09:42 PM #338
    sad but true. I'll be the first to admit it....
  24. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-07-2012 09:50 PM #339
    Keep us informed
  25. Member 1broknrado's Avatar
    Jul 6th, 2005
    24v Corrado
    05-07-2012 09:51 PM #340
    hopefully its not that extreme. Best of luck to you with finding out the problem.
  26. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-07-2012 09:55 PM #341
    Keep us informed
    will do, thanks...
  27. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-07-2012 09:55 PM #342
    dammit, was running so good too. 1.2 bar was fun!
  28. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    Limassol, CYPRUS (That's in Europe,lol)
    '90 Corrado 1.8 8V G60 (previously was 1.8 16V KR), '80 MK1 Golf GTI 1.6 8V EG aka "Heron"
    05-08-2012 04:32 AM #343
    Damn man, sucks this happened
    My brother had a crank pulley bolt snap on his 1 week of driving his recently acquired MK3 Golf - luckily he didn't bent any valves and we had a spare crank so...
    Hope its not a very big damage...
    Quote Originally Posted by dogger View Post
    ... (Corrado) might be the greatest collection of bad VW ideas ever put into one car.
    My Corrado (sort of) build thread / On Database
    My MK1 build thread
    SpoonFedTuning
  29. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-08-2012 09:21 PM #344
    So, motor was totally locked. Steps taken:
    1) Remove timing belt, top end was free.
    2) Intermediate shaft was free.
    3) Bottom end would not budge.
    4) Drop oil pan, pieces everywhere.
    ~wait pieces are plastic! WTF!?
    ~wait where is the oil baffel? up in the crank!
    5) Remove oil baffel, millions of little pieces.
    6) Motor still no budge.
    7) Loosen rod bearings, motor now moves.
    8) plastic pieces in oil journals of crank.
    9) remove rod caps. oil starved and spun bearings.
    Crank seems pretty bad, don't think emery is going to clean it.
  30. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-08-2012 09:49 PM #345
    Ouch, makes me re-think my plastic baffle, although it is brand new, doesn't quite look like that one tho.
    mine
  31. Member REPOMAN's Avatar
    May 3rd, 2001
    Portland OR
    1990 VW Corrado
    05-08-2012 10:07 PM #346
    That Sucks... That crank is DONE.
    why did the oil pressure drop causing the rod bearings to fail.
    I would use the aftermarket windage tray/oil pan gasket and ditch the oem baffle.
    Also a great idea to lock tight the oil pump bolts.
    Looks like you are looking for another crank and rods?
    block and pistons should be OK.... Sucks you gotta tear it all down and start again.
    500HP 1990 Cowrado
  32. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-08-2012 10:22 PM #347
    Quote Originally Posted by REPOMAN View Post
    Getting metal baffle.
  33. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-18-2012 11:57 PM #348
    Everything came together pretty good. Metal baffel is now installed along with new rod bearings. She lives again!
  34. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-19-2012 12:00 AM #349
    Oh, and some more pictures. Was bored tonight.....
  35. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    05-19-2012 01:46 AM #350
    And nice photos
    My MK1 build thread
    SpoonFedTuning
