Results 1 to 35 of 35
Thread: Tail lights?
    Jul 19th, 2011
    CT
    08-20-2011 12:51 AM #1
    i wanna put in the fog light bulb for my tail lights but idk what bulbs to use, can anyone help me?
    Also are there any procedures for replacing the top brake light above of the trunk in a sedan?
  2. Classified Advertiser fcpgroton's Avatar
    Sep 4th, 2008
    CT
    B5 A4 Quattro
    08-20-2011 09:14 AM #2
    First thing first what year Passat do you have? Also have you wired your car up to have the rear fog light function?
    877-634-0063 | info@fcpgroton.com
    FCP Euro - European Car Parts Specialists
    FCP Import - Import Replacement Car Parts
    [/LEFT]
  3. Member flygliii's Avatar
    Jun 29th, 2006
    SF Bay
    a Mk2, a Mk4, a B5, and an FZJ80
    08-20-2011 09:47 PM #3
    There is a seller that formerly advertised on here IIRC that sells the wire and bulb kit on eBay. Or you can search for the same online, they're cheap. Don't forget the European headlight switch for the double pull on the fog...the second pull is for the rear fog. It's a fairly easy job.
    Gone and missed: '84 Scirocco, '81 Scirocco S, '80 HiLux 4x4, '77 Kawi Enduro, '74 sparkling green Schwinn Stingray
  4. Member
    Jul 19th, 2011
    CT
    08-21-2011 12:56 AM #4
    I have a 99, and no i havent, i didnt know i was suppose to i just saw that it had the spot for it and that a regular bulb didnt fit due to the fitment on the actual tailight not where the bulbs stay
  5. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    08-21-2011 01:04 AM #5
    Quote Originally Posted by Hgarcia View Post
    There you go. USA spec cars don't have the control or wiring for a rear fog light, just the vestigial bulb socket. You can modify the car to support it, you'll need something like THIS and THIS.
  6. Member
    Jul 19th, 2011
    CT
    08-21-2011 01:50 AM #6
    ohh ok thank you, but do you know the size of the bulbs?, i already have the wire and the adapters at home i work a lot with electrical stuff so i dont think i wanna buy the kit when i dont need it.
    and does anyone know how to replace the high mount bulbs?
  7. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    08-21-2011 11:04 AM #7
    Should be pretty easy. According to the Bentley manual, You reach under and unplug the electrical connector. Then you press the "lock retaining spring" and pull the bulb holder out. The seven type 2825 bulbs just pull out of the holder.
    I'm pretty sure the rear fog bulb is an 1156, though it (obviously) doesn't show up on USA replacement charts.
  8. Member Steve in Chicago's Avatar
    Dec 13th, 2008
    Chicago, Illinois
    1999 Volkswagen Passat GLS
    08-21-2011 02:05 PM #8
    The bulb socket in the back plate accepts a standard single filament bulb. You'll need to open up the hole at the back of the tail light fixture reflector to accept the bulb. I did this to mine when I did the 5-brake light modification. I used a stepped drill bit.
    Jul 19th, 2011
    CT
    08-21-2011 10:52 PM #9
    wow thanx guys, ill try the high mount bulbs when i get a chance
  10. Member
    Jul 19th, 2011
    CT
    08-22-2011 09:38 AM #10
    i got the high mount bulbs out, they got stuck but i took out a clip and slid it right out
  11. Member flygliii's Avatar
    Jun 29th, 2006
    SF Bay
    08-22-2011 02:19 PM #11
    1156 and it is 21w, IIRC.
    Jul 19th, 2011
    CT
    02-13-2012 05:50 PM #12
    so i was going to do the rear fog light, and my friend said he did some research and said i needed a diode, i havent touched it because of the cold weather, but i wanna know if i just wire it to the switch or do i really need the diode?
  13. Member Steve in Chicago's Avatar
    Dec 13th, 2008
    Chicago, Illinois
    02-13-2012 08:19 PM #13
    I can't think of a reason why you'd need a diode if you get power from the correct pin on the headlight switch and bring that power (you'll need to pull a wire from the switch to the tail light fixture) back to the correct contact on the tail light assembly.
    Now if you were going to construct a circuit so those extra bulbs would function as both rear fog lights off the headlight switch and extra brake lights (like the 5 brake light mod) off the brake light circuit... then you'd need some diodes.
    How An Engine Works... Exhaust gases go into the turbocharger and spin it, witchcraft happens, sign posts fly by at light speed, the girl in your passenger seat screams!
  14. Member
    Jul 19th, 2011
    CT
    02-14-2012 10:42 AM #14
    oh ok that makes sense, thank you for answering all of my questions
  15. Member flygliii's Avatar
    Jun 29th, 2006
    SF Bay
    02-14-2012 10:54 PM #15
    Na, no diode needed.
    Matter of fact, I recall seeing a how-to on here or Passat World for getting power to the dash icon so it can light up, too. Should still be around, if you are interested.
    Hey, do any of you know if this is mod is just as easy on the newer Passat models? Why a comparable Audi includes it and the VW doesn't makes no sense to me...
    Anyway, good luck with your project, it's a very practical one, IMO.
  16. Member
    Jul 19th, 2011
    CT
    02-15-2012 12:52 AM #16
    thank you very much, i think it should be the same way i dont see why not
  17. Member
    Jul 19th, 2011
    CT
    02-15-2012 12:53 AM #17
    i saw a gti with them, they were aftermarket lights but it should be the same
  18. Member
    Jul 19th, 2011
    CT
    02-15-2012 02:16 AM #18
    by any chance do u know what u searched, or have a link, im pretty interested and wanna see some of the steps
  19. Member flygliii's Avatar
    Jun 29th, 2006
    SF Bay
    03-06-2012 01:09 AM #19
    No link. But, IIRC, I had googled "Passat rear fog" or something like that. I just did it the one time I did the mod several years ago, but there still should be something around.
  20. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    Formerly London Dub B5.5 Passat V6 4mo Wagon, MK6 GTI 6MT
    03-06-2012 09:13 AM #20
    Just buy the ECS kit...
    Buy my clear GTI sidemarkers cheap!
    Will VagCom Mk5 and 6 in the GTA for donuts!
  21. Member flygliii's Avatar
    Jun 29th, 2006
    SF Bay
    03-06-2012 10:48 PM #21
    Quote Originally Posted by E CODE View Post
    Totally the easy way to go. But, I thought the OP was also trying to illuminate the dash icon? That's a bit more involved, but wiring the rear fog is fairly simple. Remove fuse panel, swap switch, wire to switch, discreetly run wire under the trim panels to light cluster/tub, throw in bulb, put it all back together, then give it a go...
  22. Member
    Jul 19th, 2011
    CT
    03-07-2012 06:29 PM #22
    yea its all actuly pretty easy its just connecting/soldering a wire running from the pin, over to a pin on the instrument cluster harness, i looked it up and its pretty awesome, i stil havent done it do to rain, and cold weather, also have been working alot and school but i should be able to get to it by next week when i have a couple of days off from school.
  23. Member
    Jul 19th, 2011
    CT
    03-23-2012 09:43 PM #23
    I have finally finished, it was pretty easy but did take me a couple of hours, still have to run it to the passenger side, but i managed to get the 5 brake mod, and the rear fog light, along with the indicator on the dashboard. PHEW!!!
  24. Member flygliii's Avatar
    Jun 29th, 2006
    SF Bay
    03-23-2012 11:02 PM #24
    Check your local laws on running one vs. two rear fogs, seems some people get freaked out enough over one rear fog...crazies.
  25. Member
    Jul 19th, 2011
    CT
    03-24-2012 06:30 PM #25
    lol i will, but i mean if worsst comes to worst i could just shut em off
  26. Member flygliii's Avatar
    Jun 29th, 2006
    SF Bay
    03-24-2012 07:22 PM #26
    Yeah, or you could just disconnect the passenger side if it's ever a legal issue. They're pretty common now, but I guess not everyone knows what they are or how they're intended to be used. Enjoy!
  27. Member nolesfan's Avatar
    Mar 9th, 2011
    Raleigh, NC
    2004 Passat
    03-26-2012 11:14 AM #27
    Congrats on getting this to work. I thought about it since I got the Euro switch a couple years ago, but haven't pulled the trigger on it yet. I want to go all out with it, getting the dash light to illuminate, but I've never tackled any wiring job and I'm a little nervous about diving in. Any suggestions?
  28. Member
    Jul 19th, 2011
    CT
    03-26-2012 04:34 PM #28
    its really not terrible, have u ever used a soldering iron or gun, if u have this turns into a simple task, I soldered everything before i ran it in the car just so i would be more comfortable, the only thing i did was pull out the the pin from the instrument panel connector, then got to soldering, are u only doing rear fogs or are you also gunna do the 5 light brake mod?
  29. Member
    Jul 19th, 2011
    CT
    04-25-2012 06:32 PM #29
    does anyone know if there is a way to make the rear fog light brighter? mine seems really dim compared to those ive seen in pictures and videos.
  30. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    04-25-2012 07:37 PM #30
    LED bulb?
  31. Member Steve in Chicago's Avatar
    Dec 13th, 2008
    Chicago, Illinois
    04-25-2012 08:22 PM #31
    Does anyone know if there is a way to make the rear fog light brighter? Mine seems really dim compared to those I've seen in pictures and videos.
    What wattage bulb did you use?
    Is it a single or double filament bulb?
    What gauge wire did you use to run from the switch all the way back to the tail light?
    Are you running just one rear fog light or do you have both tails wired and bulbed?
  32. Member
    Jul 19th, 2011
    CT
    04-25-2012 11:28 PM #32
    im not sure how many watts, i got some of the smd Led bulbs, im sure its single, i think i ran it with either 16 or 18, i ran it to both sides along with the diodes with the 5 brake light mod.
  33. Member
    Jul 19th, 2011
    CT
    04-26-2012 11:09 PM #33
    Is it bad if i have Led, bulbs?
  34. Member Steve in Chicago's Avatar
    Dec 13th, 2008
    Chicago, Illinois
    04-27-2012 07:35 PM #34
    The LED's will draw fewer amps, create less heat and are supposed to last longer (if not over-volted).
    If you have a set, pop in some regular incandescent bulbs and see how those look. The LED's may not have the light output you're looking for.
  35. Member
    Jul 19th, 2011
    CT
    04-27-2012 09:58 PM #35
    alright, im gunna see if i got one kicking around, thank you.
