VWVortex.com - AWD Picture Thread
    Page 2 of 3 FirstFirst 123 LastLast
    Results 26 to 50 of 51
    Thread: AWD Picture Thread
    1. Member climbingcue's Avatar
      Feb 2nd, 2001
      Kremmling, CO
      '12 VW GOLF R, '03 Toyota 4Runner, '12 RZR 900 XP
      05-24-2012 10:18 AM #26
      Awesome build really look forward to seeing the car once it is finished
      Bill
      Quote Originally Posted by madness maker View Post
      few shots of my mk1 2.5t haldex 02m....
      United Motorsport 12.311@112 mph on 93 octane
      Georgia 1/2 mile 2014 135.78 mph
    2. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      96 Golf VRT, 09 Vw Passat 4Motion 2.0TDI Highline
      05-26-2012 01:30 PM #27
      Anyone have pics from mk4 02M mount on a mk2/3 ?
      1996 Golf MK3 GT35R 12V 02M Lugtronic Turbo. http://forums.vwvortex.com/showthrea...er-VR6-T/page4
      2009 Passat b6 2.0TDI 4Motion Highline
      Dec 14th, 2009
      mohnton, pa
      05-27-2012 04:01 AM #28
    4. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      05-29-2012 10:01 AM #29
    5. Member ejg3855's Avatar
      Sep 23rd, 2004
      Rochester, NY
      1993 UrS4
      05-29-2012 12:59 PM #30
      I have heard the frame rails on mk2/3 platform aren't strong enough to mount an engine with the Mk4 mounting methods.
      CUSTOM TUNING - IMMO DEFEAT - AWD DYNO - FABRICATION - MACHINED/DESIGNED PARTS
      NOW OBD FLASHING MK6/MK7 2.0T
      BREAKOUTMOTORSPORTS
    6. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      05-30-2012 04:16 AM #31
      A friend of mine have been driving with the mount on the frame since 2009 on a 645whp VRT dragcar. No issues.
      This is my old setup:
    7. Member ejg3855's Avatar
      Sep 23rd, 2004
      Rochester, NY
      1993 UrS4
      05-30-2012 08:23 AM #32
      Quote Originally Posted by Norwegian-VR6 View Post
      Did he do any significant reinforcement to the frame rails or just weld on some plates to mount too ?
      BREAKOUTMOTORSPORTS
    8. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      05-30-2012 04:05 PM #33
      Quote Originally Posted by ejg3855 View Post
      Same as me. Welded on plates. And welded it with alot off support all around.
      But I defently see your point. Its not the thickest steel the frame is made off.
      Its in my opinion better than the "standard" 02M/02Q" mount that I used to have. As you can see in the pics.
    9. Member ejg3855's Avatar
      Sep 23rd, 2004
      Rochester, NY
      1993 UrS4
      05-30-2012 08:59 PM #34
      after seeing your pictures I am more worried about the standard 02M mounting methods. just looking for others that have gone the welded route.
      Sent from my phone forgive auto correct errors
      BREAKOUTMOTORSPORTS
    10. Member give_it_to_dem's Avatar
      Jan 27th, 2005
      Brooklyn
      Haldex Jetta, VR6 Rabbit
      07-10-2012 05:59 PM #35
      24V GLI with AWD Swap:
      Check us out on FaceBook---> ///Brooklyn Auto Rennen
      www.pagparts.com
    11. 07-12-2012 03:03 AM #36
      i am really impressed
    12. Member tuntsfaah's Avatar
      Apr 2nd, 2007
      Chicago, IL
      2004 / Audi / A4 USP, 2001 / Audi / S4, 2005 / VW/ Jetta GLI, 2001/ VW/ Jetta Wolfsburg
      08-22-2012 04:55 PM #37
      Quote Originally Posted by fouckhest View Post
      here is my haldex swapped mk4 gti
      This is ultimately what I want to do, but with a MKIV GLI (1.8T version). Do you have any tips, or how can I determine if I can fuse like an B6 Audi USP with my GLI?
    13. 08-25-2012 12:29 AM #38
      here is what >800 AWHP 4cyl power looks like launching for world record low 9 second pass @ >153 mph! launched with 15 psi boost and 1.6G acceleration.
      quickest and fastest Audi Quattro 1/4 mile car in N America, and also quickest and fastest 4cyl Quattro drag car in the entire world.
      using a custom geared Par-Engineering dogbox, welded center diff and Wavetrac front diff, with locked factory rear diff. custom axles, stock driveline. 0-60 in 2.3 sec. 60-130 in 4.9 sec.
      best to date is 9.34 and 153.84 and 1.400 60'.
    14. Member lorge1989's Avatar
      Sep 3rd, 2008
      Buffalo, New York
      '88 Audi 90 20V(handofgod) MS3X | '94 Audi 90 V8
      09-08-2012 01:27 AM #39
      Quote Originally Posted by tuntsfaah View Post
      Not a chance. A lot easier to just get a rear end from a MK1 TT / R32, cut out your rear floor plan and convert it to Haldex.
      If you wanted to do quattro everything would be custom, as well as the engine would need to be mounted longitudinally.
    15. Junior Member abf16vt's Avatar
      Dec 27th, 2009
      Freeport NY
      92 mk2 golf 16vt. 84 Rab GTi. 97 Cabrio.
      10-13-2012 04:52 PM #40
      I do believe that 16Vampir has the fastest time at 8.6 sec. Mk2 golf 1.8 16v turbo awd.
    16. Member
      Nov 15th, 2004
      Somewhereville,NJ
      AWD-06 Passat APR Stg 3+
      10-28-2012 04:20 PM #41
      I did the awd conversion this passed summer to my 06' VW Passat 2.0T. The conversion was pretty straight forward, no cutting involved accept for cutting a hole to except the 2nd fuel sender unit under driver side rear seat. Here are some pic:
      New Audi S3 aluminum rear subframe attached to 3.6 Passat 4motion rear diff:
      New awd Passat 3.6 motion gas tank:
    17. Member lorge1989's Avatar
      Sep 3rd, 2008
      Buffalo, New York
      10-28-2012 07:49 PM #42
      That is so sick. Any more info on that swap?
    18. Member
      Nov 15th, 2004
      Somewhereville,NJ
      10-28-2012 09:35 PM #43
    19. Awaiting Email Confirmation toy_vw's Avatar
      Feb 10th, 2006
      London Ontario
      87scirocco,99 A4, 98 TDI
      11-27-2014 01:06 AM #44
      Add my newest build...
      Was a 16v turbo syncro
      New build will be 2.7 tt Quattro
    20. Member atoson's Avatar
      Dec 28th, 2002
      San Jose, Ca. South Bay Area
      12 Golf TDI, 00 GTI, 00 NB, 84 Scirocco, 80 Dasher
      11-30-2014 07:56 AM #45
      Quote Originally Posted by toy_vw View Post
      add my newest build...
      new build will be 2.7 tt quattro
      i'm gonna like this one!
    21. Member raddo's Avatar
      Dec 22nd, 1999
      Pasadena Maryland
      93 Corrado VR6T Haldex, 2011 Audi Q7 TDI, 2004 Jetta TDI
      12-04-2014 06:16 PM #46
      Some pics of my car
    22. Member Bearvr6's Avatar
      Feb 19th, 2008
      Bum Rushing Flushing, NYC
      96 Golf 4dr Vr6, 88 GLI Vr6,MK4 GTI 24V & B5.5 Wagon AWD
      12-10-2014 03:00 AM #47
      Nice Raddo what gas tank or fuel cell did you use ?
    23. Member raddo's Avatar
      Dec 22nd, 1999
      Pasadena Maryland
      12-10-2014 03:40 PM #48
      Quote Originally Posted by Bearvr6 View Post
      It was a custom made one from JAZ, but there really is nothing special about it. They said they could build one to my specs for the same price as one of there productin ones, so I gave them my specs and they made it.
    24. Member Bearvr6's Avatar
      Feb 19th, 2008
      12-10-2014 07:08 PM #49
      Quote Originally Posted by raddo View Post
      Thats kool can you PM me there contact info ? Im doin my awd swap in my mk2 gli so the rear ends are pretty much the same so if possible can you send me pic's of how yours is mounted so i can see if thats the setup im looking to do on mine. You can send them to my cell if you have any? 646-453-6708
    25. Junior Member Hellenic Vanagon's Avatar
      Aug 3rd, 2010
      Athens - Greece
      VW VANAGON SYNCRO, PASSAT G60 SYNCRO
      02-20-2015 02:48 PM #50
