Page 4 of 16 FirstFirst 1 2 3 4 5 6 7 8 14 ... LastLast
Results 106 to 140 of 526
Thread: .:Shaved Bay Information Resource Thread:.
    Feb 10th, 2002
    Pittsburgh, PA
    '94 Jetta, '08 Rabbit, '12 2500HD
    09-06-2011 11:08 PM #106
    Quote Originally Posted by pubahs View Post
    Afazz -- for extending wires, do you recommend a specific type of wire? I know some wires you need to be careful with because using improper wire wont shield it enough and yuo can get interference. Let me know, I need to extend my MAF plug, ISV, IAT
    The only shielded wires I found were the O2 sensor, crank position sensor, and knock sensor. Even those didn't seem to be truly shielded; they were wrapped with some busted ass foil insulation, but neither end was tied to ground. As long as your electrical connections are good and the splice is waterproof, you should be fine extending the MAF, ISV, and IAT.
    As for wire, SXL or TXL or GXL are good wires to use. The insulation on these is cross-linked PVC, very similar to the stock wire if not identical. Stay away from regular PVC wire (GPL) because it doesn't have a very high temp rating, and it will burn/melt instead of just bubbling like cross-linked PVC. I used all teflon insulated wire, which is more expensive and harder to work with but comes with a higher temp rating.
    Feb 10th, 2002
    Pittsburgh, PA
    09-06-2011 11:12 PM #107
    Here is a little A/C teaser
    Aug 28th, 2011
    MD 21703
    09-06-2011 11:28 PM #108
    Any tips on separating the wiring harness engine wiring from the lights/other? Since I'm doing a swap I don't need the engine part and wanted to simplify the harness as much as possible. Me being dumb and not thinking about it disconnected all the plugs from the motor without labeling them first because I wasn't planning on reusing the harness. Now I have to go to a junkyard and pull a harness and label each connector so I know what goes to what so I can delete what I wont be using.
    BTW is for a 2.0 engine harness
  4. Member
    Aug 28th, 2011
    MD 21703
    09-11-2011 03:28 AM #109
    I spread the harness out on the floor and removed all the wrapping. I can not for the life of me figure out how you get some of the wires untangled. It looks like the only way is cutting and splicing back together or removing the pins from the connectors and putting them back...or am I just missing something?
  5. Banned RUDE337's Avatar
    Jan 19th, 2006
    Boston. City of champs!!
    Minty fresh 94 Jetta GLX. 06 Audi A8L. Boss
    09-11-2011 07:11 PM #110
    Seems like Afazz is the man when it comes to shaving. You and a few others should start prefabbing them. Chase bays seems to only be for the jdm crowd. You'd make a killing if you did. It's my way of saying. I'm to lazy to one myself. But I did order a inline coolant filler cap. To delete the bubble. I'll post pics when I get it all set up.
  6. Member inertpyro's Avatar
    Oct 4th, 2007
    Chippy Waffles, WI
    11' Audi A4
    09-11-2011 08:37 PM #111
    I just stumbled on to this site. http://braunstadt.com/lugtronic/node/16
    Not sure how they are doing their harnesses and/or if they are lengthened to be hidden or anything. Maybe something to look into? It kind of looks like you have to use their ecu, but maybe you could just snip off the ecu end and wire it into the stock ecu? For $500-600 its not a bad deal and appears to be made out of quality materials.
  7. 09-13-2011 12:03 AM #112
    That would be Mr. Kevin Black's web site. He is a long time VW/Audi tuner. Those of you who know him know of his high quality work.
    Great thread btw
    Aug 26th, 2007
    '08 touareg, '97 jb de x2, '86 vr6 Rocco, '84 8v Rocco, '95 Vr cabby "hers"
    09-13-2011 12:12 AM #113
    there is a product called all metal dont use bondo if u actually drive the heat will crack it over time, all metal is kinda like bondo just a lil tip the street rod guys at work showed me
  9. Member BlueDevilCabby's Avatar
    Jul 6th, 2006
    Grand Rapids, MI
    97 Cabrio / 95 Harley Jetta / 94 GTI
    09-13-2011 08:12 AM #114
    Quote Originally Posted by sweetrocco420 View Post
    Plenty of people have used "bondo" without any issues so I highly doubt your statement, although all-metal is a good product.
  10. Member inertpyro's Avatar
    Oct 4th, 2007
    Chippy Waffles, WI
    11' Audi A4
    09-13-2011 09:49 AM #115
    Quote Originally Posted by BlueDevilCabby View Post
    I agree, your engine bay will be just as hot as a black car sitting out in the sun on a hot day. Not to mention street rods are going to have much larger, hotter engines in them. All metal it some good stuff though, I've used it in a few places, the resin activator stuff is kind of messy though. I would just get a good Evercoat body filler and you should be good.
  11. 09-13-2011 06:19 PM #116
    Quote Originally Posted by AsWeFlyBy View Post
    And that is a screaming deal for the harness.
    Are you from New Jersey, or did you just get the paint job in New Jersey?
  12. Junior Member deadtofall89's Avatar
    Sep 3rd, 2009
    North Providence Rhode Island
    1995 Cabrio
    09-13-2011 08:18 PM #117
    quick question while reading threw this thread someone said that the passat vr6 engine harness is longer then the vr6 gti harness and you do not have to lengthen it to tuck wires. If thats true why do people go about wasting their time lengthening the gti harness if you can just go get a passat harness and use that? that's just from what i read idk myself but i was asking also because i have a passat harness. thank you sweet thread tho
  13. Senior Member skidplate's Avatar
    May 4th, 2004
    Beaverton, OR
    89 GTI 90 Audi Coupe Quattro 06 Xterra
    09-13-2011 09:29 PM #118
    Quote Originally Posted by inertpyro View Post
    "The Custom Harness uses the inexpensive Wire-In ECU, and replaces your entire engine harness."
    http://braunstadt.com/lugtronic/node/14
    Flickr
    Quote Originally Posted by Mr. Knappy View Post
    We really need breeding standards like they have with dogs.
    Quote Originally Posted by pete@blackforest View Post
    I remember when people modified their Volkswagen to enhance the driving experience. What ever happened to Fahrvergnugen? Bags are for kids that grew up watching Pimp My Ride. Turbo is for all of us that enjoy actual motorsport.
  14. Member
    Aug 28th, 2011
    MD 21703
    09-13-2011 11:59 PM #119
    Holy ****, $1600-2000 for the harness/ecu......
    Ill take my chances on separating and lengthening my own harness haha
  15. Member fastmaxxcooper's Avatar
    Sep 24th, 2003
    Norwich, CT
    12 Leaf 09 Jetta TDI 06 Cooper S 98 Jetta 90 Corrado
    09-14-2011 03:35 AM #120
    whats everyone doing for the heater assembly in terms of mounting it to somewhere besides the firewall. any proven method?
  16. Member inertpyro's Avatar
    Oct 4th, 2007
    Chippy Waffles, WI
    11' Audi A4
    09-14-2011 07:59 AM #121
    Quote Originally Posted by skidplate View Post
    Yes I seen that but you in theory could just snip off the end that plugs into the not so inexpensive ECU and rewire it to the OEM ecu. It would cut out 90% of the work making the rest of the harness.
  17. Member pubahs's Avatar
    Apr 1st, 2002
    NYC & Niagara Falls
    95 VR6 Turbo
    09-15-2011 12:14 AM #122
    Quote Originally Posted by fastmaxxcooper View Post
    Define heater assembly?
    If you're referring to the fan control module, i'd suggest first and foremost ditching the stock VR fans and going with dual slim fans and a shroud if you can. The shroud will only maximize your fan efficiency. i believe my fans are Flex-a-lite or Derale. Mounted on the engine side of my mishimoto radiator and they run as 'pushing' fans. I believe a 10" and 12" both fit. I have clearance issues with my short runner intake
    As for the wiring maybe someone more knowledgeable can speak on it, but essentially you just wire the fans in to run off the relay/fan switch. Mine currently are either off or run in full mode. I deleted my AC, so that fan control module also has additional wiring for the AC fan controls.
    Been awhile, so excuse me if I am incorrect in any of this.
    chris
    AD 3 AD Labs ..... LugTronic
    autocrat.
  18. 09-15-2011 12:39 AM #123
    You can remove the FCM, all its wiring, ect, which gets rid of almost 1/4 of the bays wiring.
    This is my entire fan wiring setup. It is easily hidden, and uses the stock fan/fanswitch.
    He seems to be speaking of the heater core though, which most people with shaved bays don't run anymore. It takes ALOT more work to do it "right" and have full functionality. (Ala Afazz. )
  19. Member pubahs's Avatar
    Apr 1st, 2002
    NYC & Niagara Falls
    95 VR6 Turbo
    09-15-2011 01:09 AM #124
    i've been contemplating removing mine as well.. to delete the hoses going to it. I only kept it in the event the windows get foggy
    chris
    autocrat.
  20. Member
    Aug 28th, 2011
    MD 21703
    09-15-2011 01:26 AM #125
    Debating.....
    Easier to weld a flat plate over the frame rail to get rid of all the holes and for later body work/paint or fill the holes in the frame rail and then body work those? I dont care about that lip that sticks up, Im not going for a full shave but I dont want to leave open holes and crap that won't be used.
    Pros?
    Cons?
  21. 09-15-2011 05:42 PM #126
    Quote Originally Posted by harlequin80 View Post
    Debating.....
    Pros?
    Cons?
    Make a removable plate, that sits flush with the lip, and hide your wiring/evap stuff underneath it.
    Easy way to stay fully emissions capable.
  22. Member
    Aug 28th, 2011
    MD 21703
    09-15-2011 07:07 PM #127
    I don't have emissions in my state
    I have heard people talk about doing that though
  23. Member BlueDevilCabby's Avatar
    Jul 6th, 2006
    Grand Rapids, MI
    09-16-2011 07:27 AM #128
    Where do you live? In MI we don't either, same with front plates!
  24. Member
    Aug 28th, 2011
    MD 21703
    09-16-2011 07:29 AM #129
    Car is registered in WV. No emissions no front plates
  25. Member Lamy207's Avatar
    Aug 5th, 2009
    Maine
    2001 jetta wagon
    09-19-2011 07:26 AM #130
    This thread needs to be sticky'd. Just sayin'.
    LAMY'S PERFORMANCE
  26. Member dceola's Avatar
    Jun 21st, 2010
    Roanoke, VA
    96 Golf Harlequin
    09-19-2011 09:02 AM #131
    Quote Originally Posted by Lamy207 View Post
    would be great if it could be.. sticky threads have to have been started by a mod :'(
    '96 Golf Harlequin VR6, Chagal Blue base
  27. Member RATFINK's Avatar
    Jan 31st, 2004
    Orange County CA
    95 cabrio, Porsche cayenne
    09-20-2011 02:10 AM #132
    can anyone tell me what you are using for radiator filling. i see some kind of inline reservoir between hoses.
    Project Mayhem cabrio widebody build
    My old rides bluersvento etc
    valuable lessons can be learned from a humbled man
  28. 09-20-2011 02:32 AM #133
    Quote Originally Posted by RATFINK View Post
    http://www.speedwaymotors.com/Inline...ign=GoogleBase
    http://www.siliconeintakes.com/produ...oducts_id=1598
    You will need some form of overflow if it is a daily.
  29. Member Lamy207's Avatar
    Aug 5th, 2009
    Maine
    2001 jetta wagon
    09-27-2011 09:38 PM #134
    Started on the milspec harness today...
    LAMY'S PERFORMANCE
  30. Senior Member skidplate's Avatar
    May 4th, 2004
    Beaverton, OR
    09-27-2011 10:02 PM #135
    True, but if I were to drop that kind of coin on a harness, I wouldn't want to cut it up.
    Flickr
  31. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    09-27-2011 11:36 PM #136
    Quote Originally Posted by Afazz View Post
    They are, it's just done strangely. The shields all run together to a common harness ground wire that runs back out to the cylinder head ground point without connecting to the ECU ground plane as well.
    The O2 you can probably ditch if you really wanted to, but crank and knock sensors *will* get grumpy without the shield if they're anywhere near a plug or coil wire.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  32. Member
    Feb 10th, 2002
    Pittsburgh, PA
    09-27-2011 11:40 PM #137
    Are you referring to the black wire twisted up with the pairs? That is grounded and does act as a shield. The foil-lined sleeving was not grounded at either end on my car.
  33. Member
    Feb 10th, 2002
    Pittsburgh, PA
    09-27-2011 11:50 PM #138
    I thought this conversation was familiar; we discussed this over PMs back in 6/2010. The shielding in my car was not tied to ground, the ground twisted with the O2/crank/knock sensors is not a shield. I have run my motor since then, it seemed to run fine from idle through redline but not under load (just running, not driving). If there was a signal noise issue, wouldn't it stall or stumble at some point through the rev range even free-revving?
  34. 09-28-2011 12:02 AM #139
    Quote Originally Posted by need_a_VR6 View Post
    Found this out the hard way.
  35. Member
    Feb 10th, 2002
    Pittsburgh, PA
    09-28-2011 07:59 AM #140
    What are the symptoms of electrical noise affecting the knock and crank sensors?
