Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 141 to 175 of 238
Thread: "Keeping Up With The Joneses"
  1. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    02-10-2012 09:29 AM #141
    Great work!
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
  2. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    92 Corrado VRT, B5 A4 1.8TQ
    02-10-2012 04:44 PM #142
    thanks guys. Has anyone had issues with these SRI bolt holes lining up? The bolts that go into the head go in, but they seem a bit off. I have thought about drilling out the holes to a larger diameter if this becomes and issue.
    Do Werk!
    EEMILITIA PA CHAPTER
    WTB Passat Syncro Rear beam
  3. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    03-11-2012 11:42 PM #143
    I got some updates. Ive been busy.
    Some orders that came in last week.
    I got some parts this weekend. Bosch 044 fuel pump, fuel filter, fittings and 60# injectors.
    went from this
    To this
    To this
    To this
    All the interior electric works except the power windows. I must have missed something somewhere. I got an appointment with the fabricator in two weeks for intercooler piping and some misc. welding bits that needs to be taken care of. Hopefully I can turn the key in 3 weeks.
    The glovebox stands alone! minus one screw.
    Do Werk!
  4. Banned dubinsincuwereindiapers's Avatar
    Jan 16th, 2008
    InYourMom
    Bugatti Veyron
    03-12-2012 12:19 AM #144
  5. Member project92raddoslc's Avatar
    Oct 15th, 2004
    PA
    2010 Autobahn
    03-12-2012 08:51 AM #145
    looks like you've been busy. good work on getting the dash back in. i pulled most of my hair out when i had to pull mine all apart
  6. 03-12-2012 10:04 AM #146
    Awesome jake... I can't wait to see the car when it's finished.
  7. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    03-12-2012 02:22 PM #147
    eurosport oil cooler kit came today.
    Do Werk!
  8. Member DRW-CORRADO's Avatar
    Dec 27th, 2005
    PA
    90 Corrado VR6T, 93 Corrado VR6, 05 GLI,88 Quantum Syncro, 87 Cabriolet, 99 Passat Wagon
    03-12-2012 07:37 PM #148
    Looks awesome!!!
    Denny's Garage Facebook
    RHD BUILD
    instagram: drw_corrado
  9. Member sdezego's Avatar
    Apr 23rd, 2004
    03-12-2012 10:16 PM #149
    haha, I remember those wiring days LOL
  10. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    03-27-2012 05:51 AM #150
    It's off to get fab work. Can't wait to see what my fab guy comes up with. This guy does amazing work.
    Do Werk!
  11. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    03-28-2012 09:56 PM #151
    Progress. Turbo blanket, down pipe reconfigured and custom throttle cable bracket.
    Do Werk!
  12. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    03-28-2012 09:59 PM #152
    Do Werk!
  13. Member DRW-CORRADO's Avatar
    Dec 27th, 2005
    PA
    03-28-2012 10:09 PM #153
    Looks Great
    RHD BUILD
  14. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    03-29-2012 10:35 PM #154
    Quote Originally Posted by DRW-CORRADO View Post
    Looks Great
    Here is another update. Loving it so far.
    Do Werk!
  15. Member jettalvr41's Avatar
    Oct 26th, 2006
    Lincoln, Nebraska
    04 jet 92 SLC
    03-30-2012 10:26 PM #155
    Dude were building like the same car! Well same build anyways. You should pm me. I'd love to ask you a few questions.
    8v mkiv 12vt slc
    Nebraska Corrado VR build
    The Depot Build
    Quote Originally Posted by cstanley19 View Post
    . Learn the car first.. then modify it...
  16. Member
    Sep 16th, 2007
    2001 Audi TT 225Q
    03-31-2012 08:28 PM #156
    Looks great!!
  17. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    03-31-2012 11:11 PM #157
    Quote Originally Posted by corradojohnt View Post
    Looks great!!
    Thanks. It has come a long way.
    Do Werk!
  18. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    03-31-2012 11:12 PM #158
    Fab guy is doin work. Manifold heat shield is almost done.
    Do Werk!
  19. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    04-06-2012 10:18 PM #159
    Chromoly crossmember
    Catch can with exhaust vacuum setup
    I should be picking up the C from the fabricator tomorrow!
    Do Werk!
  20. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    93' SLC VR6 90' G60 99' Jetta
    04-06-2012 10:23 PM #160
    Wow that's some awesome fabrication! What's the reasoning behind the crossmember
    [B] INSTAGRAM: europeein
    Facebook: facebook.com/addmichael
  21. Banned dubinsincuwereindiapers's Avatar
    Jan 16th, 2008
    InYourMom
    Bugatti Veyron
    04-06-2012 11:24 PM #161
    Damn... Good things are happening every time I click on this thread.
    for a well thought out, and executed build.
  22. Member JamesS's Avatar
    Nov 17th, 2008
    Regina Saskatchewan
    91 JDM Corrado
    04-06-2012 11:26 PM #162
    Any more info on that chromoly crossmember? I noticed you and vwflygti have made them up. Any specifics on how they were done/ the advantage of it?
  23. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    04-07-2012 10:13 AM #163
    Quote Originally Posted by HavokRuels View Post
    Quote Originally Posted by JamesS View Post
    The reason I chose to go this route with the crossmember is for rigidity. I dont think the stock crossmember was designed to handle 500+hp, and the last thing I wanted is for the motor and trans to be flopping around. Thats when things start breaking. (axels, mounts, etc) I also have a forward trans brace that will go down to the crossmember. This way there is a solid mounting point for the trans brace as well. Plus going this route gave me some options for mounting awic heat exchanger, awic pump, and rad. As far as the specs the chromoly is super beefy. Im trying to remember but im pretty sure its 1/4" wall tubing. Stuff is crazy expensive. There are also chromoly gussets that were installed on the 90* corners that arent shown in the pic. I will have better pics of everything today. Stay tuned for the chromoly awic core bracket.
    Quote Originally Posted by dubinsincuwereindiapers View Post
    Thank you sir!
    Do Werk!
  24. Member sdezego's Avatar
    Apr 23rd, 2004
    04-07-2012 10:58 AM #164
    Quote Originally Posted by ItsNotaScirocco View Post
    ... There are also chromoly gussets that were installed on the 90* corners that arent shown in the pic. I will have better pics of everything today. Stay tuned for the chromoly awic core bracket.
    Nice. I was going to suggest that , but figured this was an in progress pic. There was also a guy a few years back who made a front cross member out or a single piece of large diam CRMO tube that was super nice. Always love to see good fabrication.
  25. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    04-07-2012 11:23 PM #165
    Moar Pics
    Do Werk!
  26. Junior Member AirmanTDI's Avatar
    Apr 26th, 2011
    Eastern Ontario-CANADA
    04-08-2012 11:28 AM #166
    Your build is awesome!!! Really enjoy the thread!
    Pain is just weakness leaving the body
    http://www.fuelly.com/sig-metric/70042.png
  27. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    04-08-2012 02:54 PM #167
    Quote Originally Posted by AirmanTDI View Post
    Do Werk!
  28. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    04-29-2012 09:09 PM #168
    She runs!! Definatly needs some bugs worked out but it runs!! Here is a ****ty cell phone video clip.
    Do Werk!
  29. 04-30-2012 10:02 AM #170
  30. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    04-30-2012 04:20 PM #171
    So far I am just having some issues connecting my laptop to ecu. Serial to usb driver error. With that being said I cant get in to see whats going on. A friend of mine has the driver so he should be able to set me straight later tonight. On another note, these little pieces of awesomeness came today.
    Do Werk!
  31. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    05-07-2012 09:57 PM #172
    Success!! I finally got to take her out for the first time in 9 months. Very pleased so far. It sounds absolutly amzing. The past couple weeks have been hell. Surge tank had a pin hole leak, fuel pressure issues, fuel gauge read 1/4 tank but it was totally empty( so I thought one of my fuel pumps died cause the 044 is loud allready but it makes some crazy noises when you run outta gas, lol), more or less just one little thing after another but I guess thats what you call "working out the bugs."
    Very impressed with these spal fans, a little loud but man do they move some serious amounts of air. I have been sending kevin black data logs and trying new maps so hopefully I will be getting into some boost soon. Here is another cell phone video clip after I got it running correctly.
    Do Werk!
  32. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    05-07-2012 09:59 PM #173
    Congrats!
    Dak
    I drive waaay too fast to worry about my cholesterol.
  33. Member ItsNotaScirocco's Avatar
    Dec 7th, 2009
    Perkasie, PA
    05-07-2012 10:11 PM #174
    Quote Originally Posted by SLC4EVER View Post
    Congrats!
    Thank you!
    Do Werk!
  34. Member project92raddoslc's Avatar
    Oct 15th, 2004
    PA
    2010 Autobahn
    05-07-2012 10:40 PM #175
    that vid sounds much better than the last! get this thing buttoned up and on the road for the TST meet on saturday!
