VWVortex.com - "Keeping Up With The Joneses"
    Page 5 of 10 FirstFirst 123456789 ... LastLast
    Results 101 to 125 of 248
    Thread: "Keeping Up With The Joneses"
    1. Member ItsNotaScirocco's Avatar
      Dec 7th, 2009
      Perkasie, PA
      92 Corrado VRT, 2011 GTI 2.0T
      01-03-2012 12:36 AM #101
      I got the head back today, lapped the valves, installed new seals and put the springs back in. I hope to have it all bolted up tomorrow. Finally getting to install some parts!
      WTB Passat Syncro Rear beam
      Sep 16th, 2007
      2012 VW CC R-LINE
      01-03-2012 01:08 AM #102
      Looking great buddy!
    3. Member ItsNotaScirocco's Avatar
      Dec 7th, 2009
      Perkasie, PA
      01-04-2012 11:51 PM #103
      Made some more progress today. I ported out the turbo manifold to match the T4 inlet on the turbo.
      I got the lifters and cams in, copper coated the head gasket/spacer and installed the head. Upon tightening the head studs the third and final time i noticed a little bit of oil seeped out around the corner closest to the exhaust manifold, crank pulley side.
      I think some of the oil/assembly lube may have dripped out of the head durning installation. I am not really sure where it came from to be honest I am just guessing. I assume this is no good for sealing purposes. Will this be ok? Should I get a new head gasket and start over since its allready been tourqed? I am not really sure on this one any help is appreaciated.
      But to ease the frustration with the oil issue I clocked the turbo and did a mock up.
      The corner of the gasket sticking out in the pic is where the oil was seeping. Also if you notice the head stud right above it. I couldnt get it to go in any further. Is that normal? It seemed to bottom out and I didnt want to over tighten it and risk damaging the block. There was plenty of thread to bolt to so I rolled with it.
    4. Member ajhvw93's Avatar
      Oct 26th, 2009
      PA
      80 Rabbit Diesel....87 16V Scirocco...87 8v Gti..93 vr6 Corrado
      01-05-2012 07:45 AM #104
      I'm not a big fan of a B kit on a C. But, I really like the look of this car!! Love the Audi wheels or reps...whatever. Keep up the good work!!
    5. Member Wompa's Avatar
      Oct 30th, 2009
      Sweden
      Corrado VR6, Golf MK2 Syncro
      01-05-2012 08:11 AM #105
      Eyh dude, nice Scirocco...
      Looks really sweet anyways!
    6. Member ItsNotaScirocco's Avatar
      Dec 7th, 2009
      Perkasie, PA
      01-05-2012 09:39 AM #106
      Quote Originally Posted by Wompa View Post
      Thanks
      I lost count how many times I have heard that scirocco comment. Its usually the older burn out guys that say that.
    7. Member ajhvw93's Avatar
      Oct 26th, 2009
      PA
      01-05-2012 11:18 AM #107
      Quote Originally Posted by ItsNotaScirocco View Post
      Thanks
      That is 100% correct. I have had older guys say as well. I'm an ole burnout. But, had a Scirooco so...I know the diff...ha ..ha!!
    8. Member Wompa's Avatar
      Oct 30th, 2009
      Sweden
      01-05-2012 12:31 PM #108
      First comment was "Is that a Scirocco.." The second was "Is it a Porsche?"
      Its getting better
    9. Member ItsNotaScirocco's Avatar
      Dec 7th, 2009
      Perkasie, PA
      01-06-2012 11:30 AM #109
      Did Work. Yes I need to empty the trash can.
      Fresh chains and guides. Resurfaced flywheel. Installed the spec stage 3 clutch. I just have to get the bung in the pan welded and then it will be time to drop this motor in.
    10. Member corrado-correr's Avatar
      Jul 8th, 2004
      Stuttgart
      01-06-2012 12:05 PM #110
      proper.
    11. Member sdezego's Avatar
      Apr 23rd, 2004
      Hurricane Central FL
      '90 Corrado | '62 Harley Panhead
      01-06-2012 03:48 PM #111
      Very much acceptable thus far
    12. Member ItsNotaScirocco's Avatar
      Dec 7th, 2009
      Perkasie, PA
      01-06-2012 09:42 PM #112
      Quote Originally Posted by sdezego View Post
    13. Member ItsNotaScirocco's Avatar
      Dec 7th, 2009
      Perkasie, PA
      01-23-2012 03:29 PM #113
      I met with the fabricator last week to talk about everything that I need done. This guy does alot of work for friends and I understand he has a good reputation in the supra world. Its a small one man operation but this guy does some crazy good work. So I dropped him my beat up oil pan for turbo drain and some reinforcement. All chromoly reinforcements and I am pretty impressed with his work. This pan will be able to stand up to abuse.
    14. Member ItsNotaScirocco's Avatar
      Dec 7th, 2009
      Perkasie, PA
      01-28-2012 12:56 AM #114
      Did moar werk! Yes I am getting a new starter. I just used the old one to get the front motor mount in place. Getting a new starter next week.
    15. Member rq1trackaddict's Avatar
      Sep 21st, 2009
      Perkasie, Pa
      SV Race Bike
      01-28-2012 10:06 PM #115
      That's awesome Jake. Good luck with the build
    16. Member ItsNotaScirocco's Avatar
      Dec 7th, 2009
      Perkasie, PA
      01-29-2012 12:10 AM #116
      Thanks Chris. Should be done in 2 months you will have to come for a ride.
    17. 01-29-2012 03:22 AM #117
      looking really good. yes new starter and yes you will be cleaning/painting the shifter cable bracket as well. you have no say in these options.
      Quote Originally Posted by BlueVR View Post
      yes i am still into Vag...
    18. Member ItsNotaScirocco's Avatar
      Dec 7th, 2009
      Perkasie, PA
      01-29-2012 05:47 PM #118
      Quote Originally Posted by hubbell View Post
      Yes. New starter and por15 on the shifter cable bracket. I am also hunting for something close to oem for the heatshield on the cables. That stuff is in pretty bad shape and needs replaced.
    19. Member project92raddoslc's Avatar
      Oct 15th, 2004
      PA
      2016 GOLF R
      01-31-2012 12:41 AM #119
      I saw Wilinksi put up a pic of a bay the other day but didn't realize it was your car. Looks great man, definitely want to check it out when it's done!!
    20. Member peskyrabbit's Avatar
      Oct 19th, 2011
      Dover PA
      08 Rabbit
      01-31-2012 02:43 AM #120
      I love your car dude its spool dope
      Sent from my DROID X2 using Tapatalk
      Replica wheels are like fake boobs. They look good on the outside, but when it comes to quality, Nothing beats the real thing.
      Instagram: BriarGW
      YOLO is GAY
      Quote Originally Posted by Matt_Mkv View Post
      Low and slow my friend.
    21. Member ItsNotaScirocco's Avatar
      Dec 7th, 2009
      Perkasie, PA
      01-31-2012 06:24 AM #121
      Quote Originally Posted by project92raddoslc View Post
      Yeah he has helped out a lot. One ride in his VRT inspired me to do this project. Hit me up sometime if you want to swing by and check it out. It's a shame you got rid of your C. It won't be long now till this is running.
      just wiring, fuel and fab work.
    22. Member project92raddoslc's Avatar
      Oct 15th, 2004
      PA
      2016 GOLF R
      01-31-2012 08:30 AM #122
      yeah i regret it sometimes, mainly just getting new parts in the mail everyday
    23. Member rq1trackaddict's Avatar
      Sep 21st, 2009
      Perkasie, Pa
      SV Race Bike
      01-31-2012 09:09 AM #123
      For sure. I have a car to show you
    24. Member ItsNotaScirocco's Avatar
      Dec 7th, 2009
      Perkasie, PA
      01-31-2012 04:00 PM #124
      I pulled the seats out and prepared for wire tuck. While I was in there I finished removing the abs harness. Once it came out, the wiring that is left is alot easier to manage. I got started on cleaning up the wire harnesses. It seemed a little intimidating at first but once I laid it out and saw what goes where it will be pretty easy.
    25. Member project92raddoslc's Avatar
      Oct 15th, 2004
      PA
      2016 GOLF R
      01-31-2012 04:39 PM #125
      seems like only yesterday that i spent hours every night repairing my harness and rewrapping from the dash to the headlights. have fun
