VWVortex.com - 17s with MEAT (aka "small" wheels with FAT tires)
    Page 4 of 20 FirstFirst 1234567814 ... LastLast
    Results 76 to 100 of 481
    Thread: 17s with MEAT (aka "small" wheels with FAT tires)
    1. Member Cspence's Avatar
      Nov 23rd, 2008
      Meriden, CT
      '09 CC VR6 / '05 E320 CDI / '87 GTI VRT
      10-03-2011 09:09 PM #76
      Bump! Lets see some more!
    2. Member EIPtuningR32's Avatar
      May 3rd, 2008
      Gainesville, FL
      1989 VW Golf 8v, 2002 C5 Z06, 1982 Porsche 928S, 2004 VW .:R32 (sold), 1962 VW Myers Manx (sold)
      10-04-2011 01:09 AM #77
      do you guys think i could run a 255/40/17 tire on an 8" wide wheel? thinking the new Enkei Fujin (new lightweight wheel that is supposed to be the new RPF1 status)
      Terminally unhinged
      '89 MKII 8v 4-door for more horze
      Oct 14th, 2004
      2004 Volkswagen R32, 1988 Ford Festiva LX, 1978 Honda Hobbit
      10-06-2011 08:26 PM #78
      Quote Originally Posted by EIPtuningR32 View Post
      doesn't QBNR32 run something like that? rolled fenders though.
    4. Member Airy32's Avatar
      Nov 14th, 2007
      NC
      MkIV R
      10-06-2011 10:17 PM #79
      Quote Originally Posted by tpr950h View Post
      IIRC he runs 245/40/17s but they are Toyo R888 which are probably quite a bit wider in the tread width than almost everything else, or more like a 255 or more.
      I'm running 245/40/17 Michelin SuperSports on 17x8 et35. I could probably fit a 255/40 with a 5mm spacer. I have around -2 front camber so the clearance is tighter with the suspension than the fender.
    5. 10-07-2011 01:07 AM #80
      It'll fit, but its not recommended, the sidewall will bubble and slow response time between input and direction change. Its also outside of the manufacturer recs.
    6. Member aircooled56's Avatar
      Jul 6th, 2006
      San Luis Obispo
      2004 R32, 1966 Volvo 122S, 2001 BMW 525it, 2001 Chevy Truck
      10-07-2011 02:12 AM #81
      My new track setup. 17x9's with 245 Hoosier R6's. This is 97Msedan's old setup.
      My daily setup. 17x7.5's with 235 Hankook RS3's.
      .:R32 RennSport
      Buttonwillow #13 2:02.411 Laguna Seca 1:45.485 Willow Springs 1:37.339 Auto Club ROVAL 1:57.529
      Fastivus King of the Hill 2011, Fastivus King of the Cross 2015, 2016
      www.fastivus.com
      May 24th, 2011
      SoCal and El Paso, TX ;-)
      MKIV.:R32 & MKVI.:R 2.:R's are better than one .:R!
      10-07-2011 03:51 AM #82
      Aircooled56 (or anyone running 17's for that matter) what wheels/tires do you recommend for a track setup? Of course what your running in the pix (Ish looks sick! ) , but want else? Anyone else fill free to chime in.
      UNDER STEER MUST DIE!!! As my skills/abilities increase UNDER STEER magically disappears!!!
      Stock is like virginity: Useless and should be gotten rid as soon as possible!!!!
    8. Member bsA41.8T's Avatar
      Feb 15th, 2004
      harrisburg, PA
      mk2 gti vr6~~2016 Jetta sport
      10-07-2011 07:43 PM #83
      Here's my new rollers...17x8 oz sl's w/ 225/45...et 35 or 38..can't remember with 15mm spacers in rear...front BARELY clears coils
      Barry
      92 gti vr6, 17" thlines, ultra ultra lows
    9. Member aircooled56's Avatar
      Jul 6th, 2006
      San Luis Obispo
      10-08-2011 02:12 AM #84
      Quote Originally Posted by GOT R32? View Post
      Whatever is lightest, widest, and stickiest that you can afford
      .:R32 RennSport
      www.fastivus.com
    10. 10-08-2011 10:49 AM #85
      So anyone going to make these work?
      silver Enkei RPF1, 17x9, ET35mm, LP 5x100
      http://www.dezod.com/pd-enkei-rpf11.cfm
      What tire profile would be used to keep as close to the factory specification and not throw off the speed much?
    11. Member Cspence's Avatar
      Nov 23rd, 2008
      Meriden, CT
      10-08-2011 11:37 AM #86
      I hope that pricing was for a set lol....I saw that there were a few gb's for the 17x9's in a 5x100, just wish it was a normally stocked size. The standard 225/40R18 is just over 25" in diameter...a 235/45R17 is only about .25" larger....a 245/45R17 is about .5" larger
    12. 10-08-2011 11:50 AM #87
      That's a set.
      I currently run 18x8.5" BBS RG-R (ET35mm) wrapped in 225/40R18 Michelin Pilot Exalto's (have ran with Pilot Sport's and PS2's in the past) with KW Street Comfort coilovers. I have a strut clearance of around 8mm (maybe 10mm) from tire to strut.
      If only Enkei can keep the specs the same and just chop .5" from the backspacing.
      Would love to go back to a nice 17" setup with higher sidewall.
    13. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      10-08-2011 12:03 PM #88
      Imola Yellow GTi
      255/40/17 - 0.2% slower - More flush fit, but not meaty (like OEM)
      235/45/17 - 1.2% faster than OEM
      245/45/17 - 2.3% faster, more meaty
      (When speedometer reads 60mph, actual speed will be 61.4mph: 2.3% faster)
    14. 10-08-2011 02:18 PM #89
      i just removed a set of 17x7.5 superleggeras that were wrapped with Hankook RS3's 225/45/17...
      that was a nice setup..very light, no worries on potholes (granted roads are pretty good here..)
      wouldnt have changed it if my buddy didnt work for CCW..
    15. 10-08-2011 02:19 PM #90
      oh..and if not mistaken they were +45 offset..I think.......
      ran for awhile with a set of 12.5mm spacers in the rear which worked out very nicely
    16. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      10-08-2011 02:53 PM #91
      Quote Originally Posted by Idok View Post
      I thought they were 17x8, was so wanting them, minus the STi color
      When speedometer reads 60mph, actual speed will be 59.7mph: 0.5% slower.
      Edit:
      For more meat, you could have went 235/45/17, which is what I have on an 8" wide wheel,
      but I am not sure if I would have done it on a 7.5" wheel.
      When speedometer reads 60mph, actual speed will be 60.7mph: 1.2% faster.
    17. 10-08-2011 03:05 PM #92
      sorry U are right..17x8
    18. 10-08-2011 11:25 PM #93
      whats the specs on the black R..last picture post 34..?
      looks GREAT!
    19. Member
      May 24th, 2011
      10-11-2011 01:15 PM #94
      Quote Originally Posted by aircooled56 View Post
      That is actually some good advice!!! Good looking out!!
    20. Member BigTimBigTurbo's Avatar
      Aug 13th, 2007
      MA
      nothing running
      10-19-2011 09:50 PM #95
      so for the bump i just want to subscribe
      The Certain People
      We Are All Whores Just Some Of Us Get Paid
    21. Member
      Jan 28th, 2008
      Rye, NY
      UG MkV R32; 4.2 Q7 Daytona Grey
      10-24-2011 02:53 PM #96
      Great thread. I've posted something similar in the mkV forum, but adding the question about performance brakes that would fit under 17" wheels.
      http://forums.vwvortex.com/showthrea...-quot-SBK-quot
    22. Member
      Oct 14th, 2004
      10-24-2011 06:44 PM #97
      looks GREAT!
      i think that car was 17x9 wheel with really big tires. i think fenders rolled too.
    23. Member vw-tim's Avatar
      Sep 14th, 2010
      California
      01-13-2012 01:47 PM #98
      so thinking i wanna go 17inch route.. what should i look for 17x8 or 17x7.5 wheels? i daily drive my car this isnt a track setup all though thats what im leaning towards as how i want me car to be?
      from what i can gather i should get 17x8 and run a 235/45/17 tire? would that be the ideal daily driver setup? i also want to still be low.. idk current set up im on 19 235/35/19 with 10mm spacers front and 20mm rear.. i like the ride height and everything i just think i wanna go with 17 inch wheel make it look clean. anyway info would be great thank you!
      pics of current setup here: http://forums.vwvortex.com/showthrea...-pics-for-2012!
    24. Member loosefalcon's Avatar
      Sep 19th, 2009
      Colorado
      '16 VW GTI
      01-13-2012 01:54 PM #99
      Quote Originally Posted by DarkSideGTI View Post
      I'm tempted to go with this setup, but maybe some Falken Azenis RT615 tires.
      bluerabbit0886 has this exact setup on his R32. PM him for his impressions. From my experiences, both driving and riding along, the tires are phenomenal. Very sticky, even in relatively cold weather (20-40 degrees Fahrenheit). Not very noisy, although I've heard that the Star Specs tend to get pretty loud towards the end of their life. Good thing the R32 has a loud exhaust.
    25. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      01-13-2012 11:15 PM #100
      Quote Originally Posted by vw-tim View Post
      I went with 23/45/17 on 17x8 and it's comfy, more wheel protection, and you go a lil faster than before.
      But?
