Results 1 to 6 of 6
Thread: aeg pistons like 3A???
  1. 08-28-2011 10:07 PM #1
    so i race a 3a bottom and a solid rabbit head and i now need a piston. 3a piston you say? good luck with that wihtout a new mortgage. i notice that the mk4 engines like aeg have the same bore and stroke and i "think" rod length. anyone know for sure if this piston and/or rod may fit? i have an aeg sitting here and don't really want to rip it apart if parts won't work.
  2. Junior Member
    Oct 22nd, 2007
    Montgomery, AL
    82 Scirocco Dirt Track Race Car
    08-29-2011 03:42 AM #2
    i don't think they are the same but it wouldn't take that long to drop the pan pull the head and pop one out and measure the pin distance between the two.
    maybe someone will chime in that knows for sure.
  3. Member Doxie Moxie's Avatar
    Mar 1st, 2009
    The Real World
    VW Mk3 Cabrio
    08-29-2011 05:03 AM #3
    The AEG will fit, but you will need to check the clearance on the skirt for the oil squirter.
    I Know One Nerd With Underwear Near Istanbul Sitting Alone Near A Street Sign Holding Onto Loser Expectations
  4. 09-05-2011 10:37 AM #4
    thanks doxmox. i put the pistons and rods in, they fit fine and there is no issue with th oil squirters. motor worked fine with this setup. the wrist pin is narrower and the piston is less of a "barrel" type that the stock 3a pistons. this setup would appear to be lighter although i didn't weigh them.
  5. 03-25-2012 10:40 PM #5
    I might do this too. AEG pistons in a 3A block.
    Any idea what a set of these piston go for?
  6. 03-27-2012 11:06 AM #6
    i bought a used AEG shortblock off vortex for $50, so i got 4 pistons/rods that way. the aeg crank will not work as it is a bit longer on the snout with the provision for the chain-driven oil pump. an aba or 9A crank will work fine if you mess up the 3A crank.
