Page 1 of 2 1 2 LastLast
Results 1 to 35 of 58
Thread: Skyline LED Tail light DIY
  1. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    08-30-2011 12:36 AM #1
    This will be mine first DIY. First thanks to Kg810 and Stylist07 for the info. this is base on the thread http://www.mk5golfgti.co.uk/forum/in...c,16607.0.html and some pic reuse from that also.
    Item list:
    5mm Clear Red LED 40 pcs
    100 ohm resistor 1/4 watt 10 pcs
    18 gauge wire
    One pair Valeo LED inner tail light
    Tools list:
    Hot glue gun
    soldering iron
    flat head screw driver
    wire cutters
    nose pliers
    Drill and 13/64 drill bit and a smaller drill bit.
    dremel
    a glove
    VAG-COM
    Before you start the mod make sure this is you want to do because you might kill $400 tail light sets
    Here we goes....
    Use flat head screwdriver, SLOWLY pry open between the lens cover and the back housing. Start with one area, gently pry the lens cover until you hear the soft cracking then work on the next. if you start to see the crack start go toward the surface STOP, work from the reverse side.
    Once you take out the lens cover. turn it over. you will see the 8 points you will need to use the nose pliers to remove the melted plastic that holds the inner housing. In the picture, the circle in green are what it looks like before remove the plastic and in blue is what will look like once you remove the plastic
    After you remove the 8 the melted plastics, you can take out the silver housing that holds the fog/reverse light
    then the red/clear cover and the clear lens
    full disassemble of inner light
    VERY VERY important DO NOT touch the chrome part of inner housing it will get your prints and if you try to clean it... the paint will come off.... wear a glove or you will repaint them....
    Use the small drill bit to pre drill the housing then use the 13/64 drill bit.. again do it slow and and use the low rpm setting on the drill. you will drill 20 holes.
    Temporary reassemble the chrome part of housing, you will notice part of inner housing has no room on the back side because is sitting against the outer housing.
    Here is where the dremel comes in.. use the dremel to sand down surrounding holes on some of back side to make some room for the LED and at same time fix of base of pointed long legs where next to the hole so the led will sit correctly.. (sorry don't have picture..)
    Assemble the LED:
    the longer leg is + and the short leg is the ground
    Now set the LEDs in the holes you just drilled and solider with 5 leds at the time. you will solider them negative leg to positive leg alternating then solider one resistor at the positive leg
    You are going to make 4 sets of 5 led lights to a string with one resistor on each string. By the time you done should look like this
    Use one wire to connect the resistor then other wire to connect all the negative. In the picture, I use green wire for ground and red wire for the positive
    After that is done, its a good time to test out the LEDs by use the 12v battery from your drill tool
    after test out the light, use hot glue to hold the leds and insulate the wires
    Drill the a small hold on the side of outer house to let the new wires out. again do it slowly..
    reassemble the light and the housing. use hot glue on the 8 points where you removed the melded plastic
    put back the lens cover then hot glue the edge. then you are done.. just have to work other side..
    You might want to add one more resistor on the new wire coming out the housing if the light is too bright. (I have to because the led i use is 15000mcd otherwise people behind me won't see anything)
    When comes to wiring the car I took out the truck panels then ran the wire down the black tube into the side wall.
    Just have to open up the airbag panel
    If you wire base on this this thread http://forums.vwvortex.com/showthrea...LED-Taillights all you have to is to connect the to the park light wire and ground wire. The new light will do driving light and brake light..
    If you want to disable the center light of outer tail light, use VAGCOM in the Central Electronics Module long coding, bits 9 through 13 to 00 00 00 0F 00 http://golfmkv.com/forums/showthread...ight=led+tails
    Finished products
    installed on the car
    If you are intersted doing the mod and have questions. I will be more than welcome to answer you.
    My Build Thread
    Quote Originally Posted by PSU View Post
    I also must say that Wei is one of the biggest bosses I have ever met.
    Quote Originally Posted by AWDMKV View Post
    Wei - he is a Funny Motha..
  2. Member DarkNeo's Avatar
    Jun 18th, 2004
    SoCal
    Golf R32
    08-30-2011 12:45 AM #2
    Official OG '08 .:R32 Owners Club Member
  3. Member gottiR32's Avatar
    Apr 24th, 2008
    Bloomingdale IL
    Previous cars are listed on Wikipedia...
    08-30-2011 03:21 AM #3
    How bout i buy the tails and send them to you and send em back all pretty...good job anyhow...
    .:R32 #1828 DBP H&R Sports H&R RSB other tid bits...
    Quote Originally Posted by exodus20 View Post
    U da damn police, bet u got a fake badge damn mall cop to entirely VW
    Quote Originally Posted by xalfa View Post
    Dumb lurker would probably be appropriate for me, but I'm going to go with "gotti flame bitch"
    http://www.performanceleds.com/
  4. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    08-30-2011 03:53 AM #4
    Still one of the biggest bosses I have ever met.
    Thanks for this write up. Killing it Wei.
    Also, you should get some LED license bulbs.
    MKV | MKIV | AWhiteRabbit| perfect.
  5. Member sixteen10's Avatar
    Nov 16th, 2008
    South Africa
    2008 Golf V .:R32
    08-30-2011 05:18 AM #5
    Sixteen10's 4 Door .:R32 | Shawn's Speed Shop | gottiR32 Approved | Milltek Sport
    Quote Originally Posted by zevion View Post
    IMO the first major 'R' engine failure was they put that puny little 4 pot into it to begin with.
  6. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    08-30-2011 07:33 AM #6
    Quote Originally Posted by gottiR32 View Post
    you will miss out the fun of this DIY... every step I did I was hoping.. please don't f up, please don't f up lol
    Thanks boss... I was thinking about to covert to all to LED, too.
    My Build Thread
  7. Member skaven-R32's Avatar
    Jun 22nd, 2008
    Renton, WA
    MkV DBP R32 #462
    08-30-2011 05:18 PM #7
    There is also be a kit (that was) available, but I don't have the link on my work computer.
    Nicely done write-up! I've always lamented the fact the inner rings were 'fake' on our platform.
  8. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    2008 CW R32, 1983 CW Rabbit LS
    08-30-2011 05:27 PM #8
    Damn son, looks dope.
    Skyline mod. I get it now.
    Holy Milltek.
    Tarmacs cut it close.
    Miami Vase
    Cams A Make Her Dance
  9. Member MoWsE's Avatar
    May 14th, 2007
    Aiea, Hawaii
    Current: 2008 MKV .:R32 Old: 2000 B5 Passat
    08-30-2011 05:39 PM #9
    If you ever get into the market of doing these for people, let me know! I'm so in! LOL! Honestly don't have the want to try and do it myself
  10. Member r-dub's Avatar
    Sep 10th, 2005
    STL
    13 goRf
    08-30-2011 05:50 PM #10
    sick!
  11. Member Ryan E.'s Avatar
    Oct 1st, 2002
    Huntington Beach
    2008 CW R32, 2003 1.8T GTI, 1974 2002 tii
    08-30-2011 06:06 PM #11
    nice work!
    Rigi Cola.
    "The VR6 was an orchestra of well-tuned cylindrical delights." - jalopnik.com
    Nov 29th, 2008
    Ladera Ranch, CA / Chehalis, WA
    Widebody 08 VW R32 Turbo | 2013 CC Sport
    08-30-2011 06:53 PM #12
    Good writeup!
    Jon Sibal did a writeup on his blog a few years ago as well.
    http://jonsibal.com/blog/2008/11/mk5...light-project/
    Newing Alpil GTI-RS Widebody MKV R32 Turbo
    2013 CC Sport (Daily Sled)
    ThePaws.com - Yes .. I sell dog toys for a living.
  13. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    08-30-2011 06:58 PM #13
    thanks all
    Quote Originally Posted by skaven-R32 View Post
    !! there was a kit...... !! I would get if it's available.. how much did it cost?? The leds and resistor cost me around $20.. and about total of 6 hours of work include the wiring in the car
    My Build Thread
  14. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    08-30-2011 07:07 PM #14
    Quote Originally Posted by willlangford View Post
    Good writeup!
    the tutorial i was trying to follow is base on the jetta's led light, but the housing is totally different...
    My Build Thread
  15. Member Ripdubski's Avatar
    Aug 12th, 2004
    G-Vegas, SC
    08 .:R32 DBP, 01 Jetta GLS GB
    08-30-2011 08:40 PM #15
    Excellent!
    Thx!
    Ripdubski
    08 .:R32 DBP, 01 Jetta GLS 2.Slow AutoTragic GB
    Flickr - shutterfly
  16. Member jwbekens's Avatar
    Sep 28th, 2005
    Virginia
    1984 SVO Mustang, 1997 Millenia S, 2006 X3, 2008 R32, 2010 Golf TDI
    08-30-2011 08:47 PM #16
    Stylish, functional, bold! Nicely done, young man!
    Candy White 2008 .:R32 #532 and Shark Blue 2010 Golf TDI
    .:R you in? I'm in. You .:R what you drive.
    Seduced by the Da.:Rk side I am.
    The Golf R brings balance to the FoRce.
  17. Member
    Nov 29th, 2008
    08-30-2011 09:13 PM #17
    Quote Originally Posted by foreverblue View Post
    Yea, exactly. Yours is great. now I just need to figure out how to do this with Euro tails. I'm not a fan of how the LED housings look. Thanks again for a great writeup.
  18. Member R3Drew's Avatar
    May 4th, 2010
    Man Jose, CA
    Personal: 2008 Silverado 1500 VMax Work: 2012 Camry L Sold: 2008 R32
    08-30-2011 10:54 PM #18
    Def a boss mod
  19. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    08-30-2011 11:41 PM #19
    Here is a theory, could use 5mm bi color LED run one more wire 5 more resistor per side. could do the park, turn and brake light just like the outer light.
    My Build Thread
  20. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    08-31-2011 12:29 AM #20
    what is the Euro inner back side looks like, i might have an idea..
    My Build Thread
  21. Member
    Nov 29th, 2008
    08-31-2011 01:22 AM #21
  22. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    08-31-2011 06:58 AM #22
    you don't want to drill any holes on the red part of housing (not the cover)
    if there is one more piece sit between the red housing and the outside housing, you could use couple clear led mount it on it... If not, you might have sit the leds on the back side of outside housing..
    My Build Thread
  23. Member germanbycar's Avatar
    Apr 27th, 2009
    Gainesville, FL
    P51 Mustang
    08-31-2011 07:59 AM #23
    I could never do this.
    Paint it black and take it back.
    Shawn's Speed Shop
  24. Member
    Nov 29th, 2008
    08-31-2011 12:51 PM #24
    Yea.. right now it's not very high up on the list, if/when I do this mod I'll pick up a new set of tails and mod them.
  25. Member l1DEMON1l's Avatar
    Mar 31st, 2008
    Italy + Virginia + Delaware
    '08 R32, '67 Chevy C10, '70 Skylark
    08-31-2011 01:23 PM #25
    Love it! Good DIY! I'd actually love to have some tails like that but I'm too terrified to crack them open since I'm not a very patient person... Don't want to go and blow $400 just to break them.
    Hi.
  26. Semi-n00b R32R36's Avatar
    Oct 13th, 2010
    Netherlands
    2006 R32 & 2008 R36
    09-09-2011 04:29 PM #26
    Nicely done! The manual is very good but doing it is not that easy.
    I had these lights in my R32, made by a former forummember. Unfortunately the quality was not good. Nobody else could make them (lights, turnsignal and brake) because of the small space inside. I have a new version from somebody else in my R36 (lights, turnsignal, brake, reverse and foglights).
    Seeing your job makes me greedy.
    VW Passat Variant R36 & Golf V R32 Full Options and beyond: = \V/ = (LED Turnsignal & S6 DRLs)
    Oo__oO & Oo__oO (Skyline taillights, JD Custom chip tuning
    My gallery: http://www.jrdejong.nl/gallery/Auto-s
  27. Member eyepoppet's Avatar
    May 2nd, 2011
    Oak Grove, MN
    08 GTI 90 G60
    09-09-2011 04:50 PM #27
    why did you have to wire them into the car rather than just tapping into the stock wiring harness???
  28. Member eyepoppet's Avatar
    May 2nd, 2011
    Oak Grove, MN
    08 GTI 90 G60
    09-09-2011 05:06 PM #28
    "Use one wire to connect the resistor then other wire to connect all the negative. In the picture, I use green wire for ground and red wire for the positive"
    Could you exlpain this one again. for some reason i feel like you did more than what the picture showed.
    Im going to try this out on a pair of stock headlights i have sitting in my basement.
  29. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    09-12-2011 07:54 AM #29
    Quote Originally Posted by eyepoppet View Post
    I tapped into the stock outer tail light wire harness. I ran the wire from the hatch to the outer tail light connector.
    follow the green wire, you will see I use the single wire start with the top and went counterclock around the leds connect the 4 grounds. same with the red wire, start at top went counterclock (under the electric tape is the resistor) connect the 4 resistors.
    My Build Thread
  30. Member eyepoppet's Avatar
    May 2nd, 2011
    Oak Grove, MN
    08 GTI 90 G60
    09-12-2011 06:03 PM #30
    ordered some LEDs a few days ago. going to figure out how to do this with the oem gti inner tails. The inner red lens is different and clearance might be a problem but i figured i could cut away from it and make it work..the LEDs only cost like 10 bucks lol so who cares if if i **** it up.
  31. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    09-12-2011 07:11 PM #31
    good luck
    My Build Thread
  32. Member
    Aug 8th, 2012
    Chicago, IL
    Audi A4'97--> Subie WRX'07 Stage 3+--> Murano--> VW GTi'11--> VW CC 2011 now
    09-07-2012 06:35 PM #32
    Pm sent
  33. Member VWNDAHS's Avatar
    Jun 20th, 2002
    San Diego
    MkV GTI, MkV R, The Beetle
    09-07-2012 10:34 PM #33
    Incredible job! I'd love to see some better pics, maybe a car park et-al, to get an idea of how they look on both sides but man, I'm loving it! ditto on the if-you-decide-to-do-it-for-pay-i'm-likely-down
  34. Junior Member dhimarko's Avatar
    May 25th, 2012
    Canada
    2009 VW Jetta tdi
    11-30-2012 05:38 PM #34
    I read you used 15000mcd, but what was the Wavelength? 630Nm??
  35. Member foreverblue's Avatar
    Mar 2nd, 2011
    Palisades Park, NJ
    08 .:R32 #2048
    12-03-2012 01:04 PM #35
    Quote Originally Posted by dhimarko View Post
    619-622nm
    My Build Thread
