Page 3 of 15 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Results 71 to 105 of 506
Thread: 30k Mile Build Thread...
  1. Member Volk14's Avatar
    Oct 18th, 2000
    Asheville, NC
    Indigo Blue B5.5 wagon (hers), Silverstone B5.5 wagon (his), 96 Passat TDI (his), 90 Corrado (his)
    09-08-2011 11:56 PM #71
    I'm sure there's a reason why you're re-doing your axles with that NEO grease but I was wondering about what's wrong with the OEM grease. Never had any issues with it
    Check out some of my vortex feedback: http://forums.vwvortex.com/showthread.php?952415
  2. Member ajhvw93's Avatar
    Oct 26th, 2009
    PA
    80 Rabbit Diesel....87 16V Scirocco...87 8v Gti..93 vr6 Corrado
    09-09-2011 07:58 PM #72
    Quote Originally Posted by SLC4EVER View Post
    I think a hood scoop done right looks good...but it will have no place on this one. Maybe I'll go there with the '93.
    The diff in throttle resp was very noticeable of coarse everything in line is modded as well Abd/ K&n filter bigger throttle body 2.9 mani cat del suitcase del cams Not only is it feeding air its also keeping warmer eng temps away from filter
    Haha! I kinda cheat though (even though the originals are what is in there)...A&E called and asked if I would do an episode of hoarders.
    My OCD was in full effect when these were on my order list.
    Thanks my friend!
    Walldoctor
    These cars are like women. You always have to make them happy... Other wise it will tend to f....k u in the bad way.
  3. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-10-2011 12:26 AM #73
    Quote Originally Posted by Volk14 View Post
    The OE grease dries out to easily, doesn't take heat well. Especially the inner passenger side since it is next to the downpipe.
    Dak
    I drive waaay too fast to worry about my cholesterol.
  4. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-10-2011 12:33 AM #74
    It's about to get serious in here.
    Dak
  5. Member ein's Avatar
    Feb 3rd, 2007
    Phila Area
    '92 8V GTI, '03 24V GTI, '93 SLC VR, '99 EK9, '03 Evo8
    09-10-2011 03:28 AM #75
    Its scratched, you should throw it out.
    I actually priced axles at the dealer recently because of all the crap I've heard about aftermarket ones.
    They wanted $300 per JOINT to replace them!
    Spoonfedtuning < If you have a Corrado you need this stuff!
    Quote Originally Posted by thecorradokid24 View Post
    Eat some bacon and man the f up.
  6. Member fastg60's Avatar
    Mar 4th, 2002
    Fairbanks, AK/Afghanistan
    92 Corrado TDI
    09-10-2011 06:13 AM #76
    Fuel filler? Details, please.
  7. Member cstanley19's Avatar
    Sep 23rd, 2006
    Las Vegas, NV
    92 Corrado 07 Mercedes e350 04 Touareg
    09-10-2011 07:37 AM #77
    I believe we are looking at a trans differential.
  8. Member Volk14's Avatar
    Oct 18th, 2000
    Asheville, NC
    09-10-2011 09:29 AM #78
    I was really hoping for a fuel filler to match the hood scoop but that looks like a transmission flange to me?
    Is it?
  9. 09-10-2011 01:43 PM #79
  10. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-10-2011 01:47 PM #80
    That....was a fun drive.
    Dak
  11. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-10-2011 01:49 PM #81
    Quote Originally Posted by ein View Post
    Was that $300 just for the parts?? Yeah, I've had a bad experience way back with aftermarket rebuilt axles. So now I make sure the grease does it's job. If I do have to replace a CV some day, I will definitely do it myself. I HATE doing them though...so friggin messy.
    Quote Originally Posted by fastg60 View Post
    Is it?
    A fuel scoop it is not. You are correct, it is indeed a drive flange.
    Quote Originally Posted by cstanley19 View Post
    You were in close proximity .
    Dak
  12. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-10-2011 07:17 PM #82
    So I got the freeze plug in to replace the nippled freeze plug (slide hammer with the right end would have been ideal). Couldn't find my driver, so I decided to eyeball it and drive in the new plug....the old eyeballs ain't what they use to be and I drove it too far.
    Needless to say I'll be ordering a couple new freeze plugs to redo and have a few spares just in case. Found my drivers, so I don't plan on screwing that up again.
    Buh bye OE heat exchanger...
    Dak
  13. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-11-2011 12:02 AM #83
    Free to good home...eight little stubborn bitches.
    Forgot how much I dislike removing diff rivets
    Dak
  14. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-11-2011 12:13 AM #84
    Case in point...30k inside passenger joint.
    Dak
  15. Member VWtrend's Avatar
    Mar 28th, 2004
    AcRoSs ThE WaTeRs
    09-11-2011 06:40 AM #85
    Im glad i stumbled upon this thread while lurking back in here
    Progress and Car looks Very classy dude
    ~Blake
  16. Member cstanley19's Avatar
    Sep 23rd, 2006
    Las Vegas, NV
    09-11-2011 09:02 AM #86
    I was thinking it was a cheap diff.. I didn't wanna be that guy to say NoooOOOO! haha. After market axles suck. I put two brand new ones on this spring and the boots are already dry rotted and the torx keep coming loose. I think it's time for dss for me.
  17. Member ein's Avatar
    Feb 3rd, 2007
    Phila Area
    09-11-2011 11:41 AM #87
    Dak, it was $300 for a complete joint.
  18. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-11-2011 01:13 PM #88
    Quote Originally Posted by VWtrend View Post
    Thanks brotha! The bar is going to work out nicely.
    Yeah, I bought a full set of LoBro boot kits, but I think I'm going to swap them out for Meistersatz boot kits. The LoBro boots are rubber, but the Meistersatz look to be a polyethylene material (much better chemical resistance). At least the outer I have is, not sure about the inners. Did you use the plate washers under the bolts? The new boot kits didn't come with them, so I'm glad I didn't throw them out. Maybe use some blue threadlock?
    So no labor...That is nutty.
    Dak
  19. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-11-2011 01:22 PM #89
    First time for me seeing one of these...she's a thing of beauty.
    Dak
  20. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-11-2011 03:51 PM #90
    It's a might as well do it while I'm in there sort of part...
    Was happy with the results on the '93, so it's go to go on the '94.
    Dak
  21. Member VWtrend's Avatar
    Mar 28th, 2004
    AcRoSs ThE WaTeRs
    09-11-2011 10:42 PM #91
    Keeps getting better and better dude. Glad it worked out for yah.
    Would love to see more shots of this car with them wheelz on
    ~Blake
  22. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-11-2011 11:54 PM #92
    Thanks brotha. The 17's aren't assembled yet...but the 18's are good to go.
    Dak
  23. Member BoostedCC-R's Avatar
    Jul 8th, 2010
    Toledo, OH
    B6 S4 & MKV GLI
    09-12-2011 12:10 AM #93
    so nasty
    2004 Audi S4 6MT arctic white - JHM fly + stg 3 clutch | Fast Intentions CB & Catless DP's | VAST tune & Phenolic Spacers | Tein Suspension | oem 19x8.5 S5 |
    2006 GLI 6MT - APR II+ | EuroJet TB | BSH intake | BSH PCV delete | H&R Race | Cherry Euro LED | FORGE diverter | AWE vent gauge | 19x8.5 BremmerKraft BR09 | 18x8.5 A8 Flat Fives
  24. Member VWtrend's Avatar
    Mar 28th, 2004
    AcRoSs ThE WaTeRs
    09-12-2011 12:16 AM #94
    Shweet!!!!!!! Definetly digin this build yah got going dude as like all your builds Clean and quality
    ~Blake
  25. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-12-2011 12:35 AM #95
    Appreciate that guys...
    Dak
  26. Member Volk14's Avatar
    Oct 18th, 2000
    Asheville, NC
    09-12-2011 08:31 AM #96
    wow, I never paid attention to that. As much as I hate to work on axles, I guess I'll have to start using using better grease on my cars
    You're not going FI with this car, right?
    Can't wait to see the finish product, good luck with all the work you're doing to it
  27. Member VR6Nutt's Avatar
    Dec 17th, 2003
    SoCAL
    93 Corrado SLC
    09-12-2011 10:24 AM #97
    Quote Originally Posted by tachycardia View Post
    I spy another ride in the background. What do you ride?
  28. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-12-2011 10:43 AM #98
    No, not going too crazy with this one. It will need to stay CA smog legal but still get me in and out of the turns as fast as legally possible...unless of course I am auto-x'ing it.
    Quote Originally Posted by VR6Nutt View Post
    The ski in the reflection or the dirbike? Assuming you mean the dirtbike, it is a YZ450F. A lot more reliable than a Corrado too.
    Dak
  29. Member ein's Avatar
    Feb 3rd, 2007
    Phila Area
    09-12-2011 11:00 AM #99
    Has anyone tried contacting DSS about buying boots from them?
  30. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-12-2011 11:05 AM #100
    Interesting thought...are they as indestructible as their axles?
    Dak
  31. Member VR6Nutt's Avatar
    Dec 17th, 2003
    SoCAL
    93 Corrado SLC
    09-12-2011 12:10 PM #101
    Off topic...but...
    Yes, the dirt bike. Nice - I don't see a whole lotta dirt bikers here on the tex. But being in SD, your riding options are still pretty open - especially further east. My ATF riding area is still Ocotillo. What year YZF? I am a die hard 2 stroke junkie here, refused to convert - love my CR500AF.
  32. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    Corrado, Mk1, LG5U Mk3
    09-12-2011 12:29 PM #102
    They are at least alot better than the stock ones. Neoprene
    SPOONFEDTUNING - For all of your carbon fiber Corrado needs.
    * IMPORTANT* The English language is completely inadequate for describing how spectacularly stupid this thread is.
    Quote Originally Posted by dogger View Post
    Is society really getting dumber or is it just this forum?
  33. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-12-2011 12:46 PM #103
    I was raised in Ramona, so Ocotillo Wells was practically in my back yard. I still prefer to ride out there, but I don't go as nearly as often as I use to. Haha. I use to refuse to convert. But one kick and I'm off riding along with using a third of the gas I am sold on four strokes. Hard to deny the 500 awesomeness though.
    Hmmmmm, it sounds like we should definitely get some answers as far as availability.
    Dak
  34. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-12-2011 12:57 PM #104
    Transmissions are finally apart...might as well order bearings while I have to re-shim the pre-loads anyway.
    Arguably the holy grail of 02a's. Should definintely get me out of the turns quicker.
    Dak
  35. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    09-12-2011 01:33 PM #105
    Gemini 6 speed setup? With matching diff?
