Page 5 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
Results 141 to 175 of 506
Thread: 30k Mile Build Thread...
  1. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-16-2011 10:57 AM #141
    Quote Originally Posted by pileofredparts View Post
    the gearbox got me interested
    The wait for parts is killin' me.
    Quote Originally Posted by yellowslc View Post
    Vw calls for a special steering rack grease.. I still have some! Hit me up and I'll send it out.
    Of course they do. Call you later today.
    Quote Originally Posted by DUBZAK View Post
    What are the Stack Ratios?
    If I was running boost I would agree with you, but there are no plans for it while I'm in CA. All (stock) motor, canyon/autocrosser is about the only time I drive it. I hate driving on the freekway, so I don't care about top end. I can't remember the last time the traffic was clear enough to let it breathe anyway, so topend is pointless to me. If it were a daily I'd be concerned with MPG though, so I would go with the 3.93.
    Gemini
    1-2.7
    2-1.8
    3-1.5
    4-1.2
    5-.95
    6-.83
    CDM
    1-3.3
    2-1.944
    3-1.308
    4-1.034
    5-.838
    I will most likely go with a 4.2, but I will probably pick up the 5.166 as well just in case I want more. It has a 3.93 in it now.
    Dak
    I drive waaay too fast to worry about my cholesterol.
  2. Member DUBZAK's Avatar
    Oct 26th, 2009
    Doin' W3rk at the Shop or my House
    Corrado SLC, Audi A8 QUATTRO
    09-16-2011 11:12 AM #142
    That 5.166 is CRAZY!!!! Crazy is good though. And enjoyable.
    |Corrado SLC 2.9LVR6|Corrado Keyless Entry | A8 "Grape Ape" | SPOONFEDTUNING |FOURSEASONTUNING|DUBNUTZ|
    Do you guys remember the time that Ryan kid started mixing and matching rods and end caps and then his motor wouldnt turn over? I do
  3. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    Corrado SLC , TT 225QC
    09-16-2011 02:11 PM #143
    I have been running a 4.24 5-speed box for the past 6 years. For road rally's I toss in a .658 TDI 5th just to keep the sanity. The 4.2 would be a great N/A selection. With boost its a bit more nutzo. I have found short gear lots of fun for the back road/mountain runs due to being able to be in a high gear and not having the engine lugging along but rather at a nice cruising rpm.
    I'm not endorsing the purchase of a Saab, cause I'd rather gargle battery acid. It was merely the best example I could think of.
  4. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    09-16-2011 02:26 PM #144
    Quote Originally Posted by SLC4EVER View Post
    Worked late...so I made some design changes.
    Indexing retro-fit-able camber plates. I'll end up turning them 90 degrees and use them as caster plates.
    looks tight!
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
  5. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-16-2011 04:11 PM #145
    We shall see I guess.
    Quote Originally Posted by DeckManDubs View Post
    That is good to know my friend! Thanks a bunch for the first hand account. Makes me feel better about spending the coin. Which box do you have the 4.2 in?
    Quote Originally Posted by sdezego View Post
    looks tight!
    Thanks brotha! I probably won't top the strut tower off on the '94, that's a bit much for now. Maybe in another 100k miles I'll consider it. The rate I'm going that will be another 35 years. Haha. The plates will be a good candidate for the '93.
    Dak
  6. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    09-16-2011 05:36 PM #146
    CDM, it was the tranny from John Livinggood from CCA. Was built by Kraftwerks. I guess he sold the car to a local Boston guy that never got around to putting it into he car (car got totaled in Florida a few years ago) I have had no problems with it, so far over 60k on it.
  7. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-18-2011 10:41 PM #147
    Indeed. It is a complete 1-6 Gemini gearset and diff I am in the process of transferring over to the CDM cases.
    Loving the build!
    I have been trying to source Gemini parts for my 02C for probably 4 years now. Do you happen to have a source for some gemini goodness?
  8. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-19-2011 03:30 PM #148
    Thanks brotha!
    If my source for Gemini parts pans out, I will let you know. What parts are you looking for? I have a cast iron transfer case for an 02c I won't be using, as well as 4cyl cases. I am still debating on the Gemini diff...it came out of the 02c, so I will have to mill the rear drive splines if I want to use it in my CDM.
    Ordered some OE parts online because I got a notice they were back in stock...two days later I received an email notification that my order is delayed because the parts aren't in stock.
    Dak
  9. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-19-2011 03:32 PM #149
    Thanks brotha!
    Put it this way
    what parts you got!?
  10. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-19-2011 03:36 PM #150
    Noted. I'll keep you updated.
    Dak
  11. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-21-2011 12:38 AM #151
    Can finally get the engine off the hoist and on the stand...
    Dak
  12. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-21-2011 12:41 AM #152
    Had to lightly grind the casting a bit for it to sit flush...
    Dak
  13. 09-21-2011 11:14 AM #153
    Niiiiice.
  14. Member Volk14's Avatar
    Oct 18th, 2000
    Asheville, NC
    Indigo Blue B5.5 wagon (hers), Silverstone B5.5 wagon (his), 96 Passat TDI (his), 90 Corrado (his)
    09-21-2011 11:35 AM #154
    oh man, you don't do that to a 30k mile Corrado block. Wasn't it easy to make a notch on that metal plate? Everything was going fine...
    On a serious note, I'll have to do a research about the gemini parts you're sourcing, I'm not familiar with them at all but they sound very promising
    Check out some of my vortex feedback: http://forums.vwvortex.com/showthread.php?952415
  15. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-21-2011 12:42 PM #155
    Haha! We're really only talking .010-.015". It's was actually ground from the factory, just not enough. I've ground more off my toe nails.
    Dak
  16. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-21-2011 09:08 PM #156
    No more dried out, cracked, soft rubber...
    The OE R32 rear a-arm bushings became too soft for my liking even with just 10k miles on them. Going to try something a little more aggressive this time. We'll see if the rears are as impressive as the fronts. This is the last step before I go spherical.
    Dak
  17. Member sdezego's Avatar
    Apr 23rd, 2004
    09-21-2011 11:01 PM #157
    Would love to know how they work out. I have red poly and can;t wait until the day when I rip them out. I have the R32s ready in the replacements, but it sounds like you were not trilled with them. As I get older, I guess I like less of the hammering sound when I hit hard bumps
  18. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-22-2011 12:47 AM #158
    I hear ya. Waay back before I discovered Powerflex I tried some red translucent bushings. After I finally got them installed, they lasted about a month and I yanked them out for the Powerflex. Never looked back. Their copper lubricant keeps them from making any noise and they are just the right amount of stiff. Wish they made them for my truck!
    Dak
  19. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-22-2011 12:51 AM #159
    This one is for the VR noobs... TDC - cam slots line up on the upper half.
    Dak
  20. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-22-2011 12:57 AM #160
    I expected it to be pretty clean inside, but I didn't expect the cam lobes to not be fully polished yet.
    Dak
  21. Member Darrsh's Avatar
    Jan 15th, 2002
    Lorton, VA
    93 Rado, 93 Rado, 94 Rado, 04 R1, 05 R6
    09-22-2011 11:36 AM #161
    wow Dak, that head is looking clean, any upgrades as far as power goes?
    Corrado VS. Rice Burner
    "Corrado Wins"
    I get a buzz out of the combination of design and sport.
    Adrian Newey
  22. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-22-2011 01:41 PM #162
    None planned at the moment. I have had a set of Schrick's sitting in a box for some time, but for now it's going to remain stock...I think.
    Not sure 268's would pass the smog inspection dyno.
    Just pulling the head off to do the HG, ARP studs, and updated tensioner. Then reassemble everything, fixing all the oil seepage everywhere in the process.
    I am happy with a stock VR for what I drive it for mostly. I have always wanted more bottom end grunt on a tight canyon/auto-x. Hopefully the Gemini gearset takes care of that.
    Dak
  23. Member VR6Nutt's Avatar
    Dec 17th, 2003
    SoCAL
    93 Corrado SLC
    09-22-2011 04:22 PM #163
    Do they put your 94 on the dyno? The don't for my 93. Always wanted a set of 268's...
  24. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-22-2011 04:29 PM #164
    Hmmm, I thought the dyno test had to do with your home address, not the year of car??? No?
    If that's the case I should definitely use the cams.
    Dak
  25. 09-22-2011 05:20 PM #165
    for some reason, started on the last page of this and then went backwards through pages
    awesome stuff so far
    Quote Originally Posted by LBSOHK View Post
    hi im here for the thread
    See Art post this and wat
    haven't seen you around in awhile... maybe I haven't been around much either
    all this activity makes me want another corrado... shame i just rebuilt my B3
  26. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-22-2011 05:29 PM #166
    Thanks brotha!
    Feels good to be working on the Corrado in the garage again. Total stress reliever when I get home....although that could be the Jager and not the car.
    Dak
  27. Member dasbeast3.0's Avatar
    Aug 14th, 2007
    Grizzly bear
    09-23-2011 12:00 AM #167
    We would get along well.
    Just caught up on the last few pages, awesome stuff here. x 100
  28. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-23-2011 01:04 AM #168
    I have to foofoo it up with Import Monster...goes down like candy. If this f**king cancer doesn't get me, that crap will. Ha! Ya only live once.
    Thanks my friend.
    Dak
  29. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-24-2011 05:36 PM #169
    Here ya go Mikki...Faux alloy.
    Dak
  30. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-24-2011 05:38 PM #170
    Powdered color and clear
    Dak
  31. Member MikkiJayne's Avatar
    Jan 1st, 2007
    UK
    09-24-2011 05:51 PM #171
    Yay shiny
  32. 09-24-2011 11:27 PM #172
    SICK!
    DK, Sir RA drove RB's turbo today...this was his post-drive reaction:
    Durrrrrtyyyyyy...
    -RB
  33. Moderator SLC4EVER's Avatar
    Oct 7th, 1999
    San Diego
    '93SLC '94SLC
    09-25-2011 12:20 AM #173
    Haha! Sounds like good times. Wish I was on that test drive.
    Dak
  34. Member s.l.c.'s Avatar
    Aug 4th, 2008
    O'side in Killa Cali
    69 Beetle 95 Corrado
    09-25-2011 09:13 PM #174
    I just read 5 pages and though to myself, did he just do all this work to a 30+ thousand miles corrado??
    I would of done it when it was at 20
    Let me know if you wanna get rid of those 268 cams, I'll stick them on my jetta
  35. Member somebodynowhere's Avatar
    Feb 10th, 2010
    203 CT
    3.0 Vr Corrado, 8v mk3, 8v mk2
    09-25-2011 10:18 PM #175
    I'm sure it's a mixture of both variables ...idk about cali though.. they should be able to to BOTH types of tests no matter what. But from my understanding a 2 pass idle test is actually MORE difficult to pass than a dyno test. This was from my emissions tech last time I got it done. Stock 93 cat and it passed with flying colors.
    (reason I know they can do both is because my car fell off the Dyno! I told them if they couldn't strap it down(too low ) than they couldn't do it. The response was that they can do a two pass idle test but it's harder to pass)
