Results 1 to 23 of 23
Thread: FAQ | Links | DIY | Reference - Table of Contents - 1.8t
  1. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-01-2011 06:28 PM #1
    The main 1.8t FAQ is great and all...but it isn't kept updated with all the new, great stuff people do. The user who created it won't respond to PM's and the mods won't edit it either. On the same note, we keep pointing all the new users at the FAQ as their first mode of defense.
    I'm creating this so we can create a supplementary FAQ. I'd also like to throw in here useful links to other 1.8t related site, services, DIYs, and reference guides.
    I'm not going to post a lot of actual information in this thread unless it's extremely simple. Think of this more as a table of contents to the world of 1.8t material than a reference thread.
    I'll work on this over the course of the next week or so. If you'd like to add a list of links feel free to post them up. After I pull your data into the thread I'll reply back to you at which point...please delete your post. That'll help keep this clean.
    ____________
    Do not post questions in here!!!!!!!!!
    Keep the thread clean. Informative material only.
    Thanks,
    Greg
    Index thread of notable 20v engine builds
    To keep the earth green, use www.earth911.com to find out where to recycle parts or dump toxic fluids.
    My Build
    Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never meet, end-goals never reached, and wives always unhappy... it's all worth it though!
  2. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-01-2011 06:28 PM #2
    -- Other good 1.8t FAQs --
    Big Turbo and High Performance Thread @ Audizine
    The old 1.8t FAQ
    1.8t FAQ @ VWVortex
    General VW Wiki
    SAVwKO's stock 1.8t tuning guide
    1.8t Dyno Database
    * Submit your dyno's here
    Elsaweb VAG Online Repair Manuals
    An FAQ on the basics of going Big Turbo on the 20v platform
    -- Engine Building Tips & Tricks --
    Block Prep
    -- Useful specialty tools --
    • TDC via sparkplug hole tool
      Link
    • These tools are perfect for disassembling a cylinder head. Both can be found on eBay:
      Left side is valve spring compressor right side is valve stem remover/installer.
    • Oetiker Clamp Removal Tool
      Sargent Tools - 9256 PRT Pincer Clamp Removal Tool
    • Metalnerd 4CYL - Crank Yank 4cyl Crank Counterhold
      Part MNYANK
    • IE Block Torque Plate
      Item #: TPLATE01
    • 10MM 12 Point, 160mm length
      ARP Head Bolts
      Early 1.8t Head Bolts
      Late Model Transmission Flange (doesn't need the long length...but doesn't hurt)
    • 20mm hex tool
      To remove injector cups
      Verdict Motorsports VMS140
    • Polydrive, 160mm length
      Metalnerd Part # MN3452
      Good for OEM Head Bolts
    • Metalnerd 6 Lobe MAF Bit
      Part MN606000
    • X-Gate Super High Temp Wastegate oil/ lube
    • Excellent Engine Sealants
      Useful for things like the cam tensioner gasket
      * Elring Engine Sealing Compound: Part Number: 977 54003 040
      * Permatex Ultra Grey
      * Wurth Green Flange Sealant (slow drying)
    • Flywheel hold tool
      Flywheel hold tool
    • Metalnerd Serrated Alternator Pulley Bit SET
      Part MN3400
    • SP Tools VW / AUDI TIMING BELT PULLEY HOLDER
      Part 67600
      or
      Metalnerd MNYANK-4CYL
    • Hylomar Universal Blue Racing Formula Gasket Dressing and Flange Sealant
      For valve cover gaskets, etc. It never dries, so it can usually be reused between installations
    • Resbond (r) Super High & Low Temp Threadlocker. Comes in 'red' or 'blue' depending on how strong a thread lock you want. Good for -300 - 2500F temps ... which means you can now put threadlocker on turbo nuts, bolts, and studs!
      Available at 034 motorsport, and McMasterCarr
    • Mail seal replacement tool. A must-have for new style main seals with the plastic lip instead of the old style spring retainer
      http://www.samstagsales.com/vwaudi.htm#crankshaft
      Seal remover, tool# Matra 3203
      Seal installer, tool# Matra T10053
    -- Big Turbo Engine Bay Picture Threads --
    -- Recommended Companies, Parts Vendors, and what they are really good at --
    • C & C Auto Parts, Long Beach, CA ** NOT PERFORMANCE FRIENDLY **
      * Fuel Injector cleaning, flow testing, remanufacturing
      * Wastegate remanufacturing
    • Ed Pink Racing Engines, CA
    • RC Performance, Huntington Beach, CA
    • Metalnerd
      * VW Tools
    • Cherry Turbo
      * Rebuild Turbos
    • So Cal Performance. 9723 Washburn rd. Downey, CA
      * Performance Parts (generic racing)
      * Methanol & Race Fuel
    • G Pop Shop
      * Rebuild Turbos
      * Re manufactured Turbos
      * New Turbos
    • Discount Cylinder Heads
      Rebuild cylinder heads for a good price
    • INA
      * Billet Parts
      * Throttle Body Spacers
      * Engine Building Services
    • 034 Motorsports
      * Billet Parts
      * OEM and OEM+ parts
      * 034 EFI Standalone Engine Management
      * In-House Tuning
    • 42 Draft Designs
      * Billet Parts
      * Gauge Solutions
    • ECS Tuning
      * OEM and OEM+ Parts
    • MJM Autohaus
    • Parts4Vws.com
    • PagParts
      * Turbo Kits
      * Amazing VW Expertise on anything custom
    • Turbo International based in CA
      * Very good prices on KKK CHRA
    • CTS Turbo
      * Turbo Kits
    • SiliconIntakes.com
      * Silicon bits
      * couplers
      * hose clamps
      Use coupon code link987 for 10% off
    • Boostcontroller.com
      * Silicon bits
      * couplers
      * hose clamps
    • Swaintech
      Powdercoating, Piston Coating, Performance coatings
    • Pag Parts
      Custom Fabrication, cam doctor, general performance shop, turbo kits, fmic kits
    • Witch Hunter
      Fuel Injector Cleaning and flow matching
    • Racetronix
      Cheap source for injectors
    • JRM Fabrication
      Billet 1.8t pieces
    • Rack Doctor
      Steering rack re manufacturing
    • Hillco, Garden Grove, CA
      Fasteners
    • Fastenal
      Fasteners, fittings, etc etc etc
    • McMaster Carr
    • Grainger
    -- Fixing & Diagnosing Problems --
    Common Symptoms
    • My Cel is flashing as I accelerate. Vag com is showing misfires (either in a code or in real time data)
      # Your coil packs and/or sparkplugs may be going out. Check the coil pack diagnostic.
      # Your coil pack harness may have cracks
    • Boost builds slower than it used to
    • DIY Boost Leak Tester
    • My car is very jerky all of a sudden
      # If you have a MAF, it could be an intake leak
    • My car blows black/grey smoke
      # You may have a pre-cat exhaust leak that is causing you to run rich
      # You may be blowing oil past the oil seals in your turbo
    • Coolant Migration
      This is an odd issue where your coolant level sensor will leak and allow coolant to 'push' into the wire loom. This coolant then migrates along the loom and goes into areas such as your ECM connector. This is a VERY RARE issue but it's good to know it can happen. FYI.
      Coolant Migration Thread
    • My car blows blueish smoke
      # You may have a headgasket failure
    • My car is overheating
      # This is a complicated one. Check the overheating diagnostic section.
    • My car is running rich
      # Check for exhaust leak
    • My car's idle is bouncing
      # Check for intake leaks. If there are none, check for exhaust leaks.
      # Unplug your MAF. If that fixes it, clean your MAF. Try again.
    1.8t Maintenance, Diagnostics, and Procedures
    • Good Youtube series on general car maintenance
      Eric the Car Guy
    • Adjusting a manual timing belt
    • Aligning your throttle body
    • Cleaning Carbon Build Up
      Method by Gdoggmoney
    • Replacing your coil pack harness
    • DIY How to replace valve cover gasket plus cam tensioner gasket / half moon seal
    • Cleaning Carbon Buildup
      Seafoam Tutorial
    • Checking your intake for leaks
      VortexDude Says: "You have a vac leak"
      Pressure Test your intake
      How to pressure test your intake
      This tip applies to both intake and exhaust leaks.
      Quote Originally Posted by gdoggmoney
      Some vacuum leaks and boost leaks only happen as the car heats up. You can grab a cold hose and it feels tight, and you are like "Wow not bad".
      Let the car get real hot under boost, lots of heat build up under the hood and then you see thermal expansion hit the hoses, and boom you suddenly have intermittent vacuum/boost leaks.
      The same thing happens with exhaust components that are not level, properly torqued or a combination thereof. Seals fine when not terribly hot. Go get it under boost, and it creeps, suddenly you have some stumbles and then once it all stops glowing, they subside a bit......
      Test hot, test cold and every vacuum/boost hose should have a clamp or something securing it tightly when cold to avoid leaks when hot.
    • Major engine rebuild
      Youtube video series on rebuilding the 1.8t
    • Problems with overheating, A/C not working, cooling fans, etc etc
      My HVAC FAQ
    • Fuel pump issues due to the crank position sensor
      The ECU shuts off the fuel pump if it doesn't get pulses from the crank position sensor; the purpose of this would be to reduce fire hazard in the event of a crash, by shutting off the fuel supply.
    • Check your exhaust for leaks
      VortexDude Says: "You have an exhaust leak"
      Seafoam your exhaust for leaks
    • Check for exhaust restrictions
      Catalytic Converter & Exhaust FAQ/ Tutorial
    • Cleaning Sensors
    • Coil Pack Diagnostic
    • Compression Testing and Leak Down Testing
    • Cooling
    • CKP
      Crankshaft Position Sensor
      Symptoms
      Wont start when engine is hot.
      Wont start at all. (Just keeps cranking and cranking)
      Very high idle.
    • Data logging a 3rd gear pull effectively in order to show what your engine is really doing
    • Breaking in a new or rebuilt engine (bottom end rebuild)
      Break in procedure
    • Intercooler
      De-Oil
    • Testing Crank Position Sensor
      Testing the crank position sensor:
      The three terminals are left to right 1,2,3 and 1 is on the square side of the connector, 3 being on the rounded side. Measure the resistance across 2&3, should be between 730-1000 ohms.
      Then check for continuity between 1&2 and then 1&3. No continuity should be indicated.
      Either test fails, its n/g. (source: chilton's manual)
    • Diagrams
      Diagrams
      * Includes Intake & Vac Routing, Details on N249, N112, N75, DV, Vac Res, EVAP, PRV, and more
      ECU Pinouts
      * APH, AWW, AWP, AWV ECU pinouts
      My Vac Routing Guide
      * N249 Delete, Catch Can w/ Recirculate, EBC, Vac / Boost Gauge, Meth
    • Fuel Filter
      Replacing
    • Fuses
      Mk4 Fuse List
      What causes the fuse box on top of the battery to sometimes melt? A: Generally this is caused by a failing alternator cable. As it gets older it builds up resistance and requires more current to reach the same voltage.
    • Fuel Pumps
      Testing
    • Starter Motor
      Fixing Grinding
    • Removing and Installing the head
      Removal & Install by INA
    • Grouding Issues
      Mk4 Ground List
    • Heating
    • Replacing alternator and/or thermostat on mk4
      More Alternator Changing Goodness
    • Testing Injectors
    • What does stock boost look like?
    • Testing Relays
    • SAI (Secondary Air Injection / EGR (Exhaust Gas Recirculation)
    • Spark plugs
      See 'Spark Plugs'
    • Timing
      Good DIY
      Very good DIY
    • Torque Specs
      1.8t torque spec list
    • stock boost flutter and surge
    • Data Logging & Diagnostics
      Good guide to interpreting readings
      1.8t Vag Com FAQ
      ECUxPlot & ME7 Logger @ Nefarious Motorsports
      - Up to 50 samples per second possible.
      - Up to 127 independent variables can be logged at same time.
    • Replacing Coolant flange on transverse engines
      1) remove air box
      2) remove coolant sensor
      3) put a bunch of rags on top of your transmission. These will catch all the coolant that is gonna spill out
      4) Remove hoses from flange. Use a 1/4" drive, 10mm deep well socket + universal joint + 10" 1/4" drive extension + 1/4" ratchet to remove the two screws holding the flange on.
      5) wipe flange area clean with a paper towel. Use a razor blade or scraping tool to scrape any residue off the head.
      6) Smear some gasket sealant on your new coolant flange o-ring. Not too much! Just a little smear to reduce the chance of leaks.
      7) Reinstall flange. Go back and forth between the two nuts so you apply even sealing force on that o-ring. These are small nuts, so don't use more than around 8-10 ft*lbs torque!!!. Remove paper towels.
      8) Reinstall hoses and sensor. Wipe area clean with a rag.
      9) Top off coolant ball with a 50/50 mix coolant/water. Leave coolant ball lid removed. Let the car sit for ~15-20 minutes so the sealant can set a bit.
      10) Start car. Keep topping off the coolant ball as the level fills up. Keep an eye on the flange to make sure it's not leaking. If it's leaking, give a little more torque on those nuts. Once the coolant stops dropping, reinstall the coolant cap.
      11) Once you're happy with the install, reinstall the airbox.
      12) Keep an eye on the coolant level for the next 50 or so miles of driving.
    • Testing MAP sensor
      Has 2 pins with 5k ohms and 1 pin is ground. A known bad MAP was tested at 233k ohms.
      How to tune your car
    • Goes over use of lemmiwinks/ unitune, vag com, advancing timing, modifying fueling, changing MAF size, and changing injector size
      Lemmiwinks Tutorial
      Lemmiwinks the guide
    My Build
  3. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-01-2011 06:28 PM #3
    -- Big Turbo Builds --
    My Build
  4. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-01-2011 06:29 PM #4
    -- Bits, Pieces, and About the Engine --
    Cutaway view of entire engine
    Another cutaway view of entire engine
    Engine Specs of many VW engines
    The 1.8T used a cast-iron engine block and an aluminum cylinder head with dual overhead camshafts and five valves per cylinder. The engine's actual displacement of 1,781 cc comes by way of an 81-mm bore with an 86-mm stroke. Part of this engine's inherent strength comes from its use of a die-forged steel crankshaft, split forged connecting rods and Mahle forged pistons (in some applications).
    Alternators
    Alternator repair thread
    Alternator Swap DIY
    The stock alternator is 90A. If you want to run the VR6 120A alternator you'll have to swap over the pulley from your old alternator but beyond that, it's pretty straight forward. Note: It takes a special tool to remove the pulley from the alternator. Many repair shops have this tool and will swap the pulleys for you for a small fee.
    Alternator underdrive pulley
    See "Pulleys"
    Air Filters
    See "Intakes"
    Battery
    Lighter, Smaller Battery in Mk4
    Blocks
    Fix Broken Repair Tab On Block - rear-most bolt on engine bracket
    Deck Cooling - Cutting coolant channels in the block and head or just the block so heat move better between the block and head plus clamping force on the head gasket will be improved.
    058 = AEB - 1.8T 20V Motor
    077 = BCY - 4.2 V8 Toaureg Motor
    06A = AGU - BIG PORT Head / Drive by cable
    06A = AUQ - Small Port Head / Drive by Wire
    AGU / AUQ isnt 058. Both are "06A" family. A timing belt kit for an AGU will work with an AUQ as well as AWP etc.
    The blocks are the same hence the water pumps are the same.
    Will a standard 11mm head bolt head fit in the hole in the AUQ (smallport) head? - Yes
    Is there any length differences between the 11mm bolts and the 10mm bolts?
    Yes. The 06a bolts are longer because the threads start so deep in the block.
    These are Raceware studs for both 058 and 06a motors. and it is also stock headbolts for each motor as well. the AEB threads start at the deck surface.
    Boost Controllers
    Intro to Boost Control
    This is the device that allows you to control how much boost (charge air) your turbo produces. There are a few different styles of boost control.
    1) PWM boost control - A solenoid that opens and closes very quickly to regulate how much pressure the wastegate sees
    2) Manual Boost Control - Ball and Spring - This doesn't allow ANY pressure to get to the wastegate before a pre-set pressure is achieved...then it opens completely which holds you at your set boost pressure
    3) Manual Boost Control - Bleed Type - This restricts flow to your wastegate. This is the worst kind of boost control because it always creates boost leaks and will hurt your spool up while limiting your max boost.
    Factory Boost Controller
    Valve Name: N75 Boost Control Valve
    Electronic Boost Controller
    Aka: EBC
    Manual Boost Controllers
    Aka: MBC
    Running a MBC on a tune written for the N75
    Here's how to run a MBC in parallel with the N75. The MBC will control your maximum attainable boost if you are running a ball and spring style MBC (aka 100% open or 100% closed)
    Bolts & Fasteners
    This is not 1.8t specific, just some good information for everyone on types of bolts, Fasteners, and what you should know about them in terms of working on the 1.8t.
    Stretch Bolts (aka Torque to Yield , aka TTY)
    TTY bolts are used where a more accurate, consistent clamping force is required. Torquing bolts with a torque wrench is rather inaccurate due to many things, e.g., the wrench, the user method, the angle, the fasteners, thread cleanliness, lubrication, etc. A TTY bolt will reach its plastic deformation stage at a relatively consistent torque, regardless of the above factors, so that the final clamping force on the two surfaces will be more accurate. TTY fasteners are typically used in more critical applications, e.g., internal engine components, etc. I only replace critical fasters with ones of a higher grade (ARP, etc.), but I have no issues with replacing stuff like motor mounts with 10.9 non-TTY fasteners that are torqued properly.
    Hardened vs. Non-Hardened Bolts
    Cut threads vs. Rolled Threads
    Tensile Strength of Bolt
    Anti-Seize, Oiling/ Greasing Bolts, and Proper Torquing
    Boost Gauge
    See "Gauges"
    Cam chain tensioner
    The Cam chain tensioner comes in both a VVT and non-VVT configuration.
    The VVT version will retard timing 22 degrees on startup, then advance it back and leave it there while running. This is an oil-pressure powered solenoid. The electrical part initiates the advancing and retarding movement...but the movement itself is oil pressure driven.
    Cam chain tensioner gasket kit
    * COMES WITH VVT CAM CHAIN PADS!!!!
    Cam Gear and Bolt
    AKA "Camshaft Gear"
    Available Aftermarket Cam Gears
    06A Block
    • Autotech Peg Vernier (1.5 deg increments)
      * Hard Anodized 6061-T6 Aluminum gear
      * Alloy steel pin, hub, and cover plate
      * Unlimited Adjustment
    • Cat Vernier
      * 7075 Aluminum
      * Outer wheel is hard anodized
      * Adjustable to +/- 10 degrees
    • Eurospec Vernier
      * I'm not sure on materials
      * I'm not sure on max adjustment range
    • Integrated Engineering Vernier
      * Hard Anodized 6061 Aluminum
      * Stainless ARP hardware
      * Adjustment to +/- 10 degrees
    058 Block
    • Autotech Vernier
      * Hard anodized 6061 Aluminum Outer, 7075-T6 Aluminum inner
      * 14 ounces
    • Eurospec Vernier
    Cam Bolt
    Always replace this.
    06A Block
    * One time use, OEM Part # 06A 109 281 A
    * Reusable ARP @ IE, Part # ARP-06A-01
    058 Block
    Part # N 906 257 01
    * Reusable ARP @ IE, Part # ARP-058-01
    Instructions for use with the ARP bolt:
    Install the gear and bolt. The bolt uses a 13/16” 12 point drive. Torque as follows- 74 ft-lb + ¼ turn with 30wt motor oil, or 78 ft-lb + ¼ turn with loctite. You will need a LONG bar to get the ¼ turn... so be prepared.
    Cam Friction Disc
    This goes between the bolt and cam gear as an aftermarket upgrade. This reduces the chance of the cam gear keyway shearing.
    IE Part # EK-FDV2
    Blow Off Valve
    Aka: BOV
    See "Diverter Valves, Blow Off Valves, Etc"
    Cam Position Sensor
    aka: CPS - This is a terrible acronym because it can be confused with the Crank Position Sensor. Please don't use this acronym!!
    Please see "Sensors"
    Camshafts
    aka: cams
    aka: camshaft
    Camshaft FAQ Thread
    Catch Cans
    Discussion on Pros and Cons of various catch cans
    • Overview of what they do
    • Recirculating vs. Vent to Atmosphere (VTA) vs. Exhaust Venturi Dump
    • Pictures of the gunk they collect
    • Common flow volumes from the valve cover at idle. Common flow volumes from the block at idle.
    • Common Configurations w/ parts required
    Catch Can Kits w/ Notes
    • INA
    • IE
    • Saiycho Michi (sp?)
    • 034
    • 42 draft designs
    Check Valves
    The 1.8t has lots of check valves that can fail over time. They typically fail 'open' which means they stop becoming a check valve and start becoming just an open piece of tube. This essentially creates vacuum leaks that only happens under vacuums and cannot be easily found by smoke testing or pressure testing your intake. They can also crack which causes a more traditional vacuum leak which can be found by smoke/ pressure testing.
    Just to reinforce this point, pressure testing is still an EXCELLENT diagnostic tool on the 1.8t.
    Many of the check valves on the 1.8t must be purchased as part of entire (expensive) hose assemblies. If you have a bad check valve but you don't want to replace the entire hose assembly, you can use these generic check valves from US Plastics for a significant savings.
    Note: OEM Check valves are often half white, half black. They do not always have directional arrows on them. OEM Black & White check valves flow from white to black.
    64108 - 3/16" Kynar® Standard Check Valves - $1.45
    64174 - 1/4" Kynar® Standard Check Valves - $1.35
    64715 - 3/8" Kynar® Standard Check Valves - $1.53
    Codes
    aka - Check Engine Codes
    Codes can be retrieved via a common ODB2 code reader. However, many of the diagnostics require a more powerful interface such as Ross-Tech Vag Com to diagnose or troubleshoot.
    16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
    Possible Symptoms
    * Malfunction Indicator Light (MIL) ON
    Possible Causes
    * Fuel Pump Relay (J17) faulty
    * Hoses/Pipes to/between Components faulty/clogged
    * Secondary Air Injection Pump (V101) faulty
    * Secondary Air Injection Pump Relay (J299) faulty
    * Secondary Air Injection Solenoid Valve (N112) faulty
    Possible Solutions
    * Check Fuel Pump Relay (J17)
    * Check Hoses/Pipes to/between Components
    * Check Secondary Air Injection Hoses/Pipes for Carbonization
    * Check Secondary Air Injection Pump (V101)
    * Check Secondary Air Injection Pump Relay (J299)
    * Check Secondary Air Injection Solenoid Valve (N112)
    Coil Packs
    AEB Coil pack Driver Pinout
    Coil Pack + Heat Shield FAQ
    Converting to mk5/6 coil packs
    INA mk5/6 coil pack adapter
    IE Coil Pack Adapters
    LS Coil Conversion Parts list
    Coil packs requiring 'Coil driver'
    (came with the AEB)
    * AEB style coil pack adapter harness made by INA allows you to use newer coils and remove your coil driver
    Mk4 / B5 / B6 Coil Packs
    FSI/ TSI Coil Packs
    RED MKV FSI Coil Packs - 06E 905 115
    BLACK MKV FSI Coil Packs - 07K 905 715 F
    * This is the recommended coil
    BLACK MKV TSI Coil Packs - 06F 905 115 F
    BLACK MKVI TSI Coil Packs - 06H 905 115
    Compression Ratio
    Our motor stock came with around a 9.5:1 compression ratio. This compression ratio has been shown to support plenty of boost 30-35 lbs while still controlling detonation. At those boost pressures the larger problem is the EGTs will roast your exhaust valves. That's why people who do this use high tech exhaust valves that are oversized. This compression ratio is a great mix of boost'ability plus off-boost response. A good thing to do to make this peppier is increase displacement.
    Some people will bump compression to 10:1 with a hardware kit in order to make the car more potent off-boost. However, this takes careful work and software tuning to prevent detonation.
    Some people drop compression to 8.5:1 or 9:1 in order to run LOTS of boost with less chance of compression. This is not recommended for most people because it makes your car sluggish when you are off boost. If you do this it is recommended to increase displacement to 2L, 2.1L, or 2.2L.
    Connecting Rods
    The Official "I Broke a Rod" Thread
    How to - Connecting Rod Install
    Rifle Drilled rods explained
    Wrist pin sizes
    • IE 19mm Rods
      * Available with Rifle Drilling
    • IE 20mm Rods
    • Carillo
    • Pauter
    • Brute
    • OEM
    Cooling
    Coolant Radiator FAQ
    Aftermarket Radiators
    The stock radiator works fine for most situations. However, a higher performance radiator is useful if you will be pushing your car for extended periods of time such as with track driving, auto-x, hill climbing, or similar situations that will cause your car produce high heat for extended periods. Most aftermarket radiators require some non-OEM hoses, fittings, fans, and other bits in order to fit.
    MODEL SPECIFIC
    * Mk4
    ** Mishimoto
    *** Need link to thread detailing Mishimoto installation, tips, and issues
    * NB
    ** Need some NB aftermarket radiators
    * B5
    ** Need some B5 aftermarket radiators
    * B6
    ** Need some B6 aftermarket radiators
    Thermo Switch (aka Fan Temp Switch)
    This is a 3 way thermostatic switch that tells your Fan Control Module (aka FCM) what speed to run the fans at. When your car is not moving there is no air flowing through the radiator, thus, the water will continue to absorb heat with no ready way to get rid of it. This is where your fans come in...your fans will kick on at either low or high speed and allow your radiator to transfer the heat from the coolant to the air. Your fan temp switch dictates at what point the coolant needs the help of the fans.
    When you are moving quickly the outside air will easily flow far more air than the fans ever could. In these situations your coolant temps in the radiator will plummet. However, due to your thermostat, your engine coolant temp will remain roughly the same.
    The ECU adjusts advance timing depending on the Water Temperature. It retards advance timing when the water temp is too high. If water temperature is too low the ECU will 'freak out' and give you results you won't like. This wasn't the case with earlier models such as the mk3.
    Our ECU have timing maps based on coolant temps. It's not going to be a fixed coolant temperature threshold that triggers correction, but rather full maps that dictates the allowable timing advance based on coolant temp vs load/calc TQ/rpm. Simply put, anything you do that lowers your coolant temp (more than marginally), and you will be hitting load cells that allows more advance to the timing curve
    Quote Originally Posted by Marcus_Aurelius
    In my case, since I also have the triangle plug and can't get a lower temp thermo switch, I simply hardwired pin 2 and 3 with a cabin mounted switch. Whenever it's needed, flip the switch and and the fans stay at high speed. Switch "off", and operation is normal based on the thermo switch threshold.
    More details can be found on my cooling thread below (read post # 136 for ECU related timing effect in my car and # 144 for the thermo switch mod).
    Cooling Thread
    The generally accepted value for a 'performance' Fan Temp Switch is 87C. This '87C' switch can be found with a square connector and is from early model mk4's. The late model mk4's moved to a triangle connector. NGP racing sells an adapter to convert your late model triangle connector to an early model square fan temp switch if you want to go that way.
    Square fan temp switch -> Triangle Connector Adapter
    Square rounded switches:
    1H0959481B: low speed 95-84 and high speed 102-92 (stock temps from a lot of cars including Golf Mk4)
    1H0959481C: low speed 90-79 and high speed 97-86 (from some Seat Ibiza/Cordoba but it seems that this one is no more available for sale and that the replacement part is 1H0959481B)
    701959481: low speed 87-76 and high speed 93-82 (from Transporter T4)
    701959481C low speed 81-70 and high speed 87-76 (from Transporter T4)
    1H0959481D: low speed 75-70 and high speed 82-77 (from some Golf Mk3)
    Triangle switch:
    1J0959481A: low speed 95-84 and high speed 102-91 (stock temps from some New Beetle and so mine)
    Coolant System
    Great reference of both stock and performance overviews of the coolant system
    Billet Coolant Fittings & Coolant Flange
    What coolant to use
    Always fill with a mix of water and g12. Preferably, use distilled water.
    Side notes and extra information if you care...
    Do not use Prestone, etc. They contain phosphates and VAG does not advise us to use phosphates in our car. Phosphates + tap water can produce deposits and corrosion using water common to Europe. Supposedly, this won't happen with North American water sources.
    Mixing long life and regular coolants in ANY car will cause brown gunk and/or a jellyto build up. Case in point, mixing G12 and regular prestone, etc will cause brown gunk to build up. G12 is a long life coolant while the normal 'green' coolant is a standard life coolant. Do not ever mix these!
    Prestone Extended Life 5/150 Antifreeze is phosphate, Silicate, and Borate free. This is theoretically compatible with VAG cars.
    Mixing long life and long life coolants should pose no problem. Prestone, Dexcool, and many other brands make long life coolants....
    My advise, just stick with G12.
    [COLOR="blue"]Crank Position Sensor/COLOR]
    aka: CPS - This is a terrible acronym because it can be confused with the Cam Position Sensor. Please don't use this acronym!!
    Crankshaft
    Differences between 2.0TFSI, 2.0FSI, and 1.8t Cranks
    Stock Crank = 86.4mm stroke
    Remember, if you change the crankshaft stroke, you need to change the piston to compensate. Do not go for shorter rods, go for a correct piston.
    Common stroker cranks:
    * 92.8mm - Most common, easy to source
    * 95.5mm - TDI (ALH) Crank, generally expensive
    * 100mm - Very uncommon, typically Eurospec Crank, MSRP $1395 USD
    Main Bearing
    OEM Main cap bolts: N 901 300 01
    Billet Main Caps
    They provide extreme rigidity to the main bearing and crankshaft, which is a necessity for high horsepower engines. In addition, the large profile and high strength material is much stronger and stiffer than the factory main caps.
    Requires machine work including line bore & hone for fitment.
    • IE Billet 4140 Tall Boy Main Caps
      For use with a girdle
    • IE Billet 4140 Standard Billet Main Caps
    • INA
    Mains bolts
    Crank Girdle
    Necessary on only the most extreme setups. Should be used in combination with billet main caps.
    Cylinder Heads
    Head Bolts & Head Studs
    Note: 06A blocks use 10mm bolts/ studs.
    058 blocks use 11mm bolts/ studs.
    If you are swapping around heads, blocks, etc...use the bolt/ stud that matches the block. The diameter of the stud is the critical element.
    I'm not sure which nuts for the studs do this, but I hear there are clearance issues with certain stud nuts and certain heads. If anyone knows the details of this please chime in.
    Head Bolts and Head Studs
    • OEM Bolts
      *Polydrive tool necessary
    • ARP Head Bolts
    • ARP Head Studs
      *Triple square tool necessary
    • Raceware Head Bolts
    • Raceware Head Studs
    Head Gaskets
    Increased thickness
    This is a method to drop compression without buying a lower compression rod/ piston set
    Brand vs. Brand
    * Victor Reinz
    * Elring
    * OEM (some say this is special)
    Head Work
    Cleaning the head
    Quote Originally Posted by Pete@Integrated
    You cannot remove those balls by drilling, they are very, very hard. Pulling them out is a project in of itself. Then, when you go to reassemble, you can't just tap all the holes where the balls went because some intersect too closely- so some have to be welded, some tapped, etc.
    Even with the balls out, the hot tank will not get the carbon build up out of there. It has to be removed by mechanical means- and DO NOT let them "glass bead" it- you will never ever ever get it all out of there.
    Decking the Head
    Head tolerances for resurfacing, honing, etc
    Line Bore
    Deletes
    See 'PCV System' for deletes related to the SAI / N249 / PCV / EVAP
    Hydraulic Power Steering -> Electric Power Steering Conversion
    Clean Up Engine Bay. Relocate Battery, Fuse block, Coolant Ball, EVAP, WS Washer, Power Steering
    Injector Wire Tuck DIY
    Vac Reservoir Relocation & SAI Inlet Hose Edit
    Air Conditioner and/or Power Steering Pump Delete
    New accessory belt required:
    * A/C and/or P/S Delete Belt Size (transverse applications) - 35"
    13/16" x 37 1/8"(20mm x 943mm) belt Gates part number is : K060365
    * A/C Delete Belt Size - 44-45.5" (OEM Belt 06A 145 933 D (1120mm/44") or NAPA/UAP belt 25-060441 for 44.75" or 25-060439 for 45.5")
    (above data works with BOTH OE pullies and ECS's lightened/underdriven pullies)
    GAP: 6DPK1195
    Displacement
    Increasing Displacement
    * Max possible bore diameter
    * Stroker Options
    * Gains
    * Good Turbos to match to increased displacement + their spool and power characteristics
    How to size a wastegate or blow off valve
    Good comparison thread
    Good discussion on the pros and cons of various DV's
    Diverter Valves
    Blow Off Valves
    • Tial 50mm
    • Tial Q
    Dog Bone Mount
    Mount used in transverse mounted engines
    aka Pendulum Mount
    See "Motor Mounts"
    Dry Sump
    INA Dry Sump Kit $2999 USD
    ECU
    ECU Codes
    Quote Originally Posted by Nefarious Motorsports
    US Market Volkswagen
    2000 Golf/Jetta: AWD
    06A 906 032 CL
    06A 906 032 CM (notes - auto)
    2001 Golf/Jetta: AWW
    06A 906 032 DL
    06A 906 032 DM (notes - auto)
    06A 906 032 GH (notes - auto)
    2002+ Golf/Jetta: AWP
    06A 906 032 HS
    06A 906 032 LP
    06A 906 032 NK
    06A 906 032 SK
    06A 906 032 RN (notes - 6spd manual)
    06A 906 032 SM (notes - 6spd manual)
    06A 906 032 LQ (notes - 5spd auto)
    06A 906 032 NL (notes - 5spd auto)
    06A 906 032 SL (notes - 5spd auto)
    1997-1999 Passat: AEB
    8D0 997 557 HX
    8D0 997 559 BX
    1999-2001 Passat: ATW
    4B0 997 020 AX
    4B0 997 020 X
    4B0 997 020 BX (notes - auto)
    4B0 997 020 CX (notes - auto)
    2001 Passat: AUG/AWM
    4B0 997 019 MX
    4B0 906 018 DA
    4B0 906 018 DN
    4B0 906 018 DQ
    4B0 906 018 FX
    4B0 906 018 CM
    1999-2000 Beetle: APH
    06A 906 032 A (notes - auto)
    06A 906 032 B (notes - auto)
    06A 906 032 S (notes - auto)
    06A 906 032 Q (notes - auto)
    06A 906 032 E
    06A 906 032 R
    06A 906 032 C
    06A 906 032 P
    2001.5 vw passat
    4B0 906 018 CL
    2001+ Beetle: AWV
    06A 906 032 FD
    06A 906 032 DP
    06A 906 032 GB
    06A 906 032 KQ
    06A 906 032 PT
    06A 906 032 EM (notes - auto)
    06A 906 032 DN (notes - auto)
    06A 906 032 GA (notes - auto)
    06A 906 032 KR (notes - auto)
    06A 906 032 PR (notes - 5spd auto)
    06A 906 032 PS (notes - 6spd tiptronic)
    2002 Beetle Turbo S: AWP
    1C0 906 032
    06A 906 032 LS (notes - 6spd manual)
    06A 906 032 QA (notes - 6spd manual)
    US Market Audi
    1997-1999 A4: AEB
    8D0 907 559
    8D0 907 557 P
    8D0 997 557 HX
    8D0 997 559 CX (notes - auto)
    2000 A4: ATW
    4B0 997 020 X
    4B0 997 020 AX
    2001 A4: AWM
    4B0 997 019 NX
    4B0 997 020 EX
    2002 A4: AMB
    8E0 909 518 F
    8E0 909 518 G (notes - auto)
    TT: AJQ
    8L0 906 018 J (notes - Quattro)
    8N0 997 018 BX (notes - Quattro)
    8N0 997 018 DX (notes - FWD)
    8N0 997 018 EX (notes - Quattro)
    8N0 997 019 AX (notes - FWD)
    TT: APX
    8L0 997 018 DX
    8N0 997 018 CX
    8N0 997 018 FX
    8N0 997 018 KX
    TT: AUQ,ARY
    8L0 997 018 CX
    8L0 997 018 EX
    8N0 906 018 AQ
    8N0 906 018 BR (notes - FWD, manual)
    8N0 906 018 CN (notes - auto)
    8N0 906 018 CR (notes - Quattro, manual)
    8N0 997 019 RX
    8N0 997 019 SX
    8N0 997 020 FX (notes - FWD, manual)
    8N0 997 020 RX (notes - manual)
    8N0 997 020 TX (notes - Quattro)
    8N0 997 020 SX
    8N0 997 020 QX (notes - auto)
    TT: BAM
    8N0 906 018 CG
    8N0 906 018 H
    8N0 997 018 PX
    8N0 997 018 TX
    TT: APP
    8N0 997 018 HX (notes - APP)
    TT: AUM
    8N0 906 018 AP
    8N0 997 019 X
    8N0 997 020 EX
    ME7/7.5 Software
    Learn about ME7
    Learn about ME7 (part2)
    Wideband ECU power requirements (different from Narrowband)
    Narrowband -> Wideband conversion harness
    * If you have a narrowband o2 sensor, you'll want to convert to wideband so you can use the much better and more advanced wideband files made by all the major software companies. They are more powerful, smoother, and give you more options.
    jwalker's wideband conversion thread
    2001 Transport's wideband conversion thread
    Injector FAQ
    * Cross references injectors with available software
    2-Step
    ...explanation of 2-step
    WOT Shifting
    ...explanation of WOT shifting
    Tweaking ME7/7.5
    Lemmiwinks Guide
    Standalone
    * Vipec
    Vipec knowledge dump for 1.8t
    * Autronic
    * 034 EFI
    My Build
  5. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-01-2011 06:29 PM #5
    Electrical
    Good sources for aftermarket wiring
    * Waytek
    * Wiringproducts.com
    * Grainger
    * Amazon/ Ebay
    * Sonic Electronix
    * Fastenal
    * McMaster-Carr
    How to get an RPM signal for use in gauges, standalone systems, controllers, etc
    Building a replacement for the stock fuse distribution block on top of the battery
    How to build a replacement B+ wire from parts at your local auto parts store
    Adding After Market Electronics Safely
    Relays - Hella relays are recommended. Use only sealed relays if installing under hood.
    Fuses - Always !!! add an appropriate fuse to aftermarket accessories. Set the fuse rating to about 50% more current than the device is expected to pull. Again, if installing under the hood use a sealed weatherproof fuse. Fuses are generally not very fast acting (from an electrical point of view) but good enough to prevent you from melting wire and whatnot in case of device malfunction or short circuit.
    Circuit Breakers - This is an optional accessory that can be added in front of the fuse, generally connected very close to the battery. I recommend rating this to 200% of your expected current output. The reason I like to use circuit breakers is it protects you from short circuits. In case of short circuit it will trip the circuit breaker immediately before your fuses blow. When you fix the wiring fault, the circuit breaker will auto-reset.
    On that note, you want a Type 1 circuit breaker. Type 1 circuit breakers will auto reset (aka cycle) when the wiring fault is removed.
    Type 2 circuit breakers require you to remove power from the circuit breaker to reset it, then you can reconnect power. I think this is very inconvenient for most situations.
    I generally use a combination of fuses and circuit breakers to make a robust solution.
    Wire
    Wire needs to be sized to the job. This is the responsibility of the wire gauge. Also, wire can handle very high currents for very short periods of time. You size the wire so that it can handle the constant load + 100% for safety margin. Also, it takes a thicker wire to handle the same load over a longer run.
    eg. According to the chart below, we can use 12AWG wire to handle a 15A load for 8.5 feet. If we had a 12 foot run we would want to step up to 10AWG wire instead.
    Sizing wire to the current and distance load
    Insulation material must be taken into consideration. If you are mounting this under hood, you want to have a chemical and abrasion resistant insulation material that will stand up to continuous over 200F temperatures.
    Core material should generally always be copper. There are very few reasons to use aluminum wire. It has higher resistance, breaks easier, but IS LIGHTER and CHEAPER. In other words, just stick with copper. It's better, lol.
    Crimps
    When you crimp something, use the proper tool. Crimps must have the proper shape in order to have good reliability and strength. In an automotive environment, solder is not a replacement for crimps. Solder can break with vibrations. Crimps are strong mechanical connections. However, soldering crimps is a wonderful idea if you are willing to take this extra step.
    Tape
    Electrical Tape - Use Scotch 33 or 88 tape for all automotive electrical tape needs. They stand up to temperature without getting gooey, they stretch better, they don't harden up over time, and they have thicker backings so they are stronger than average tape. Scotch 88 has a thicker backing than Scotch 33.
    Friction Tape - This is an excellent tape to wrap a wire bundle that you want to add abrasive protection to. I recommend 3M Temflex Cotton Friction Tape.
    Splicing Tape - This tape is not very sticky to most things, but is stretchy as can be and bonds securely to itself. This is a great tape to seal something up with. I recommend Scotch 23.
    If you want to wrap a wire bundle I recommend wrapping it with splicing tape to seal it up from the elements then wrap that in friction tape to protect it.
    If you want to connect multiple bundles the old fashioned way you can learn to lace the wire. This is done using lacing tape. If you don't want to do it old school, use your electrical tape and tape them together every 8 or so inches.
    Heat Shrink
    This is a very professional way to seal and protect wires. This is sold in adhesive and non-adhesive styles. In 2:1 shrink and 4:1 shrink. In various colors, diameters, and thicknesses.
    I recommend Raychem. That heat shrink is by far the highest quality I've worked with. 3M is a close second. Many of the other brands seem to have far less abrasion resistance than I like.
    All of the electronic valves in the car that are directly controlled by the ECU are switched 'low side'. This means the ECU connects ground to that device in order to complete the circuit.
    SAI
    This is a three part system designed to speed up catalytic converter warm up time.
    DELETE: If you delete any part of this system you will get a "SAI improper flow" code due to the computer not seeing expected output from the oxygen sensors when the SAI pump should be running. In order to remove this code you must get it 'coded out' in software. If you do not code out you will get a check engine light but will not have any performance detriments.
    The most common reasons to delete is due to a failing expensive component or for hose simplification in the engine bay.
    1) Combi valve on the side of the head. This is a vacuum operated valve that allows the SAI air pump to 'push' air into the exhaust ports. Vacuum is controlled by the N112. There is a small (~3/4") hole drilled across the head that connects all four exhaust ports.
    If you delete the combi valve you must plug this port with a block off plate that properly seals itself against the head.
    2) SAI air pump. This is an electric air pump that sucks air in from the the intake tract. Air comes after the air filter but before the MAF, so it is unmetered air. The electrical connection for this pump is driven by a relay, not directly by the computer. The relay is driven by ECU pin 66.
    If you delete the SAI air pump it does not need to be resistored.
    3) N112 Valve. This is a electric pneumatic valve that controls vacuum to the Combi Valve. It pulls vacuum directly from the intake manifold. The electrical connection is driven directly by the ECU on pin 9.
    If you delete the N112 Valve you must replace it with a 1W 330 ohm resistor. If you do not resistor it you will get a code plus you will not get fuel trims (block 32)
    N249 Valve
    This electric pneumatic valve controls the Diverter Valve by controlling vacuum and pressure. It also connects to the vacuum reservoir on top of the valve cover so that the diver valve can be opened when there is no vacuum present in the intake manifold.
    If you delete this you must replace it with a 330ohm 1W resistor. Furthermore, you must run a vacuum line from the intake manifold to your diverter valve. If you don't resistor this you will throw a code, but your fuel trims will still adapt.
    N80 Valve
    This electric pneumatic valve and charcoal filter diverts fuel vapor from the gas tank into the intake manifold. This is for emissions purposes. This is known as part of the EVAP system.
    If you delete this you must replace it with a 330 ohm 1W resistor or you won't get fuel adaptations.
    N75 Valve
    This electric pneumatic valve controls boost pressure to the turbo wastegate.
    If you delete this you must replace it with a 330 ohm 1W resistor. Furthermore, you need to use some other means to control the turbo boost pressure. If you don't resistor this you will get a code, but your fuel adaptations will work.
    This sensor tells the engine how fast the motor is turning. In other words, you can directly correlate the pulses from this sensor into RPM's. The crank position sensor wheel has ___???____ windows per revolution.
    Diagnosing the Crank Sensor:
    When the crank sensor fails and causes an out-of-sync situation with the ECU the ECU cuts response to the throttle in order to prevent major engine damage. This throttle cut generally happens within a certain RPM range.
    Another symptom you may also notice is that your tach (RPM) gauge hangs at a higher rev even though the car's speed is slowing. This symptom is due to the throttle being restricted by the ECU, as previously described.
    Yet another symptom is the car wont start on cranking. This is because the ECU cannot determine how fast the crank is rotating due to the failed or failing crank sensor. This problem is further exacerbated by the electrical interference the starter is throwing out as you are cranking the engine which further confuses the ECU. This starting symptom is commonly incorrectly diagnosed as a failing starter throwing out extra electrical interference. However, this is rarely the case and is simply a failing or failed crank position sensor.
    If the sensor is fine the problem can be mechanical. The crank position wheel is attached to the crankshaft via press fit and then secured with a screw. The screw can come loose, the screw can fall out, or the screw can shear off. Also, during old maintenance on the car the wheel can be bent by a careless mechanic which can throw off the crank balance a bit, increase the likelihood of the screw problem previously mentioned, or simply confuse the crank position sensor. This mechanical problem is typically not seen on cars turning stock RPM's (under 7500) and stock displacements. It is far more common on stroker setups or setups that turn high RPM's (over 7500). Both of these setups cause increased vibrations on the crank and in turn, put more stress on this crank position wheel. The fix for this problem if you are building a high RPM or stroker setup is to tack weld the screw in place or fully weld the entire position wheel in place.
    You can get a replacement crank sensor for $20 online. It's a cheap fix for a big problem.
    Fuel Pump
    Controlled by the 409 relay under the dash. Battery side is pin 30. Fuel pump side is pin 87.
    Pin 87 and 30 are the two 'big' pins in the relay
    Oxygen Senors
    aka: o2 sensors
    See "Oxygen Sensors"
    FAQ - How to check 12V sources and Grounds
    How to test for parasitic drain
    Fabricate a test lamp consisting of a 12v lightbulb, socket, wiring, and alligator clips. With the battery fully charged, disconnect the positive cable and connect the test lamp between the positive battery terminal and the positive battery cable. If you have a parasitic drain, the lightbulb should be brightly lit.
    Starting at the main fuse panel on the top of the battery, disconnect the fused red wiring one-by-one. When the lightbulb goes out (off), you've found the circuit causing the problem. If this circuit feeds the interior fuse panel located to the left side of the dashboard, reconnect the wire and start removing fuses one-by-one until the light goes out.
    Hint, the wiring leads should be long enough for the lightbulb to reach the interior of the car so that you can observe it when you start removing fuses.
    Engine Codes
    Large list of engine codes and details
    1.8t (and other) engines info
    Block Codes
    • 06A
      * Came on 1.8t's with transverse arrangements (eg. golf, TT, jetta, Beetle Turbo, seat leon cupra R, A/S3, etc)
    • 058
      * Came on 1.8t's with longitudional arrangements (eg. Passat, A4, etc)
    Head Codes
    • AQA
    • ARZ
    • AUM = AUQ
      * Very similar to AWP engine
    • AUM
      * TT225
      * 20mm Wrist Pins
    • AWP
      * Wideband
      * Small port
      * w/ SAI provisions
      * Came with VVT
      * Wideband
    • AWW
      * Small port
      * w/ SAI
      * Past -> Early '01 was narrowband, Late '01 -> Present was wideband
    • ADR
      * Big Port
    • ADL
      Is the European version of the AEB engine code. The main difference is that it came in a mixture of big port and small port configurations. Was released exclusively in a longitudinal engine.
    • AJL
      * Big Port
    • AEB
      * Big Port
      * No port for combi valve
    • AGU
      * Big Port
    Ethanol Conversion (E85)
    See "Fueling"
    Exhaust
    Exhaust Size - Theory
    Quote Originally Posted by Jay Kavanaugh
    Howdy,
    This thread was brought to my attention by a friend of mine in hopes of shedding some light on the issue of exhaust size selection for turbocharged vehicles. Most of the facts have been covered already. FWIW I'm an turbocharger development engineer for Garrett Engine Boosting Systems.
    N/A cars: As most of you know, the design of turbo exhaust systems runs counter to exhaust design for n/a vehicles. N/A cars utilize exhaust velocity (not backpressure) in the collector to aid in scavenging other cylinders during the blowdown process. It just so happens that to get the appropriate velocity, you have to squeeze down the diameter of the discharge of the collector (aka the exhaust), which also induces backpressure. The backpressure is an undesirable byproduct of the desire to have a certain degree of exhaust velocity. Go too big, and you lose velocity and its associated beneficial scavenging effect. Too small and the backpressure skyrockets, more than offsetting any gain made by scavenging. There is a happy medium here.
    For turbo cars, you throw all that out the window. You want the exhaust velocity to be high upstream of the turbine (i.e. in the header). You'll notice that primaries of turbo headers are smaller diameter than those of an n/a car of two-thirds the horsepower. The idea is to get the exhaust velocity up quickly, to get the turbo spooling as early as possible. Here, getting the boost up early is a much more effective way to torque than playing with tuned primary lengths and scavenging. The scavenging effects are small compared to what you'd get if you just got boost sooner instead. You have a turbo; you want boost. Just don't go so small on the header's primary diameter that you choke off the high end.
    Downstream of the turbine (aka the turboback exhaust), you want the least backpressure possible. No ifs, ands, or buts. Stick a Hoover on the tailpipe if you can. The general rule of "larger is better" (to the point of diminishing returns) of turboback exhausts is valid. Here, the idea is to minimize the pressure downstream of the turbine in order to make the most effective use of the pressure that is being generated upstream of the turbine. Remember, a turbine operates via a pressure ratio. For a given turbine inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible discharge pressure. This means the turbine is able to do the most amount of work possible (i.e. drive the compressor and make boost) with the available inlet pressure.
    Again, less pressure downstream of the turbine is goodness. This approach minimizes the time-to-boost (maximizes boost response) and will improve engine VE throughout the rev range.
    As for 2.5" vs. 3.0", the "best" turboback exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely suboptimal with 2.5". For 400-450 hp, even 3" is on the small side.”
    As for the geometry of the exhaust at the turbine discharge, the most optimal configuration would be a gradual increase in diameter from the turbine's exducer to the desired exhaust diameter-- via a straight conical diffuser of 7-12° included angle (to minimize flow separation and skin friction losses) mounted right at the turbine discharge. Many turbochargers found in diesels have this diffuser section cast right into the turbine housing. A hyperbolic increase in diameter (like a trumpet snorkus) is theoretically ideal but I've never seen one in use (and doubt it would be measurably superior to a straight diffuser). The wastegate flow would be via a completely divorced (separated from the main turbine discharge flow) dumptube. Due the realities of packaging, cost, and emissions compliance this config is rarely possible on street cars. You will, however, see this type of layout on dedicated race vehicles.
    A large "bellmouth" config which combines the turbine discharge and wastegate flow (without a divider between the two) is certainly better than the compromised stock routing, but not as effective as the above.
    If an integrated exhaust (non-divorced wastegate flow) is required, keep the wastegate flow separate from the main turbine discharge flow for ~12-18" before reintroducing it. This will minimize the impact on turbine efficiency-- the introduction of the wastegate flow disrupts the flow field of the main turbine discharge flow.
    Necking the exhaust down to a suboptimal diameter is never a good idea, but if it is necessary, doing it further downstream is better than doing it close to the turbine discharge since it will minimize the exhaust's contribution to backpressure. Better yet: don't neck down the exhaust at all.
    Also, the temperature of the exhaust coming out of a cat is higher than the inlet temperature, due to the exothermic oxidation of unburned hydrocarbons in the cat. So the total heat loss (and density increase) of the gases as it travels down the exhaust is not as prominent as it seems.
    Another thing to keep in mind is that cylinder scavenging takes place where the flows from separate cylinders merge (i.e. in the collector). There is no such thing as cylinder scavenging downstream of the turbine, and hence, no reason to desire high exhaust velocity here. You will only introduce unwanted backpressure.
    Other things you can do (in addition to choosing an appropriate diameter) to minimize exhaust backpressure in a turboback exhaust are: avoid crush-bent tubes (use mandrel bends); avoid tight-radius turns (keep it as straight as possible); avoid step changes in diameter; avoid "cheated" radii (cuts that are non-perpendicular); use a high flow cat; use a straight-thru perforated core muffler... etc.”
    Comparing the two bellmouth designs, I've never seen either one so I can only speculate. But based on your description, and assuming neither of them have a divider wall/tongue between the turbine discharge and wg dump, I'd venture that you'd be hard pressed to measure a difference between the two. The more gradual taper intuitively appears more desirable, but it's likely that it's beyond the point of diminishing returns. Either one sounds like it will improve the wastegate's discharge coefficient over the stock config, which will constitute the single biggest difference. This will allow more control over boost creep. Neither is as optimal as the divorced wastegate flow arrangement, however.
    There's more to it, though-- if a larger bellmouth is excessively large right at the turbine discharge (a large step diameter increase), there will be an unrecoverable dump loss that will contribute to backpressure. This is why a gradual increase in diameter, like the conical diffuser mentioned earlier, is desirable at the turbine discharge.
    As for primary lengths on turbo headers, it is advantageous to use equal-length primaries to time the arrival of the pulses at the turbine equally and to keep cylinder reversion balanced across all cylinders. This will improve boost response and the engine's VE. Equal-length is often difficult to achieve due to tight packaging, fabrication difficulty, and the desire to have runners of the shortest possible length.”
    Here's a worked example (simplified) of how larger exhausts help turbo cars:
    Say you have a turbo operating at a turbine pressure ratio (aka expansion ratio) of 1.8:1. You have a small turboback exhaust that contributes, say, 10 psig backpressure at the turbine discharge at redline. The total backpressure seen by the engine (upstream of the turbine) in this case is:
    (14.5 +10)*1.8 = 44.1 psia = 29.6 psig total backpressure
    o here, the turbine contributed 19.6 psig of backpressure to the total.
    Now you slap on a proper low-backpressure, big turboback exhaust. Same turbo, same boost, etc. You measure 3 psig backpressure at the turbine discharge. In this case the engine sees just 17 psig total backpressure! And the turbine's contribution to the total backpressure is reduced to 14 psig (note: this is 5.6 psig lower than its contribution in the "small turboback" case).
    So in the end, the engine saw a reduction in backpressure of 12.6 psig when you swapped turbobacks in this example. This reduction in backpressure is where all the engine's VE gains come from.
    This is why larger exhausts make such big gains on nearly all stock turbo cars-- the turbine compounds the downstream backpressure via its expansion ratio. This is also why bigger turbos make more power at a given boost level-- they improve engine VE by operating at lower turbine expansion ratios for a given boost level.
    As you can see, the backpressure penalty of running a too-small exhaust (like 2.5" for 350 hp) will vary depending on the match. At a given power level, a smaller turbo will generally be operating at a higher turbine pressure ratio and so will actually make the engine more sensitive to the backpressure downstream of the turbine than a larger turbine/turbo would.
    http://www.tercelreference.com/terce...st_theory.html
    Pseudo Exhaust for mk4 review
    42 draft design
    billy boat / APR
    Milltek
    Custom
    Materials:
    Stainless
    Aluminized Steel
    Size:
    2.25" (stock)
    2.5"
    3"
    Coating:
    Jet-Hot (aka Ceramic)
    Downpipes:
    Flanges:
    Tip Style:
    Exhaust Manifolds
    See "Turbo's"
    Fan
    See "Cooling"
    Fan Control Module
    aka: FCM
    See "Cooling"
    Fan Switch
    See "Cooling"
    Fluidampr
    See "Pulleys"
    FMIC (Front Mount Intercooler)
    See "Intercooling"
    Fuel Injector
    See "Fueling"
    Fuel Pressure Regulator (FPR)
    See "Fueling"
    Fuel Pump (FP)
    See "Fueling"
    See "Electrical"
    Fueling
    1.8t typically has a BSFC of around .45-.58
    Additives Calculator
    * Use this to calculate adding additives like Toluene and Xylene to your fuel.
    Comparison of the best fuel pumps
    Fuel Pump Voltage Diagnosis
    Note: This test will allow you to jumper the fuel pump into working if the fuel pump relay were to die. As such, if you think that your fuel pump isn't working because your fuel pump relay is dead, try this first. Also, if you would like to test the voltage at the pump, use this method to jumper the pump on, then test the voltage at the pump terminals so that plug and wire losses are taken into account.
    Note: Pins 87 and 30 are pretty easy to identify as they are the 2 fat ones perpendicular to each other
    Method 1:
    1) Remove the fuel pump relay (relay 409 under the dash)
    2) Bridge pin 87 to 30. You should now hear the fuel pump running. Aka, the fuel pump is now seeing battery voltage.
    Method 2:
    2) Use your finger to push the main relay contactor down onto the relay solenoid. You should now hear the fuel pump running. Aka, the fuel pump is now seeing battery voltage.
    Fuel Pump Diagnosis
    The resistance of a fuel pump's motor is a prime indicator of its health.
    0 ohms - it's dead.
    1-3 ohms - Normal Pump
    High Resistance (>100 ohms) - Failed motor coils or basket terminal to pump issue
    windings are bad and it will cause drivability issues.
    The OEM intake manifold injector inserts are made of plastic and are known to leak and crack over time. Verdict Motorsports has made billet parts (w/ o-rings) to replace the OEM plastic parts.
    Verdict Motorsports Injector Cups
    DIY for replacing injector cups
    What power level is supported by a given injector size at a given fuel pressure?
    Fueling and Injectors FAQ
    * Covers Lines, Fittings, Check Valves, Tools, Fuel Pumps, Fuel Rails, Software, Caveats, and more
    Injector FAQ
    * Covers 1.8t injectors and cross references them with software
    Converting to use E85
    Gauges
    Mk4 A-Pillar Gauge Install
    Mk4 Center Console Dual Gauge Install
    [b]Boost/Vacuum Gauge[/url]
    Mk4 DIY
    Wideband
    How to test your wideband gauge sensor
    Innovative Motorsports LC-1 Wideband Install
    EGT Gauge
    Inexpensive EGT Probe/ Gauge set (used by Frankenturbo for their testing)
    Head
    See "Cylinder Heads"
    Heat Shielding, Heat Wrap, Etc
    See "Coil Packs"
    Heater Core Fittings
    On the Mk4 the heater core lines come straight out of the firewall and often get in the way of top mount big turbos. Below are a few methods of dealing with this problem
    90 Degree Heater Core Modification
    * Useful for top mount turbo w/ 4" inlet
    Injectors
    See Fueling
    Intakes
    Discussion on velocity stacks
    Ram air
    "If you over oil an oiled-type aftermarket air filter, excess oil and dirt will get onto the hot film and damage the MAF. If you re-oil any aftermarket oiled air filter, just put a very thin bead at the top and let it migrate throughout the filter because any more will probably damage the MAF."
    Source
    Velocity stacks
    • BPI
    • Blox
    Filters
    • AEM Dryflow
    • K&N
    • ITG
    CAI + Anti-Hydrolocking bits
    Filter on a turbo
    Intake Manifolds
    Intake Manifold Comparison Test by INA
    Technical discussion on Intake Manifold Design
    Transverse Options:
    * RMR (out of production) - Small/ Big Port
    * SEM
    * ABD - Small Port
    * Integrated Engineering - Big Port
    * --need to fill in more--
    Longitudinal Options:
    * SEM
    Billet OEM Manifold Injector Seats
    * Solves the cracked & Leaking injector seat issue. The stockers are plastic.
    Intake Manifold gaskets
    OEM
    • Felpro
      Smallport
      Part # _____
    • Victor Reinz
      Smallport
      Part # _____
    • Felpro
      Bigport
      Part # _____
    • Victor Reinz
      Bigport
      Part # _____
    Aftermarket
    • New South Performance Powergasket
      This is a discontinued part. The original powergasket was known to have some problems with warpage and only mediocre performance benefits. The Powergasket Plus has made improvements across the board.
    • New South Performance Powergasket Plus
      Smallport
      Thickness: _____
      Material: Proprietary
      Smallport - Part # GAS 005 - $65
      Bigport - Part # GAS 006 - $65
    • 034 Motorsports Phenolic Gasket
      Thickness: ____
      Material: Phenolic
      Small Port - Part # - $ ____
      Big Port - Part # - $ ____
      Transitional - Part # - $ ____
    My Build
  6. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-01-2011 06:30 PM #6
    Harmonic Balancer
    See "Pulleys"
    Intercooling (AAIC, AWIC, etc)
    Good read on a hybrid charge air cooling setup & Experiment
    Ebay Intercooling (mk4) Thread
    FMIC Showoff Thread
    For an air-to-air intercooler a good rule of thumb is this...
    * Stock SMIC will heatsoak with even a stock turbo. If you chip it it will definitely heat soak. This intercooler is just a little intercooler for daily duties. If you push your car, any upgrade is a good upgrade.
    * TT225 dual SMIC. This performs similar to a single upgraded SMIC.
    * SMIC - The best of these (generally considered the Tyrolsport SMIC) is good for up to around 275 WHP applications. Above that, it just heat soaks too fast
    * FMIC - They make small FMIC's that fit under the bumper with little to no trimming or modifying. Generally these are the smaller FMIC's. These smaller units perform similarly to an upgraded SMIC. The larger FMICs can support very large HP applications depending on how you size them.
    Cores
    • Treadstone
    • Garrett
    • Precision
    • Various chinese stuff off ebay
    Mk4 FMIC Kits
    • APR 'U' style
    • CTS 450HP Kit
      * Designed for their top mount turbo kit + SEM intake
    • CTS 750HP Kit
    • Treadstone
    • Eurojet
    • Kinetic
    Mk4 / TT Vented Fender Liner for SMIC
    Note: These will require modifications into a mk4. Direct swap for a mk1 TT
    Part #'s for the Auti TT vented wheel liners:
    left: 8N0821171B
    right: 8N0821172B
    Vented Fender Liner Install - Useful for SMIC installations
    Mk4 SMIC Kits
    * Tyrolsport
    * Pwrhaus
    New-Beetle SMIC
    * Tyrolsport
    * Eurojet
    B5 SMIC Kits
    * TyrolSport UG SMIC Intercooler for B5 Passat/A4 1.8T - $749
    * Ringer Apikol B5 A4 1.8T SMIC Kit - $550
    AWIC
    Discussion on AWIC design
    Discussion on choosing an AWIC core
    Lines
    OEM Oil Feed Line
    Taken from Psi Concepts
    This kit will fit on the following turbochargers and setups:
    - PSi "Concept" and MHI Series turbochargers utilizing PSi's Signature Series exhaust manifold (T25/T3).
    - Garrett T and GT Series turbochargers utilizing PSi's Signature Series exhaust manifold (T25/T3).*
    - Garrett GT "Eliminator" Series (GTRS/GTxx) turbochargers utilizing the OE or AFM exhaust manifold.
    - Borg Warner/KKK (K03/K04/Kxx) OEM-style turbochargers on an OE platform.
    Will fit both B5 and B6 platforms, including 058 (AEB/ATW) and 06A (AWM/AMB).
    * = Garrett T-Series (T25/T28) will require a different drain flange, which can be substituted upon ordering for no additional charge.
    Oil Feed:
    1 x 4' long -4 AN braided stainless steel Teflon oil feed line
    1 x M12 x 1.5 to -4 AN adapter fitting (Audi Engine Oil Supply)
    1 x M12 x 1.25 to -4 AN adapter fitting (for Borg Warner/KKK, MHI, and PSi Concept Series)
    1 x M11 x 1.0 to -4 AN adapter fitting without restrictor (for Garrett T Series)
    1 x M11 x 1.0 to -4 AN adapter fitting WITH restrictor (for Garrett GT Series)
    4 x copper crush washers for adapter fittings
    1 x 4 AN male to -4 AN female 90-degree adapter fitting with swivel
    Oil Drain:
    1 x 11.5" long -10 AN braided stainless steel Teflon oil drain line
    1 x Universal T6061-6 aluminum drain flange (for Garrett GT, MHI, PSi, and Borg Warner)
    1 x Gasket for drain flange
    2 x M8 x 1.25 pitch fasteners (for Garrett GT Series)
    2 x M6 x 1.00 pitch flanged fasteners (for PSi/MHI/Borg Warner/K03/K04)
    1 x -10 AN to 1/2" NTP adapter fitting
    1 x -10 AN to 1/2" NTP 90-degree adapter fitting
    1 x Audi/VW 1.8T oil pan drain flange
    1 x Audi/VW 1.8T oil pan drain flange gasket
    2 x M6 x 1.00 pitch fasteners for oil pan drain flange
    Coolant Supply:
    1 x 20" long -6 AN braided stainless steel Teflon coolant return line
    1 x 13" long -6 AN braided stainless steel Teflon coolant supply line
    1 x -6 AN to 13mm barb adapter fitting (for 058 AEB/ATW block supply)
    1 x -6 AN to M14 x 1.5 pitch banjo adapter fitting (for 06A AWM/AMB block supply)
    1 x -6 AN to 10mm barb adapter fitting (for coolant return)
    2 x -6 AN to M14 x 1.5 pitch banjo adapter fitting (to turbocharger)
    1 x -6 AN male to -6 AN female 90-degree adapter fitting with swivel
    6 x 13mm copper crush washers
    MAF (Mass Air Flow) Sensor
    S4 Wiki's EXCELLENT article on the MAF Sensor
    The mass air flow sensor is a 'hot wire' sensor that measures how much it cools as air flows across it. Being that it also knows the cross sectional area of the MAF housing the mass of air flowing into your engine at any given time can be calculated. Also, it should be noted that this reading can only be accurate if the flow is uniform across the MAF housing. This means that your filter should be at least 3" or so from the sensor and should pass through a flow straightener screen (or equivalent). It should also be noted that you should not over-oil your air filter if you have a K&N style filter as it can leave oil deposits on the MAF sensor over time. This oil will impeded proper readings on the hot-wire sensor.
    When you choose your software tuners will specify which element and housing size you must use. This is a critical piece of many pieces of software. Do not substitute different housing diameters or elements than what is specified.
    There are two variables in our MAF's: 1) MAF housing diameter and 2) MAF sensor element.
    Pinout
    * Most people agree that the 'black' wire is the MAF signal wire. This is commonly tapped for progressive water/meth injection, electronic boost controllers, etc.
    From AWP:
    Pin 1 :
    Pin 2 : Blue/Yellow : 12V
    Pin 3 : Green : Ground
    Pin 4 : Red/ Violet : 5V
    Pin 5 : Black : 5V Output Signal (Analog)
    From S4 MAF (Hitachi):
    Green/ Yellow : 12V
    Violet/ Grey : 5V
    Black/ Green : Ground
    Green : Signal
    MAF Housing
    (Diameters are outside diameters)
    • 2.75" OD
      60mm ID = 2.36"
      Comes stock on most versions of the 1.8t such as the AWP
      Housing Part # _______
    • ??? OD
      70mm ID = 2.76"
      TT225
    • 3" OD
      73mm ID = 2.874"
      Comes stock on B5 S4 & mk4 VR6
      Housing Part # 280 217 529
      Eurocode Billet 3" Housing
      APR Stg3/ 3+ Cast 3" Housing
      Where to get 3" MAF
    • ?? OD
      83mm ID = 3.27"
      RS4
    MAF Elements
    • AEB MAF Element
    • mk4 chassis 1.8t element
    • TT225 Element
    • mk4 chassis vr6 element
    • S4 Element
    • RS4 Element
    Main Caps / Main Bolts
    See "Crankshaft"
    Aka "MBC"
    See "Boost Controllers"
    Motor Mounts
    If you want to replace your motor mount bolts with non-OEM bolts, be sure to use Grade 10.9 bolts. These are stronger than stock.
    Motor Mount FAQ
    * Options & opinions
    * False misfire due to stiff mounts
    Transverse applications have:
    * Pendulum Mount (aka Dog Bone Mount)
    * Transmission Mount
    * Engine Mount
    For the mk4 body style, here are some notes on the engine mount.
    Motor Mount Bracket -> Block:
    * Stock bolt is a stretch bolt. Replace every time.
    * If you want to use a non-stock bolt, replace with Grade 10.9 bolts with flanged head, zinc plated.
    (1) M10 x 1.5 x 112mm
    (2) M10 x 1.5 x 86mm
    Motor Mount -> Motor Mount Bracket:
    * If you want to use a non-stock bolt, replace with Grade 10.9 bolts, zinc plated. Head type can be flanged head or you can use a standard head + hardened washer.
    (2) M12 x 1.5 x 65mm
    Motor Mount -> Chassis:
    * If you want to use a non-stock bolt, replace with Grade 10.9 bolts, zinc plated with flanged head.
    * Bolt length can be longer. There is plenty of space under there.
    (2) M10 x 1.5 x 60mm
    N249 (Diverter Valve Electronic Control Valve) Delete
    "The N249 provides for the ECU to open the DV even if the intake manifold pressure is positve above ambient air pressure. The reason for doing this is to reduce pumping losses while at light load cruise, and other conditions, to increase fuel economy. The other reason for having the ability, is to dump excessive boost if the wastegate fails closed."
    http://www.audi-sport.net/vb/a3-s3-f...l-economy.html.
    http://s4wiki.com/wiki/N249
    While the N249's primary role is ECU actuation of the diverter valve, added benefits from adjusting load through the D/V's regulation seem to affect fuel economy some.
    Narrow band (Narrowband)
    See 'Oxygen Sensors'
    Oil
    Engine Oil Discussion
    Recommended Full Synthetics
    As recommended by Chickenman35 ....
    * Amsoil AMO 10w-40 would be an excellant choice.
    * Amsoil full SAPS EFM Euro 5w-40. The mid SAPS AFL 5w-40 would also be good.
    * Shell Rotella T6 5w-40. This is a diesel oil, but can be used in gasoline engines. Pros: Good level of phosphates and zincs. Great price point. Highly ranked at BITOG and most motorcycle forums ( Bikes are hard on oils as are diesels ) Cons: Obviously not tested for VW standards but that really doesn't mean a whole lot these days. Your cars out of warranty so that won't be an issue and it is
    a proven product in the field.
    * Motul 8100 X-Cess
    * Any full group IV synthetics by Red Line, Motul, Total, Brad Penn, Joe Gibbs in a 5w-40 or 10w-40 weight.
    Secondary Decent Choices
    These are good oils, but they don't have the phosphates and zinc additives that keep our cam lobes and hydro lifter buckets happy.
    * Castrol Syntec 5w40
    * Mobil 1 5w40
    * Mobil 1 10w30 (although I personally don't like the 10w oil)
    Recommended oil filters
    * OEM PN # 068115561B (Mahle Brand) (Upgraded size filter per factory bulletin)
    Note: Mann W 940/25 is equivalent to this OEM part number
    * Napa Gold (Rebranded Wix)
    * Amsoil
    * K&N
    * Mobil 1
    * Bosch Premium
    * Purolator PureOne
    * Fram Xtended Guard
    * Hastings
    Oil Pan
    When replacing the oil pan, if you don't want to use the gasket sealer that the Bentley recommends and comes factory on the car you can use Felpro Model # OS30708R instead. It is a rubber gasket that will keep you away from that messy gasket sealer.
    Also, when replacing the oil pan, don't overdo it on the gasket sealer. Excess sealer will fall off in the oil and can clog your oil pickup screen.
    * Steel hybrid
    * Baffled* Magnetic Drain Plugs
    Oil Pressure (Typical)
    Cold Idle: ~80 psi
    Cold 2k rpms: ~90 psi
    Cold 3k rpms: ~100psi (pegs the gauge)
    Hot Idle: ~24 psi
    Hot 2k rpms: ~50 psi
    Hot 3k rpms: ~70 psi
    Hot at redline can still peg the gauge (100 psi)
    Oil Pump
    ..needs OEM oil pump info here...
    ...needs info about oil pump chain tension noises/ problems...
    Performance Oil Pump Kit
    Oxygen Sensor
    Fused Version of the ECU - Handles oxygen sensor shorts that normally 'blow' the ECU
    Narrowband -> Wideband Conversion
    See "ECU"
    'Wayne' Angle Block
    * Fixes CEL for people running high-flow cats or no cats at all
    * Rear o2 spacer
    -- NEVER PUT A SPACER ON YOUR FRONT o2 SENSOR!!! --
    Narrowband
    TT mk1
    ATC - 180hp - narrowband
    AMU - 225hp - narrowband
    Audi A4
    AEB - narrowband
    ATW - ME7 Narrowband - Year 2000 only
    AWM - ME7 wideband and was 2001 for B5
    --not sure - a4 ---
    AUG
    Golf/Jetta/NB
    AWD
    APH
    Wideband
    TT mk1
    AWP - 180hp - wideband
    BEA - 225hp - wideband
    Audi A4
    AMB - wideband
    Golf/Jetta/NB
    AWW
    AWV
    AWP
    Audi TT got wideband in 2003 starting with engine code AWP
    A4 got wideband in ____??? starting with engine code ____
    Mk4's got wideband in late 2001 starting with engine code _____
    NB's got wideband in ____ starting with engine code ____
    Fuse 43 protects the o2 sensor heater (and other stuff)
    For AWP engine code
    Front o2 sensor
    o2 harness plug
    Pin 3 is heater +
    Pin 4 is heater gnd
    Heater + is 12v with ignition keyed on
    Ecu pin .. Harness Wire color .. o2 connector number ... o2 sensor wire color .. Purpose
    52 .. grey/red .. 6 ... Red ... Heater +
    71 .. black .. 2 .. Not connected
    51 .. grey/white .. 5 .. Yellow ... Pump Circuit (adds and removes o2 from sensor)
    70 .. green .. 1 .. Black ... Signal +
    5 .. white .. 4 .. White ... Heater -
    Relay 87A .. blue/red .. 3 .. Grey ... Signal Ground[/quote]
    PCV System
    In order to keep your fuel trims the following sensors (at a minimum)must be resistored:
    * N112 (SAI/ Combi Valve Controller)
    * N80 (EVAP)
    * N75 (Boost Controller)
    If you'd like to resistor other things like the SAI pump you can, but you don't have to.
    You can resistor it yourself using 1 watt 330ohm resistors.
    nstevic01's SAI/N249/PCV/EVAP delete
    SAVwKO's SAI/N249/PCV/EVAP Delete
    Drilling a head so it can have a Combi Valve (and in turn a SAI system)
    Delete kit for transverse applications
    Pendulum Mount
    See "Motor Mounts"
    Pistons
    20V Piston FAQ
    Wristpins
    See "Wristpins"
    Power Steering
    * Deleting the power steering pump
    * Increasing Steering Effort
    Pulleys
    Aka: Harmonic Balancer Pulley, Power Steering Pulley, Alternator Pulley
    Why you should use a fluidampr - Exploding Crank Trigger Wheel Inside
    4 Bolt to 6 Bolt Harmonic Balancer Conversion
    * This is a great direct swap to better equip your car for high RPM operation.
    Underdrive and lightweight pulleys
    It is ok to run lightweight and/or under-driven (smaller) alternator and power steering pulleys.
    The lightweight pulleys will reduce your rotating engine mass.
    The under-driven pulleys will reduce the mechanical energy fed into the devices they're connected to. If you under drive your A/C, it's condenser pump cannot operate as powerfully so your A/C will not work as well. If you under drive your power steering you will not get as much power steering assist. If you under drive your alternator your alternator will not put out as much current and thus cannot charge your battery as quickly. Tip: Do not underdrive your alternator if you have lots of big audio amps and stuff in your car.
    DO NOT use an under-drive or use a lightweight crank dampener pulley!!! This pulley has the very important job of balancing your rotating mass and is built the way it is because of the harmonics of our engine. You can damage your main bearings or worse if you use this part.
    ...There is one exception to my statements about the crank dampener pulley. If you get your rotating assembly balanced with your lightweight crank pulley, you can use it. BUT THAT IS THE ONLY CONDITION!!! To do this you must submit your entire rotating assembly to a shop that has a machine capable of spin balancing the entire assembly. It is essential to keep harmonics out of your crank, flywheel, and all the critical bits!
    Rods
    See "Connecting Rods"
    Rod Bearings[*] Calico Coated[*] 034 anti friction[*] Mahle Race
    Excellent Generic Read on Secondary Air Injection
    Shaved Bay
    See "Deletes"
    ME7/7.5 Software
    See "ECU"
    SMIC - (Side Mount Intercooler)
    See "Intercooling"
    Spark Plugs
    DIY Replacing Spark Plug
    How to read your spark plug (and tune your car by reading the spark plug[/url]
    Rules of thumb:
    * For stock motors use a spark plug with a NGK heat range of 6.
    * For chipped or larger motors use a spark plug with a NGK heat range of 7.
    * For stock motors or basic (stg1) chipped motors a platinum plug is recommended. It's long lasting and performs well.
    * For high boost applications a copper or iridium plug is recommended. Do not use multi-prong plugs for high boost applications (>25 PSI). Copper performs well but should be changed every other oil change. It is easy to gap copper plugs. Iridium plugs are trickier to gap. NEVER put any pressure on the iridium tip!!! Even if it doesn't break you may weaken it and it can break off in your motor! Iridium plugs are long lasting and very good plugs, albeit at least 5x more expensive than copper plugs.
    Common plugs:
    Stock...
    * VW 101000063AAKT, iridium
    * NGK PFR6Q, platinum
    Chipped (1 step colder heat range)
    * NGK BKR7E (4644), copper plugs
    * Denso IK22, iridium plugs
    * NGK PFR7B, platinum plugs
    Gaps
    Stock
    * .032"
    Chipped
    * .028
    High Boost
    * Start at .022 and keep regapping higher until you start seeing misfires...then close the gap a bit. Personally, I run a .026" gap on my car w/ BKR7e plugs running around 26 PSI boost.
    Note regarding upgraded coil packs:
    * Many people think that upgrading your coil packs to the fsi/tsi coils means that you can run a large .040 or so gap. This is not universally true. You can generally gap it larger due to the increased spark energy, but you need to discover this yourself. Each car is different. Start the gap at .028 and keep working the gap larger until you start seeing misfires under high boost. Then back the gap back down.
    Note regarding worn spark plugs:
    * Worn spark plugs put increased load on the coil packs. Worn spark plugs can contribute to coil pack failure.
    Note regarding larger spark gap:
    * Larger spark gap puts more load on the coil packs. Larger gaps can reduce the life of the coil packs.
    Why not to use anti-seize on your spark plugs
    NGK Reference Chart
    Suction Jet Pump
    Standalone Engine Management
    • 034 EFI
    • Lugtronic
    • Megasquirt
    Swaps
    Swapping an Audi 1.8t into a VW 1.8t, and vice versa.
    Differences:
    * Oil pump pickup - Audi (longitudinal) is different than VW (transverse)
    * Audi (longitudinal) manual cars need a pilot bearing
    * VW (transverse) manual crank is good to pop in a pilot bearing
    Throttle Bodies
    Throttle Body Cleaning Tutorial
    DBW pinout
    Pin 7 - 5v+ or TPS VCC
    Pin 4 - Negative or TPS GND
    Pin 5 - TPS or signal
    INA Throttle Body Shootout
    Size & Fitment
    Size is the inner diameter.
    Most adapter plates can be made with a 1/8" NPT tapped hole for W/M injection
    DBW
    • 60mm
      * 1.8t stock
    • 65mm
      * VR6 24V
      ** -> Stock manifold : Requires adapter plate
      *** INA carries this adapter
    • 70mm
      * Audi B5 S4
      986 605 115 01
      078 133 062
      ** -> RMR manifold : Requires adapter plate
      ** -> SEM Manifold : Requires adapter plate
      * Porsche 986
      ** "986 Porsche uses the same throttle body as the B5 Audi S4 just different TPS"
    • 75mm
      * R32
    • 80mm
      Quote Originally Posted by INA
      There are actually 4 different versions of the "hemi" 80mm DBW throttle body.
      Technically it should be called VDO 80mm unit since they are found on more vehicles that just Dodge Hemi's.
      When you order one make sure it is the 805 or 801 so 5161805AA or 53032801AC (last 3 #'s of the Dodge part # as these have the throttle body lip for silicone but they are taller) . Do not get the 847 unit as that is the shallow unit but has no lip for a silicone hose so above 1.5 bar expect that silicone hose to blow off.
      If you have anymore questions do not hesistate to send me an email.
    DBC
    • 60mm
    • 65mm
      * OEM Sources
      ** VR6 OBD1
    • 70mm
      * A6 2.8 V6
    • 75mm
    • 80mm
    Timing Belt
    Timing Belt DIY - Golf/Jetta/TT/Jetta Mk4 - A4
    Timing Belt DIY - Audi A4 - B6
    Note: When doing your timing belt you will have to remove the motor mount on transverse applications. Please always replace the four OEM stretch bolts with new stretch bolts. Stretch bolts are called that because the STRETCH aka Torque to Yield. This means they can only be used once to achieve proper torque. If you reuse them they may not break, but they will not reach the correct torque spec.
    Name brand vs. Chinese Roller
    * This demonstrates the poor quality control of Chinese parts. The bolt for the roller was ~1/8" too short, which caused incorrect pressure to be applied, and in turn the bolt for the tensioner roller snapped while the user was driving. This cause the head to be trashed.
    Don't cheap out on these sort of critical parts!
    Standard Belt
    The Continental brand timing belt that comes OE is a great belt. It almost never fails, is reasonably priced, is easy to source, and in general is a great option. The only place where people question it is in HIGH RPM operation. We're talking people who regularly turn over 8500 RPMs. At these RPM's there is fear of the OE belt stretching in the best case or jumping teeth on the crank in a worst case. However, the OE belt has been in high HP applications such as Speeding-G60's 9 second drag car with repeat success. This goes to show that the OE belt can definitely be used in high HP, high RPM applications.
    The reasons for an uprated timing belt
    Discussion on the benefits of uprated belts
    Stretching:
    This will cause your timing to be off (obviously the cam and crank aren't in TIME anymore). A car that isn't in exact time will be harder to tune and will be harder to run at maximum performance.
    Tooth Strength:
    Jumping a tooth could cause your timing to go off. Jumping a few teeth means you just wrecked your head or worse (depending on how fast the engine's turning when it happened + your luck at that moment). However, the OE belt, the RAI belt, and the INA racing belt do not have problems with this. Timing belt tooth shear is not a problem on this platform. If you are having wear issues on your belt it is likely for other reasons such as misaligned rollers causing the belt to rub on something. I've also seen where someone dropped a small 10mm nut down by the crank bolt, which wedged against the timing belt, and caused the belt to disintegrate as the nut filed it away. This just goes to show that you need to use care when working on or around your timing belt.
    Longevity:
    The uprated timing belts are rated to increase change intervals. Many users are getting over 100,000 miles out of their uprated belts with no to minimal signs of wear. NOTE: You should still check your timing belt every oil change or two. Just remember, the belt will generally outlast the tensioner. It is the tension that you are checking first and foremost. The condition of the belt is just as much of a concern, but less likely to cause failure than the tensioner.
    Please note that the OE hydraulic tensioner can become dangerous long before the belt wears out. At this point, your change interval is determined by the life of the hydraulic tensioner. You have to replace this part as preventative maintenance. Failure of this part means your timing belt jumps and you wreck the head.
    The manual tensioner conversion does away with the hydraulic tensioner. The manual tensioner is a parts bin pull from the old 16v 4 cylinder engines. It was a very reliable part with users reporting never changing it in the life of the engine (over 200,000 miles). Of course, the 1.8t has engine bay temperatures higher than the 16v motor and regularly turns more RPM's than most 16v motors, so I still conservatively recommend replacing the manual tensioner every 100,000 miles or at the first sign of timing belt wear.
    Any unusual timing belt wear is generally an indicator of something that is wrong.
    It is common for the timing belt to ride to the edge of the cam gear, but not OVER the edge of the cam gear.
    If one side of the belt looks more worn than the other, this could be an indicator that your tensioner wheel/ bearing is going bad. Look into this ASAP. Replace the faulty part and the belt.
    If a belt looks frayed it is likely that it is rubbing on something. I had a motor mount come loose and my belt was rubbing on the motor mount. Look into this ASAP. Repair the problem. Replace the belt.
    If you hear squeaking or loud, unusual noises from the timing belt side of the engine, this could be a bad bearing in the tensioner, the idler pulley, or the water pump. A failure of any of these will cause catastrophic failure. Look into this ASAP.
    History of the uprated belts
    OE Belt:
    The OE belt for the 1.8t was a continental belt. It has been used to much success and is a fantastic belt.
    034 Motorsports Kevlar Timing Belt:
    This is a kevlar reinforced belt that was commissioned by 034. It had multiple known failures and was pulled from the market. If you are using one it is recommended you change it for one of the other good brands.
    INA Engineering Gates Blue Racing Belt:
    This belt was commissioned by INA to Gates to make an 06A compatible timing belt from the Gates Racing line of timing belts. This belt is a performance belt in every sense of the word but is not Kevlar. When the belt was commissioned Gates did not make a kevlar timing belt. This belt is extremely popular and has been used successfully in many performance builds.
    RAI Motorsports Gates Kevlar Timing Belt:
    This belt was commissioned by RAI Motorsports to Gates to make an 06A compatible timing belt from the new Kevlar line of timing belts. This belt is of excellent quality and is very reliable.
    Note: Even non-performance builds can use a performance timing belt. The performance timing belts offer improved reliability over the OE continental timing belts.
    All Kits
    * OE Belt (06A Block): Part # 06b 109 119a
    * Gates Kevlar Belt (06A Block): Part # GR-T306RB
    * 034 Kevlar Belt (06A Block): Discontinued due to failures
    * RAI Kevlar Belt (06A Block): Part # RAI-12008MGT-K
    * OE Belt (058 Block): Part # 058 109 119C
    Standard Timing Belt Kit
    REQUIRED PARTS:
    * Hydraulic Tensioner w/ Idler Roller: Part # 06B109477
    * Timing Belt Tensioner Roller: Part # 06B109243
    Manual Timing Belt Kit
    Discussion on Pneumatic/Hydraulic/Spring OE tensioner vs. Manual Timing Belt Tensioner
    REQUIRED PARTS:
    * Stud: Specs _____
    * Nut: Specs ______
    * 16v tensioner: part #051 109 243
    OPTIONAL PARTS:
    * IE Tensioner Backing Plate: IE Part # _____
    * IE Idler Roller: IE Part # ________
    Replacement Parts for the IE Idler Roller:
    * Lower Roller: Part # 06B 109 244
    Common parts while you're at it...
    * Motor Mount -> Frame: Part # _____
    * Motor Mount -> Block: Part # ______
    * ECS Motor Mount Bolt Kit: ECS Part # 038121119B
    * Accessory Belt Tensioner: Part # _____
    * Accessory Belt (w/ A/C): Part # 06a 260 849c
    ** This is made by Continental
    * 2 x Coolant (G12 plus, 1 Gallon): Part # g012 a8g 1g
    * Internal Water Pump (metal) (06A block): Part # 06a 121 011t
    ** See section "Waterpumps" for more details about waterpumps
    * 87C Thermostat: Part # 050121113C
    * Thermostat Housing: Part # 06A121121
    * Thermostat O-Ring: Part # 038121119B
    Transmission
    My Transmission FAQ
    How to adjust shift linkage if you have a broken home position switch
    O2J Transmission Fluid Change
    Performance Shifting Solutions
    Performance Transmission Solutions
    5 speed to 6 speed swap (mk4)
    SQS Racing - Performance Transmission Offerings
    APTuning / G-Force Transmissions - Upgraded Gearsets and Diffs
    Limited Slip Differential
    Consider one of these for all BT builds ESPECIALLY if you don't have Quattro. Once you get over 250HP you need more grip or it's all 1 wheel burnout city. The three majors are all solid offerings
    1) Quaiffe
    2) Peloquin
    3) Wavetrac
    O2J
    Upgrades:
    * Upgraded Secondary Slave Cylinder Line (Braided stainless)
    * Aluminum, stainless, or delrin shifter bracket bushings
    * Aluminum, stainless, or delrin shifter end link bushings
    * Short throw kits of various forms
    ** Diesel Geek Sigma 6 Kit
    ** TT stock shifter
    ** Many other vendords
    Weaknesses:
    Spider Gears/Side Gears Break
    Cross Shaft Breaks
    Cross Shaft Roll Pin Breaks & Corss Shaft Punctures Case
    Rivet Breaks and Punctures Case
    * Use high strength bolts instead of OEM rivets
    Shift fork breaks
    * Use welded, reinforced shift fork
    Case breaks at pinion
    * Use reinforced pinion brace
    http://www.vwtransaxles.com/02j.html
    My Build
    Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never meet, end-goals never reached, and wives always unhappy... it's all worth it though!
  7. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-01-2011 06:30 PM #7
    Transmission Mounts
    See "Motor Mounts"
    Turbos
    Frankenturbo Setup thread
    Garrett Turbocharger Installation Advice
    * Note: The advice in this thread is applicable to all turbos and should be followed for any turbo install
    Transverse Big Turbo Kits w/ notes
    Longitudinal Big Turbo Kits w/ notes
    • Frankenturbo F4T
    • Frankenturbo F23
    • Pag Parts Bottom Mount
      Available for FWD and AWD
    • APR stg3/ stg3+
    • CTS Top Mount
    • RAI Motorsports Borg Warner EFR
    Oil Restrictors
    Most dual ball bearing turbos require an oil restrictor. Most (if not all) journal bearing turbos do not require an oil restrictor. This is because journal bearing turbos work by pushing high pressure oil between the bronze parts causing them to glide nicely WHILE UNDER OIL PRESSURE. If you starve a journal bearing turbo of it's oil IT WILL DIE. You can starve a turbo by either not giving it enough feed (-4AN recommended) or by not allowing the oil to leave easily (-10AN recommended). With a DBB turbo the bearings just need to stay lubricated. They roll all on their own. Too much oil pressure can blow the bearing seals...which means oil will start getting into your intake and exhaust...aka black smoke and/or an oil coated intake.
    Garrett Series BB Turbos use a .035" orifice. -4AN restrictor. Use -4AN feed line
    Turbo Upgrade Parts
    • Treadstone Compressor Housings for EFR Turbos
    • HTA Compressor 'Aero' Wheels
      Readily applicable for the Garrett GT28, GT30, GT35 turbochargers
    • Tial V-Band Compressor housings for Garrett Turbos
    • V-band Turbine Housings for Garrett Turbos
    Mounting Hardware
    Non-Vband manifolds and turbos use studs, washers, and nuts to secure them together. There are other fastening aids such as locking plates, locking tabs, tac welding, safety wire, and others. I'll go over some good techniques and parts. The grades of these are also very confusing for many people so I'll put together a good list.
    Discussion on loose turbo nuts
    Bolt/ Nut Locking Liquids and Pastes
    *Loctite (or equivelant) (Needs to withstand >1200F continuous heat)
    * Exhaust Putty on bolt head or nut will reduce chance of it coming loose
    Discussion on using exhaust putty
    Bolts
    * Grade 12 Stainless Bolts (These are good for GT flange -> downpipe. Not for Turbo -> Manifold)
    * Stage 8 Fasteners
    * For stock turbos use M10x1.5, 50mm long . Grade 8.8
    * For turbos such as the godspeed, Kinetic, Etc use M10x1.5, 75mm long. Grade 8.8
    ** Note: may be applicable to ATP and clones):
    - Need to install turbo to manifold first, then manifold to cylinder
    - Manifold nuts virtually impossible to tighten (casting too tight around nuts).
    Studs
    * ARP Black Oxide Studs (Think of these as common exhaust studs ++. No defective metals here)
    * Grade 8 Common Exhaust Studs (They can deal with the heat. Do not use SS)
    * Stage 8 Fasteners
    Washers
    * Nordlock (use mild steel nordlocks. The SS nordlocks expand more and will loosen)
    * Hardened flat style (you want these to stay rigid. A non hardened washer is more apt to warping)
    Nuts
    * Eccentric Zinc + copper plated exhaust nuts
    * Grade 12 nut
    * High temp Jet Nuts
    * Stage 8 Fasteners
    Locking Tabs
    INA Locking Tab Plates
    Gaskets
    Nissan GT25/ GT28 OEM gasket for GT 5 bolt flange
    Nissan GT25/ GT28 OEM gasket for T25/T28 flange
    OEM turbo -> Manifold gasket is the best gasket for the ko3 range of turbos (scotch brite the surface first)
    Common Big Turbos and some notes on them
    • KKK
      * K04-001
      K04-001 FAQ
    • Precision
      * Precision Turbo Direct Fit Series - Direct fit from Garrett Turbos
      -- HP GT3562R
      || w/ Billet Wheel
      * HP 4000 Series
      -- HP 4957
      * HP 5000 Series
      -- HP 5031E
      -- HP 5457
      -- HP 5557
      -- HP 5757
      -- HP 5857
      || w/ Billet Wheel
      -- HP 5865
      -- HP 5957/62/65
      * HP 6000 Series
      -- HP 6057
      || w/ Billet Wheel
      -- HP 6157/62/65
      -- HP 6262/65
      || w/ Billet Wheel
      -- HP 6365
      -- HP 6765
      || w/ Billet Wheel
      -- HP 6765/HPQ
      * HP 7000 Series
      -- HP 70HPQ/HPS
      -- HP 71HPS
      -- HP 72HPS
      -- HP 74HPS
      -- HP 76HPS
    • Garrett
      * Pag Parts Billet PPT 71B-SS (3071 derivitive w/ your choice of journal or bb flavors)
      * GT Ball Bearing Series
      * GT Journal Bearing Series
      * T Series
    • Borg Warner EFR Series
      * EFR
      * Bullseye Power S200 Series
      * Bullseye Power S300 Series
    Turbo Bracing
    Valve Covers
    Thread talking about differences in the various valve covers
    Installing an AGN valve cover
    IE -10AN Valve Cover Breather Adapter
    *Loctite 68015 10-Ml Retaining Compound 680 High Strength
    -- Use acetone to clean parts first, then smear some of this on before installing the IE valve cover fitting to ensure a long term, 100% seal
    Valvetrain
    Articles
    How to remove and install valve stem seals and Valve Guides
    Installing new valve guides
    Benefits of 'oversized' valves, what size oversize valve to go with (+.5mm, +1mm), use on intake and use on exhaust, and the work required to use an oversized valve
    * Oversized valves tend to sell for the same price as non oversized valves.
    Single groove vs. Triple Groove valves
    Valves
    Stock Exhaust Valve Specs
    Head Diameter: 29.9mm
    Stem Diameter: 5.96mm
    Overall Length: 103.92mm
    Tip Length: 5mm
    26 degree Flo. , Triple Groove
    Stock Intake Valve Specs
    Head Diameter: 26.9mm
    Stem Diameter: 5.97mm
    Overall Length: 105.1mm
    Tip Length: 5mm
    24 degree Flo. , Triple Groove
    Comparison of intake valve materials
    ...need some info. Are they all made of Stainless?
    Comparison of exhaust valve materials
    Valve Materials @ Precision Tech
    Super Alloy:
    Quote Originally Posted by Ferrera
    Our super alloy valves are a custom blend material, but are based on Nimonic 80A as the base material.
    They are generally 2 piece valves, but the process of joining the materials occurs before valve forging at the raw material stage. We do this to optimize the best material for the parts of the valve. On issue with all the super alloy type high nickel materials is that they can not be heat hardened, so if we made the whole valve out of this material, it would require a lash cap on all motors that run rockers
    Inconel:
    ...could someone chime in with some Inconel tidbits?
    Hollow Stem, Sodium Filled:
    * Porsche and RUF use sodium filled exhaust valves in their high performance engines.
    * Ferrera does not offer these for our application.
    * OEM valves are made from this style. However, people have been known to 'drop' OEM exhaust valves...that is one of the benefits to upgrading to an aftermarket exhaust valve.
    Intake Valve Manufacturers
    • Ferrera
      PN: 51556P
      Material: Super Alloy
      Mass / Valve: _____
      $316 / set
    • Ferrera +1mm
      PN: 51557P
      Mass / Valve: _____
      $ _____
    • Ferrera +1mm
      PN: F1085P
      Material: Hollow Stem, Sodium Filled
      Mass / Valve: _____
    • Supertech
      Mass / Valve: _____
      $239 / set
    • Supertech Single Groove
      PN: _____
      Mass / Valve: _____
      $260 / set
    • Supertech Single Groove +1mm
      PN: ____
      Mass / Valve: _____
      $270 / set
    • AE
      PN: ______
      Mass / Valve: ______
      PN: 058109601C
      $10 / per (12 needed) ... $120 / set
    • Techtonic (also available in single groove)
      PN: 109 119
      Mass / Valve: ____
      Material: Stainless, black nitride treatment
      $28 / per (12 needed) ... $336 / set
    • Techtonic +1mm, single groove
      PN: 109 119x
      Mass / Valve: ____
      $29 / per (12 needed) ... $348 / set
    • TRW
      PN: 058109601C
      Mass / Valve: _____
      $16.70 / per (12 needed) ... $200 / set
    • Osvat
      PN: 058109601CIT
      Mass / Valve: _____
      Material: Stainless
      $10 / per (12 needed) ... $120 /set
    Exhaust Valve Manufacturers
    • Ferrera
      PN: _____
      Mass / Valve: _____
      $282 / set
    • Ferrera +1mm
      PN: F1555P
      Mass / Valve: _____
      $36 / Valve (12 needed) ... $432 / set
    • Ferrera +1mm
      PN: F1084P
      Mass / Valve: _____
      Mass / Valve: _____
      $ _____
    • Techtonics (also available in single groove)
      PN: 109 120
      Material: Inconel
      $ 34 / per (12 required) ... $408 / set
    • Techtonics +1mm , single groove
      PN: 109 120x
      Material: Inconel
      Note: Single Groove Keepers included
      $ 40 / per (12 required) ... $480 / set
    • Supertech
      $160 / set
    • Supertech
      Material: Inconel
      $260 / set
    • Supertech Inconel Single Groove
      $280 / set
    • Supertech Inconel Single Groove +1mm
      $290 / set
    • OSVAT
      PN: 058109611EIT
      Material: Head 21-4N + Stem X45CrSi9-3 . Stem Chromed
      $20 / Valve (12 needed) ... $240 / Set
    Valve Seats
    Valve seats get beat up by high-revving engines, high spring rates, and by high mileage. A good sealing valve seat is essential to having a tight seal in your cylinder and making power.
    Intake Valve Seat Manufacturers
    • Integrated Engineering
      Bronze Alloy, better than stock
      ~$20 / seat (12 needed). $240 / set
    Valve Stem Seals
    Intake Valve Stem Seal Manufacturers
      PN: _____
      Polyacrylic
      $0.69 / per (12 needed) ... $12 / set
    • Hebmuller
      PN: 036109675A
      ??? material
      $2.43 / per (12 needed) ... $29 / set
    • Elring
      PN: 036109675
      ??? material
      $2.10 / per (12 needed) ... $25 / set
    • Victor Reinz
      PN: 036109675
      ??? material
    Exhaust Valve Stem Seal Manufacturers
      PN: _____
      Viton
      $0.99 / per (8 needed) ... $8 / set
    • Hebmuller
      PN: 036109675A
      ??? material
    • Elring
      PN: 036109675
      ??? material
    • Victor Reinz
      PN: 036109675
      ??? material
    Valve Guides
    Valve Guide Manufacturers
      PN: ____
      Bronze Alloy
      $10 / guide (20 needed) ... $200 / set
    • Techtonics Tuning
      PN: 109 235
      silicone bronze
      $6.50 / guide (20 needed) ... $130 / set
    • Canyon
      PN: 058103419
      ??? Material
      $4 / guide (20 needed) ... $80 / set
    • Supertech
    Lifters aka Cam Followers
    Solid lifters
    Solid lifters reduce the possibility of valve float due to the hydraulic lifters. However, you pay for this high revving with increased lifter wear, increased precision required during assembly, needing perfectly fitting lash caps, and lots of extra engine noise while running.
    Most high horsepower 1.8t's will NOT need solid lifters. It it not recommended to move to solid lifters for most BT applications.
    A note from a very fast CQ 1.8t tells stories of split lash caps, split shims, adjusting spring pressures, dealing with bind....generally a real pain in the butt.
    Exhaust Cam Follower Manufacturers
    • INA
      PN: 058109309E
      $13 / per (8 required ) ... $104 / set
    Intake Cam Follower Manufacturers
    • INA
      PN: 058109309F
      $14.70 / per (12 required) ... $176 / set
    • Meyle
      PN: 058109309F
      $18.95 / per (12 required) ... $227 / set
    Valve Springs
    Valve Springs, spring rates, etc
    Valve springs & Valve Spring Retainers
    Do you have to match the valve spring retainer mfg to the valve spring company?
    Manufacturers
    • Ferrera Springs
      Intake Spring Rate = ???
      Exhaust Spring Rate = ???
      Titanium Retainers
      ~$797 / set
    • Supertech
      Titanium Retainers
      $450 / Set
      Titanium Spring Retainers
      ~$650 / set
    • Techtonics Tuning
      $495 / Set
    Valve Jobs
    DIY vs. Professional vs ... valve 'jobs'. Also, notes and costs for a 'three angle valve job'
    Wastegates
    AKA: Internal Wastegate , External Wastegate
    How to size a wastegate or blow off valve
    Internal Wastegate Options
    http://forums.vwvortex.com/showthrea...4#post81205494
    Internal Wastegates, External Wastegates, Dump Tubes, Wastegate Actuators, Etc
    • Tial 38mm
      Vband or Tial flange
      Supports up to 400 HP (or 800 HP w/ a divided flange)
    • Tial 44mm
      Supports up to 750 HP
    • Tial 60mm
    VIN
    Vehicle Identification Number
    Decoding what your VIN means
    Water/ Meth Injection
    Water/Meth Injection FAQ
    Water/Meth Tuning
    Nozzle Size Calculator
    Mixing your own 50/50 Water/Meth
    50/50 Water/Meth is by 50% water, 50% meth by weight
    Methanol is 6.6lb/US gallon, water is 8.33/US gallon
    Methanol should be stored in a HDPE container
    For a 2 or 2 1/2 gallon bottle:
    102 ounces of distilled water with 128 ounces (1 gallon) of methanol, which fits conveniently in a 2 or 2-1/2 gallon fuel container.
    10bottles of HEET and 1gal of DISTILLED water will give you roughly your 50/50 by weight
    Meth= .825oz per fluid oz
    Water= 1.04375oz per fluid oz
    58.575oz Meth / 59.493oz Water = 49.6% meth/50.4% water
    Water pump
    Very good discussion on metal vs. 'plastic' water pumps
    On internal waterpump cars (06A blocks) the stock 'plastic' waterpump is notorious for the impeller self destructing and in turn, causing your car to overheat.
    As such, this has brought to light the options in waterpumps. Here is the rundown from a VW mechanic who has dealt with lots of different pumps...
    1.Lasso--plastic/German
    2.Geba--plastic/German,OK,but have had leakers
    3.GRAF=crap,made in Italy
    4.Solari=OEM for BMW,total crap,had one fail at 7K and wipe out valves on a Audi 3.0
    5.OEM=plastic and hit or miss,seen some fail at 70-80K some leak at 30K,total crapshoot,but decent.
    6.Hamburg Technik--I have seen these but would never use one,made in China
    7. Autolite--yes they make a water pump for VW,it totally sucks,pressed steel impeller,garbage
    8. Hepu--the bomb,99% reliability,MADE IN GERMANY.
    As such, for all intents and purposes, consider the HEPU brand water pump your go-to pump. Consider Lasso, Geba, and OEM all decent alternatives.
    Anything else, stay away.
    Another point of failure is leaking at the seal. Even if the impeller is in good shape, no one likes their car to mark their territory. As such, follow the recommended water pump brands above.
    Wideband
    Wrist Pins
    Tool Steel vs. Mild Steel
    Good thread on this
    * General rule of thumb according to IE and JE is that mild steel is good for <500 WHP. Go tool steel for high HP applications
    JE Tool Steel Wrist Pin
    PN# 787-2250-18-PTC
    Edge Type: Chamfered
    Length: 2.250 in
    Weight: 90g
    OD: .787in = 19.9898 mm
    Series: PT
    Material: 9310 Nickel Carbon Steel Alloy
    Wall Type: Tapered
    19mm vs. 20mm
    * About the same rule applies. Go with a 20mm pin for high HP setups. The 19mm setup will do great in a typical 3-400 WHP build. Above that it'll hold...but it'll wear faster.
    My Build
  8. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-15-2011 05:53 PM #8
    insert more here 6
    My Build
  9. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-16-2011 12:22 AM #9
    More stuff here 7
    My Build
  10. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    11-04-2011 07:17 PM #10
    Updated section on throttle bodies. If anyone wants to step up and fill in the rest of the details it would be much appreciated.
    Started section on big turbo builds. PM me if you have a good candidate for me to put in there. Give me a link plus a quick summary of the build.
    My Build
  11. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    11-09-2011 06:57 PM #11
    What engine codes am I missing in that section?
    What engine codes have provisions for combi?
    Are exhaust ports different on any of the heads?
    Are there any other big port engine codes?
    My Build
  12. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    12-19-2011 05:16 PM #12
    Tons more stuff added. If anyone wants to add any more stuff just let me know and I'll put it in.
    This FAQ is becoming more and more complete.
    On the same note, if you see places to improve it just let me know and I'll do that too.
    My Build
  13. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    02-02-2012 02:02 PM #13
    To-Do.
    Alphabetize and cross reference maintenance procedures.
    My Build
  14. n00b
    May 11th, 2012
    GERMANY Lippstadt
    05-11-2012 07:43 AM #14
    THX a lot
    this was information i am looking for :-)
  15. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    1989 Helios GLI 1997 Mk3 ****box
    09-24-2012 05:17 PM #15
    Awesome thread here. Some info I found while chasing my tail on the stock boost curve for my aww. http://forums.subdriven.com/showthre...-Boost-numbers
    Delete this post once you've reviewed the link.
  16. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    09-25-2012 03:56 AM #16
    Quote Originally Posted by Dave926 View Post
    Thanks. Added the best graph outa that thread to the FAQ
    My Build
  17. Member DasKafer's Avatar
    Sep 6th, 2000
    Decatur, Il
    98GTI,05GLI, Aircooled dubs everywhere
    10-01-2012 12:12 PM #17
    You can get the Polydrive tool from SEARS! It's a whopping 17 dollars!
  18. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    10-07-2012 01:29 AM #18
    Quote Originally Posted by DasKafer View Post
    yep, i was looking at one earlier today, but i got ahold of a snap-on one locally
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  19. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    10-25-2012 05:05 PM #19
    There are lots of spots that need more info.
    Please PM or post here if you have information to contribute.
    My Build
  20. Member Superman's Avatar
    Dec 8th, 2000
    Dasher Diesel, Rabbit GTI, Polo, 16V Jetta, Audi 4000, 1303S
    12-19-2012 07:56 PM #20
    This picture is not mine so I can not confirm the information and it needs the weight.
  21. Member Andaloons's Avatar
    Apr 16th, 2004
    Houston, TX
    2004 GLI 02M; 1997 Ford F-150
    03-14-2013 09:20 PM #21
    Wow, this thread has improved dramatically since the last time I checked it out 5-6 months ago. Well done Groggory!
    There tools are perfect for disassembling a cylinder head. Both can be found on eBay:
    Left side is valve spring compressor right side is valve stem remover/installer.
  22. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    03-14-2013 09:45 PM #22
    Quote Originally Posted by Andaloons View Post
    Thank you.
    My Build
  23. Member derekb727's Avatar
    Dec 22nd, 2007
    Central Ky
    2001 Audi A4 2.0Tqm
    03-23-2013 09:34 AM #23
    Add this to the TDC tool at the top of the post
    Search: AF98-2036
    Why? Because the link you have you can't purchase it.
    2001 Audi A4 1.8t Quattro 6spd Black on Black
    2L • BorgWarner S259 • AEB Head • ST Valves & Springs • IECVA1 Race Cams • JE Pistons 8.8:1 • ID1000s • Bosch 044 • Aeromotive FPR • Apexi Intercooler w/ 3" piping • 80mm Hemi TB • HKS SSQV BOV • Custom Big Plenum NubWorks IM • Turbonetics 38mm WG • Eurodyne Maestro • FX 850 SS • 01E Swap •
