VWVortex.com - New valve cover gasket leaking?
    Results 1 to 17 of 17
    Thread: New valve cover gasket leaking?
    1. Member jakemoore89's Avatar
      May 25th, 2010
      Tullahoma, TN
      87 Cabriolet
      09-02-2011 10:20 PM #1
      Yesterday I flushed my cars oil, and replaced both the valve cover gasket and the oil pan gasket. After all done, I started the car and oil was seeping out the back of the valve cover. Gasket is 1 piece ordered from germanautoparts.com. New studs were included with the kit, but were not installed. Any ideas?
    2. Member jakemoore89's Avatar
      May 25th, 2010
      Tullahoma, TN
      87 Cabriolet
      09-02-2011 10:20 PM #2
      Car is 1987 cabriolet.
    3. Member CajunSpike's Avatar
      Mar 11th, 2009
      New Orleans, LA
      91 Burgundy Etienne(2), 06 Jetta 2.5, 08 GTI 2.0T FSI
      09-02-2011 10:33 PM #3
      I'm guessing the fact that you didn't replace the studs, is what the problem is. Those studs have a different shape to allow the new gasket to seal fully. No studs, no seal.
    4. Member jakemoore89's Avatar
      May 25th, 2010
      Tullahoma, TN
      87 Cabriolet
      09-02-2011 10:37 PM #4
      Alright I'll give it a shot when I get off work. Will old ones will one out with vice grips? Hah
    5. Member CajunSpike's Avatar
      Mar 11th, 2009
      New Orleans, LA
      09-02-2011 11:00 PM #5
      If you could lock two nuts together real tight, then you could use the nuts to back out the old.
      I haven't done this but reading here for a couple years, people said its not easy to get them out.
      Yes last resort use vise grips, but try NOT to break a stud in the hole..thats real bad.
      Read up in this old thread.
      http://forums.vwvortex.com/showthrea...t=piece+gasket
    6. Member jakemoore89's Avatar
      May 25th, 2010
      Tullahoma, TN
      87 Cabriolet
      09-03-2011 03:21 AM #6
      Thanks for the help. Installing the new studs worked beautifully.
    7. Member sprocket007's Avatar
      Oct 14th, 2002
      Alberta, Canada
      '00 TT,'92PassatG60 Syncro,'90 G60Corrado,'89 Cabriolet,'86 Jetta Coupe,'81 Rabbit,'74&'69Westfalia
      09-03-2011 03:57 AM #7
      Is it the cork valve cover gasket? Those dont like to be over tightened and leak...
      BSc.N, EMS/FIRE
    8. Member jakemoore89's Avatar
      May 25th, 2010
      Tullahoma, TN
      87 Cabriolet
      09-03-2011 09:36 PM #8
      nah, I upgraded to the 1 piece rubber gasket. It was leaking, but since I installed the new studs, It hasn't leaked a drop.
    9. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      09-03-2011 10:20 PM #9
      And you tightened the nut to 87 in/lbs?
    10. Member jakemoore89's Avatar
      May 25th, 2010
      Tullahoma, TN
      87 Cabriolet
      09-04-2011 12:40 AM #10
      I guessed the 87lb. I dont think the gasket is coming loose any time soon
    11. Member sehaare's Avatar
      Aug 4th, 2003
      Palatine, IL. But I'll NEVER call Chicagoland home.
      2013 TDI Sportwagen, 81 Rabbit Convertible, 92 Cabby (Daughter's), 98 SUV, 2011 Legacy
      09-04-2011 09:17 AM #11
      yep got to use the new studs. The old studs have a shoulder in them near the head to prevent crushing the old style cork gasket. The new studs are shoulderless because the new rubber gasket has its own metal insert to prevent crushing. old studs + new gasket = gap next to studs.
      Your not the first to make this mistake I did the same thing 7 years ago with the same results. The only difference was that when I was removing my last "double nut" I dropped it into the oil return hole in the corner and had to fish it out of the oil pan.
      Steve
      Enjoy every sandwich - Warren Zevon
    12. Junior Member
      Jul 15th, 2011
      Long Island, NY
      92 VW Cabriolet Auto, 04 Jeep Wrangler Unlimited, 02 Acura TL-S, '10 Subaru Legacy 3.6R
      09-04-2011 10:45 AM #12
      I just did this last week, just get some vises and back the old studs out, mine were not that tight, then replace the studs tighten it down working your way from the opposite corners. Then torque it all to spec.
    13. Member
      May 2nd, 2001
      CNY
      2012 CW Golf R 4dr, 2017 SB GSW 4MO
      09-04-2011 06:33 PM #13
      I've tried the two nut method and it doesn't always work as the nuts may slip. A better way is to add a washer or two between the two nuts.
      Quote Originally Posted by CajunSpike View Post
    14. Member sehaare's Avatar
      Aug 4th, 2003
      09-04-2011 06:54 PM #14
      Quote Originally Posted by B5Speedo View Post
      never heard of that, guess you can teach an old dog new tricks
    15. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      1986 Cabriolet Best Seller; 1990 Vanagon Westfalia; 2016 Golf GTI S
      09-05-2011 01:49 AM #15
      And sometimes, it just plain doesn't work. All but 2 or 3 studs came out with just a wrench on mine; the others required Vice Grips with sandpaper.
      Cabby-Info.com -- Your online guide to VW Cabriolets/Rabbit Convertibles
      Old Blue's Blog -- The adventures of a 1990 Westfalia
      "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
    16. Member
      May 2nd, 2001
      CNY
      09-05-2011 12:06 PM #16
      Quote Originally Posted by kamzcab86 View Post
      Glad to hear you got them out.
    17. Member
      May 2nd, 2001
      CNY
      09-05-2011 12:09 PM #17
      Quote Originally Posted by briano1234 View Post
      I still have the cork gasket on my '83 GTI with no leaks. Tightening the nuts slowly, a little bit at a time, and methodically is the key.
