VWVortex.com - FS: Eurodyne Maestro 7 ECU with Cable 1.8T Immo Defeat AWW/AWP.... 630cc, MAFless, SAI,EVAP,O2 Delete
    Results 1 to 11 of 11
    Thread: FS: Eurodyne Maestro 7 ECU with Cable 1.8T Immo Defeat AWW/AWP.... 630cc, MAFless, SAI,EVAP,O2 Delete
    1. Banner Advertiser Mike@VXTuning's Avatar
      Jul 1st, 2010
      Texas
      2001 1.8T
      09-08-2011 01:07 AM #1
      Hi Guys,
      Im planning on selling my Maestro 7 630cc ECU with cable. To be honest i really dont know how to mess with the numbers and graphs so therefore im going with just a regular Big Turbo file ready for plug and play. This Maestro deal is for someone who knows what they are doing and have a dyno in hand, and thats not me I will include ECU and Cable for $750 + Shipping.
      ECU has the following options:
      IMMO Defeat
      630cc
      Mafless
      O2 Delete
      EVAP Delete
      SAI Delete
      70mm Throttle Body
      and some other goodies or i think that is it. If you're interested send me a message or email me at volxtuning@hotmail.com for faster communication. Thank you!
      Follow us on INSTAGRAM and Facebook
    2. Banner Advertiser Mike@VXTuning's Avatar
      Jul 1st, 2010
      Texas
      2001 1.8T
      09-09-2011 12:52 AM #2
    3. Banner Advertiser Mike@VXTuning's Avatar
      Jul 1st, 2010
      Texas
      2001 1.8T
      09-13-2011 12:32 PM #3
    4. 09-18-2011 02:43 PM #4
      Bump bump
      MK4 Junker : PAG 50trim Kit : AEB : RMR : Eurodyne
      P.P.T. - Pag Parts Turbo
      B6 A4 : Slow
    5. Banner Advertiser Mike@VXTuning's Avatar
      Jul 1st, 2010
      Texas
      2001 1.8T
      09-18-2011 03:44 PM #5
      Quote Originally Posted by screwball View Post
      I think you're not gonna like this.
      Thanks for your info, but that is not correct. This ECU has IMMO defeat and that is only applied when the ECU is flashed for the particular car it will be running without the immobilizer defeat. In this case since it has IMMO defeat it can be plugged in on any 1.8T AWP/AWW. And Im telling you because that is how I bought this ECU (USED). I plugged it in directly into my car and it worked great, all it needed was adjustment which is very confusing for me since i dont know too much about logs and the other stuff related due to that the ECU had options that my car didnt have or that I was not using, so I had to remove them or adjust the ECU to my car.
      I see in your signature that you have Eurodyne, but does that mean you have maestro or your ECU is flashed? Also it doesnt make sense about the VIN, how does the guys running 1.8T swaps on other platforms use maestro? if they need to transfer the ECU from the MK4 to other platforms. I think VIN will be useless. That is why they get their ECU's IMMO defeated so they can make it plug and play on any 1.8t AWW/AWP and i think others, Im not too sure.
    6. Member L.I.VW13's Avatar
      Apr 8th, 2006
      Long Island
      Built mk4
      09-18-2011 05:58 PM #6
      Not sure if your interested in trading for a BT Uni ecu thats IMMO defeated? I can change the setup to whatever you have in your car.
    7. 09-18-2011 09:36 PM #7
      Cheers
      B6 A4 : Slow
    8. Banner Advertiser Mike@VXTuning's Avatar
      Jul 1st, 2010
      Texas
      2001 1.8T
      09-18-2011 10:59 PM #8
      Just to save you from more discussion, it will work and vin is not required for it to work. We have tried this ecu with 3 different cars and it has worked flawless. The only thing is that you won't be able to edit the basefile or have chris make you another one. In this case you will have to adjust this ecu to whatever setup you're running. So to end the discussion, it will work guaranteed.
    9. 09-19-2011 08:13 AM #9
      Little bump
      B6 A4 : Slow
    10. 09-19-2011 08:55 AM #10
      Bump for a good deal!
    11. Banner Advertiser Mike@VXTuning's Avatar
      Jul 1st, 2010
      Texas
      2001 1.8T
      09-19-2011 01:37 PM #11
      Quote Originally Posted by 20v=godsmotor View Post
      Thanks!
