VWVortex.com - 2001 Golf IV European 1.9l TDI Red I
    Results 1 to 7 of 7
    Thread: 2001 Golf IV European 1.9l TDI Red I
    1. Junior Member ericowen's Avatar
      Jul 11th, 2008
      The Netherlands
      2000 Audi TT MK1 Roadster 225 HP
      09-09-2011 10:09 AM #1
      The cruise control will not engage and the glow plug indicator is flashing in the dash. I replaced the brake light bulbs and switch The issue went away for a few days but came back. Any suggestions on how to use the VAG COM to solve this issue?
      Regards,
      Eric
      Dec 23rd, 2005
      Near Philadelphia,PA
      2010 VW Tiguan
      09-09-2011 01:32 PM #2
      Please post an autoscan so we have the information needed to assist you.
    3. 09-09-2011 03:17 PM #3
      Yup
      I know your answer but need an auto-scan to verify.
      Please post one up NooB.
    4. Junior Member ericowen's Avatar
      Jul 11th, 2008
      The Netherlands
      09-10-2011 09:15 PM #4
      I will run an autoscan tomorrow and post it here. Here in the Netherlands it is currently 0214 am.
      Best regards,
      Eric Owen
      BTW... I am a seminoob here.
    5. 09-10-2011 10:05 PM #5
      Acknowledged.
      OK SEMI BOOB NOOB.
      Please let me know so I can help.
      best,
    6. Junior Member ericowen's Avatar
      Jul 11th, 2008
      The Netherlands
      09-12-2011 09:38 AM #6
      Monday,12,September,2011,14:25:43:05448
      VCDS Version: Release 10.6.4 (x64)
      Data version: 20110418
      Chassis Type: 1J - VW Golf/Bora IV
      Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
      76
      Mileage: 354330km/220170miles
      Address 01: Engine Labels: 038-906-019-AXR.lbl
      Part No: 038 906 019 DF
      Component: 1,9l R4 EDC G000SG 1237
      Coding: 00002
      Shop #: WSC 01317
      VCID: 5EAD4CD4F0A7
      3 Faults Found:
      17978 - Engine Start Blocked by Immobilizer
      P1570 - 35-10 - - - Intermittent
      16955 - Brake Switch (F): Implausible Signal
      P0571 - 35-10 - - - Intermittent
      18062 - Please check DTC Memory of Instrument Cluster
      P1654 - 35-10 - - - Intermittent
      Readiness: 0 0 X X X
      Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
      Part No: 1C0 907 379 C
      Component: ABS FRONT MK60 0103
      Coding: 0001025
      Shop #: WSC 01317 785 00200
      VCID: 2A45D004FC6F
      No fault code found.
      Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
      Part No: 6Q0 909 605 A
      Component: 0F AIRBAG VW5 01 0004
      Coding: 12358
      Shop #: WSC 01317
      VCID: 357FF37825D1
      3 Faults Found:
      00532 - Supply Voltage B+
      07-10 - Signal too Low - Intermittent
      01281 - Airbag; Drivers Side; Disabled
      35-00 - -
      01286 - Belt Tensioner; Drivers Side; Disabled
      35-00 - -
      Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
      Part No: 1J0 920 805 G
      Component: KOMBI+WEGFAHRS. BOO V04
      Coding: 01122
      Shop #: WSC 00299
      VCID: 2A45D004FC6F
      Part No: Ident
      Component: Nr. WEGFAHRS.:VWZ6Z0Y2105233
      Ident.-Nr. WEGFAHRS.:VWZ6Z0Y2105233
      2 Faults Found:
      00562 - Sensor for Oil Level/Temperature (G266)
      30-10 - Open or Short to Plus - Intermittent
      01176 - Key
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway KCAN 0001
      Coding: 00006
      Shop #: WSC 01317
      VCID: F0F1826C9A33
      Address 35: Centr. Locks Labels: 1C0-962-258-II.lbl
      Part No: 1C0 962 258 J
      Component: 05 Zentr.Verriegel. 0002
      Coding: 00257
      Shop #: WSC 01317
      VCID: 2E4DDC14C087
      End ---------------------------------------------------------------------
      Interesting. The last time I did an autoscan I didn't get a brake switch: signal implausible.
      Regards,
      ericowen
    7. 09-12-2011 11:53 AM #7
      :::::ALERT FORUM ACTION EMERGENCY MESSAGE:::::
      THIS POST MOVED/VACATED BY JACK TO PROTECT CONTENT FALLING INTO THE GAPING HOLE OF THE VORTEX
      IT SEEMS NO GOOD DEED GOES UNPUNISHED!
      http://www.youtube.com/watch?v=HaoySOGlZ_U
      Just email or PM John Acton@VMG as to why I have chosen to do this for a modification answer to these posts.....
      Ultimately this is his fault for how the account was handled.
      john@vortexmediagroup.com
      You could say I feel insulted and abused..........
