VWVortex.com - Testing Fuel Pump Problems & Solutions thread
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 67
    Thread: Testing Fuel Pump Problems & Solutions thread
    1. Member g60racer's Avatar
      Nov 18th, 2000
      South Bend
      93 VR6 Corrado, 04 R32
      09-10-2011 07:37 PM #1
      There are 3 pages of posts that come up when you search for "fuel pump" in our forum, so I thought it would be nice to collect the pertinent info and put it in one thread.
      First off, the problem: The motor turns over but doesn't start.
      Questions to help diagnose:
      1) when you open the driver door, do you hear the buzzing noise from under the car? If you hear that, your fuel pump is working. Your problem is not the fuel pump, fuel pump relay, or fuel pump fuse. Stop reading this thread, it does not apply to you.
      If you do not hear the buzzing noise when you open the driver door, the fuel pump is not priming. Continue to step 2.
      2) Does your interior dome light turn on when the door is open? Does the door chime sound when the key is in ignition and the door is opened? If the answer to both of those is "no", then your door latch microswitch is not working correctly. Go search for threads on how to fix that problem.
      If the dome lights turn on with the door open, continue to step 3.
      3) Is fuse #28 blown? That is the fuel pump fuse.
      If it is blown, try replacing it (15A fuse) and see if normal operation resumes. Warning: blowing that fuse is usually indicative of a relay and/or pump going bad! If it blows when you put a new fuse in and turn the ignition on, continue to step 5. If nothing happens when you replace it, go to step 4.
      4) Test the fuse location with a test light or mutimeter to see if there is 12V+ when the key is on. If there is 12V+, go to step 6. If there is not, go to step 5.
      5) Check fuel pump relay. It's the 4th from the left on the bottom row of relays, under the dash. The label next to it says "diesel F". It's relay #409, part # 1J0 906 383 C. Costs about $43 online, and $66 at the dealer.
      I'll let the experts weigh in here on how to "properly" test the relay.
      Here are two possible methods that don't involve using jumpers in the fuse block or trying to wiggle a multimeter in there:
      1) Borrow a 409 relay from anyone else who has a Mk4. Swap it in. If your fuel pump works with their relay in there, you've found the problem. This is by far the easiest way to test. Everyone knows someone else with a Mk4 - doesn't matter what model.
      2) Go to step 6 & test the fuel pump itself, thus determining the relay was faulty.
      6) Test fuel pump & connector. It's located under the right rear passenger seat. Remove the lower cushion, and fold the square flap forward to access the panel. Remove the 3 screws and pry up the cover panel gently. Check to see the main connection is in decent shape. Some of them are defective and come loose. Use a multimeter and see if it's getting voltage at the outer connections on the terminals. If there is no voltage, the relay may be the problem.
      If you have a small battery (RC car battery works nicely) for testing, use the outer connections on the cover to the fuel pump to see if the pump operates when you apply current. Alternately, you can use a square 9V battery with a couple of leads from it. That should give enough current to see if the motor at least turns with current applied. It's a loud little thing, will be very evident whether it works or not.
      If the motor works when you apply current, the relay may be faulty or the connector may be faulty. You'll have to do some more circuit testing to see what the deal is.
      If the motor does not work when you apply current, the motor is toast. Replace it.
      germanautoparts.com has the motor for $201.48 as of this writing.
      More to be added to this posting as the experts weigh in...
      Brendan Prout
      04 R32 144k miles
      93 VR6 Corrado 192k miles
      90 G60 Corrado 304k miles - RIP 2/12/11
    2. Member g60racer's Avatar
      Nov 18th, 2000
      South Bend
      09-10-2011 08:45 PM #2
      DIY Fuel Pump Removal
      Before you start: Rule of thumb here is TAKE YOUR TIME. Don't be in a rush. Everything here is somewhat delicate.
      Continuing on from the post above & assuming you've already removed the back seat cushion and cover panel...
      Location of fuel pump:
      Under right rear seat cushion...
      Unhook cushion and remove
      Pull back square carpet
      Remove screws and cover plate
      Now on to the fuel pump.
      1) Disconnect electrical connector. IT IS BRITTLE! BE GENTLE!! Use a small flathead screwdriver inserted into the connector slot to very gently pry up on the release, and wiggle the connector back and forth until it slides off. Take your time with this.
      2) Disconnect the two fuel hoses. There is a small flat button on each of them around the bottom trim, opposite side from where the hose necks are. Push in on the button and wiggle it a little, and the hose should slide up off the nipple easily.
      3) Remove the ring securing the top panel of the fuel pump.
      There are a series of small holes in the trim ring that secures the top panel in place. Spray a little bit of penetrating lubricant into each hole and let it sit for a couple of minutes. If you have the special VW tool for removing the fuel pump panel trim ring, use it! Otherwise, you can use a very large flathead screwdriver and a mallet to loosen it.
      TAKE YOUR TIME WITH THIS!
      Make sure the head of whatever screwdriver or chisel you use is worn and has no sharp edges. I use a short pry bar, which is very rounded off. The trim ring needs to come off counter clockwise. Angle the driver against one of the flat ridges and give it a few whacks with the mallet. Then do the same with the one 180* from that ridge. Then pick another pair on a different angle and repeat. Work your way all the way around, loosening each ridge section. You may see the ring move in one section and deform slightly, without other sections moving. IF you see this, move on to another section so you don't break the ring! After you've worked your way all around the trim ring a few times, the whole thing will start to come loose and you'll be able to unthread it. It typically takes about 10 minutes of persistent hammering to get it loose. Again, TAKE YOUR TIME WITH THIS!
      4) Once the ring is removed, you'll be able to pop the panel up and out. Remove the rubber seal that was under the trim ring.
      5) Disconnect the black fuel hose, using same type of button release mechanism as the outer hoses.
      6) Disconnect the black 2-wire electrical connector.
      7) Pull up on the white lever on the right side of the outside of the fuel pump. This is just a long thin white plastic bit with a couple of hooks that let it attach to the outside of the fuel pump. It has a hose attached to the bottom of it. DO NOT disconnect this hose! Just pulling up on the lever should allow the connection to fall free.
      8) Carefully pull the fuel hoses connecting the top panel to the pump assembly up and out, but do not disconnect them. You just want them out of the way so you can pull the pump assembly free.
      9) Gently pull the fuel pump straight up and out. The Fuel Level Sender and float move around and they will require you to maneuver it around a little bit to get it all out free and clear. Have a pan or tub or at least a towel ready to catch fuel that will spill out of the pump as you lift it out.
      10) Have some plastic wrap and a large rubber band handy to seal up the tank while you've got the pump out, especially if it will be a few days before you put in another one. It will keep the vapors in the tank and out of your interior.
      11) Reinstallation is basically the reverse of Disassembly. Some differences:
      - The main pump unit is held in place by spring tension from the top panel. It will take a few tries to get it lined up properly and secure. TAKE YOUR TIME.
      Also - I recommend using some petroleum jelly to lubricate the black rubber seal as you're putting it back on... helps the top slide back into place instead of the seal bunching up.
      Here's what the fuel pump looks like out of the tank:
      Here's what the secondary vacuum pump connection looks like disattached from the main pump.
      Also inside the tank you can see the bottom of the fuel filler pipe (upper left) and secondary pump return hose & electrical connector. It's fine for them to just be swimming in there... just know generally where they are, because they do like do slip out of sight when you're putting it all back together.
      Brendan Prout
      04 R32 144k miles
    3. Member mikey_o's Avatar
      Mar 25th, 2005
      SF/SEA
      04 R32 TR, 12 Jetta SEL, 13 GTI Wolfy
      09-11-2011 03:21 AM #3
      Good info Brendan, thanks for putting this together
      Maybe Ian or someone can add this to the DIY/FAQ sticky...
      2004 R32 Wirbelsturm Rot. Mein Deutsch ist nicht sehr gut. Ich lerne langsam.
    4. Member Brake_Dust's Avatar
      Sep 23rd, 2001
      Toronto \/ \/\/ PA
      MK4 R32
      09-11-2011 11:14 AM #4
      Don't you mean right rear passenger seat?
    5. Member g60racer's Avatar
      Nov 18th, 2000
      South Bend
      09-11-2011 04:22 PM #5
      Quote Originally Posted by Brake_Dust View Post
      Yes! Thanks for pointing that out! Will edit.
      Brendan Prout
      04 R32 144k miles
    6. 09-11-2011 04:47 PM #6
      Depends which country
      MK4 R36 x Precision 6776 Turbo = Large Grin
    7. Member VeeRsixx's Avatar
      Jan 5th, 2004
      Harrisburg PA
      '04 R32 Black Magic
      09-11-2011 08:36 PM #7
      Excellent info ! Pics will help even more. It's good to have this information available before a problem happens.
      past dubs: (all black) - 1984 GTI - 1992 GTI 16v - 2001 GTI VR6
    8. Member Brake_Dust's Avatar
      Sep 23rd, 2001
      Toronto \/ \/\/ PA
      MK4 R32
      09-12-2011 12:11 AM #8
      Quote Originally Posted by g60racer View Post
      Thanks for making this thread
      This will help a lot of people out
    9. Member g60racer's Avatar
      Nov 18th, 2000
      South Bend
      09-13-2011 02:19 AM #9
      Quote Originally Posted by VeeRsixx View Post
      Will be taking pix and adding them shortly. Had to deal with getting my Corrado roadworthy today, will focus on the R32 on Wednesday when I have another block of time for it.
      Brendan Prout
      04 R32 144k miles
    10. 09-13-2011 02:27 AM #10
      Dayum. I call for FAQ sticky immediately!
    11. Member Daemon42's Avatar
      Feb 9th, 2001
      colorado
      04 R32T, 95/98 4runner
      09-13-2011 02:47 AM #11
      Report the thread to a moderator and ask em to add it to the FAQ/DIY thread.
      That's how it's done.
      ian
    12. Member g60racer's Avatar
      Nov 18th, 2000
      South Bend
      09-16-2011 05:45 AM #12
      Pix added!
      Brendan Prout
      04 R32 144k miles
    13. Member huichox4's Avatar
      Nov 8th, 2004
      83 Rabbit - 02/04 .:R32 Jetta wagon - 04 .:R32 - E30 325i & Alfa GTV6 Chumpcar Racecars
      09-16-2011 04:48 PM #13
      awesome thread, just made my day !!!!! I thought my pump was bad because my fuse was intact and the door switch was good too, checked voltage at the fuse and the pump and there it was the problem...... 1.72v were it should have been 12+v took the relay out , banged it on my hand and reinstall then try to start and it purrrrrssss again !!!
      nothing beats a repair when it is free...... although I will get a new relay as a spare just in case
    14. Member g60racer's Avatar
      Nov 18th, 2000
      South Bend
      09-18-2011 12:50 AM #14
      Quote Originally Posted by huichox4 View Post
      That is awesome. Now I'm tempted to go bang on my original relay and see if that jolts it back into working.
      Will know exactly what to raid Mk4's for at the junkyard now, though!
      Brendan Prout
      04 R32 144k miles
    15. Member
      Jun 24th, 2006
      Buffalo, ny
      04 BMP R32, 87 16v Rocco stripped and caged(sold). 99 passat: low and slow(gone) 89 Gti 16v(rip)
      11-26-2011 08:29 PM #15
      Could the micro switch really be a problem? I'm pretty sure mine has been broken since before I got the car(3 months). Today my car wouldn't start, pretty sure the pump failed, but could that switch have such a great affect?
    16. Member Daemon42's Avatar
      Feb 9th, 2001
      colorado
      11-26-2011 08:56 PM #16
      The microswitch only affects the priming action when you open the door. It won't prevent the
      pump from running when the engine is starting or running. Failure to prime can result
      in a delayed start, but that's it. Check the pump fuse and relay first before you
      go digging for the pump itself.
      ian
    17. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      11-26-2011 09:07 PM #17
      banging/tapping a relay (on or off) and working after is 'usually' a very temp fix.
    18. Junior Member SchnellerR32's Avatar
      Jan 5th, 2012
      Utahr
      02-26-2012 02:36 PM #18
      I'd like to confirm point#4 please.... My vehicle is currently not starting. Isn't it true that Fuse #28 will only light up (test light) with 12 volts at "prime" stage, OR only when the car is actually running?? With the key only in the "on" position (car not running), it should not have any power to it.
      My pump primes just fine at door open. I only have 12v at fuse 28 when priming. I've replaced and tested relay 409, all is working fine. I've jumped (wire lead) at fuse replay block to test fuel pump constant on, and it's flows just fine. I've also removed inlet to fuel rail, placed hose in a cup, and opened the car door to observe a nice healthy stream flowing. Someone mentioned a secondary primer pump on this forum? Is there such a secondary pump on our cars? Or only the one main in-tank unit reference above?
      Thanks
      Reflex MKIV R32 - VF Stage 2
    19. 03-19-2012 01:23 PM #19
      I have a few notes on reassembly:
      Make sure the arrows on the pump and the tank line up. I didn't see the arrows when I disassembled things because they were covered with dirt.
      Make sure the seal fits down in the tank lip - it wants to get pinched between the lip and the pump.
      Once the new pump has pressurized the lines they will spray quite a bit of gas all over when you disconnect them. I had to do this and gas went all over. wrapping the end of the lines with a cloth when you disconnect them will at least prevent too much spray.
      be careful when re-installing the ring - it can be over-tightend and stripped.
      Thanks for the excellent write up and pictures - it made the job so much easier than it would have been.
    20. Member BOUDAH's Avatar
      Aug 15th, 2008
      New Haven, Connecticut
      2007 F250 PSD, 2004 BMP .:R32 / 2013 Island Grey Metallic CC Sport 6 spd ; 2002 Passat 30V V6 5 Spd
      03-19-2012 02:11 PM #20
      Now that i think about it, my car doesnt make it past # 2....thankyou for posting this. Also for Mooney for suggesting this a while ago, lol..
      U.S. Army
      OIF / OEF Veteran
    21. Member g60racer's Avatar
      Nov 18th, 2000
      South Bend
      03-19-2012 03:07 PM #21
      Quote Originally Posted by SchnellerR32 View Post
      Thanks
      Just one pump, no secondary primer pump.
      Fuse 28 should see power continuously when the pump is running, according to the wiring diagram, but I'll have to hit it with a multimeter to answer you for sure.
      One thing I've noticed with worn fuel pumps is they will still physically operate, but they won't put out the 70psi they're supposed to put out, or their flowrate decreases. (I forget how many liters per hour this one is supposed to push through, but measuring flowrate with a graduated cylinder is the one way to be sure about that.)
      In the case of my R32's pump, the flowrate and pressure were significantly decreased, and the load on the circuit was increased. Lots of resistance, overloaded the relay.
      Brendan Prout
      04 R32 144k miles
    22. Member g60racer's Avatar
      Nov 18th, 2000
      South Bend
      03-19-2012 03:10 PM #22
      Quote Originally Posted by corduroy_sfo View Post
      YES!! Thanks for pointing that out!
      Use some petroleum jelly to help it sit properly, and fit into place without getting pinched.
      Yup.
      Brendan Prout
      04 R32 144k miles
    23. Member
      May 30th, 2006
      Mesa, Arizona
      '04 R32 w/ HPA FT400 w/ UM tune - '95GTIVR6 - '02 TTQuattro
      05-30-2012 02:32 AM #23
      Thanks for the DIY! Helped me a lot. Changed fuel pump today, still working but after 8 years, preventive maintenance.
    24. 10-22-2012 11:45 PM #24
      Here's the best price I could find... http://www.ebay.com/itm/290406528501...84.m1497.l2649
    25. Member VincewagenR32's Avatar
      Nov 6th, 2010
      Turnbull Canyon, Hacienda Heights, CA
      MKIV R32-RS & 06 Specialized Rock Hopper
      10-23-2012 06:28 PM #25
      Quick question regarding the pump primering.
      When u first open the door the pump primes correct? Does this also mean that if i open the door and not start the car but let it sit, set alarm and then unlock, open door again, will the pump primer again? Mine sounded like it primed once when i was checking it but then i let the car sit and didnt start it for about an hour then went back to get in the car, the prime didnt happen. I started the car and the first turn over it wouldnt start. 2nd time it did. Im suspecting the relay but want to be sure of it before hand.
      "A genius is not measured by what he knows, but with what he can figure out with what he already knows."
      Quote Originally Posted by power_mind View Post
      Also, remember that you can throw the whole parts bin at the car, you can even pick and choose, but the best modification is to tighten the loose nut behind the wheel.
      Instagram : Visualblurr
