VWVortex.com - Car Randomly Dies and Battery Symbol Flashes While Driving......HELP APPRECIATED
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 66
    Thread: Car Randomly Dies and Battery Symbol Flashes While Driving......HELP APPRECIATED
    1. Member SD1017's Avatar
      Aug 11th, 2009
      SD, CA
      2004.5 VW GLI
      09-13-2011 12:59 PM #1
      Hey all, I recently picked up a 2004 GLI from someone in the San Diego area, and this car has been meticulously maintained, and has 72500 miles as of today. The engine bay is really clean, and I have records for all the services including the last one @70000miles, and the checklist the last mechanics went over, was perfect nothing wrong or in the yellow or red.
      Heres my problem:
      Twice in the past two weeks I have been in 3rd or 4th gear not driving aggressively, relaxed driving and the car will just shut off completely, flashing the battery icon at me. So i stop and start the car back up and there is no problem!
      I recently got the battery checked and there was nothing else wrong. I was just wondering if anyone had any other ideas or thoughts on what could be the problem......or how to best direct the mechanic who last fixed it where to look.
      The car drives perfectly normal otherwise, not a hiccup, and does not show a CEL or any other kind of light. Any help would be appreciated as I am unsure, I thought it might be the alternator but am not positive.
      Anything helps!
      Pics of said carro
    2. Member SD1017's Avatar
      Aug 11th, 2009
      SD, CA
      2004.5 VW GLI
      09-13-2011 01:57 PM #2
      really no one can help or offer suggestions?
    3. Member BriceSMASH's Avatar
      Jun 7th, 2010
      SoCal
      2003 GTI, 2015 Jetta, 2015 R-Line Tiguan
      09-13-2011 03:29 PM #3
      I've had a similar problem with my GTI as well except my car shuts off on me when I'm in neutral. No battery light comes on and my car starts up right again as if I turned it off myself. Sadly, I have no idea what's wrong either.
      ۟rojerks
    4. Member SD1017's Avatar
      Aug 11th, 2009
      SD, CA
      2004.5 VW GLI
      09-13-2011 03:32 PM #4
      Quote Originally Posted by BriceSMASH View Post
      no one can your the second person to say it has happened one time before, and then never again
      i dont wanna take it to the stealership and get ass rammed by their costs to look for something that is probably easy to fix...or at least i hope
    5. Member woteg's Avatar
      Apr 7th, 2009
      nubraska
      06 a3; 05 gli; 93 fox
      09-13-2011 05:26 PM #5
      take it to a parts store and get codes pulled and make them test everything else they can test there - alternator etc...
      Quote Originally Posted by Hawaii5-0
      never let a woman touch your car, it should have never been in the kitchen for her to touch
    6. Member desertdubs_C's Avatar
      Sep 20th, 2009
      Phoenix
      2005 VW Jetta GLI Blue Lagoon --all stock--
      09-13-2011 06:36 PM #6
      Its possible you may have a pinched ignition wire causing an intermitten short making the car shut off as if you turned the key. Also check your charging system. Alt, wire from alt to fuse (top of battery), and for any loose grounds.
      I thought my alt was bad on my GTI when my battery died on me a couple times in the same week. Turned out to be the pos+ wire coming from the alt to the battery fuse box had a break causing my headache.
      GL
      (new thread) -vDubGuy-build-content-(aka-RootsNeverDie)
      (old thread) My never ending project RootsNeverDie
    7. Member RobbieRolex's Avatar
      Sep 5th, 2011
      Ireland
      Seat Leon Cupra R
      09-13-2011 08:58 PM #7
      Sounds like a fuel cut by the ECU, Would put money on that it probably only happens on part throttle, you need to get it scanned for errors otherwise it's a very long guessing game.
      Jun 13th, 2009
      San Diego
      2003/VW/1.8T Jetta 5sp Automatic
      09-13-2011 09:02 PM #8
      Intermitent errors are stored in the ECU and it doesn't necessary triggers a CEL or MIL, but if you scan the computer you will know where those errors happened and you can start looking there.
      My car once stopped accelerating and engine speed got stuck at 900 or so RPMs but I got different kind of MILs like CEL, ASR, battery, etc.
      It turned out to be the alternator and alternator harness.
    9. Member sabbySC's Avatar
      Dec 28th, 2009
      Toronto
      2003 GTI
      09-13-2011 09:19 PM #9
      check all your connections on top of the battery are tight (fuse box on top), also check power and ground wires are tight.
      Get the codes read and postback here, we will be able to help with more info.
      CTS gt3071r and more
    10. Member SD1017's Avatar
      Aug 11th, 2009
      SD, CA
      2004.5 VW GLI
      09-14-2011 12:22 AM #10
      Quote Originally Posted by desertdubs_C View Post
      GL
      For sure I will check this out. Thanks a lot
      Quote Originally Posted by RobbieRolex View Post
      Yes that's exactly it!!!
      Only on partial throttle.
      Car is new to me so I will get a scanner this weekend or get it scanned. Thanks a lot that sounds the most like it.
      Quote Originally Posted by carfreak01 View Post
      Cool. I thought it was my alternator at first too, so I will get it a scan first, a report back....thanks
    11. Member SD1017's Avatar
      Aug 11th, 2009
      SD, CA
      2004.5 VW GLI
      09-16-2011 10:51 PM #11
      OK so i got my car scanned and the only code it came up with was for the clutch switch.
      I figured either this one or the brake light switch was out bc my cruise control would not set.
      Could this solve all my problems? and wasnt there a recall on this i can not recall.
      Thanks A lot
    12. Member BassNotes's Avatar
      Mar 15th, 2005
      Costa Mesa, Calif., USA
      2002 VW GTI 1.8t
      09-17-2011 01:03 AM #12
      Quote Originally Posted by sabbySC View Post
      This.
      Before you start spending money replacing this and that, do this.
      Bob Lee
      2002 GTI 1.8t 262,000+ miles
      VCDS 15.7.3 with KEY-USB interface
    13. Member SD1017's Avatar
      Aug 11th, 2009
      SD, CA
      2004.5 VW GLI
      09-17-2011 07:00 PM #13
      Quote Originally Posted by BassNotes View Post
      This.
      That's the first thing I did. I would not jump to buying parts and throwing money at it lol.
      I'm going to get the clutch switch and replace it and see if that solves it, although the car has been driving perfect recently
    14. 09-18-2011 04:20 AM #14
      I'm pretty sure it would be your brake light switch. Even if you've had the recall done already for the switch. The cruise control not setting is a dead giveaway. Ask your dealer if you have any open recalls.
      I had similar problems and sure enough it was the switch.
      Good luck to you!
    15. Member SD1017's Avatar
      Aug 11th, 2009
      SD, CA
      2004.5 VW GLI
      09-18-2011 01:30 PM #15
      Quote Originally Posted by cameronmfjay View Post
      Good luck to you!
      Yup its the clutch switch not the brake light but they pretty much have the same affect if they go out right??
      Yea I called the dealer by me this weekend to see if it was a recall but the service dept was closed and they couldn't check.
      So I am calling on Monday to check with them and get this fixed, or order the part if it is not a recall.
      Thanks for the help!
      Sent from my car using the alternator and antenna.
    16. Member BassNotes's Avatar
      Mar 15th, 2005
      2002 VW GTI 1.8t
      09-18-2011 02:47 PM #16
      Quote Originally Posted by SD1017 View Post
      A lot of guys "check" the connections but don't actually do anything to check or fix them. If they don't say how they checked them, there's a good chance that they just eyeballed it and didn't dig any further.
      So, make sure you check the connections first. Actually check them.
      Bob Lee
    17. Member RedPartyCup801's Avatar
      Jan 24th, 2007
      Fairfield, CT 06824
      '04 RS .:R, '03 TRed Wolf (Sold)
      09-18-2011 05:05 PM #17
      GL
      This...
      Exact same thing was happening to me only wasn't 3rd and 4th gear it was 2nd and 3rd. It was the exact same problem with the wire from the alt to the fuse box. Definitely check into that
      .:R eflex 32
    18. 09-19-2011 08:06 AM #18
      Oops i didn't even take into account the clutch switch. When i had this problem it was on my 03 Jetta GLS (2.0L with auto tranz).
      But your right, they wont have the exact same effect but pretty dam close.
    19. Member SD1017's Avatar
      Aug 11th, 2009
      SD, CA
      2004.5 VW GLI
      09-19-2011 12:43 PM #19
      Gracias
      I am calling the dealer at one of my breaks from work today to see if I can get this fixed under recall for free....otherwise ill just buy the part and fix it myself.
    20. Member
      Jun 30th, 2011
      Yorktown, Va.
      2016 TR Golf R 2013 RB Golf R-sold 2004 Blue GLI-sold
      09-19-2011 02:48 PM #20
      correct, if the clutch pedal switch is activated your cruise will cut off. If that switch is permanently activated then your cruise won't set since it looks like you have the clutch pedal pressed. The clutch pedal switch isn't covered. Still a good idea to have the brake switch updated if it hasn't been. These will not cause the car to die while driving however. I'd suspect fuel or crank sensor being more likely to cause the car to cut off while driving off idle. Did the car just cut off or did it sputter a little before dying?
      you said that the battery light flashed, did it blink constantly or just come on when the engine shut off?
      2004 GLI
      Euro Pros Auto Repair
      http://europrosautorepair.com
    21. Member SD1017's Avatar
      Aug 11th, 2009
      SD, CA
      2004.5 VW GLI
      09-19-2011 03:10 PM #21
      Quote Originally Posted by Jayj View Post
      It happened so fast the two times that it did that I did not even notice any sputtering.
      The battery light just came on did not really flash when the engine shut off, and it disappeared when i turned the car back on. (but i can not be sure as to whether the battery light flashed or was constant, this has only happened twice...about 2-3 weeks ago)
      I also just did a throttle adaptation on my car over the weekend, and my throttle response and overall feel of the throttle is a lot better. Someone was having the same problem and they did this and have not had a problem since. I am keeping my fingers crossed hoping that this fixed whatever problem I had.
      for the help
    22. Member ~Enigma~'s Avatar
      Jul 8th, 2009
      Enid, Oklahoma
      2002.5, Jetta, 1.8t
      09-19-2011 03:46 PM #22
      well keep in mind that the battery light coming on means its an electrical or charge issue... IF the issues comes back I would look at the ignition switch... in any newer car when these go bad a lot of weird hard to explain sheit happens... good luck man
      Chaotic Conceptz NW
      Pick your poison
      253-273-9861 *txt works wonders... p.m.'n. Me doesn't work well because I do this on mobile web*
    23. Member SD1017's Avatar
      Aug 11th, 2009
      SD, CA
      2004.5 VW GLI
      09-19-2011 03:51 PM #23
      Quote Originally Posted by ~Enigma~ View Post
      i will keep that in mind
    24. Member
      Jun 30th, 2011
      Yorktown, Va.
      09-20-2011 04:56 PM #24
      if the car dies with key on then the battery light is operating as designed since the alt is no longer charging since it stopped spinning. so you might as well take that out of the equation.
      2004 GLI
    25. 09-21-2011 03:08 AM #25
      Im pretty sure that if the brake and gas pedals are both being pressed for an extended period of time (say 20 seconds or so) it activates this sort of "failsafe" where the ecu will shut everything down. (If brake light switch is indeed faulty then it wouldnt be uncommon for the ecu to be seeing it as on while your driving around town. Therefore it activates the failsafe and shuts everything off). Im not sure if the same applies to the clutch as well.
      I drove around for only god knows hows long with a faulty switch..
