VWVortex.com - Buying an '02 Jetta w/ issues, wondering if it's worth it - please help
    Results 1 to 6 of 6
    Thread: Buying an '02 Jetta w/ issues, wondering if it's worth it - please help
    1. 09-13-2011 07:05 PM #1
      Just a little background, looking at an '02 wagon, 2.0l, a hair over 100k miles. Car runs great when cold, 5-10 minutes after start up it starts sputtering and gets progressively worse. Scanned it and below is what I get. A whole lot of codes and all systems seem to be tied to "low voltage", except the misfires for the engine. Car is in generally good shape, what's it worth and any ideas on the engine/electrical issues?
      Thanks, and all help is much appreciated.
      y,09,September,2011,20:55:25:56347
      VCDS Version: Release 10.6.4 (x64)
      Data version: 20110418
      Chassis Type: 9M - VW Jetta IV
      Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
      76
      VIN: WVWSK61J52W263288 Mileage: 164450km/102184miles
      Address 01: Engine Labels: 06A-906-032-AVH.lbl
      Part No: 06A 906 032 FR
      Component: 2.0l R4/2V G 4070
      Coding: 00003
      Shop #: WSC 00000
      VCID: 73EE2BAF6B25
      WVWSK61J52W263288 VWZ7Z0A4140724
      2 Faults Found:
      16684 - Random/Multiple Cylinder Misfire Detected
      P0300 - 35-00 - -
      16688 - Cylinder 4: Misfire Detected
      P0304 - 35-00 - -
      Readiness: 0110 1101
      Address 02: Auto Trans Labels: 01M-927-733.lbl
      Part No: 01M 927 733 KQ
      Component: AG4 Getriebe 01M 4892
      Coding: 00000
      Shop #: WSC 00000
      VCID: 8912E94799A9
      No fault code found.
      Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
      Part No: 1C0 907 379 J
      Component: ABS FRONT MK60 0103
      Coding: 0004097
      Shop #: WSC 01317 785 00200
      VCID: 3162E1A7D1B9
      Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
      Part No: 6Q0 909 605 F
      Component: 03 AIRBAG VW6 0202 0004
      Coding: 12339
      Shop #: WSC 01317
      VCID: 3A70C68B0CCF
      2 Faults Found:
      00532 - Supply Voltage B+
      07-10 - Signal too Low - Intermittent
      65535 - Internal Control Module Memory Error
      00-00 - -
      Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
      Part No: 1J0 907 487 A
      Component: Lenkradelektronik 0003
      Coding: 00118
      Shop #: WSC 01317
      VCID: 2F66E7DFC78D
      1 Fault Found:
      00926 - Terminal 30
      Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
      Part No: 1J0 920 906 K
      Component: KOMBI+WEGFAHRSP VDO V02
      Coding: 07232
      Shop #: WSC 00000
      VCID: 3064E4A3DAB3
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway KCAN 0001
      Coding: 00006
      Shop #: WSC 01317
      VCID: F0E4A4A39A33
      Address 46: Central Conv. Labels: 1C0-959-799.lbl
      Part No: 1C0 959 799 C
      Component: 1G Komfortgerát HLO 0003
      Coding: 00258
      Shop #: WSC 01317
      VCID: 3776DFBF3FDD
      Part No: 1C1959801A
      Component: 1G Tõrsteuer.FS KLO 0002
      Part No: 1C1959802A
      Component: 1G Tõrsteuer.BF KLO 0002
      Part No: 1C0959811A
      Component: 1G Tõrsteuer.HL KLO 0002
      Part No: 1C0959812A
      Component: 1G Tõrsteuer.HR KLO 0002
      10 Faults Found:
      01330 - Central Control Module for Central Convenience (J393)
      53-10 - Supply Voltage Too Low - Intermittent
      00928 - Locking Module for Central Locking; Front Driver Side (F220)
      54-10 - Incorrectly Equipped - Intermittent
      00929 - Locking Module for Central Locking; Front Passenger Side (F221)
      00930 - Locking Module for Central Locking; Rear Left (F222)
      00931 - Locking Module for Central Locking; Rear Right (F223)
      01331 - Door Control Module; Driver Side (J386)
      01332 - Door Control Module; Passenger Side (J387)
      01359 - Internal Central Locking Switch; Passenger Side (E198)
      27-10 - Implausible Signal - Intermittent
      01333 - Door Control Module; Rear Left (J388)
      01334 - Door Control Module; Rear Right (J389)
      Address 56: Radio Labels: 3B7-035-1xx-56.lbl
      Part No: 3B7 035 180
      Component: Radio NP2 0007
      Coding: 04031
      Shop #: WSC 01025
      VCID: DDBAED177DA1
      2 Faults Found:
      00668 - Supply Voltage Terminal 30
      01305 - Databus for Infotainment
      37-10 - Faulty - Intermittent
      End ---------------------------------------------------------------------
    2. Member GTI Junkie's Avatar
      Feb 10th, 2011
      2003 Jetta Wagon
      09-13-2011 07:37 PM #2
      how much is the seller asking for it?
    3. 09-13-2011 07:45 PM #3
      $3500, but seems to be inclined to negotiate - just want to know what I'm getting myself into. Seems like the electrical issues stem from the same issue - bad grounding somewhere.
    4. Member GTI Junkie's Avatar
      Feb 10th, 2011
      2003 Jetta Wagon
      09-13-2011 08:13 PM #4
      hmmm, I thinks that's too much for it, I paid 3600 for mine and it didn't even had a cel on, I would get it if it were a great bargain.
      Electrical problems can turn into a nightmare, sometimes they seem an easy fix, if you're good with car electric stuff and he gives you a price you can't refuse, go for it.
      GL
    5. Member Shaniqua's Avatar
      Oct 14th, 2008
      Sweet home, Alabama
      '00 Cabrio, '02 Passat
      09-13-2011 08:35 PM #5
      i would not buy it for $3500. maybe for 1500 if the body was perfect
    6. 09-15-2011 08:47 PM #6
      Any ideas on the issues? I'm pretty handy mechanically and the body and interior are in very good shape.
