VWVortex.com - TDI stuff
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 33
    Thread: TDI stuff
    1. Member 95 avus blue's Avatar
      Jan 9th, 2007
      00 Jetta TDI, 01 Jetta TDI, 14 CRV, 09 JSW TDI 6 spd.
      09-14-2011 01:13 PM #1
      PD100 injectors. $400
      PD 150 Inj w some broken pins, will need service * * * * $150
      PD 100 AC compressor $100
      PD150 EGR hose $40
      ALH down pipe with cat $140
      Oil filter cap
      ALH Pancake pipe $25
      ALH EGR cooler pipes $75
      ALH ABS pump $90
      ALH Dog Bone in very good condition. $40.
      ALH down pipe wth cat from ALH. $140
      ALH AC line 55.00
      ALH Vacum pump 70.00
      ALH Vacum ball/Reservoir 15.00
      ALH Cam sprocket from 30.00
      ALH Injection pump/ Alternator bracket 100 shipped.
      ALH Upper timing belt cover $45
      ALH Lower Tim belt cover 45.00
      ALH Metal timing cover pieces 20.00
      Fuel filter holder 25.00
      Fuel filter Tee 5.00
      Windshield Washer Reservoir 25.00
      Turbo oil return line (less than 5k miles) 55.00
      Valve cover oil cap (Castrol Brand) 40.00
      Airbox to intake hose 35.00
      Airbox snorkel. 35.00
      Power steering reservoir 40.00
      Motor mounts 35.00
      Black Grey cloth armrest 75
      Grey leather arm rest 75
      AC Condensor from 05 Golf TDI 75
      Intercooler hose upper 65.00
      intercooler hose lower (aluminum). 75.00
      Coolant Reservoir with cap 15.00
      Castrol Valve covet Oil Filler cap 20.00
      Oil Filter housing cap. 20.00
      00-02 (4) window motors * $100
      Sold. ALH Temp sensor housing with coolant glow plugs. Sold
      Sold.ALH valve cover sold
      Sold. Alternator 140 amp sold
      I have the cylinder head, camshaft, lifters, bearings, cam, injectors from an 04 Golf with 60k miles. All parts are in excellent condition.
      01 Silver Arrows Jetta,front is damaged. Door onwards is fine.
      All parts are or best offer.
    2. Member TheVolksracer's Avatar
      May 25th, 2004
      cleveland, ohio
      1995 jetta 2.0 16VT, 2001 TDI, 1989 Audi 200
      09-14-2011 06:44 PM #2
      i am interested in your alh engine harness. is it from an early or late model car. i have the early style needle lift in mine
      thanks
    3. Member 95 avus blue's Avatar
      Jan 9th, 2007
      09-14-2011 07:24 PM #3
      It's from an 01 ALH Jetta.
    4. Member 95 avus blue's Avatar
      Jan 9th, 2007
      09-30-2011 01:26 PM #4
      Quote Originally Posted by TheVolksracer View Post
      thanks
      Still inerested in the harness?
    5. Member 95 avus blue's Avatar
      Jan 9th, 2007
      10-04-2011 10:52 AM #5
      120A alternator is sold.
    6. Member 95 avus blue's Avatar
      Jan 9th, 2007
      10-06-2011 09:45 PM #6
      Sold one Oem downpipe.
    7. Member 95 avus blue's Avatar
      Jan 9th, 2007
      10-07-2011 08:39 AM #7
    8. Member 95 avus blue's Avatar
      Jan 9th, 2007
      10-12-2011 11:41 AM #8
    9. Member 95 avus blue's Avatar
      Jan 9th, 2007
      04-20-2012 11:14 AM #9
      TTT.
    10. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      04-22-2012 08:13 AM #10
      Year and miles the vac pump came out of?
    11. Member 95 avus blue's Avatar
      Jan 9th, 2007
      04-22-2012 10:10 AM #11
      From an 01 Jetta, pump has 50k miles.
    12. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      04-22-2012 02:00 PM #12
      damn low miles.
      have the belly pan and side covers that it attaches to?
      was it an auto or manual?
      oil pan?
    13. Member 95 avus blue's Avatar
      Jan 9th, 2007
      04-22-2012 02:23 PM #13
      Yes, the side covers aren't in the best shape, but works just fine.
      They are from a manual car.
    14. Member 95 avus blue's Avatar
      Jan 9th, 2007
      05-06-2012 10:08 PM #14
      ALH fuel lines are sold.
    15. Member 95 avus blue's Avatar
      Jan 9th, 2007
      05-08-2012 09:50 PM #15
      R32 MAF housing, and Accordian pipe are sold.
    16. 05-10-2012 06:54 AM #16
      Is the lower intercooler pipe you have the upgrade to get rid of the pancake pipe. I have a 2004 BEW with upgraded turbo and I was told I should get the upgrade that isn't the pancake.
      Thanks,
      John
    17. Member 95 avus blue's Avatar
      Jan 9th, 2007
      05-10-2012 10:43 AM #17
      Quote Originally Posted by JStriz View Post
      Thanks,
      John
      John,
      It is the pancake pipe that I'm selling. It's an aluminum one from a PD130.
    18. Member 95 avus blue's Avatar
      Jan 9th, 2007
      05-12-2012 11:44 PM #18
      TTT.
    19. Member 95 avus blue's Avatar
      Jan 9th, 2007
      06-01-2012 12:26 PM #19
      Replied.
    20. Member 95 avus blue's Avatar
      Jan 9th, 2007
      06-07-2012 11:05 AM #20
    21. Member 95 avus blue's Avatar
      Jan 9th, 2007
      06-29-2012 07:53 AM #21
    22. Member 95 avus blue's Avatar
      Jan 9th, 2007
      07-11-2012 03:40 PM #22
    23. Member 95 avus blue's Avatar
      Jan 9th, 2007
      08-23-2012 03:47 PM #23
      Replied.
    24. Member rallydiesel's Avatar
      May 10th, 2006
      SK
      2006 Jetta TDI, 1981 Rabbit, 1991 Jetta TD (sold)
      09-15-2012 11:46 PM #24
      Is that four pd150 injectors?
      Once you go "clack", you never go back.
    25. Member golfs4life's Avatar
      Sep 10th, 2007
      Windsor, ON, Canada
      2000 Golf TDI, 07 Rabbit
      09-16-2012 08:19 AM #25
      Valve cover in good condition?
