VWVortex.com - air bag light on my 1990 cabriolet why is it on?????
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 29
    Thread: air bag light on my 1990 cabriolet why is it on?????
    1. Member MKIIICDogg's Avatar
      May 23rd, 2008
      Pennsylvania
      2000 VW Passat 1.8T & 1990 VW Cabriolet 1.8 N/A
      09-15-2011 02:40 PM #1
      so it seems every year my cabriolet needs something fixed minor or major luckily its been minor for the past few years but my air bag light came on solid whenever i run the car and i dont understand why. it just came on out of the blue can anyone help me as what i should diag? its not the airbag itself i already tried a different airbag and it didnt fix it
    2. Member CajunSpike's Avatar
      Mar 11th, 2009
      New Orleans, LA
      91 Burgundy Etienne(2), 06 Jetta 2.5, 08 GTI 2.0T FSI
      09-15-2011 02:54 PM #2
      The light on means theres a fault in the airbag system. You can try to reset the light, but if there is a real problem, the light will just come on again.
      If you didn't reset the system after the airbag replacement, the light would just say on whether you fixed the problem or not.
      After any repair, it has to be reset so it can self test again.
      Read up.
      http://forums.vwvortex.com/showthrea...%E2%80%99s-how.
    3. Member 4supreme2gambino0's Avatar
      Mar 25th, 2009
      92' cabby, 73'slammed standard, 69' BayWindow, 66' rag beetle
      09-15-2011 03:00 PM #3
      The light will automatically come on every 10k miles, it was set up by VW that way so the customer would come back into the dealership to have it reset as "routine maintence". It doesnt necessarily mean anything is wrong with the airbag system at all. To top it off it requires an "OBDI" scanner and the traditional scanners of today are "OBDII" so it will not work. OBDI scanners are pretty much obsolete, so good luck finding one. There are other ways to get it to turn off by messing with the comp and wiring, but Im not about to get into that one. Mine has been on for 5 yrs now and do not intend on getting it turned off unless I come across an OBDI scanner.
    4. Member CajunSpike's Avatar
      Mar 11th, 2009
      New Orleans, LA
      09-15-2011 03:19 PM #4
      Hey gambi, read up on that link I posted. We found a way to do a reset with a couple of wires and/or a specific pc program and the right cables.
    5. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      1986 Cabriolet Best Seller; 1990 Vanagon Westfalia; 2016 Golf GTI S
      09-15-2011 03:41 PM #5
      You can also read more airbag info at: http://cabby-info.com/airbag_system.htm .
      Cabby-Info.com -- Your online guide to VW Cabriolets/Rabbit Convertibles
      Old Blue's Blog -- The adventures of a 1990 Westfalia
      "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
    6. Member MKIIICDogg's Avatar
      May 23rd, 2008
      Pennsylvania
      09-15-2011 04:00 PM #6
      i'd like to just delete it as stated on cabby-info but i dont know where the connector is that is pictured in the link with the spliced wires does anyone know where that is and if you do possibly direct me in the right way or take a picture of the connector so i can get a feel for what connector ill be modding
    7. Member MKIIICDogg's Avatar
      May 23rd, 2008
      Pennsylvania
      09-15-2011 04:02 PM #7
      Disconnect the battery.
      Disconnect the wire harness connectors (#14 and #16 in the image above) located below the fuse/relay panel. On the smaller connector (#14 in the image above), find the two black wires that connect to T6/3 and T6/4 and splice them together (splice them without cutting, or cut both wires and splice all four ends together and system restoration is as simple as reconnecting the controller harness). Click here for a picture example.
      directions from cabby-i
      i bolded the portion in question
    8. Member CajunSpike's Avatar
      Mar 11th, 2009
      New Orleans, LA
      09-15-2011 04:04 PM #8
      On my cars, that flat connector passed so close to the fuse box, it was held in place by a plastic clip, TO the fuse box.
      The wires in that connection didn't go thru the fuse box...but it was in very close proximity.
    9. Member MKIIICDogg's Avatar
      May 23rd, 2008
      Pennsylvania
      09-15-2011 04:04 PM #9
      http://reflectionsandshadows.com/cab...-bypass-03.jpg
      and theres the site with the picture
    10. Member MKIIICDogg's Avatar
      May 23rd, 2008
      Pennsylvania
      09-15-2011 04:06 PM #10
      @cajunspike yo is the one with the goofy red clip inbetween the connection because thats the only one i saw really O.I.T.O and it is connected the metal housing of the fuses
    11. Member 4supreme2gambino0's Avatar
      Mar 25th, 2009
      09-15-2011 04:20 PM #11
      Quote Originally Posted by CajunSpike View Post
      Werd...
    12. 09-15-2011 04:26 PM #12
      Hey CDogg,
      Did that work for you? I tried, but my airbag lights stayed on.
    13. Member MKIIICDogg's Avatar
      May 23rd, 2008
      Pennsylvania
      09-15-2011 04:29 PM #13
      im gonna f- with it tmrw at work see if it works or not worth a shot
    14. Member MKIIICDogg's Avatar
      May 23rd, 2008
      Pennsylvania
      09-15-2011 04:32 PM #14
      @ho_ is it the connector on the fuse panel?
    15. Member MKIIICDogg's Avatar
      May 23rd, 2008
      Pennsylvania
      09-15-2011 04:34 PM #15
      alla nswers were received thank you cajun
    16. Member tolusina's Avatar
      Oct 18th, 2004
      '95 Ranger, '74 Gitane Pista
      09-15-2011 04:37 PM #16
      Quote Originally Posted by 4supreme2gambino0 View Post
      The light will automatically come on every 10k miles, it was set up by VW that way so the customer would come back into the dealership to have it reset as "routine maintence".......
      Bull. Repeat.
      Such a scheme as you've posted is likely illegal as well.
      Bull.
      Quote Originally Posted by ho_mgnt View Post
      Hey CDogg,
      Then you did it wrong, read the instructions again, it's not complicated.
      http://reflectionsandshadows.com/air-bags/
      Quote Originally Posted by kamzcab86
      I hate reading: "But I bought this car for $500 and don't want to put another dime into it."
      ____(hey, it's VW AND it's electrical, what's not to fail?) neoBentley+
    17. Member MKIIICDogg's Avatar
      May 23rd, 2008
      Pennsylvania
      09-15-2011 04:39 PM #17
      http://www.the152.com/modules.php?na...adee244c0a9887
      if anyone has q's this shoold answer them
    18. Member CajunSpike's Avatar
      Mar 11th, 2009
      New Orleans, LA
      09-15-2011 04:46 PM #18
      Even if you correctly reset the airbag system...the lights will come on again IF there is an actual problem still existing.
      If there is NO current problem after reset, they still stay off.
    19. Member MKIIICDogg's Avatar
      May 23rd, 2008
      Pennsylvania
      09-15-2011 04:49 PM #19
      i dont need an airbag anyway! lol the car is unsafe as a car can be to start its an old convertible! all we got goin for us is the nice thick sheetmetal and middlebracebar
    20. Member 4supreme2gambino0's Avatar
      Mar 25th, 2009
      09-15-2011 04:50 PM #20
      [QUOTE=tolusina;73557961]Bull. Repeat.
      Bull.
      QUOTE]
      Wrong, read your owners manual pal.
    21. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      09-15-2011 05:48 PM #21
      [QUOTE=4supreme2gambino0;73558184][QUOTE=tolusina;73557961]Bull. Repeat.
      Bull.
      I have read the owners manual and It isn't in it.
      Matter of fact get your facts straight.
      I feel safer in my mk1 than any other car I drive. I have been rear ended, t-boned, and front smacked in a mk1 and drove away every time.
      Grounds, Grounds, Grounds Replace them things.
      Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
      Another Useless Ground Thread
      HAVE YOU CHECKED THE FAQ's ABOVE..PAGE 3 Thread 75? Why bother no one else does.
      You can lead a user to a link, but you can't make them click.
    22. Member CajunSpike's Avatar
      Mar 11th, 2009
      New Orleans, LA
      09-15-2011 05:51 PM #22
      I was rear ended by a full size F150 doing about 20 and only had a crumpled fender to show for it.
      The very fact that it is a convertible means it has additional strength and bracing that other cars don't have.
      If it was any other car, the whole back end would have been crushed.
      I think my car is very safe.
    23. Member tolusina's Avatar
      Oct 18th, 2004
      09-15-2011 06:29 PM #23
      Quote Originally Posted by tolusina View Post
      Bull. Repeat.
      Bull.
      Post a screen shot or photo of your owners manual to back up your statement and I'll apologize for calling bull, until then, Bull.
      Consider, if 10k, then to the dealer was true, "air bag lights are on on my '90 to '93 Cabby" threads would be as common here as "my fuel pump is noisy" and/or "my '80 to '89 CIS runs bad, I gots no Bentley, timing light, dwell meter, injector seals or idle o-ring what do I do now with no time, money or effort?" threads by '80 to '89 owners.
      My owner's manual is long gone, I am trying to steam open the pages of my '92 - '92 Maintenance book, until then............
    24. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      09-15-2011 08:03 PM #24
      Totally glossed over this one:
      No where have I ever encountered ^that statement in bold. No way, no how would Volkswagen (and Siemens for that matter) set up a time interval like that. That's absurd; customers would've been extremely put-off by something like that (Mk4 CELs, anyone?). The lifespan of the airbag is 10 years; the lights come on when there is a fault detected in the system and/or the 10-year time frame has elapsed. There should be a sticker on the sun visor giving the 10-year interval date as to when the airbag should be replaced.
      "Every 10K..." Good one. Yeah, I'd like to see a scan of the page that states that.
    25. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      09-15-2011 08:28 PM #25
      I have read and re-read the Air bag section on my 92 and 93 Cabriolet's Owners manual, and re-read the 1990 one and the "closest" they come to anything related to a time interval is on pg 25 of the 93.
      "To assure continued reliability, the airbag system must be inspected by a qualified Volkswagen technician 4 and 8 years from the date of manufacture appearing on the safety compliance sticker (left doorjamb) and every two years thereafter. See your Authorized dealer"
      That is a bit more than every 10K.
      But I understand that it was Bush's fault and not yours.
      Seeing how it is only warrantied for 10, after 10 it would definitely be on you.
