Results 1 to 19 of 19
Thread: DYI: Homemade ram air intake and heat shield
    Oct 22nd, 2008
    Ohio
    08 TSI Passat
    09-15-2011 03:17 PM #1
    decided i didnt want to pay a arm and a leg for an intake so i decided to make one. everyone likes the design of the carbonio with the ram air sealed design so i decided to give it a try.
    small black plactic trash can, black oil funnel duct tape and loctite plastic epoxy
    used painters tape to mark off section of the trash can needed to cut. tape was just used the follow a straight line while cutting
    cut the bottom of the can just smaller than the diameter of the funnel that that the lip of the funnel cant pul through
    now cut the funnel to allow 3" piping to fit through
    no its time to glue. from the inside i used duct tape to hold the two pieces together then used the plastic epoxy to bond the pieces. this does hold up very strong i pushed on it with over 20lbs of force and it didnt come apart.
    i cut a small 2" slit in the side to allow theslide over the whole factory ram air duct
    6" long piping and a AEM dryflow filter. just slip the intake through the large end and out the small and secure to the MAF with silicone couplers.
    All for right around $80 with filter and all supplies. im sorry and no offence to anyone who has bought or any manufacture but im not paying $200-300 for a filter on a stick!
    08 Black TSI Passat /ABT lip/HI-DEF side skirts and spoiler/Color matched rear bumper/Rokkor coilovers/19" Black RS4 wheels
  2. Member SDbirdman's Avatar
    Jan 20th, 2011
    San Diego, CA
    2010 Candy White Passat 2.0 TSI
    09-15-2011 10:41 PM #2
    props. do you notice any gains?
    Unitronic Stage 2 -- 42DD 3" catless downpipe -- votex front lip -- HiDef side skirts -- painted rear valence -- mkvi wheel w/DSG paddles -- DDM HID headlights -- Euro side markers -- Interior & licence plate LEDs -- Skyline style Euro Tail Lights -- Podi gauge and pod kit -- revision D diverter valve -- Eibach DG springs (waiting to be installed)
    Oct 22nd, 2008
    Ohio
    08 TSI Passat
    09-16-2011 12:26 PM #3
    Quote Originally Posted by SDbirdman View Post
    Yes right away. Throttle responce has greatly improved and the car def pulls harder up top.
  4. Member ruetzal's Avatar
    Dec 17th, 2007
    Wisco
    '13 WRX, 2009 A3 sold, '03 GTI sold
    09-16-2011 01:15 PM #4
    great timing on this was looking for a cheap alternative. I can understand why you wanted to make the flow to the filter but couldn't you just keep the filter open too? instead of making the air ducting to the bumper. I would thing just a open filter would probably still take in enough air without the air tunnel?
    Oct 22nd, 2008
    Ohio
    08 TSI Passat
    09-16-2011 02:44 PM #5
    Quote Originally Posted by ruetzal View Post
    I made this to simulate the design of the apr carbonio and the forge twintake. both of these intake are completely sealed and have a ram air duct connection to the front bumper. the sealed design helps prevent the intake from sucking in hot air from the engine bay and only getting cool air from outside.
  6. Member ruetzal's Avatar
    Dec 17th, 2007
    Wisco
    09-16-2011 02:53 PM #6
    gotcha
    any chance of rain water getting sucked thru the intake with the ram air duct?
    Oct 22nd, 2008
    Ohio
    08 TSI Passat
    09-16-2011 02:57 PM #7
    gotcha
    just as much as the other manufactures
  8. Member Aguilar's Avatar
    Jan 28th, 2006
    El Paso, TX
    02 Z06, 93 MX-5 LE, 2013 GTI
    09-17-2011 04:33 PM #8
    You get Internet points for ingenuity.
  9. 09-17-2011 08:10 PM #9
    Quote Originally Posted by uber_mkv View Post
    Instead you paid $80 to put a trash can under your hood. To each their own.
  10. Member
    Jun 3rd, 2003
    SF Bay Area
    2011 VW GTI DSG Autobahn
    09-17-2011 08:13 PM #10
    nice attempt at recreating a Modshack intake, but his looks much better im afraid. Velocity stack, all kinds of heat reflecting materials, top notch.
    2013 Dodge Charger SRT8 Superbee
    LastHumansGarage
  11. Member D-OriginalTopshotta's Avatar
    Mar 16th, 2004
    T.Dot
    2007 Jetta 2.0t, 2007 Passat 2.0t
    09-17-2011 10:19 PM #11
    Quote Originally Posted by placenta View Post
    DIY on this?
    Jun 3rd, 2003
    SF Bay Area
    09-17-2011 10:21 PM #12
    Quote Originally Posted by D-OriginalTopshotta View Post
    DIY on this?
    its not a DIY.. its an actual product for sale.
    LastHumansGarage
  13. Member
    Oct 22nd, 2008
    Ohio
    08 TSI Passat
    09-17-2011 11:11 PM #13
    true it does look better but they still want almost $250. and yes it is technically a trash can but at the end of the day it still works for a fraction of the cost. the only thing i could do to make this better would be to use some sort of heat reflecting material on the inside of the filter housing.
  14. Member ruetzal's Avatar
    Dec 17th, 2007
    Wisco
    09-18-2011 10:08 AM #14
    Top Notch? for 250 they could have at least gave you a place to attach that breather tube
    An intake is cheap as He** to make since all it is is a mandrel bent tube with a filter at the end. The most it will do is give you a better sound from the DV! the hp gain is so minimal most people don't even notice.
    I would rather spend the money on a chip and at least I would get HP. Most I will probably do is buy the tube and get a filter! Once the air hits the turbo it heats up extremely quickly anyway, especially on these small turbos.
  15. Member VR6 BELIEVER's Avatar
    May 26th, 2004
    2009 GTI
    10-10-2011 03:39 AM #15
    Quote Originally Posted by MR2ToVW View Post
    I was thinking it, but you typed it. LOL
  16. Member
    Oct 22nd, 2008
    Ohio
    08 TSI Passat
    10-10-2011 09:00 AM #16
    Anyone have a better idea on material to use? IMO the fact that it started off as a trash can dosnt really matter. It is a pre molded piece of plastic that is easy to work with. I'm open to more ideas
  17. Member kaban's Avatar
    Nov 11th, 2005
    NoVA
    mk5 tsi hatchback
    10-11-2011 04:45 PM #17
    Props to the op for taking the time to put this together. Although I think my k&n drop in will work just fine I give props for your work sir.
  18. Member kaban's Avatar
    Nov 11th, 2005
    NoVA
    mk5 tsi hatchback
    05-02-2012 11:55 AM #18
    Curious to know how this home made intake held up.
  19. Member
    Oct 22nd, 2008
    Ohio
    08 TSI Passat
    06-05-2012 08:25 AM #19
    Quote Originally Posted by kaban View Post
    Its still on my car and working great.
