Results 1 to 18 of 18
Thread: 2011 No-Charge Maintenance: When are the oil changes?
  1. Junior Member
    Jul 18th, 2011
    2011 Routan SE Race Van; 2009 Saturn Aura XR
    09-16-2011 11:28 AM #1
    So in July, we bought a new 2011 Routan SE which includes the "no-charge" Carefree Maintenance for the first 36,000 miles.
    At 2,000 miles we took it in for the "2,000 Mile Courtesy Check" where they went over the vehicle and fixed a couple of minor things (loose antenna and loose rear door interior light).
    Well this week, VW mailed me a notification telling me that is time for my "no-charge 4,000 mile Carefree Maintance." So I called the service department to ask what is done at the 4,000 mile service and they said "Nothing, if you already came in for your 2,000 Mile Courtesy Check."
    So I asked them, when is my first oil due and they said "8,000 miles." I thought is was supposed to be 6,000 miles between oil changes.
    So what should be done at 4,000 miles and when should I get my first oil change (under the no-chare Carefree Maintenance program)?
  2. Member JETwagen's Avatar
    Mar 1st, 2002
    York, PA
    2002 Jetta Wagon GLS 2.0L 5-speed, 2010 Routan SEL w/RSE
    09-16-2011 12:23 PM #2
    Talk to your service department. I was told by my local dealer either when the "change oil" display comes on or 6k miles from last change, whichever comes first. Did they perhaps change your oil at the 2k checkup and that's why they told you 8k miles?
    I drive a wagon... even if you beat me, can you brag about it?
    - Mike (previosly vwsr2cool)
    | 1000th Post | DodgeForum.com | Xbox Live: JETwagen |
  3. 09-16-2011 12:33 PM #3
    Does anyone have the service intervals for this van? (60k timing belt? Etc) I just bought a used one and am drinking through the firehose right now. It probably would be a good idea to put this in the FAQ if someone has it.
  4. Junior Member
    Jul 18th, 2011
    09-16-2011 01:07 PM #4
    Quote Originally Posted by JETwagen View Post
    I did talk to them ... that was the source of the confusion. They did not change the oil at the 2K check-up.
    I was thinking oil change at 6K, but when "she" said "8K" that threw me for a loop.
    Jun 27th, 2007
    58 Ragtop Bug, 2005 Passat Wagon, 2010 Routan SEL
    09-16-2011 01:15 PM #5
    Quote Originally Posted by Trail Ryder View Post
    2011 3.6VVT engines have an 8K oil change interval or 6 months, the older 3.8L and 4.0L had a 6K change. Follow the oil change reminder on your start up when you get the extra ding and you gauge cluster says "Change Oil".
  6. Member
    Jun 23rd, 2011
    Roswell, GA
    2005 Passat GLS TDI, 2009 Routan SEL
    09-16-2011 02:18 PM #6
    Quote Originally Posted by TheSpatulaOfLove View Post
    What year and motor? The 3.6L Pentastar engine on the '11 and '12 MY has 4 chains, I believe. The 3.8L is a pushrod so should have a short timing chain. The 4.0L has a timing belt which has 102k mile interval.
    Most of the service interval information is included in your manual. I'd check there for OCI, coolant flush, transmission fluid, brake fluid, etc.
  7. 09-16-2011 04:36 PM #7
    Our change oil light came on at about 3500 miles. Brought it into the dealer and all they did is reset it claiming first oil change is at 6K. I called VW to verify and they old me 8K miles.
    Jun 23rd, 2011
    Roswell, GA
    09-16-2011 04:51 PM #8
    Quote Originally Posted by rmilchman View Post
    What does the manual say? Given some of the things I've heard from VWoA and VW dealerships, I wouldn't fully trust what they told you. Some vehicles have a break-in oil from the factory and the first OCI is much shorter than regular OCIs, so it wouldn't surprise me if the first OCI was closer to half of normal. If it were me, I'd probably pay to have the first one done at 3500-4000 miles. $30 bucks on a $25-$40k vehicle isn't a whole lot of money in the grand scheme of things.
    Jun 23rd, 2011
    Roswell, GA
    09-16-2011 05:10 PM #9
    Just looked at the 2012 DGC manual (free online - novel concept) and it says nothing about the first OCI being different than regular OCI. It says to change the oil at the sooner of 8k miles, 6 months, or within 500 miles of when the "change oil" light illuminates.
    I dunno, if it were me I'd probably still spend the $30 to have the first one changed at 4k miles. Brand new engine with virgin metal likely to have more contaminants suspended in the oil, would be my line of thought.
  10. Member JETwagen's Avatar
    Mar 1st, 2002
    York, PA
    09-16-2011 05:51 PM #10
    Quote Originally Posted by 58kafer View Post
    Wasn't aware of this, do you know if it is based on conventional oil or synthetic? My dealership put conventional oil in my '10 4.0L because synthetic was not required by the manufacturer (thus not paid for by VWoA), maybe the 3.6L gets synthetic?
  11. Junior Member
    Jul 5th, 2011
    North Carolina
    2011 Routon SEw/RSE
    09-16-2011 07:16 PM #11
    Last week my change oil light came on at 3600 miles and VW changed the oil with no charge. They told us that a maintenance bulletin came out which tells them to change the oil no matter what the mileage is if the change oil light comes on. It's due to the new pentastar v6 being "smarter" and tells them that it needs an oil change. Has anyone heard of this maintenance bulletin?
    Jun 27th, 2007
    09-17-2011 12:13 AM #12
    It holds 6 quarts of conventional. Check the rating on the fill cap. I think it's a new oil that's engineered to give better fuel economy and have extended change intervals. GF5 rating I think. It may even cost close to synthetic oil. But if you switch to synthetic you still need to make sure it meets the correct rating.
  13. 09-17-2011 11:07 PM #13
    Quote Originally Posted by Zambee500 View Post
    I have a 2010 3.8 (I believe). I just bought it 'Previously enjoyed', and didn't get a user manual - thus I turn to smart people on Vortex!
    I'm not being a smart ass here - I'm very happy with the wealth of knowledge found on this forum already...Just hungering for more!
    I know earlier Chryco minivans were plagued with trans issues, specifically because of fluid intervals being overlooked. I need this van to last me awhile, and I really don't want any big surprises. That's why I was asking for the interval information, hopefully in FAQ form so others may benefit.
    Thanks for the quick response about the timing belt/chains.
  14. Member
    Jun 27th, 2007
    09-17-2011 11:40 PM #14
    If you would like a copy of the paper manual that goes in the glove box PM me your email address, I have it scanned in to my PC in PDF form. It's for a 2010, but covers the 3.8 and 4.0 it looks like. Although it looks like we missed page 70 that is for the maintence schedule, but that can be scanned in before I would email you.
  15. Junior Member
    Jul 18th, 2011
    09-18-2011 09:21 PM #15
    Well, the mystery is over. At 3,500 miles, the CHANGE OIL notification just started coming on.
  16. Junior Member
    Apr 29th, 2011
    2011 Volkswagen Routan SE w RSE
    09-19-2011 01:18 AM #16
    The oil change intervals on the 2011 Routan with the 3.6 liter engine is 8,000 miles. I too received the 4,000 mile card, and I too was told conflicting stories before I talked to a dealer that knew the facts.
    Our 2011 "Change Oil" came on around 3,800 miles, and Volkswagen did a free oil change.
    I believe what was stated above - no more than 8,000 miles, but if the change oil comes on before then, Volkswagen will cover it.
  17. Junior Member
    Jul 18th, 2011
    09-19-2011 11:52 AM #17
    Quote Originally Posted by NCrsx View Post
    Mine came on at 3,500 miles.
    Does anyone know the number of the maintenance bulletin?
    I am going in on Thursday (this week) for an oil change and the dealer says that I will have to pay for it: $65 per oil change!!! It will probably be less, as I will be taking in my own Mobil 1 Synthetic. But $65??? After the "no charge" maintenance runs out, I don't think that I will be visiting the dealer for oil changes.
    My 2009 Saturn includes free oil changes for life (dealer promotion, not GM).
  18. Junior Member
    Jul 18th, 2011
    09-22-2011 08:39 PM #18
    ... the dealer says that I will have to pay for it: $65 per oil change!!! It will probably be less, as I will be taking in my own Mobil 1 Synthetic. But $65??? After the "no charge" maintenance runs out, I don't think that I will be visiting the dealer for oil changes.
    Well, I went in today with 3,658 miles on the odometer expecting to pay for an unscheduled oil change. They performed a 6,000 mile service (oil change and tire rotation) for no charge (warranty). Weird.
