Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Results 106 to 140 of 291
Thread: ABA Fox build
    Feb 7th, 2011
    Dudley, MA
    1987 VW aba Fox, 1977 Chevy ElCamino, 7 jetskis...
    10-20-2011 08:54 PM #106
    2011-10-18_09-40-31_826 by ChevyAndVW, on Flickr
    ^ "cutting corners" i had to remove the teeth and trim the end that bolts to the block down and flip around to work.
    Feb 7th, 2011
    Dudley, MA
    10-20-2011 08:57 PM #107
    2011-10-20_14-06-43_988 by ChevyAndVW, on Flickr
    drives perfect and ALOT of power. well worth the time and $ and fyi... dont get POR-15 on ur hands or it will stay for a week...
    Feb 7th, 2011
    Dudley, MA
    10-20-2011 09:03 PM #108
    well 1st "documemnted" FULL ABA fox swap??? runs good. ill post some videos and pics tomorrow. and ill be at BrokeDown..
  4. Member
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    10-20-2011 10:16 PM #109
    nice. that's so weird seeing the a3 intake manifold in a longitudinal setup.
    I really suck at smog.
  5. Member Banned wagon's Avatar
    Mar 3rd, 2004
    2013 Model S P85s Outback 89 4Runner 90&89 fox wagons 89 4door fox 89 2Door GL Fox
    10-20-2011 10:53 PM #110
    Good job way to make quick work on this swap. I think you can still buy the dual outlet manifold (Bfi) you just need to make a dp
  6. Member
    Feb 14th, 2007
    Allentown PA
    1993 VW Fox 1994 Chevy S-10
    10-20-2011 11:22 PM #111
    for getting it running. I am impressed. It looks very clean. Looking forward to seeing how you get a hood to close.
  7. Member themagellan's Avatar
    Mar 30th, 2007
    NorthShore, MA
    1991 Audi 200 20vt Quattro
    10-21-2011 09:24 AM #112
    Quote Originally Posted by Edcon91 II View Post
    can't wait to check this thing out, You "could" cut the piping so it has a straight air inlet, the filter would be in the front passenger side.
  8. Member 90quattrocoupe's Avatar
    Feb 6th, 2002
    Long Beach, CA.
    90 Audi S8coupe, 90 Fox Wagon, wife's 2008 CW R32, kid's 89 2l 16V gli, 2010 Jetta TDI
    10-21-2011 12:59 PM #113
    you could vent the hood in the rear, where the battery was, and put an airbox there, ala Sport Q. Higher pressure at the bottom of the windshield than the front of the car. For the hood, you could get the bubble from Mitsu Eclipse. Would look clean. Not like the pictures posted earlier.
    Greg W.
    They have my car when they pry my dead cold fingers from the steering wheel.
    Feb 7th, 2011
    Dudley, MA
    10-23-2011 06:19 PM #114
    so... NEVER use SeaFoam..... i ran the ABA for the whole day with no issues at all. since reading all the good things about this bullshyt in a can i decided to use it on the new-used aba. well i read all about how to properaly use it in the vaccum line and only used a 1/3 of a can VERY slowly and blew somthing. motor smoked like it sould with the seafoam and after it was ticking and making a bunch of different random noise. after all the seafoam was out all it did is smoke oil.. like a quart an hour.
    located a aba 2 hours away with a low 94k miles for less $ and a warenty. after getting off the phone we left to go grab the engine in the broken aba fox. since i have no back seat we got there and motor fit right in the back. what a smokey ride! and didnt get pulled over with no hood and all the smoke.
    got engine back. stripped it down. next day (yesterday) pulled the broken aba in like 45 mins. took off the intake and other good parts off the old engine put them on the good engine and installed the engine. took the car for a ride and seemed so slow! and the clutch was slipping a little.
    after figuring out and a bunch of tests. it was only the distributer. we retimed the new engine but the distributer was F-ed up. so the engine was like 20 degrees off. took the old 1 off and replaced. at 1am it was done. just in time for Broke.Down vw show. just came back from the show and car ran great. just will need a clutch soon. which i figured.. and TheMagellan it was very nice meeting you and talking. thank you for all the support and i gotta check out the car meets in Salem sometime.
    so basicaly my friend and I did put 2 ABAs in a Fox in 7-8 days. 1st and 2nd ABA into Fox swap?? heh. the hp increase is well worth the time.
  10. Member
    Feb 7th, 2011
    Dudley, MA
    10-23-2011 06:22 PM #115
    also. ill be cutting the hood to fit the aba and doing a hood like the mustang in the in movie Gone In Sixty Seconds. should look good. ill post more pics.
    and in the near future ill start an other thread on turboing my aba. any questions please feel free to ask. i didnt get into too much detail.
  11. Member
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    10-23-2011 06:31 PM #116
    that's weird and unfortunate. i swear by seafoam, but it's too expensive nowadays. recently, i've just been using water.
    Feb 7th, 2011
    Dudley, MA
    10-23-2011 07:11 PM #117
    2011-10-21_17-24-48_564 by ChevyAndVW, on Flickr
    ^ new engine delivery via Fox with the old messed up engine
  13. Member
    Feb 7th, 2011
    Dudley, MA
    10-23-2011 07:16 PM #118
  14. Member Banned wagon's Avatar
    Mar 3rd, 2004
    10-23-2011 07:54 PM #119
    I still question the hp gains of the crossflow stock (for now) aba compared to a aba with big valve head. But I am enjoying your build
  15. Member
    Feb 7th, 2011
    Dudley, MA
    10-23-2011 08:05 PM #120
    i was saying huge hp increase going from a stock engine vs the aba in the fox. i had a mk3 2.0 and the fox with the aba is wayyyy faster. no lie it felt same or faster than a couple of stock vr6s ive drivin.
  16. Member
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    10-23-2011 08:35 PM #121
    nice. the fox should be around 600 pounds lighter i'd imagine. even if you're losing your top end power with the single outlet manifold, it's still slightly more power than a stock low comp 1.8.
    can't wait to see your turbo build.
  17. Member
    Feb 7th, 2011
    Dudley, MA
    10-23-2011 08:47 PM #122
    thank you. the aba isnt staying this way for long. cam and turbo very soon. looking for the parts now. i need a quantum turbo diesel manifold. cant seem to find 1. this will be another budget build. sooo i gotta find the parts for cheap. even tho it wont be very cheap. but im working on it...
    308937_10150876253330316_869450315_20837864_126544 900_n by ChevyAndVW, on Flickr
    this hood?? ^ i gotta make somthing soon...
  18. Member
    Feb 7th, 2011
    Dudley, MA
    10-23-2011 08:50 PM #123
    i need a clutch soon. any suggestions? or turbo suggestions or parts finds for older vws
  19. Member
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    10-23-2011 08:53 PM #124
    dang. I never even thought about that when I was planning my original turbo build. I had the turbo and manifold (with the 5th runner cut and welded) from an audi 5000, but it got stolen.
    Would have been smart to grab that when I got a 9q.
    I'm imagining the whole manifold/turbo/downpipe is a direct bolton for the fox? Wonder what that small turbo would do. I'm planning on keeping cis-e, so 160whp is all I'd be after anyway. Sounds like a real elegant solution!
    were there turbo diesels for all years of quantums?
  20. Member themagellan's Avatar
    Mar 30th, 2007
    NorthShore, MA
    10-24-2011 12:26 AM #125
    car was awesome! You guys were definitely cool people, I'm sure we will be in contact soon- i'll look around for that chip!
    One my friend with the 4k snapped
  21. Member sippin.fnordies's Avatar
    May 22nd, 2011
    Portland, OR
    1989 VW Fox 2-door, 1979 VW Dasher 4-door
    10-24-2011 12:51 AM #126
    Quote Originally Posted by ChevyAndVW View Post
    Congratulations! You've succeeded in somehow making the nose of a Fox EVEN MORE BOXY! j/k Seriously though, nice fix. Also nice write-up and awesome swap. It kind of reminds me of a fox body mustang a bit.
  22. Member
    Feb 7th, 2011
    Dudley, MA
    10-24-2011 08:43 PM #127
    very nice pic of my car at brokedown btw! it was nice seeing you
    the quantum turbo parts i need are bolt on.
    the pic of the black "elenor" hood is photoshoped but it looks good and more boxy lol so i guess ill be trying to find that piece. today i cut the hood. also my intake pipe finaly came in. so thats hooked up now. and tossed that dumb oil beather and ran a catch can. "rock star" can right now. but i will be putting a "busch" beer can cuz its what i drink and its blue lol
  23. Member
    Feb 7th, 2011
    Dudley, MA
    10-24-2011 08:44 PM #128
    2011-10-24_19-50-14_578 by ChevyAndVW, on Flickr
    ^ the engine barely sticks out!! alot less than i thought it would
  24. Member
    Feb 7th, 2011
    Dudley, MA
    10-24-2011 08:44 PM #129
  25. Member
    Feb 7th, 2011
    Dudley, MA
    10-24-2011 08:45 PM #130
  26. Member
    Feb 7th, 2011
    Dudley, MA
    10-24-2011 08:48 PM #131
    still got some more to do. since the idle stablizer has a new location it idles real low and stalls out somtimes. so gotta fix that and make an exhaust shield or intake box things around my air filter.
  27. Member
    Feb 7th, 2011
    Dudley, MA
    10-24-2011 09:23 PM #132
    and hood scoop...
  28. Member Banned wagon's Avatar
    Mar 3rd, 2004
    10-24-2011 09:26 PM #133
    That's not too bad. Is that with stock motor mounts and unmodded subframe?
  29. Member
    Feb 7th, 2011
    Dudley, MA
    10-24-2011 09:35 PM #134
    stock motor mounts and subframe. i used windweld in the side mounts and a 80 stiffness front mount from TT. but thats irelevent. same motor mount height. i guess you could relocate and fab up different mounts and use hokey pucks on the sub frame and it should fit. i might try this in the future.
  30. Member Banned wagon's Avatar
    Mar 3rd, 2004
    10-24-2011 09:41 PM #135
    Use e30 mounts and shim the sub frame & trans mount down the rest of the way with large washers. drill new holes for the front mount. with the understructure cut out on the hood. you might not even need to lift the rear of the hood or cut at all.
  31. Member
    Feb 7th, 2011
    Dudley, MA
    10-24-2011 09:53 PM #136
    thats probaly what ill do. e30 mounts are stiffer and lower. just a little moding and it will work. i have a brand new hood from vw so i didnt feel too bad cutting this hood for now. when i do the turbo i might do this.
  32. Member doppelfaust's Avatar
    Aug 15th, 2007
    Tacoma, WA
    1988 Fox GL Wagon
    10-24-2011 10:44 PM #137
    I have to admit, I am quite impressed. I can honestly say you are the first person in several years to discuss a motor swap and actually complete it, kudos!
    Looks like the hood clearance shouldn't be too difficult to overcome.
  33. Member
    Feb 7th, 2011
    Dudley, MA
    10-24-2011 11:27 PM #138
    thank you. i have big plans for this car. already with the aba. its faster than the g60 Corrado i used to have. just doesnt handle as good. but that will come in time. when i do decide to lower the engine i think it might help a very little with the handling. im not changing the appearance too much. want it to perform and look clean and simple. also i want the most power and perforamce for short $.
  34. Junior Member bigdaddykool99's Avatar
    Jan 13th, 2011
    long island ny
    91 fox 05 cadi dts
    10-25-2011 04:29 PM #139
    now i want to pull my motor
  35. Member QuantumSyncro's Avatar
    Apr 28th, 2000
    Des Moines, IA
    97 Jetta TDI, 89 Fox diesel, 92 300SD turbo, 82 GS1100E
    10-25-2011 07:56 PM #140
    Quote Originally Posted by ziddey View Post
    Yes, the Audi 5 cyl exh mani is same pattern as 4 cyl with the 5th runner cut off and welded closed, same for the intake too on engines with same side int / exh ports. The audi exh mani puts the turbo near the front of the engine rather than back and down low like MF longitudinal exh mani ala quantum / 4000 TD, but that also means there's less fussing with the frame rail too if there's a conflict.
    82-85 Quantum had turbo D engine, Audi 4k from 82-83.
