Page 8 of 9 FirstFirst ... 4 5 6 7 8 9 LastLast
Results 246 to 280 of 291
Thread: ABA Fox build
  1. Member j-boogie253's Avatar
    Nov 30th, 2009
    Tacoma, WA
    90 Fox, 91 Jetta, 98 A4 (RIP)
    01-24-2012 07:12 AM #246
    Quote Originally Posted by ziddey View Post
    http://www.autohausaz.com/search/pro...20Cable%20Part
    this guy. got one coming on thursday myself. swear i got one before but not sure where it went.
    That's the crappy foam one that will deteriorate over time
    THIS ONE is better quality
    If you were a Volkswagen....who would your owner be?
    Feb 7th, 2011
    Dudley, MA
    1987 VW aba Fox, 1977 Chevy ElCamino, 7 jetskis...
    01-24-2012 02:29 PM #247
    perfect beause i dont know how long the zip tie will hold hah.. it happened at night on the Mass Pike, in rush hour; the pedal went to the floor... luckly i had 1 random zip tie in my car to make it home... and drive around. i was thinking of making a better design thats stiffer for like .001% faster throttle responce with like a clip on the end or somthing.
  3. Member j-boogie253's Avatar
    Nov 30th, 2009
    Tacoma, WA
    01-24-2012 02:34 PM #248
    That "plastic" one I posted is much stiffer than the foam one and should work great. I got one installed on my Fox. I had to squeeze it in with channel locks it was so stiff
  4. Member
    Feb 7th, 2011
    Dudley, MA
    01-24-2012 06:33 PM #249
    perfect ill order that 1. the piece is cheap and small but $8 for shipping?
    maybe theres some other stuff i can order
    took my fox for a long ride on back rds. drove great. just trying to keep only 1/3 throttle is hard. but i gotta break in the clutch correctly
    Feb 7th, 2011
    Dudley, MA
    01-24-2012 06:59 PM #250
    just ordered the bushing and some other small idems. like striker pins. shipping stayed the same so i feel better about it hah
  6. Member
    Feb 7th, 2011
    Dudley, MA
    02-20-2012 10:29 PM #251
    started cutting and welding the Corrado seats to fit the fox WHAT A PAIN!!
    Untitled by ChevyAndVW, on Flickr
  7. Member simon_C's Avatar
    Oct 4th, 2006
    SFBAY
    1983 Rabbit GTI
    02-20-2012 11:05 PM #252
    Quote Originally Posted by ChevyAndVW View Post
    hey i recognize that vice clamp! we made those in my welding class here.
    You just need to narrow the mounting legs an inch or so to fit the fox right?
    How does a rotary work? This one's easy: the magic triangle spins in the peanut and then apex seals come out.
  8. Member doppelfaust's Avatar
    Aug 15th, 2007
    Tacoma, WA
    1988 Fox GL Wagon
    02-20-2012 11:35 PM #253
    Wow, those are rusty!
    Feb 7th, 2011
    Dudley, MA
    02-20-2012 11:51 PM #254
    you need to cut like 3/8 on both sides.. i can double check tomorrow or next day when i have time to finish the other seat... you also need to cut some of the sheet metal part on the outside of the seat... and i cut off the lap belt part since i wont be using it. its very hard to weld were u need to weld after it is cut. i also cut to seat part clip part and lowered it. i guess i could start a how to thread but maybe its already posted? not really worth the time to do this but i love the look and comfort of the G60 seats.
    and yes very rusty... the seats where actually sitting outside...i got them this way... but for free!! and the vinyl and cloth part cleaned up perfectly!. so im just going to clean up the rust after everything is finished
  10. Member
    Feb 7th, 2011
    Dudley, MA
    02-23-2012 02:20 PM #255
    good place for a much needed fire extinguisher. just in case...
  11. Member
    Jan 22nd, 2006
    DCI CO
    87 Cabby
    02-24-2012 12:24 PM #256
    Top #1 mod everyone should be doing.
  12. 02-24-2012 12:45 PM #257
    Why are you cutting and welding?It took me all of 15 minutes with 4 whacks of a BFH to fit them in my wagon.
  13. Member
    Feb 7th, 2011
    Dudley, MA
    02-27-2012 08:09 PM #258
    Quote Originally Posted by blkparati View Post
    how do the seat slide? does the seat still adjust? it seemed like wayyy too much bending. idk. welding isnt so bad. any chance i get to weld i do. its fun lol
  14. 02-28-2012 09:02 PM #259
    Everything worked as they should.Not much bending at all really.
  15. Member
    Feb 7th, 2011
    Dudley, MA
    03-01-2012 10:12 PM #260
    1 seat is done. im kind of slacking. and have other things and projects going on. but i might just try bending the second seat... theres not much to weld to.
    also. picking up another 4speed tranny and putting the final drive out of a 5 speed. should work wonders. but i need to finish getting injectors, chip, intercooler piping, and tires (not sure what tires to get) etc
    also i found out Delorean rims are 4x100! the rears are 15s and wide. so a stretch with these would be nice.. down the rd, not my 1st priority tho.
  16. Member simon_C's Avatar
    Oct 4th, 2006
    SFBAY
    1983 Rabbit GTI
    03-01-2012 11:23 PM #261
    you can get NOS delorean rear wheels for 270 each here
    http://www.delorean-parts.com/Mercha...egory_Code=650
    i would think the offset would be terrible though.
  17. Member
    Feb 7th, 2011
    Dudley, MA
    03-02-2012 07:55 PM #262
    thats were id order them from. i still have more things i gotta purchase 1st. power>looks heh idk about the offset but im keeping my options open. i want some sort of stock, light, rare, direct bolt on rims. right now i have BBS RA's and Corrado Sebring's. i like the sebrings myself but everyone i talk to like how the bbs looks on the fox. im looking for some new tires. somthng very grippy of course
  18. Member
    Dec 16th, 2005
    Williamsburg, VA
    1993 Volkswagen Fox 4-door, 2012 Ford Focus SE Sport 5MT
    03-02-2012 09:05 PM #263
    I like the Sebrings a lot myself. And I think they look great on Foxes.
    Post some pics of the seats once they're installed.
  19. Member
    Feb 7th, 2011
    Dudley, MA
    03-21-2012 10:24 PM #264
    decided to go with Trans Am GTA rims with adaptors and doing a stretch. =D
  20. Member
    Feb 7th, 2011
    Dudley, MA
    03-21-2012 10:26 PM #265
    new stance =D
  21. Member
    Feb 7th, 2011
    Dudley, MA
    03-21-2012 10:27 PM #266
    new stance. backs after tires and tires but winter mode in the back and burnout tires in front
  22. Member ODEL's Avatar
    Oct 26th, 2009
    MA
    03 Jetta Wagon; 94 Saturn SW2 (RIP)
    04-29-2012 07:16 PM #267
    subscribed
  23. Member vwturbofox's Avatar
    Jul 31st, 2010
    washington,everett
    1989 vw fox gl turbo, Holset hy35 on meth:)new project 1968 bug
    04-30-2012 01:39 AM #268
    hey i used to have my fox in that same stance looks good and looks bada$$
    old look
    [IMG][/IMG]
    new look
    [IMG][/IMG]
  24. Member
    Feb 7th, 2011
    Dudley, MA
    05-04-2012 03:06 PM #269
    some body work done. had to get it back from the body shop to cruise to Staggered. then back in the body shop Monday....
  25. Member
    Feb 7th, 2011
    Dudley, MA
    06-26-2012 05:28 PM #270
    installed Corrado seats.. finally.. much better. makes me miss my Corrado tho =/
  26. Member
    Feb 7th, 2011
    Dudley, MA
    06-26-2012 05:32 PM #271
    need to lower the back..
  27. Member
    Feb 7th, 2011
    Dudley, MA
    08-31-2012 04:40 PM #272
    10.1 brakes coming sooooooooon! just in time for H2O and hopfuly turbo.
  28. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    1998 Jetta GT, 1998 GTI 2.0, 2012 GLI, 2012 GTI
    09-03-2012 11:31 PM #273
    Thinking of doing one of these, but I don't want a hole in my hood. Anyone use a SRI or a different intake manifold to clear the hood?
    If you want to make your 2.0 8v faster, read the thread below!
    http://forums.vwvortex.com/showthrea...owerful-2.0-8v.
  29. Member
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    09-03-2012 11:41 PM #274
    Quote Originally Posted by Hurt View Post
    Are you fixed on running the ABA crossflow head? You could use a Fox2 or other big valve counterflow head. It's still a competitive head compared to the ABA, especially if you're considering a little port work.
    I am imagining that even with bmw e30 motor mounts, it'd still be too tall.
    A SRI or similar would definitely help with the hood clearance issues. But with the radiator, alternator, and clutch cable right there, you will probably still have tough fitment issues.
    I really suck at smog.
  30. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    09-04-2012 06:18 PM #275
    No, but I prefer the ABA 8v head or a 8v hydraulic lifter head.
  31. Member
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    09-04-2012 06:54 PM #276
    All Fox heads are hydraulic
  32. Member Hurt's Avatar
    May 3rd, 2011
    Boston, MA
    09-04-2012 09:49 PM #277
    I've never worked on a Fox before. Does the ABA block bolt up to the Fox head/trans?
  33. Member doppelfaust's Avatar
    Aug 15th, 2007
    Tacoma, WA
    1988 Fox GL Wagon
    09-04-2012 11:52 PM #278
    Yep, you'll need a 2.0 16v head gasket to put the counterflow head on but it bolts right to the transmission
  34. Member efritsch's Avatar
    Aug 21st, 2002
    Kitchener
    1992 Passat Syncro Wagon, 1987 Fox Wagon (Project)
    09-05-2012 08:21 PM #279
    Why do you need a 16v headgasket to bolt put a counter flow head on an ABA block?
    Quote Originally Posted by 90quattrocoupe
    I am old enough that I only have to be nice when I want to.
  35. Member
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    09-05-2012 08:31 PM #280
    It's been a while and I'm hazy on it too. I seem to recall 16v or 3a headgasket, because of the coolant passages.
    I do remember also reading that all ABA HGs are MLS, and it'd be way cheaper than getting an MLS 16V, so ?!?! However, I can say that the ABA I pulled did not have a MLS HG on it.
    I got most of my parts years before I put my ABA together, but I believe I found a 16V HG. I had to cut off the hole for the locating pin, because it was too small compared to the one on the ABA.
