VWVortex.com - Roof Rack?
    Page 3 of 8 FirstFirst 1234567 ... LastLast
    Results 51 to 75 of 199
    Thread: Roof Rack?
    1. Member cheapa55TDI's Avatar
      Sep 30th, 2011
      2012 Passat TDI SE
      01-12-2012 02:31 PM #51
      Looks great! It's scary to think they didn't make one bc the roof is not strong enough to hold it.
    2. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      01-12-2012 02:42 PM #52
      Quote Originally Posted by Paul@KefferVW View Post
      The reason Vw is not designing a roof rack is because the roof was not designed to handle weight.
      The strange part about that is that the Passat handled the roof crush tests better than any other car in its peer group:
      http://www.iihs.org/ratings/roof/detailsbyclass.aspx?30
      20,592 lb peak force.
      "To measure roof strength, a metal plate is pushed against one corner of a vehicle's roof at a constant speed. The maximum force sustained by the roof before 5 inches of crush is compared to the vehicle's weight to find the strength-to-weight ratio. This is a good assessment of vehicle structural protection in rollover crashes."
    3. Former Advertiser Parts@DeanMcCraryImports's Avatar
      Jul 6th, 2011
      Daphne, AL
      1998 Jetta TDI, 2012 MK6 Golf
      01-12-2012 02:50 PM #53
      Quote Originally Posted by cheapa55TDI View Post
      My guess is it was more of a monetary decision. How many roof racks would VW have to make and sell for it to be cost productive. My guess is based on what the demographics of what VW expected the Passat owner to be, the made a business decision that they would not sell enough roof racks to justify production......Just a guess!
    4. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      01-12-2012 03:18 PM #54
      So no roof rack here hence none from VW?
      http://www.toyota.com/camry/accessories.html
    5. Member Turbonium20V's Avatar
      Jun 30th, 2002
      Virginia
      2015 GTI SE 4Dr DSG
      01-12-2012 08:35 PM #55
      Quote Originally Posted by Bud@DeanMcCraryImports View Post
      Totally agree, the Passat's roof is stronger than all other cars on the crush test. I don't see anybody having problems with racks on the B7.
    6. Junior Member
      Nov 28th, 2011
      Colorado
      B7 3.6 SEL Premium
      01-13-2012 12:27 PM #56
      That doesn't explain the admonishment in the user manual (http://forums.vwvortex.com/showthrea...1#post74709632). It's not just that VW is not making a roof rack for the Passat, they are warning us to not use any roof rack on the Passat. I am quite puzzled by this and I still wonder if there is any legitimate reason for them to warn us against putting on a roof rack, or if it's just a CYA because they didn't want to test any roof racks.
    7. Former Advertiser
      Oct 28th, 2009
      Huntersville
      01-13-2012 12:37 PM #57
      Quote Originally Posted by miff View Post
      As stated previously the roof on this car was not designed to support a roof rack. That does not mean that if you put one on the car the roof will fold like a soft taco. I would venture to say the people in VWOA Accessories would not give up on designing a roof rack for what VW projects is going to be their #2 seller in the nation. Most likely what happened was that when the car was engineered they did not keep roof racks in mind. Causing them to building car that was not structurally intended support the weight on the roof. This would mean the Accessory team would not be able to make roof racks for legal reason.
    8. Member jsmyle1%...'s Avatar
      Jun 6th, 2006
      '15 PP GTI; '89 Cabriolet
      01-13-2012 09:29 PM #58
      I tend to believe this hypothesis.
      Most VW models (GTIs, Golfs and previous body style Jettas) had a hole manufactured into the inside of the frame of the roof (where the door closes). The hole is covered by a plastic screw-like cap that simply needed to be "backed out" prior to installing the front cross bars of an OEM rack.
      The NA B7, unfortunately, is devoid of this design feature. As a result, VVOA is adamantly against a roof rack of ANY kind.......at least for now I suppose.
      I wouldn't be surprised if the mysterious hole mysteriously appears for '13.
    9. Member Rdeuce's Avatar
      Jun 29th, 2006
      Rocky River, OH
      2012 Passat tdi, 1993 SLC
      01-13-2012 10:17 PM #59
      Agreed. I am not trying o sell the Yakima system or anything but compare the mounting points between the 2 pictured system. The Yakima rack does not mount or rest on top of the roof's sheet metal but more on the structural edge of the roof line. Seems stronger to me.
      Dropped about 3-4 mpg btw.
    10. Member
      Apr 16th, 2011
      ny
      01-14-2012 02:09 PM #60
      Item
      Unit Price
      Qty.
      Cost
      thule-480R [remove]
      $170.96 +/-
      $170.96
      thule-544 [remove]
      $53.96 +/-
      $53.96
      thule-ARB53 [remove]
      $134.96 +/-
      $134.96
      thule-KIT1669 [remove]
      $62.96 +/-
      $62.96
      Subtotal:
      $422.82
      Total:
      $422.82
      u can preorder set form thule for 2012 vw passat it willbe available in march as foot kit with rubbers is in production now
    11. Member
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      01-16-2012 01:07 AM #61
      Quote Originally Posted by jsmyle1%... View Post
      Nope, not going to happen. There are only a few changes happening for 2013 Passats and thats not one of them.
      Jul 19th, 2010
      Hopatcong NJ "we're lake people"
      2008 Tuned Rabbit
      01-19-2012 12:45 AM #62
      do tell, what changes, and also like i asked a long time ago, when can we buy a '13?
    13. Member jsmyle1%...'s Avatar
      Jun 6th, 2006
      01-22-2012 04:16 PM #63
      Rdeuce,
      In an effort to avoid starting a whole new thread, maybe you can attempt to answer a concern of mine regarding the Yakima setup.
      What are the chances of me being able to get away with using the VW OEM bike carriers with the the Yakima cylindrical bars? The OEM bike carrier has two different options: 1) the type that has the hex bolts that slide into the OEM bars or 2) the "clamping" type setup that I have successfully used with a Honda Odyssey rack system.
      Am I to ASSume that if clamped properly (front and rear), it won't matter if its a cylindrical, rectangular, or square bar?
      Learn me...
      Thanks in advance.....
    14. Member Rdeuce's Avatar
      Jun 29th, 2006
      Rocky River, OH
      01-25-2012 08:01 PM #64
      My set up is a clamp on and the Yakima bars are cylindrical. I don't see why your OEM bike carriers wouldn't work with the cylindrical Yakima bar. If it doesn't work, the bike carriers aren't to pricey. Does that help answer your question? If not reply back to the thread
    15. Member jsmyle1%...'s Avatar
      Jun 6th, 2006
      01-26-2012 08:36 PM #65
      Quote Originally Posted by Rdeuce View Post
      Guess I'll be taking a leap of faith of sorts.
      I'm sure all will be just fine.
    16. Member
      Apr 19th, 2007
      CT
      02-06-2012 10:51 AM #66
      I'm waiting for someone to post that they took their Passat in for one of the free oil changes while the car was fitted with a rack, and the service manager hands them an invoice for the maintenance with a note at the bottom informing them that their warranty is void.
    17. Member jsmyle1%...'s Avatar
      Jun 6th, 2006
      02-06-2012 02:06 PM #67
      Quote Originally Posted by brian81 View Post
      Not a chance Sir.
      It just can't happen like that...... Hypothetically speaking, if your A/C stopped working, the warranty CANNOT be denied due to the presence of a roof rack.....APR software......tinted windows.....20" alloy wheels......leopard-skin seat covers.....unless the specific dealer can PROVE the modification in question caused the failure.
      Jus' sayin'......
    18. Member Rdeuce's Avatar
      Jun 29th, 2006
      Rocky River, OH
      02-06-2012 05:23 PM #68
      Once set up initially, it only takes a minute to break down and put back up.
    19. Member gwernerjr's Avatar
      Dec 12th, 2011
      Richmond VA
      2011 Touareg TDI Exec
      02-06-2012 09:20 PM #69
      The part numbers listed lead me to believe that the euro passat is only a face lift. To my knowledge the us made passat is not being exported, and is a design on its own.
      The US passat is the same passat from China; Actually with far less than the chinese version. But don't be fooled by the Chattanooga plant. The car is chinese not german; It just uses some german parts..
    20. Member gwernerjr's Avatar
      Dec 12th, 2011
      Richmond VA
      02-06-2012 09:23 PM #70
      I guess the chinese don't ski, bike, or surf haha! They made a car meant to not have racks... yikes! Although I doubt it would void the warranty as it just states not to overload the roof; Not anything about voiding the warranty just because you put something aftermarket on the roof. Then every car with a thule would have a voided warranty..
    21. Member
      Apr 19th, 2007
      CT
      02-07-2012 09:26 AM #71
      Not a chance Sir.
      Jus' sayin'......
      I agree completely...and appreciate your response knowing you work at one of the best dealers in the US.
      My point was merely that at some point somebody who never heard the term "Moss Magnuson" will get their weenie pulled by some big fish in a dixie cup service writer, and that, as we all know here is wrong on several levels. It happens and will continue to happen.
      I have about a dozen VW dealerships within an hour of me, and they range from a world class store that the factory would be pleased to represent them in Wolfsburg to a couple so slimy that "stealership" would be a legitimate complement. Having lived here almost 20 years, nothing posted on vortex surprises me as far as how customers are treated.
      Now ...let's rack 'em up...
    22. Member jsmyle1%...'s Avatar
      Jun 6th, 2006
      02-14-2012 11:34 PM #72
      Well....I did it!..... I ordered the Yakima rack....FINALLY.
    23. Former Advertiser Parts@DeanMcCraryImports's Avatar
      Jul 6th, 2011
      Daphne, AL
      02-15-2012 06:11 PM #73
      As I am told ALL the time, It's not true without pictures!
    24. Member jsmyle1%...'s Avatar
      Jun 6th, 2006
      02-15-2012 09:17 PM #74
      Wanna see the order??........Oooooooh-kay....
      Austin Canoe & Kayak
      11604 Stonehollow Dr #300
      Austin, TX 78758
      512-687-3055
      888-828-3828
      customer@austinkayak.com
      www.austinkayak.com
      We are happy to inform you that #XXXXXXXXXX has been shipped.
      We have shipped your order via UPS and you may track your order at http://www.ups.com or by using tracking number(s) below.
      UPS estimates your order will take 3 business days to arrive. This is an estimate provided by UPS based on your shipping destination. Actual transit time may vary. Blah...blah....blah..
      AND.....
      Dear JSmyle:
      Thank you for shopping at Jenson USA!
      This note is an acknowledgement of the following order:
      Order #: XXXXXXXX
      Order date: Feb 11, 2012 at 7:22 AM
      Shipping method: Standard Shipping
      Estimated shipping date: Feb 13, 2012
      Estimated delivery date: Feb 21, 2012
      Yakima Fairing 44" (RA299Z03 44) $69.00
      Yakima Cross Bar(Pair), 58" (RA299Z04 58) $70.00
      Yakima Q-Tower Black, 4 Pack (RA298Z64BLK 4) $159.00
      Subtotal: $298.00
      Sales Tax: $0.00
      Shipping: $0.00
      Oversize Charges: $0.00
      Order Total: $298.00
      You asked for pics!
    25. Member Rdeuce's Avatar
      Jun 29th, 2006
      Rocky River, OH
      02-18-2012 08:22 AM #75
      I thought the 58 crossbars were too long. I have one 48 and one 58 (cut to 52ish).
