its been a while, but here is a little vid my friend came up with. Oh and I have power slot slotted rotors and geenstuff brake pads in the trunk right now.
#72
#74
#75
Time for an update.
Since I last posted in this thread I have installed power slot slotteed front rotors and greenstuff pads front and rear. Great set up for the price.
Also I deleted my muffler and put on techtonics tuning exhaust tips, I had them turned up a little. I really like the noise itand how it pops.
I put 2.0fsi coilpacks and integrated engineering adaptors.
Unfortunatly my diverter valve blew yesterday. So a forge 007 is in the mail as of right now.
Thats pretty much it on with the pics
I also got around to polishing the shaft so it would match all the polished parts of the gated shifter
A quick question as well. I saw PLAYED's build thread and noticed that all of the lines ontop of the motor had been removed. I pmed him and he said he relocated them to underneath his battery. Does anyone have a DIY on how to do this?
Pic for reference all of the stuff in the black circle
#76
Also my Thule 757 is up for sale
http://forums.vwvortex.com/showthrea...e-757-For-Sale
#77
Some new stuff
Forge 007
My friend and I polished my charge pipe.
Any advice on how to make the charge pipe pop a little bit more? It just looks like bear metal right now.
#78
I would just get a silicone one in whatever color looks the best.
#79
No one makes a silicone replacement but forge does bake a polished one thoe
#80
#81
#82
Oh charge pipe. Gotcha. You could get it ceramic coated is some cool color. Other then that I would just let it be
#85
I havnt updated this thread in a while!
I havnt been at my house for over a month, but when I get back alot of things are happening to the TT.
Heres a little exhaust vid my friend shot a couple months back.
Enjoy.
#87
Its been a while looking good so what's next![]()
http://forums.vwvortex.com/showthrea...t-done-I-guess
^^^Big Turbo build lots of pics^^^
Best shop for repair and custom workin ma
http://www.wentworthmotorsports.com/
#88
Haha it has been a while. I don't know what's next really. Im definatly going lower front and rear. After that clean up the engine bay by relocating all of the vac lines. I also scored a nardi wheel which I will put on soon. Other than that nothing, but im sure ill think up something else to drain my wallet some more.
#89
wd40 and like 1000-2000 sandpaper
its like wet sanding for polishing metal
works good
DubCult _ Florio Special _ S3
#91
The mk2 wheels look awesome, I always liked them and wondered how'd they'd look on our TT
N249/vac delete: http://forums.vwvortex.com/showthrea...-1-N249-delete
(note: you do not need a resistor for the project, just keep the N249 plugged in and tucked away in the engine bay, same goes for the N112 evap valve, if you decide to ditch the SAI stuff as well)
#92
#95
Awesome work! I'm watchin!
Hella4 | GermanPlates | ADstudio Custom Banner Ads | Audi TT Bild | Need Retargeting or Display Advertising?
#96
Clean car, would be cleaner if you debadge the rear!![]()
| BENPURKISSDESIGN |
STANCE - Related words:
hellaflush-hellafail-stanced-stancing-mental retardation-beaners etc.
#97
#98
If you still need to do this, take a look at my latest fotki folder. Sorry, but they are not all neatly together and you may need to page thru all four to see the changes I made.
http://public.fotki.com/TTQ2K2/tt-engine/
The spaghetti mess you refer to are all of the vacuum hoses connected to the N249. While I didn't hide mine, I did replace all of those rubber hoses with silicone hoses. I could have moved the N249 by just using longer hoses where necessary.
I believe others have moved theirs, moved them to below the metal plate at the front of the engine (where the N75 is hiding), below the plastic plate at the oil dip stick. There is actually quite a bit of room there and it is easier to get to than say, below the battery, if you need to change things out at a later date.
The key is: the N249 is the center of the spaghetti hub. So, you only need longer hoses to got back to the DV (if it is in the original spot). Of the two hoses that go from the N249 to between the opening in the intake manifold, one is already connected to the N75 (below that metal plate) and the other is connected to a nipple on the bottom left-side of the intake manifold. All of the others are very visible so easy to run longer hoses.
You will need 3.5 or 4mm (I used 4mm as it is easier to find) for the two going thru the manifold. Use 6mm for the DV to N249 and 8mm for the others. The only one you will not replace with normal silicone, is the rubber y-connector that is on the right side of the N249 that has that little black valve attached to it.
If you decide to do this and have any questions, PM me.
cheers.
You don't own a TT, you support it: 2001 LZ7W coupe; REVO chip; Forge hoses and DV relo; MadMax DV; Modshack VTDA; BlueFlame Catback, OSIR corners, Forge bling, H&R, Bilsteins, DEFCON2, 986 seats, 18in OZ Vela II; OEM TTQS alcantara steering wheel, knob, ebrake; OEM: BBS RS IIs; roof rack; trunk rack; phone bracket; trunk mat; all weather floor mats; 4-piece Votex kit. My Mods here: http://public.fotki.com/TTQ2K2/. 2007 3.2 S-Line A3.
#99
^Thanks for that post,
I have run into a bit of a problem lately with my boost pressure.
About a week ago I was driving on the hwy and noticed that my car was exceptionally slow. I looked at my boost gauge and sure enough it was only putting out 5 psi vs. the normal 18psi.
I immeadiatly came to the conclusion that it was a boost leak, but I couldnt hear a leaking sound. Evrything was spooling up just find and then it just flatspots at 5psi.
I just remembered that during the track day I did two weeks ago I got a cel. Someone at the track scanned it for me and gave me the code. I looked it up and it had to do with the maf. It didnt effect performance so he just cleared it
I didnt have another cel until about 2 days ago when another one popped up which im guessing its for the maf.
So my question is do you think my maf is causing the boost failure? I tried cleaning the maf, but that didnt do anything.
Any ideas?
#100
Anybody? I just ordered a new maf. Hoping that will cure it.
#101
So on my way to work this morining I get on the on ramp to the hwy and what do you know, my car decided to give me my boost back after 3 weeks. Oddest car I have ever seenhaha
#102
Some new photos with the front set down a little and the rear perches removed:
Untitled by Brennan L Aust, on Flickr
Rivalry by Brennan L Aust, on Flickr
#103
Looks great!
| BENPURKISSDESIGN |
#104
#105
I sniped this guy from across the street and parked next to him. I couldnt pass up this photo opp.
Sorry for the absolutly hideous cell phone quality shot.
