Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 106 to 140 of 157
Thread: Black Forest Industries 18 Hour Swap: MK1 VR6
  1. Junior Member
    Apr 22nd, 2010
    81 Rabbit, 88 jetta carat vr6
    12-22-2011 06:49 PM #106
    very nice, are the stage 3 kits ready, to be ordered want to extra safe with the vrt... im really excited for this kit i think it will be a hit cause alot of people now want a mk1 vr which is a pain in the ass, untill now but when building a car i dont think money is really an issue. its all about the love!
    Aug 2nd, 2007
    LAX
    McCaddy
    12-22-2011 07:53 PM #107
    I need VR6 in my life...
    nicely done!
  3. Member VWM4YH3M's Avatar
    Sep 20th, 2011
    where it rains... PDX
    slammmerreddd 84 GTI, adidas
    12-22-2011 08:09 PM #108
    Quote Originally Posted by grippymonkey View Post
    nicely done!
    Who doesn't
    THE ONLY BAGS I USE WRAP AROUND MY 40oz LOWcal whORse. VOLKSWAG'N
    SECONDS FROM THE END, WHATS IT GONNA BE?
    PULL THE TRIGGER BITCH
  4. Member TM87's Avatar
    Dec 30th, 2008
    Windsor CT
    VW
    12-22-2011 08:40 PM #109
    I was admiring deathhare, now eurowise and bfi
    AbaT vs VR. Temptation temptation temptation.
  5. Member VWM4YH3M's Avatar
    Sep 20th, 2011
    12-22-2011 10:28 PM #110
    ^^^^^^ il like too see
  6. Member T-Giv's Avatar
    Mar 13th, 2011
    Crawlorado
    1984 Rabbit 16V SOLD, 1982 Caddy 20V 1.8t, 2011 Jeep Wrangler JK
    12-22-2011 10:39 PM #111
    I'll donate my mk1 to the next vr6 swap!
  7. 12-22-2011 11:42 PM #112
    Quote Originally Posted by TM87 View Post
    A high compression 16v abf clone will make more power than a VR, and similar numbers to an abaT. Without a turbo. Now add a turbo.
  8. Member TM87's Avatar
    Dec 30th, 2008
    Windsor CT
    VW
    12-23-2011 01:18 AM #113
    Quote Originally Posted by etta gli View Post
    I was more thinking out loud. Ditch my abaT plans, sell the stuff and jump on VR bandwagon. Temptation temptation.
    Not which one is better/faster/cooler.
  9. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    12-23-2011 10:30 AM #114
    A high compression 16v abf clone will makesimilar numbers to an abaT. Without a turbo. Now add a turbo.
    Link to this NA ABF clone making 250+whp
  10. 12-23-2011 12:09 PM #115
    Quote Originally Posted by grizzlyone View Post
    Link to the NA VR swap making 250whp without MAJOR MONEY for internals. If you want to play that game you might as well put a turbo on both.
    Then watch the VR blow up
    You'll make 150whp out of both. Headerback on both, decked block on the aba 16v and matched cams. Now which costs more to mod, which costs more to turbo, which weighs more, and which is a filthy pig on fuel.
    This looks to be a really good setup, and definitely simplifies the swap. Combined with CE2 this would work really nicely, but I personally do not believe a VR belongs in a mk1. Now a ce2 mk2 coupe... that's a whole different story
  11. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    12-23-2011 02:51 PM #116
    You might want to go back and read what part of your statement I actually quoted and was asking for proof of
  12. 12-23-2011 03:03 PM #117
    went on a vr tangent
    u win
    but turbos cost money. I haven't seen any cheap 250whp abaTs. Though I'd love to, I can't decide between abaT and a built 16v.
  13. Member Two . Slow's Avatar
    Aug 4th, 2009
    wrightsville, PA
    82 caddy turbo diesel
    01-05-2012 01:19 PM #118
    how much more difficult would it be to use a ob2 vs obd1? im thining about this a lot and obviously you wouldnt use the ac and ps...what else can be taken off? im sure there is a bunch of emissions that can be deleted which id think would simplify wiring by a decent amount. also what is used for cooling? stock mk1 rad enought to keep a vr cool?
    thanks and well done!
    Quote Originally Posted by McSlo2.0 View Post
    Oh that and the fact that more rice has been showing up here lately than in the stir fry I just cooked for dinner
  14. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    01-05-2012 02:31 PM #119
    Quote Originally Posted by Two . Slow View Post
    OBD1 or 2 are about the same difficulty as far as wiring goes.
    You can delete EGR, SAI, cat and even rear o2 on the obd2 with the right chip.
    Deleting these things dont simplify the wiring at all. I deleted them on my swap and I actually think that the SAI pump probably wouldnt have fit anyway so it needs to go regardless probably.
    Many people have used a mk1 rad although IMO, the larger the better. Im running a Corrado VR radiator with two 12" slim fans, low temp fan switch and low temp thermostat.
  15. Member Two . Slow's Avatar
    Aug 4th, 2009
    wrightsville, PA
    01-05-2012 03:12 PM #120
    Quote Originally Posted by deathhare. View Post
    ok so deleting things is always the best but that frees up more room which is a plus. thanks for the info. my caddy is diesel so id need some sort of fuel pump i guess inline? and clean the tank..also stock mk1 brake booster? then a vr pedal cluster?
  16. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    01-05-2012 03:40 PM #121
    You should mount a rabbit CIS pump inline in the stock location. Works perfect.
    You cant use the VR pedal cluster. Use the stock rabbit one.
  17. 01-05-2012 04:10 PM #122
    DH did you run the dual speed fan wiring, or keep the oem rabbit fan wiring? Assuming you can delete the big under overflow fuse box if you use MKI wiring.
    LE6B
  18. Member bansheelos's Avatar
    Nov 29th, 2004
    Dirty Jer-Z
    94 Golf VR, 78 Bay Bus VR under const.
    01-05-2012 04:13 PM #123
    Quote Originally Posted by adam@blackforest View Post
    Like all VR's, including stock, yes the oil pan is quite low. I have talked with Mike about coming up with a shorter pan and pick up combo to offer as an option for the kit
    Like the R32 pan and p/u?
  19. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    01-05-2012 04:20 PM #124
    Quote Originally Posted by sk8ordie View Post
    I used the rabbit wiring.
    Quote Originally Posted by bansheelos View Post
    A little less than 13mm gained.
    Not really worth the cost eh?
  20. Member UghRice's Avatar
    Sep 8th, 2010
    nine seven hate
    Tank/Minivan, Parking space filler
    01-05-2012 04:21 PM #125
    Hmmm...you guys should use my car to show off how much power the stg3 can hold
    ICP DA BEST EVA <3333
  21. Member Two . Slow's Avatar
    Aug 4th, 2009
    wrightsville, PA
    01-05-2012 04:23 PM #126
    ok thanks for the help. got some thining and searching to do now.
  22. Banned vento86's Avatar
    Oct 13th, 2008
    01-05-2012 06:18 PM #127
    Quote Originally Posted by UghRice View Post
    the jawny jawn? get out of here ya mk4 owner
  23. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    01-06-2012 10:05 AM #128
    These kits are now available on our webstore.
    Stage 1
    Stage 2
    Stage 3
    Black Forest Industries /// 919.468.5400 ext. 7014
    PM, Facebook, E-mail, or call us with any questions
  24. 05-25-2012 12:52 PM #129
    We haven't had much time to dedicate to the VR6 Rabbit but we are determined to get it on track very soon!
    Since we last posted up we have :
    Installed Sparco seats and harnesses - made custom brackets
    Installed Ignition/Battery Kill Switch
    Finished and Painted Cage
    Installed Custom Gauges
    Installed Push Button Ignition
    Mounted Custom Oil Cooler
    Upgraded Brakes (Still waiting on new front Wilwoods)
    Modified Shifter for Custom Short Shift
    Raised the Shifter Box - Custom Brackets
    New hub and steering wheel are on the way - as well we are going to clean the car up and apply some livery.
    Here are a few shots of some of the progress
  25. Member Erthan's Avatar
    Sep 9th, 2011
    Hellertown, Pa
    VW Truck 16v
    05-25-2012 07:45 PM #130
    Car looks good, can't wait to see the livery.
    I woke up in a new Bugatti
  26. Member
    May 14th, 2009
    85 Cabby, 03 GLI 24v, mk3 Jetta
    06-02-2012 04:11 AM #131
    What rad are you guys running in your setup? Mike mentioned to me that they run the stock rabbit rad but flip it 180 degrees so the inlet/outlet are on the driver side... But I have yet to see pictures of it mounted and piped in.
  27. Member iceman2.0's Avatar
    Mar 28th, 2006
    W.Mass
    MANY,84 Jetta Coupe, CC w/DSG
    06-03-2012 08:18 PM #132
    1/2" is still better than nothing....
    What are you doing about the pan to road issue?
    He said I had a nifty little car. Oh, he did get me on not having a windshield washer reservoir..... luckly It only took me a minute to install it for a sticker. I brought it to a shop in Shelburne and the guy walked out of his office and said "No Way" just by looking at it
    Curbdawg
  28. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    06-03-2012 08:46 PM #133
    Quote Originally Posted by iceman2.0 View Post
    I live in south where the roads dont protrude upwards and ruin ****.
    Never had an issue but I know you guys in the NE have it bad in places.
  29. Member vwbull23's Avatar
    Nov 16th, 2006
    newport news VA (NJ = <3)
    2009 cc vr6 awd, 82 vr6 rabbit pickup 82 diesel rabbit pickup
    06-03-2012 10:36 PM #134
    this is awesome
    i am in the process of doing a vr6 pickup it funny i use to be a a 16v guy. but now i have 3 cars with vr in them i love my 3.6 cc and i cant wait to drive my pickup
  30. 06-04-2012 10:44 AM #135
    Quote Originally Posted by AWopGenius View Post
    Where do you think Mike got the idea from in the first place
    Yes our is using a stock MK1 rad flipped 180*. Made a simple top mount bracket and used the stock vr6 coolant hoses, slightly shortened.
  31. Member ncbrock's Avatar
    Sep 28th, 2010
    Raleigh, NC
    e36 M3 Sedan, M Coupe, FFR Cobra
    06-04-2012 02:05 PM #136
    you guys do the roll bars in house?
  32. 06-05-2012 11:04 AM #137
    Quote Originally Posted by ncbrock View Post
    We did indeed
  33. Member JCdubber's Avatar
    Sep 11th, 2005
    ansonia CT
    81VRthruthehood,1980MtGreen,86 cabby,86golf,64 choptop bug, +4 4door rabbits
    06-05-2012 11:34 AM #138
    i have been running mine with a flipped rabbit radiator with a single aftermarket electric fan wired on its own little harness using the stock thermoswitch for around 3000 hard miles...hard because i drive the crap out of my rabbit, and its nothing but fun all day. my temp has never gone over the center mark (except when the plug wasnt on it that one time )
    also, my bfi front engine mount is effortlessly handling the abuse i am throwing at it. though i just have a stock vr with a lsd, it people were still skeptical for some reason. i believed in you.
  34. Member
    May 14th, 2009
    06-05-2012 05:00 PM #139
    Haha, cool. Thanks.
    Quote Originally Posted by JCdubber View Post
  35. 11-08-2012 03:45 PM #140
    Well its been awhile since any updates, with all the shows and summer business its been hard to put time in on the car. But that has changed.
    We recently did a series of major engine work and upgrades: timing chains, guides, BFI cooling kit, BFI billet crack pipe, BFI lw flywheel and clutch kit, and a set of Cat cams.
    Along with a series of smaller things including: catch can, exhaust tweeks, and fab'd up some lower rear axle tiebars/adjusters
    A few pics:
    It will be vinyled up for its first track weekend on Sept 17th and GMP's Fallout track day at CMP
