VWVortex.com - Installed BFI Stage 2 Chip, ran great for 4 days, now idle problems & rev hang
    Page 5 of 16 FirstFirst 12345678915 ... LastLast
    Results 101 to 125 of 399
    Thread: Installed BFI Stage 2 Chip, ran great for 4 days, now idle problems & rev hang
    1. Member GloryFreak's Avatar
      Feb 19th, 2009
      North Carolina
      05 VW GLI 1.8t, 96 VW Golf 2.0, 90 VW Corrado G60
      10-18-2011 07:01 PM #101
      Updates?
      PTE 5858 @ 27 psi - 82mm Wisecos - Brute Rods - Supertech Valves w/ Gold Cat Springs - Gonzo BT mafless - Genesis 1000cc G2 Injectors - IECVA1 Cams - IE Adj Cam Gear - Custom Intake w/K&N - HKS SSQV BOV - 42 DD 3" TB Exhaust w/No Cat - Kinetic T3 Manifold - Tial 38mm WG - VF Mounts - Walbro 255 Inline - Fozen Boost FMIC - ECS LW Pullies - I.E. Manifold w/ 80mm TB - Devils Own W/M Stg 2 - HPA SS - WOT Box - FST LW Flywheel - Nitto 555R
    2. Member cm123's Avatar
      Jun 3rd, 2010
      Westchester/Long Island NY
      98 mkIII Jetta Wolfsburg(sold), 2005 Volvo s60R
      10-20-2011 10:07 AM #102
      Quote Originally Posted by GloryFreak View Post
      Updates?
      gonna be installing the ecu with the new c2 chip today, ill take a video to show how the car reacts..
      hope this one works!
    3. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      Previous: 1997 8v Golf. Current: 2000 1.8t Passat
      10-20-2011 10:34 AM #103
      FYI....its probably going to idle weird when you put the new ECU in. That is completely normal. The throttle body needs to adapt. Give the motor few cold starts before posting your results.
    4. Member cm123's Avatar
      Jun 3rd, 2010
      10-20-2011 01:40 PM #104
      Quote Originally Posted by tdogg74 View Post
      thanks for the info tdogg..
      im honestly just looking to see if the car is going to shut off or not after the warm up cycle. I just drove it now so i am going to wait for it to cool down a little before installing it
    5. 10-20-2011 01:49 PM #105
      ^^so excited right now...can't wait eekkkkkk
      "Team Shenanigans...Tell your girl we said hi"
    6. Member cm123's Avatar
      Jun 3rd, 2010
      10-20-2011 01:53 PM #106
      of course the code reader i ordered wont be coming in until tomorrow
      hopefully no codes come up
    7. 10-20-2011 03:12 PM #107
      X2 for no codes!!!!
    8. Member cm123's Avatar
      Jun 3rd, 2010
      10-20-2011 04:08 PM #108
      ok so i just installed the ECU with the new C2 chip.
      the idle is at a constant 900rpms
      no check engine light as of now!!
      letting it idle for a while to see if it will shut off or not.. will keep you posted
    9. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      10-20-2011 04:15 PM #109
      Out of curiosity, what was changed with the chip programing?
    10. Member GloryFreak's Avatar
      Feb 19th, 2009
      North Carolina
      10-20-2011 04:57 PM #110
      I have a weird theory. If people such as myself are getting system too rich codes and rev hangs with the bfi chip, but uninstall the chip/run for a week or so (100+ miles mixed between highway/city) without ANY codes found or any rev hang issues, wouldn't you think that there is something wrong with the tuning? ....Like I said this is just a theory and not a fact.
    11. Member cm123's Avatar
      Jun 3rd, 2010
      10-20-2011 05:29 PM #111
      to be honest with you im not sure..
      chris just swapped my chip which was about a year old with a brand new one
    12. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      10-20-2011 06:04 PM #112
      Then, technically, there should be no difference. It's a cookie cutter program.
    13. Junior Member
      Nov 24th, 2007
      SoCal
      98 Mk3 Jetta ABA
      10-20-2011 08:13 PM #113
      I'm still waiting for my new chip from BFI (it's in the mail I'm told), but BFI told me that Chris from C2 had their new programmer look at the code (the old programmer has left C2 since working on the code for these chips). This new programmer didn't find any "glaring errors" but did "identify a few lines of code that seemed to be the problem areas" on our 1998+ cars. The new programmer also cleaned up a number of other lines of inefficient code within the program, so these new chips really are different from those of the past.
      -Patrick
      98 jetta 2.0 ABA 5spd, Autotech CAI, OBX header, straight thru CAT, TT exhaust, Borla muffler, head rebuilt milled .040, dual valve springs w/ Ti retainers, Viton valve seals, 3-angle valve job, 270 cam installed @ -4deg, BFI stage 2 chip Rev B, SAI del physically & via VAGCOM, cleaned/flow matched injectors, light flywheel, ACT clutch, Autotech springs/dampers & anti-roll bars, Energy Suspension bushings, OZ Record 15in wheels
    14. Member cm123's Avatar
      Jun 3rd, 2010
      10-20-2011 09:43 PM #114
      Quote Originally Posted by Patrick007 View Post
      -Patrick
      yea that's what Chris was telling me.
      i was very surprised with the top end it has now..
      once it hits 80 it just keeps going
    15. 10-21-2011 12:29 AM #115
      Sweet! mines is in the mail..........................so did it also solve the rev hang issue?
    16. Member cm123's Avatar
      Jun 3rd, 2010
      10-21-2011 01:11 AM #116
      Quote Originally Posted by bluntman220 View Post
      Yea I'm having no problems with the rev hang issue
    17. Member Kiyokix's Avatar
      Dec 16th, 2005
      Delaware, US
      '98 Jetta 2.0 (Wolfy) '01 Jetta 1.8T (Wolfy) sold, '13 GLi Autobahn DSG (daily)
      10-21-2011 08:28 AM #117
      Quote Originally Posted by cm123 View Post
      Happen to have a video (cell or anything) of how the car is running and idling? I must say even though I don't want it to be a chip problem...I WANT it to be a chip problem so we can stop chasing ghosts lol.
      Kei
      Quote Originally Posted by VWestlife View Post
      If you pace the cars around you, I bet you'll find that people rarely accelerate to 60 MPH in any quicker than 20 seconds.
    18. Member GloryFreak's Avatar
      Feb 19th, 2009
      North Carolina
      10-21-2011 09:28 AM #118
      -Patrick
      So does this mean all of the non 1998+ people are still screwed with the whole issue?
    19. Member cm123's Avatar
      Jun 3rd, 2010
      10-21-2011 11:21 AM #119
      Quote Originally Posted by Kiyokix View Post
      Kei
      i will take one today
    20. Member Kiyokix's Avatar
      Dec 16th, 2005
      Delaware, US
      10-21-2011 01:28 PM #120
    21. Member The Big V's Avatar
      Jul 11th, 1999
      NYC
      '99 mk3 Golf Wolfsburg (Black, 5spd, 239k mi +), '89 BMW E30 325iS 5spd RACE CAR
      10-21-2011 02:31 PM #121
      mine is in the mail....very very excited...anyone in nyc w/ vagcom? i'll do video etc after i get mine in...i think i can have my work's obd2 reader scan running data to maybe add to the tech info...
      take the road less travelled...
      __________________________
      GermanAutoParts | TyrolSport | USRT | HGB transmissions
      TT | 4Season | BrokeVW | Dan Reed's DIY VW site
    22. Member cm123's Avatar
      Jun 3rd, 2010
      10-21-2011 02:45 PM #122
      I just took a video of starting up the car. This video was taken 20-30min after i drove it so the car was still pretty hot.
      i will be taking another one later today to show how it is on a cold start
      its not letting me post up the the video straight onto the post so here is the link:
      http://img851.imageshack.us/img851/5506/tcm.mp4
    23. Member GloryFreak's Avatar
      Feb 19th, 2009
      North Carolina
      10-21-2011 02:56 PM #123
      So what do I need to do to get a hold of this "new" chip? Do I contact chris @ c2 or bfi directly and does it cost anything or could I just drive down there and ask for a swap?
    24. Member cm123's Avatar
      Jun 3rd, 2010
      10-21-2011 03:27 PM #124
      to be honest with you i would call c2 since that's who i dealt with to get the problem fixed.
      since my chip was a over year old, they charged $50 to get a brand new chip.
      but i believe if your within the year purchased it should be a free upgrade?
    25. Member Kiyokix's Avatar
      Dec 16th, 2005
      Delaware, US
      10-21-2011 04:25 PM #125
      Thanks, any thoughts now that you've driven on it a bit...how does the car drive, are there any legit (aka non placebo lol) differences you've noticed in how your car behaves, etc.
      Kei
