VWVortex.com - DIY: Innovative Motorsports MTX-L Wideband + Gauge Install
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 28
    Thread: DIY: Innovative Motorsports MTX-L Wideband + Gauge Install
    1. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      09-23-2011 03:59 PM #1
      Originally written by Maddness...
      after reading an article in EuroTuner about how much they stand behind this gauge, i decided to get 1 for a mier $199
      extra bung, AFR 02 sensor and gauge, custom harness, Innovate Motor Sports program on a CD to install it to your laptop, special wire and connector (the funny lookin 1 with the 2 fastenign screws on the side) to connect to your lap top, and 2 option on bezzle right and face plates for the gauge.
      quit alot of stuff for that price imo.
      i was surprised.
      on with pics.
      extra bung welding in.
      i had a local shop, D&D Muffler, cut the whole. i welding it in at home.
      now dont just go and put the extra bung anywhere, or directly across from the exsiting bung just because mine is.
      however, it is crucial to have it aligned with the exsiting o2 sensor as this will give your gauge an exact reading of what the ECU is seeing.
      you need to mount the whole thing to see exactly where you will have room for another AFR o2 sensor.
      once you have found this spot, mark it and make a hole.
      do not do what the dumb ass, who i bought it from, did here.
      and dildo baggins sold this to me as a good usable setup.
      jack ass.
      anyways,
      see how he's got the 2 next to eachother almost inline.
      now this means your not gonna get the same reading as the ECU.
      either because the ECUs o2 sensor doesnt have full flow over it OR the gauge's o2 sensor doesnt have full flow. depending on which sensor is where.
      not only will it not be accurate, the placement of the second bung is too close to the heat shield and therefor i couldnt mount it with a o2 sensor in it.
      ps: the cap on the 1st bung was a temporary thing. it is now on the second hole.
      so i got in there with a file and bored it out a bit. took only about 10 mins or so.
      and i used the gromet that in there too. it was a tight fit to get the connector through it, but it works.
      i wired up the gauge too.
      for the power i used 1 of those 2-in-1 fuse holders.
      2 10A mini fuses, and plugged it into the head light slot on the fuse box.
      and ground it just about anywhere except for "noisy" grounds (audio, ignition).
      and tada. haha.
      the gauge come with start up/calibration instructions, but just for the sake of this being a DIY.
      so once the power and ground are connected. turn the ignition to the ON position WITHOUT the sensor connected.
      keep it on for a minimum of 30 secs. turn the car off.
      the connect the o2 sensor but DONOT plug the sensor into the exhaust. it needs to be callibrated in clean air.
      turn the key to the ON position again, it will warm up in about 40-60 secs. depending on how cold it is.
      when it is done the gauge will read max AFR, 22.4
      now if you did all of the above, but didnot run the wire through the fire wall. you can disconnect the wire and o2 sensor. but DONOT turn the car on or you will have to re-calibrate the gauge.
      so after all this plug in the o2 sensor into the exhaust and your good to go.
      My Build
      Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never met, end-goals never reached, and wives always unhappy... it's all worth it though!
    2. Member MÄDDNESSS's Avatar
      Oct 18th, 2010
      mi casa
      '03 GTI 1.8FT, '88 Jetta Coupe.
      09-24-2011 05:26 PM #2
      as i said befor, i tapped it into the 10A mini fuse. fuse 19.
      the other fuse towards the bottom is to my air ride. its connected to the windshield wiper fuse.
      here is the power source. its under the dash. could get real good light in there, but its labled.
      ground.
      the 1 that isnt on securely is to my TurboTimer Companion Lite.
      both of the ground didnt work with the doghnut connection. the bolt wasnt long enough to go through the heavy metal plate. so i took of the connections, and strip the wire about 1inch back and wrapped it around the bolt. works perfectly.
      this will show when its heating up.
      then the red light will sweep through and max out. now its ready to operate.
      I have HEX-CAN VAGCOM. PM me if you want me to come out to you.
      The Apartment Build.
      My Down Souf build/progress thread
      Look what I brought home today! (sitting in SoCal)
      Quote Originally Posted by 87vr6 View Post
      Stop. Sell your VW, get off vortex.
    3. Member MÄDDNESSS's Avatar
      Oct 18th, 2010
      mi casa
      09-24-2011 05:34 PM #3
      btw, its the MTX-L wideband.
    4. Member tedgram's Avatar
      Jul 2nd, 2005
      Maine
      2001 Audi TTQ , 2006 A4Q 2.0T, 1996 A4Q
      09-25-2011 12:32 PM #4
      Will have to check that out. Would sure help me with tunning. $185 on Amazon.com.
      2001 225 Quattro Coupe, Aviator, Giac-X Chip, TurboX/S H25 Bov, Mofo, adjustable Fpr, Water injection, Boost Machine, Neuspeed p-flow, Neuspeed short shift, dogbone , Cat 51 cam, FK spacer 25MM R, 42 Draft spacer 8MM F, Defcon 2 bushings, Sport Edition KM11 wheels 18x8, tires 225/45-18, Eibach Springs, Neuspeed 19mm rear swaybar, 42 Draft Down pipe, Blue Flame exhaust, 6 point roll bar. LTA record holder G/BGSS mile 142.317, 1.5 mile 150.624.
    5. Banned madmax199's Avatar
      Oct 28th, 2009
      Long Island NY
      09-25-2011 03:20 PM #5
      I run the lc-1 controller in all my cars and it's a good unit. The controller is a little more complicated to wire and use than similar controllers but when it's working it's one of the best (The radio plug thing is really outdated). The XD-16 gauge is another story, Ive had nothing but trouble with them (4 total in two cars). If I were to do it again, I'd go with a more simple and bullet proof analogue gauge that's compatible with the LC-1 controller
    6. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      09-25-2011 03:31 PM #6
      Quote Originally Posted by madmax199 View Post
      I run the Innovative G5 gauge in my car.
      My Build
    7. Member MÄDDNESSS's Avatar
      Oct 18th, 2010
      mi casa
      09-25-2011 11:38 PM #7
      on the back of the gauge there are 2 connections. the kit comes with a cord that plugs into the 2 connections and the other side plugs into my laptop. i havnt quite figured out what these are for.
      im thinkin tuning of some sort, but to understand how.
      any ideas?
      thanks.
    8. Member MÄDDNESSS's Avatar
      Oct 18th, 2010
      mi casa
      10-29-2011 02:32 AM #8
      so my AFR gauge works great.
      i threw in a 4Bar when diagnosing my previous problem.
      and i just left it in there.
      i was gonna take it out, but all day long, in the city, it was reading 14.0-15.3 4500-5000 RPMs.
      and on the high way it stayed at 14.7, i havnt gotten a tune yet.
      around 5K it would start going rich and at redline it was about 11.3.
    9. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      10-29-2011 02:40 AM #9
      the dongle is for data logging. Not a big deal for you.
      You could do high speed data capture of the AFR...but you won't have RPM and other stuff to compare it to.
      In other words, without a bunch more wiring, you're best off sticking with vag com or maestro (if you have eurodyne)
      My Build
    10. Member MÄDDNESSS's Avatar
      Oct 18th, 2010
      mi casa
      10-29-2011 02:55 AM #10
      no tune as of yet. but getting Malone3+.
      and i dont have VAGCOM yet either. but working on that as well. i'll need it when Mark needs to tweak my file.
      is there another software i can use to maybe tweak my stock file a little bit?
    11. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      10-29-2011 03:54 AM #11
      Quote Originally Posted by MÄDDNESSS View Post
      lemmiwinks and the other similar programs will work...
      but you'll need an odb2 programmer.
      My recommendation....buy vagcom asap. I promise. You'll need it.
      My Build
    12. Member MÄDDNESSS's Avatar
      Oct 18th, 2010
      mi casa
      03-16-2012 02:03 AM #12
      Quote Originally Posted by groggory View Post
      didnt see this till now.
      i did get VAGCOM for Christmas. very helpful. great investment.
      i still have yet to get the tune.
      and still have yet to play around with lemmiwinks.
    13. Member MÄDDNESSS's Avatar
      Oct 18th, 2010
      mi casa
      03-16-2012 02:06 AM #13
      if anybody is on the fence about this product, i would highly recommend it. its a nice little insurance policy. its worked great from the get go.
      i have a boost/vac gauge and this AFR gauge. so if i have a boost/vac leak it reflects on both gauges.
      def worth it.
    14. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      03-16-2012 10:46 AM #14
      def worth it.
      My G5 gauge starting acting weird for me.
      I am replacing it with a Podi dual gauge that shows AFR and fuel pressure.
      My Build
    15. Member MÄDDNESSS's Avatar
      Oct 18th, 2010
      mi casa
      03-16-2012 11:24 AM #15
      i almost got a Podi gauge a few months back. its read AFRs and EGTs. but at the time i hadnt heard of them and he wanted almost full retail price for it. so for $10 extra bucks i could buy the same kit, brand spankin new.
      let me know how you like it, im interested in your review on it.
      oh ya, you should change the title of this thread. it isnt the LC-1.
    16. Member MÄDDNESSS's Avatar
      Oct 18th, 2010
      mi casa
      03-17-2012 04:09 AM #16
      just noticed you corrected it.
    17. Semi-n00b
      Dec 15th, 2011
      Austria
      03 Skoda Octavia 1.8T
      04-06-2012 04:41 AM #17
      As the MTX-L has two 0-5V outputs is it possible to replace an existing standard O2 sensor with the O2 sensor provided with the gauge and wire one output to the stock ECU?
      The reason I'm asking is I would like to have a wideband A/F gauge but I don't want to weld a new bung into my downpipe.
      I would appreciate any advice or help, thanks
    18. Semi-n00b
      Dec 15th, 2011
      Austria
      09-11-2012 08:27 AM #18
      Can anyone help? Maybe something like this?
      NOTE: I already have a wideband ecu.
      Quote Originally Posted by MetalMan
      To find out what your A/F ratio is without being on a dyno you need a wideband sensor/gauge. No way around it. I went with an Innovate Motorsports MTX-L gauge/sensor. The gauge itself has the wideband controller built-in, and it allows logging and has 2 analog outputs. So here’s how I configured this:
      -Installed the wideband sensor where the stock primary O2 sensor goes, after the turbo and before the cat
      -wired an analog output from the MTX-L gauge to the stock O2 sensor wiring
      -left the 2 white heater wires on the stock O2 sensor intact, to prevent O2 sensor heater fault codes
      -have the stock primary O2 sensor dangling from the secondary firewall
      -bought a column pod to mount the MTX-L wideband gauge/controller
      Source: http://www.audiforums.com/forum/nitr...0/#post1351194
    19. Member MÄDDNESSS's Avatar
      Oct 18th, 2010
      mi casa
      09-11-2012 10:10 PM #19
      sorry for the lag broski, havnt spent much time on here. life is pickin up.
      but to answer your question, idk how to do the wiring. i just welding in a new bung. but im a welder by trade, so it was easy for me.
    20. Semi-n00b
      Dec 15th, 2011
      Austria
      09-12-2012 03:21 AM #20
      No problem, I keep looking.
      I may have to do some work on my downpipe anyway, so this would be a perfect time for a additional bung
    21. 09-12-2012 06:31 AM #21
      The 2 analog outputs are meant for datalogging systems, they are not meant to be used as a way to "fool" your stock ecu and replace the main 02 sensor.
      You see when you use these outputs with a datalogging system, you then calibrate the system to the voltage readings you see as they match up with the gauge, or better yet the wideband manufacturer will send with it a voltage chart that you can plug into the datalog calibration. You don't have this with the stock ecu, so your basically hoping on a prayer the voltages coming from the wideband match with what the ecu wants to see, most likely... they will be "close enough" to "work okay". Well that's really not good enough for me, but I like precise tunes and with garbage input you can't have a precise tune.
      It's honestly not that hard to weld another bung in to the downpipe and use 2 sensors... you also gain the ability to quickly diagnosis when your front 02 sensor is getting lazy or going bad since it will start to read slower in the datalog then the MTX-L one and vise versa, depending on which one is going bad.
    22. Semi-n00b
      Dec 15th, 2011
      Austria
      09-13-2012 04:12 AM #22
      Thank you for your input. So it doesn't make sense to use the Innovative O2 sensor for a gauge AND the ECU.
      Alright, I'll go with the additional bung then.
    23. Member
      Dec 20th, 2003
      San Marcos, TX
      1981 Scirocco 2.0 16vT -- 1998 Jetta 2.Slow
      10-05-2012 09:46 AM #23
      Quote Originally Posted by Cryser View Post
      I have to respectfully disagree, that's exactly what the two analog outputs are for! It specifically says in the instruction manual that if you want to run the wideband as a replacement to your narrowband, you can...by using the output 1 wire to replace your OEM signal wire..which is an oscillitating value by default, and is 'simulated' at a constant voltage by the Innovate wideband controller.
      But, yes, you'll need to tune, or match the output voltage range provided by the output 1 of your innovate wideband to OEM narrowband O2 sensor specs.
      searching for O2 info will yield some voltage ranges, but if anyone can quote a VW source values and post them to this thread, that would be better than assuming standard Bosch values.
      Edit/Update:
      The MTX-L wideband is working great in my scirocco. It was installed and replaced the oem 3-wire O2 sensor (i'm running Digifant G60). While the brown wire is a perfect output 'map', I had already put a spade connector on the yellow wire (#1). I simply hooked up a serial cable from the MTX-L to a computer, installed their programming software and set the values for the yellow wire to match the brown wire. Car runs with no problems. Just remember to follow all instructions for both install and daily use.
    24. Member
      Jun 2nd, 2005
      the burgh
      04.5 blue lagoon gli, 1976 bmw 2002, audi TT(project)
      04-22-2013 12:40 PM #24
      I am glad no body had the issues with this f@#%ing thing like myself, first, cable melted by the downpipe, probably my fault, mustve fallen off where I had it fastened. ok my fault, finally replace cable, now my e5 error code turns to an e8 error code, just replaced the sensor over the weekend and it works for the first minute then i get the e8 code again, now I have to send this fu$%ing gauge to Innovate in Cali, on my dime, and its out of warrenty, even though its probably worked for around a month out of the year I have owned it. I imagine im goign to have to pay for them to fix it too even though its worked for like maybe 4 weeks out of the 50+ weeks I have owned it, I know I am the only only one to blame for the cable but this 200$ kit I have probably now spent another 100$ on for the extra cable and another sensor, and now I am going to have to pay to ship it back and forth to Cali, and then I am probably going to have to pay for them to fix it...not a super thrilled customer...
    25. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      04-22-2013 01:25 PM #25
      Quote Originally Posted by jagt21VR6 View Post
      Sounds like this problem was on you, sorry to say.
      I think the fact that Innovate is taking the product in for repair is a positive mark on their side.
      My Build
