VWVortex.com - 24v VR6 Timing Chain Change Prices
    Results 1 to 8 of 8
    Thread: 24v VR6 Timing Chain Change Prices
      Mar 4th, 2011
      Long Island/Northern VT
      2003 VW GTi VR6
      09-25-2011 09:19 AM #1
      So i've searched a bit and havent really found much. I'm looking for a price range of how much a shop should charge to do the timing chains in a 24v. If you've had yours done, how much did it cost? If you work at a shop/dealership, how much would they charge?
      Just posting a price with a brief description of the specific work done would be great. Thanks in advance.
      Quote Originally Posted by B518tko4 View Post
      Instead of driving a cheap rice burner you drive an expensive Jew burner.
      2003 VW GTI VR6 <<<clicky
      SHIFT HAPPENS
    2. Member jlsgli89-03's Avatar
      Aug 25th, 2003
      Suffolk, Virginia
      2007 Jetta GLI 2003 Jetta GLI ,1994 Jetta GL.
      09-25-2011 12:42 PM #2
      Gonna be pricey because the transmission has to come out.Might as well have the clutch done too good luck
      Mar 4th, 2011
      2003 VW GTi VR6
      09-25-2011 02:18 PM #3
      Yeah i know its gonna be expensive. I just want a ball park of how much it will be so 1; i know how much to save up and 2; i dont get ripped off at the shop.
      SHIFT HAPPENS
    4. Member crazymoforz's Avatar
      Jan 19th, 2006
      LA, OC
      3.2 Swap MKIV Jetta
      09-25-2011 04:09 PM #4
      well cali shop prices are a bit steep. average around 80-90HR.
      3-4hr transmission R&R (GIVE OR TAKE)
      3-4hr to do timing job (DEPENDS ON SHOP AND HOW FAMILIAR THEY ARE)
      LABOR ABOUT 1K
      Clutch, Cams, Engine Tuning, Coilovers etc. Call (714)997-5842
      www.FourSeasonTuning.com
    5. Member 24vGTiVR6's Avatar
      Sep 13th, 2010
      Canada, eh
      MK4 VRT
      09-25-2011 05:03 PM #5
      cost me about 1500 in Canada before tax.... replaced all guides, tensioner, and chains
      word of advice.... get them to change the slave cylinder while they have the tranny out. After I paid good money to the mechanic I had to drop my tranny myself 2 weeks after the chains were done because the slave cylinder popped. It's cheap insurance... slave cylinder isn't that expensive and it's better to do it all at once...
    6. Member
      Mar 4th, 2011
      2003 VW GTi VR6
      09-25-2011 06:26 PM #6
      Quote Originally Posted by 24vGTiVR6 View Post
      Good to know, thanks. I was thinkin i'd do the clutch while it's in there so the slave cylinder shouldnt be bad either.
      SHIFT HAPPENS
    7. Member jlsgli89-03's Avatar
      Aug 25th, 2003
      Suffolk, Virginia
      09-28-2011 11:38 AM #7
      Oh thats a good Idea. Do the Slave Cylinder.. and maybe the input shaft seal on the Tranny too.
    8. Member jaso028's Avatar
      Aug 12th, 2007
      02.5 24v GLI, 09 Tiguan SEL 4 Motion
      09-29-2011 12:37 PM #8
      slave cyl is a must!!!
      question, why are you doing the chains?? because you want to or because there is an issue??
      cause they say our chains are pretty good in the 24v, not like the 12v and dont really need to be replaced...
      as long as you run some good quality oil you should be in good shape..
      I have 188k on Origanal clutch, slave and, chains.. no issues and drive it like i stole it! lol
