Results 1 to 5 of 5
Thread: HELP!!! Clutch issues
  1. Junior Member Lowridah313's Avatar
    Jul 12th, 2011
    Petawawa, Ontario
    1988 VW Cabriolet, 2008 Jeep Liberty
    09-25-2011 06:13 PM #1
    I just installed a new clutch kit and Eurospec light weight flywheel into my 88 Cabriolet. When I press down on the pedal there is zero resistance, and the clutch pedal does return on it own. I can't see that I have installed anything wrong, but I could have being my first VW clutch. Everything is new expect for the clutch cable, which appears to be newer.
    Any insight from the more knowledgeable Mk1 owners would be greatly appreciated.
    -ToM-
  2. Member trocco84's Avatar
    Jun 20th, 2012
    Round Lake, Illinois
    2013 Jetta, 1984 Sciroccoo
    08-08-2012 07:06 PM #2
    I am also having this same problem on my 84 scirocco. Did you ever find the problem? This is also my first vw clutch.
  3. Member twinair's Avatar
    May 12th, 2008
    Nokesville VA
    90 triple white Cabriolet, 2005 BMW 530, 97 Ford Ranger Splash
    08-08-2012 08:26 PM #3
    Tighten up the cable. The clutch lever the cable attaches to should be at the 9 o'clock when the cable is tightened properly
  4. Junior Member Lowridah313's Avatar
    Jul 12th, 2011
    Petawawa, Ontario
    08-09-2012 09:32 PM #4
    Definitely make sure that the cable is adjusted properly. That was my problem, I hadn't adjusted it far enough so it wasn't engaging properly.
    Mar 17th, 2012
    Rochester, NH
    1989 Cabriolet
    08-09-2012 10:35 PM #5
    Quote Originally Posted by Lowridah313 View Post
    i think spec is 12mm gap between the arm and the bell housing on the adjuster. i had the same issue multiple times (didnt really tighten the set nut tight enough) I finally brought it to spec and it made a world of difference
