VWVortex.com - Hub Centric Ring Size??
    Results 1 to 7 of 7
    Thread: Hub Centric Ring Size??
    1. Member 3DM's Avatar
      Aug 7th, 2011
      Aliso Viejo, CA
      02 jetta 1.8t
      09-25-2011 08:09 PM #1
      I need hub centric rings on my stock gls 17" rims and i know the wheel bore is 57.1mm but every ring I look at has two measurements and I can only seem to find one. So which exact hub centric ring is the right one for my car? Thanks for looking!
    2. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      Car that looks good from afar.
      09-25-2011 08:12 PM #2
      every ring has 2 measurements:
      inner diameter = hub bore
      outer diameter = wheel bore
      so the inside of the hole should be 57.1mm which is what will fit onto your hub. the outside of the ring fits into the wheel and should match up with the bore size of the wheel.
      IF your wheels are 57.1mm, then you dont need hub centric rings because theyre made for your car
      || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
      || Please don't PM me with offset questions, post in THIS THREAD instead ||
      May 16th, 2008
      RI
      09-25-2011 08:30 PM #3
      going along with clean pg's info:
      if you have aftermarket wheels, you may need to contact the manufacturer of the wheels to get the bore diameter. I had this issue with my jeep and once i had both measurements, I was able to find the hub centric ring to find my application.
      I wish i had the website for you, but if you google it, you will find it.
      Erik
      01' jetta 1.8t 78K
      02' jetta 1.8t 132K
    4. Member .Ant's Avatar
      Jun 7th, 2011
      South Jersey
      Tow truck
      09-25-2011 09:07 PM #4
      Quote Originally Posted by Mr. Rictus
      Don't bomb threads with any variation of any combination of letters, numbers, words, phrases, icons, smilies, memes, pictures, videos or any other sort of post.
      Maintenance is paramount.
      GTS 3071R l Eurokraft Performance
    5. Member 3DM's Avatar
      Aug 7th, 2011
      Aliso Viejo, CA
      02 jetta 1.8t
      09-25-2011 09:08 PM #5
      thanks guys! my problem is that i have non hub centric spacers so im running bolt centric and my wheel shakes, i definitely shouldve mentioned this sorry! i dont have the money for new spacers and a friend suggested rings as a cheap fix
    6. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      09-25-2011 09:24 PM #6
      Quote Originally Posted by 3DM View Post
      rings will fix the problem then. figure out the center bore of the spacer and get a hub centric ring with an outer diameter that matches your spacer and that also has a 57.1mm inner diameter.
      May 16th, 2008
      RI
      09-26-2011 11:01 PM #7
      thats it! justforwheels.com i am glad someone else had the website.
      Erik
      01' jetta 1.8t 78K
      02' jetta 1.8t 132K
