VWVortex.com - Drive shaft bolt?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 40
    Thread: Drive shaft bolt?
    1. Member Tredmark4's Avatar
      Jan 24th, 2009
      Orlando/Naples Fla
      MKIV TR R32
      09-26-2011 02:41 PM #1
      Just looking for some clarification. I have heard that there is a bolt that is intentionally left out of our drive shaft and it's connection to the Haldex in the rear. It's purpose is for balance of the spinning drive shaft. Can anyone verify this and if it is true point out where it is.
    2. 09-26-2011 03:18 PM #2
      Quote Originally Posted by Tredmark4 View Post
      Where did you hear that because who ever said it needs to keep their thoughts to themselves.
      MK4 R36 x Precision 6776 Turbo = Large Grin
    3. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      09-26-2011 03:22 PM #3
      all my bolts are present.
    4. Member Tredmark4's Avatar
      Jan 24th, 2009
      Orlando/Naples Fla
      MKIV TR R32
      09-26-2011 03:23 PM #4
      Was from a thread from last year. Just read it the other day. Can't locate the thread now though. In the thread he said he found the info in the R32 FAQ section. I did not find it, but that doesn't mean it's not there.
    5. Member Tredmark4's Avatar
      Jan 24th, 2009
      Orlando/Naples Fla
      MKIV TR R32
      09-26-2011 03:25 PM #5
      Quote Originally Posted by ThatVdub View Post
      Good to know. Thanks.
    6. 09-26-2011 03:29 PM #6
      ALL the bolts should be there 3 holding the front of the prop to the tranferbox....6 on the CV joint...and three holding the rear of the prop to the rear diff unit.
    7. Member bolide's Avatar
      Mar 22nd, 2007
      Las Vegas, NV
      04 R32
      09-26-2011 03:45 PM #7
      The factory used nuts on the back of the bolts that serve no other purpose but balancing the driveshaft.
      So if a nut is missing dont add one.
    8. Member graeme86's Avatar
      Jun 27th, 2003
      Brisbane Qld
      2004 DBP R32; 1971 Superbug
      09-26-2011 04:00 PM #8
      For balancing purposes, you may also find thicker washers on some bolts.
      PM if you are looking for: Euro Headlight switches; RHD folding Stubbies.
      OEM+ freaks click here: Graeme's Webspace - Latest Updates: TPMS; More cluster programming goodies; Fuel & Brake Line Protection; Audi Rear Wiper; Passenger Footlight Mounting Bracket.
      Oct 28th, 2004
      Wstchstr Cnty, NY
      2012 Golf R DBM
      09-26-2011 04:14 PM #9
      Quote Originally Posted by bolide View Post
      This^^^^^
      Quote Originally Posted by graeme86 View Post
      And this^^^^^
      It's all in the FAQ. With pictures if I remember correctly. The FAQ is full of important info.
      Search can be your friend if you don't clog up the database with the same F'ing questions over and over.
      --Chuck--
    10. Member Tredmark4's Avatar
      Jan 24th, 2009
      Orlando/Naples Fla
      MKIV TR R32
      09-26-2011 06:32 PM #10
      I ask because I could not find. Sorry to make your vagina hurt. Thanks anyway.
    11. 09-26-2011 08:01 PM #11
      Adding a thicker washer will do bugger all to balance the prop, you really think a 1gram washer will counter balance a 15kg prop lol no...... You don't find the CV joints being balanced with washers etc...
    12. Member Daemon42's Avatar
      Feb 9th, 2001
      colorado
      04 R32T, 95/98 4runner
      09-26-2011 08:17 PM #12
      Quote Originally Posted by Slapbladder View Post
      The CV joints don't need to be balanced this way.
      The propshaft does, and that's what the extra or missing nuts and washers are for.
      Since they're going to bother to balance it, might as well do it accurately which is why it's done
      to the granularity of the weight of a washer, and not just a nut.
      ian
    13. 09-26-2011 08:31 PM #13
      Quote Originally Posted by Daemon42 View Post
      ian
      they don't need to balance it....why would they? its a tube with a machined end which will be balanced anyway....also the fact that there is a rubber donut to remove any harmonics and vibration from the prop on both ends....find me the section in elsa that says when you have removed the prop you need to rebalance it and make sure the bolts and washers are in the right order....
    14. Member Daemon42's Avatar
      Feb 9th, 2001
      colorado
      09-26-2011 08:39 PM #14
      http://forums.vwvortex.com/showthread.php?1561609
      BTW, this is the very first Q&A in the R32 FAQ.
      ian
    15. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      09-26-2011 08:43 PM #15
    16. Member
      Oct 28th, 2004
      Wstchstr Cnty, NY
      2012 Golf R DBM
      09-26-2011 10:26 PM #16
      Why so irritable? You got your answer handed to you on a silver platter.
      I'd think you'd be happy to get it.
      --Chuck--
    17. Member Tredmark4's Avatar
      Jan 24th, 2009
      Orlando/Naples Fla
      MKIV TR R32
      09-27-2011 12:08 AM #17
      That's why I said thanks.
    18. Member M00NEY's Avatar
      Jul 9th, 2004
      DMV
      2012 A3
      09-27-2011 12:48 AM #18
      so many wow's
      signatures do not show up in tapatalk
    19. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      09-27-2011 01:34 AM #19
      I am still suspicious about missing bolts, washers maybe, but entire bolts seems too weird.
    20. 09-27-2011 07:12 AM #20
      this is for resonance (droning) to offset harmonics its technically not to balance the shaft. You would need more weight and place it near the outer edge of the prop donut.
    21. Member Tredmark4's Avatar
      Jan 24th, 2009
      Orlando/Naples Fla
      MKIV TR R32
      09-27-2011 05:53 PM #21
      The whole reason for me asking this is My problem is I have a nasty whine coming from the rear end and this started immediately after getting my car serviced and them telling me they replaced a missing bolt on my drive shaft Haldex connection now boom I have a terrible whine.
    22. 09-27-2011 09:05 PM #22
      by adding a bolt that was missing woudl not cause the whine....
      What did they do in the service? Did they touch the rear diff? change the haldex oil etc?
      There have been cases in the UK where muppets working at garages let out the diff oil by mistake refilling it with haldex oil and the other way round....if there is a whine this will point to a mechanical diff issue..
    23. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      09-27-2011 09:23 PM #23
      Took off my V3's today, and took a pic for ya.
    24. Member M00NEY's Avatar
      Jul 9th, 2004
      DMV
      2012 A3
      09-27-2011 10:25 PM #24
      So, don't go wow like u know something.
      When have you ever seen me act like that? Don't get defensive, I directed nothing whatsoever at you in particular.
      I was wow-ing at the fact that statements get made as if they are fact, when they are in fact completely incorrect.
      I was wow-ing at the fact that someone mentioned that they thought this info was in the FAQ but could not find it, when it is in fact right at the top, as was mentioned.
      And I was wow-ing st the fact that Ian stopped in (who historically has demonstrated more knowledge on the R32 than anyone, but is never arrogant about it), gave the info, and was promptly told he was wrong - by the guy who was wrong. (a guy who really seems to know his ish too, btw)
      So relax ThatVdub. I have never categorically stated anything on these or any other boards, and I tend to clarify that I may or may not remember something correctly, and that I am by no means an expert on cars or mechanics. I like to drive, and I like to learn. I also like to help. If I can, I do.
      I do not like to argue or be a dick, which is what you took me for doing, and exactly why I left my comment vague. It's not my style, and it bothers me that regulars around here, like you, would think that my intention first.
      Make no mistake, I fully understand the uneasy feeling when something looks very wrong on you're car or anything else you take pride in and enjoy.
      GL getting it fully sorted. I will quietly lurk and watch the progress so as to not accidentally offend you again.
    25. Member Tredmark4's Avatar
      Jan 24th, 2009
      Orlando/Naples Fla
      MKIV TR R32
      09-27-2011 10:35 PM #25
      I did an oil change and a Haldex service with the addition of the drive shaft bolt being installed.
