Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 89
Thread: **Introducing Solo-Werks Coilovers for MK2/3/Corrado @ AMI - $499 Shipped**
  1. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    09-26-2011 07:13 PM #1
    AMI is proud to introduce Solo-Werks Coilovers to the market!
    Designed by a joint engineering staff from Germany and the USA, the S1 coilover is built for the enthusiast that is looking for an ideal balance of ride quality and performance.
    In the front the S1 coilover for the MK2, MK3 VW/Audi Group platform features 400 lb/inch
    spring rate matched to a twin tube low pressure gas damper mounted in a
    heavy gold zinc plated threaded coilover housing that provides not only
    great handling, but also exceptional corrosion resistance.
    The rear features a 285 lb/inch coil spring & helper spring matched with a
    specially tuned sport damper mounted inside the rear version of the
    high quality heavy gold zinc plated threaded coilover housing.
    Features at A Glance
    - Front & Rear 45-85mm (1.8-3.4") Lowering Range
    - Heavy Gold Zinc Plated Housings
    - 400lbs Front Spring Rate (VR6 rating)
    - 285lbs Rear Spring Rate
    - Slotted Front Spindle Mount for camber adjustment
    - Silver spring perches - double lock ring design
    - Platform Specific Spring Rates and Matched Valving
    - 3 year Limited Warranty
    Fitments:
    All 2wd MK2 /MK3
    aka A2/A3 platform & Corrado
    All Motors inc:
    1.3- 2.0 4cyl, VR6, TDI
    Intro Sale Price: $499.00 Shipped (within lower 48 states)
    Click Link to Order: http://www.amimotorsports.com/store/..._detail&p=7526
    Don't hesitate to ask us any questions!
    AMI - extremely euro
    sales@amimotorsports.com
    Toll Free 1 (888) 362-3117
    Contact us for a personalized quote!
  2. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-01-2011 03:29 PM #2
    Hello Everyone,
    First thanks for all the interest in the SOLO WERKS Coilover kits!
    We have been getting quite a few questions about the kits, so we decided to do our own install to get the data to answer the questions that were being put out there.
    We were able to secure a MK4 GTI from vortex member Darktuner who was able to drop off his GTI on late Thursday afternoon and leave it with us until Sunday.
    We have been in the shop since then working to get every bit of info we could get for everyone who is interested.
    We finished the install and all the data late last night, and I am compiling the data today as well as finished install pics and hope to have everything posted by Monday at the latest.
    Darktuner will be picking the car up on Sunday and has a few hundred miles of driving to do that day, so he should have a pretty detailed review from an owners perspective.
    We will be doing an install in the coming weeks on a MK3/MK3 platform as well and we will be posting our review in the same fashion.
    Stay tuned
    Glen @ AMI
  3. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-04-2011 09:06 PM #3
    Sorry for the delay everyone, got hit hard with a cold .
    I hope to have everything together tomorrow shortly after the Dayquil kicks in
    Thanks
    Glen @ AMI
  4. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-11-2011 06:21 PM #4
    Hello Everyone,
    We have finished our MK4 install and testing, and we will have a MK2/MK3 coming in next week for the same treatment.
    I wanted to post this as info/cross reference for the time being
    After working with the engineers, and getting the max lowering sorted out here is what we have.
    The measurements below are taken between the center of the wheel and the fender as in the diagram below:
    • The max lowering shown in the tables above is achieved at the lowest position of the threaded adjustment on both front and rear axles.
    • Helper Springs have been retained and should not be removed! See notes below on the Helper Springs.
    • These measurements allow for the shock absorbers both front and rear to have the minimum amount of travel required by the engineers to do their job before full bump stop engagement.
    • You must trim 50% off of the included Front bump stops to achieve this lowering & travel range.
    • Removal of the OEM sway bar is necessary to achieve the max lowering due to contact issues with the drive shaft. Aftermarket units are available that will clear this issue.
    • Depending on your wheel and tire combination, you may need spacers to clear the coilover perch/springs. SOLO WERKS recommends at least 5mm clearance in this case.
    • At the lowest level, you may need to modify one or more of your body panels to allow for sufficient travel of the wheel inside the fenders. Please ensure that you have clearance from all obstacles through the complete travel of the wheels.
    NOTES:
    • The Helper springs are there to keep tension on the main spring during full extension of the shock absorber.
    • The main spring is not long enough on its own to keep the shock at full extension.
    • Removal of the helpers will result in the main spring being able to travel away from its upper and lower spring perches, and will result in damage to your suspension as well as other components.
    • DO NOT REMOVE THEM!!!
  5. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-11-2011 06:28 PM #5
    Hello Everyone,
    We have been receiving quite a few PM's and emails about the SOLO WERKS S1's, and I wanted to summarize them for everyone who is watching this thread or interested in the coilovers.
    First, to clarify the measurements in the chart.
    When we state at max lowering, this means at the end of the threads on each corner.
    To illustrate this point, here is what the front and rears would look like:
    The Golf that we did the installation on is not at full lowering for the kit, it has been raised up to suit the owner and the car.
    On our test Golf, the Front measurement is set at 12.5" front, and 12.5" rear using the measurement style of the center of wheel to fender.
    The Fender to ground on this vehicle in its current setup is 24 1/4" Front and 24 1/8" rear. At this setting, the vehicle is visually level to the naked eye.
    At this level the passenger side drive shaft WILL RUB on the OEM Sway bar setup under hard left turns or large bumps, but is fine under normal driving conditions.
    The owner has removed the front inner fender wells previous to the installation.
    A 5mm spacer was used with this wheel/tire combination to clear the coilovers.
    Let us know if you have any additional questions!
    Glen @ AMI
  6. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-11-2011 06:58 PM #6
    Here are some additional pics from the small photo shoot we did after the suspension was installed
    If you are interested in getting a set of these for yourself, you order can be placed one of three ways:
    1. Click here to log on to our website and purchase through our web shop.
    2. Send us your email address and we can send you an E-invoice that you can pay via PayPal, Visa, MC, Amex or Discover
    3. Give us a call directly at 1-888-362-3117 x 101 and we can process your order over the phone ( Visa, MC, Amex or Discover)
    Thanks,
    Glen @ AMI
  7. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-12-2011 05:23 PM #7
    Thanks to everyone who has called, PM'd and emailed.
    All questions have been responded to, and all orders are processed and ready to ship out today.
    All orders that were received before 2 PM Pacific will be shipping today!
    Thanks!
    Glen @ AMI
  8. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-13-2011 07:08 PM #8
    Thanks again for all the questions on the SOLO WERKS coilover kits
    All orders received today have been shipped, check your email inbox for tracking.
    Glen @ AMI
  9. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-14-2011 07:28 PM #9
    TGIF
    Thanks again to everyone who has purchased this week! All orders have just been picked up at our Fresno CA warehouse and they are on their way to the new owners.
    Check your inbox for your tracking info.
    If anyone has any questions, just let us know!
    Glen @ AMI
  10. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-14-2011 11:40 PM #10
    Darktuner has just posted his review of the SOLO WERKS S1 Coilovers on his MK4:
    Solo Werks Coilover review
    Thanks!!!
    Glen @ AMI
  11. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-15-2011 05:45 PM #11
    Thanks again to Darktuner for posting and your continuing work with us!
    Crazy amount of questions came in overnight, and I am happy to say that all emails & PM's have been answered.
    Let us know if there is anything else we can do for you all!
    We also have specials on ordering new bearings and mount refresh kits for both kits
    If you are interested the order can be placed one of three ways:
    1. Click Here to log onto our website and order online
    We look forward to hearing from you
    Glen @ AMI
  12. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-18-2011 08:04 PM #12
    Thank you again to everyone who has sent in questions and placed orders!
    All orders that were received before 2pm pacific time have been shipped picked up by UPS and FedEx, and are on the way to their new owners.
    Let us know if you have any questions!
    Thanks,
    Glen @ AMI
  13. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-20-2011 06:19 PM #13
    All questions have been responded to, and all orders processed for today
    All orders that were received before 2pm pacific time have been shipped, and tracking information should be in your inbox.
    Thanks again, and let us know if you have any questions!
    Thanks,
    Glen @ AMI
  14. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-24-2011 07:00 PM #14
    Thanks again to everyone for another great week & weekend of sales & questions.
    All Emails, PM's and calls have been responded to and all orders have been filled and on their way to their new owners. Check your email for your tracking numbers
    Please do not hesitate to post a question or contact us for any of your VW needs!
    Thanks,
    Glen @ AMI
  15. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    10-26-2011 07:44 PM #15
    ONLY 5 DAYS LEFT on the INTRO $499 SHIPPED PRICING!!!!
    All orders that were in today before 3PM pacific have been shipped out and tracking info will be in your inbox shortly!
    All PM's and emails have been responded to. Thanks again to everyone who has ordered!
    Glen @ AMI
  16. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-09-2011 07:57 PM #16
    SOLO WERKS has authorized an extension of the into offer pricing of $499 until the end of 2011!!!
    We have full stock of SOLO WERKS coilovers on our shelf and can ship same day as your order
    We also offer Front & Rear Upper Bearings & Bushing combos at discounted prices as well as Boesheild T9 Anti Corrosion spray. Simply select them as options with your SOLO WERKS order and they ship for free!!!!!
    Thanks
    Glen @ AMI
  17. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-10-2011 06:30 PM #17
    Thanks to everyone who emailed, PM'd and called in today!!!!
    All inquiries have been responded to, and all orders have been processed and are shipping this afternoon.
    1. Log on to our website CLICK HERE to purchase online
    We look forward to hearing from you!
    Glen @ AMI
  18. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-11-2011 08:17 PM #18
    TGIF
    Thanks to everyone who has sent in questions and of course orders!!!!
    All orders received before 3:00 PM pacific time have been processed and are on their way to their new owners.
    Check your inbox for tracking info
    Thanks!
    Glen @ AMI
  19. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-14-2011 08:26 PM #19
    Hello Everyone,
    Now that there are a number of Solo Werks S1 Coilover sets out there and installed, we need your feedback!
    AMI & Solo Werks are looking for current Solo Werks S1 Coilover owners to post their reviews online - Vortex and any other forums - the more detailed the post the better
    Post up your reviews in new threads in the forums and send Solo Werks an email (info@solo-werks.com) with the thread link, as well as your contact info and you will be sent a limited run Solo Werks T-shirt!*
    Sizes Large to 3XL are available!
    Thanks!
    Glen @ AMI
    *Solo Werks will contact you with full details that you will need to provide, and verification of purchase/ownership will be required.
  20. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-15-2011 06:44 PM #20
    TUESDAY UPDATE
    All orders received before 3:00PM today Pacific time have been processed and are on the dock ready for UPS & FedEx to pick up!
    All questions in all forms (PM, Email & VM) have been responded to.
    Don't forget, we also have Front Upper Mounts and Bearing sets available at a discounted price with no additional shipping when purchased with a Solo Werks Coilover kit!
    Thanks,
    Glen @ AMI
  21. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-16-2011 06:58 PM #21
    SHIPPING INSANITY!!!!
    Crazy day today, not only are the SOLO WERKS S1's flying off the shelf, but our FK airfreight order has arrived... Our shipping department is just flying!!!!!
    All orders received today before 3:30 PM Pacific Time are on the dock ready for UPS to pickup.
    Don't forget to get your Solo Werks Reviews in to get your free Solo Werks T-shirt!
    Glen @ AMI
  22. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    11-18-2011 07:03 PM #22
    All PM's, emails and calls have been answered/returned!
    Thanks again to everyone who has ordered, any orders that were received before 3:00 PM PST today are on today's UPS
    Glen @ AMI
  23. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    01-31-2012 04:51 PM #23
    The Solo Werks $499 sale is back on!
    We are fully stocked on MK2, MK3, MK4, MK5 and MK6 Solo Werks S1 Coilovers and shipping daily!!!!
    If you would like to get your new Solo Werks S1 coilover on its way, your order can be placed one of three ways:
    1. Log on to our website or click the appropriate links above
    Let us know!
    Glen @ AMI
  24. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-01-2012 06:24 PM #24
    Thanks to everyone for their questions & orders!
    Our shipping department is busy getting your kits shipped this afternoon for everyone who has ordered as of 3:00PM pacific time today, watch your email for tracking
    Glen @ AMI
  25. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-04-2012 08:19 PM #25
    Thanks to everyone who ordered last week!!!!
    All orders that were received before 3 PM pacific time on Friday have been shipped, and your tracking information should be in your inbox (check your junk folder just in case!)
    All Questions have also been responded to that have been received as of Saturday evening.
    Thanks!
    Glen @ AMI
  26. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-06-2012 07:16 PM #26
    Thanks again to everyone who ordered over the weekend!
    All kits are on their way that were ordered before 2:30 PM today
    For those who have ordered, do not forget to post your reviews online on Vortex or other forums and email your ship to info & Shirt Size into Solo Werks (info@solo-werks.com) along with the link to the thread and they will get a Solo Werks coilover shirt sent out!
    Glen @ AMI
  27. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-07-2012 07:12 PM #27
    Our shipping department is really busy trying to get out all the orders today!
    They get a bit carried away, but they are pretty sure they can get everyone's order that was placed in the last 24 hours out today!
    Orders shipping out today will have tracking emailed to them via our automated system + UPS/FedEx
    Keep the questions coming!
    Glen @ AMI
  28. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-08-2012 07:00 PM #28
    Another great day!
    As always, all orders received before 3:00 PM pacific time are in process and will be shipping today and tracking information will follow - watch your email boxes for the info (and check your Junk folder just in case)
    Thanks!
    Glen @ AMI
  29. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-09-2012 07:21 PM #29
    Thursday Bump!
    Keep the questions and orders coming!!!
    Thanks
    Glen @ AMI
  30. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-10-2012 08:18 PM #30
    TGIF!!!!
    All orders that were received before 3PM today are on their way via UPS / FedEx
    We will be in and out of the office this weekend, so don't hesitate to send us a PM or email!
    Have a great weekend!
    Glen @ AMI
  31. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-11-2012 06:51 PM #31
    Saturday Update.
    All PM's and emails have been responded to and all orders processed in the warehouse.
    Thanks!
    Glen @ AMI
  32. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-13-2012 06:44 PM #32
    Thanks to everyone who Ordered, PM'd or sent in Emails over the weekend
    All orders placed by 3:00PM today are on the shipping doc ready for pickup by UPS for domestic or FedEx for International - tracking numbers to follow in your inbox later tonight
    Thanks again,
    Glen @ AMI
  33. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-14-2012 06:36 PM #33
    Tuesday Bump!
    All orders from the last 24 hours are on the shipping dock waiting for UPS/FedEx pickup
    Thanks again for all the questions and orders!
    Glen @ AMI
  34. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-16-2012 07:29 PM #34
    Almost the end of another great week!
    As always, orders placed in the last 24 hours are on the dock and ready for UPS/Fedex to pickup and get on their way to their new owners - with tracking numbers automatically going to your inbox!
    Let us know if you have any questions, and don't forget to post your reviews on Vortex and send in the link to the review and your info inc shirt size to info@solo-werks.com for your free shirt!
    Just as a reminder, Solo Werks S1 Coilovers are in stock and shipping for:
    MK2 + MK3's 2wd
    (Golf, Jetta, Passat B3...)
    MK4 2wd (Golf, Jetta, Beetle...)
    MK5 + MK6 (Golf, Rabbit, Jetta, Passat, Eos, CC, R32 ...)
    All for $499 shipped within the lower 48!
    Thanks
    Glen @ AMI
  35. Banner Advertiser Sales @ AMI's Avatar
    Sep 2nd, 2010
    2002 Audi TT 225Q
    02-17-2012 06:05 PM #35
    Welcome to the Weekend!
    Thanks again to everyone that has ordered and sent in questions on these kits
    Our shipping department has all orders that have been received over the last 24 hours on the dock ready for UPS/FedEx pickup.
    Glen @ AMI
Tags for this Thread
