VWVortex.com - Stock R wheels not doing it for you? Show us the wheels you would like to see on your R
    Page 3 of 81 FirstFirst 12345671353 ... LastLast
    Results 51 to 75 of 2014
    Thread: Stock R wheels not doing it for you? Show us the wheels you would like to see on your R
    1. Member venom600's Avatar
      Sep 9th, 2002
      Claremont, CA
      2013 VW Beetle Turbo Fender Edition
      10-05-2011 12:03 AM #51
      Quote Originally Posted by Brandon@SoCalStanceShop View Post
      RS3s have a reversed staggered tire?
      You beat my ninja edit! Yeah, the RS3 wears wider tires up front. I've read 255 and 235... I know 235 will fit, but I don't know about 255.
    2. Former Advertiser Brandon@SoCalStanceShop's Avatar
      Jul 5th, 2011
      2011 Jetta SEL, 2012 Fiat 500 Sport
      10-05-2011 12:05 AM #52
      Hadn't heard that; odd.
      It really depends on your budget, but I'd say if you went 18x9 all around you could fit at least a 245 on there without... easy.
      Sep 20th, 2011
      Smithtown, NY
      10-05-2011 12:08 AM #53
      Quote Originally Posted by venom600 View Post
      Good value here for a 19 incher @ $199 a pop. Heck 20" is only $30 more.
    4. Member
      Mar 17th, 2004
      Oviedo, Fl
      2013 Audi Q5 3.0T S-Line, 2012 Golf R , 2013 Touareg VR6 (Wife's)
      10-05-2011 08:10 AM #54
      What will the stock wheel and tire size be?
      18x7 with 225/40/18 tires?
      Need to know this before I decide what wheel and tire package I get.
      Scott
    5. Former Advertiser Brandon@SoCalStanceShop's Avatar
      Jul 5th, 2011
      10-05-2011 11:22 AM #55
      Quote Originally Posted by scottisha View Post
      Scott
      Out of curiosity, why would the stock size dictate what wheels and tires you would get?
    6. 10-05-2011 02:50 PM #56
      A "crazy custom wheel" would never effect the amount of tire you can fit. It's about finding a wheel that has the right width and offset for what you're trying to accomplish. In terms of trying to stuff the most rubber under there as possible, that will 100% be dependent upon your ride height, plans for driving style, etc.
      Sorry I know "crazy custom wheel" wasn't all that clear. I guess what I am saying is I don't want to pay big bucks for custom wheels just to get a bit of extra rubber down.
      On my B6 S4 I could realistically only get 245's on the car without rubbing. According to Stassis Engineering you could get 265's on that car if you got a wheel built to particular specs...but it was cost prohibitive. No other off-the-shelf wheel that I looked at would work.
      As for the R it will be a daily driver but I will also autocross it regularly in a street tire class. I probably will not be lowering the car from stock ride height.
    7. 10-05-2011 02:57 PM #57
      245's fit nice on an 8" rim. I like when the sidewall is nice and vertical. I'm not overly keen on too much of a stretched look.
      Mar 17th, 2004
      Oviedo, Fl
      10-05-2011 03:52 PM #58
      I'd like what I choose to be as close to the stock circumference as possible..
      What I found is I can go with the Miro 111 in an 18x8.5 et35 with a 245/35/18 tire and be within a fraction of the stock overall circumference.
      Using a tire/wheel calculator I should be .2" closer to the suspension and .6" closer to the fenders.
      and 1.3% slower. So when speedo says 60mph, I should only be doing 59.2mph. I'd rather be a little smaller than taller. Car will accelerate quicker with less mass and technically a slightly smaller gear (due to the circumference being smaller)
      I went ahead and ordered 2 of the Miro wheels just a few minutes ago. I'll order 2 more next week and then the tires in a similar fashion. Then I'll have VW mount and balance them when my car comes in, so the car comes home with them on.
      Scott
    9. Member zlos's Avatar
      Oct 6th, 2011
      PL, EU
      '08 Golf R32T 750hp
      10-06-2011 06:57 AM #59
      for a blue one?
    10. Member
      Sep 20th, 2011
      Smithtown, NY
      10-06-2011 08:36 AM #60
      Quote Originally Posted by zlos View Post
      for a blue one?
      Starscream edition? Not feeling those bud.
    11. Member Max Rebo's Avatar
      Apr 11th, 1999
      Pottstown, PA
      '07 BMW 335i
      10-06-2011 03:47 PM #61
      I've had these sitting in my garage for the past 1.5 years (from my '07 GTI). I'm secretly hoping I'll be in another VW so I can use them again.
      Oddfellows Local 726
      Mar 17th, 2004
      Oviedo, Fl
      10-07-2011 12:05 PM #62
      Hey Brandon@socalstance...........What happened to you? No return PM or email in a couple of days, yet you seemed pretty eager to earn my business.
      Scott
    13. Member Tampavw's Avatar
      Nov 16th, 2006
      Tampa FL
      2008/VW/R32
      10-07-2011 07:37 PM #63
      I think I found the wheels I want..Called Miro 111's
      18x8.5 5x112 et35 offset:
      R32/939
    14. 10-08-2011 08:00 PM #64
      I've been eyeing some reps of the wheels that come on the RS3:
      These are 19x8.5 +47ET. I gather that will work on the R? I like the anthracite ones better, but they aren't offered in +47ET.
    15. Member
      Aug 20th, 2009
      Charlotte
      RB MK6 Golf R, Red Audi A3 (wife's)
      10-09-2011 01:10 PM #65
      Quote Originally Posted by sassynapoleon View Post
      +1
    16. Member
      May 24th, 2011
      SoCal and El Paso, TX ;-)
      MKIV.:R32 & MKVI.:R 2.:R's are better than one .:R!
      10-11-2011 04:13 PM #66
      How much does these things weigh?
      UNDER STEER MUST DIE!!! As my skills/abilities increase UNDER STEER magically disappears!!!
      Stock is like virginity: Useless and should be gotten rid as soon as possible!!!!
    17. Member
      Nov 28th, 2001
      Canada, eh?
      2012 S4, 2004 Golf GTI 1.8T
      10-11-2011 05:15 PM #67
      Almost. 18x7½J with 225/40R18 tires.
    18. Member Fahrvergnuugen's Avatar
      Nov 13th, 2000
      Great Sacandaga Lake
      10-11-2011 06:44 PM #68
    19. Member
      Sep 20th, 2011
      Smithtown, NY
      10-11-2011 06:49 PM #69
      Looking good.
    20. Awaiting Email Confirmation GCAutoparts's Avatar
      Aug 25th, 2011
      2005 Touareg 4.2 V8 1994 Vento 1969 BMW 2002 2010 Jetta TDI
      10-11-2011 07:12 PM #70
      Rotiform - NUE Forged 3 piece Super Concave
    21. Member
      Mar 17th, 2004
      Oviedo, Fl
      10-13-2011 12:31 PM #71
      Quote Originally Posted by Fahrvergnuugen View Post
      Glad you posted this picture. I saw the ECS Tuning copyright and decided I'd check out their wheel selection.....Turns out, they have the Miro 111 18x8.5 et45 wheels in stock. $899.00 with free shipping.
      Just ordered a set.
      I think 19's would probably look better, but with the car lowered properly, these will look sweet.
      Scott
    22. Member
      Mar 17th, 2004
      Oviedo, Fl
      10-13-2011 01:10 PM #72
      OK...So, here's what my car will look like, except mine will be four doors.
      This may sound crazy, but I'm seriously considering having the car completely re-painted.
      Hyundai's Titanium Gray. Talked to my body shop guy today. Not a Macco guy either. Lot's of custom stuff, hotrods, choppers, etc.., besides everyday collision repairs.
      Scott
    23. Member
      May 8th, 2011
      Charlotte, NC
      VW Scirocco 1982 (SOLD), 3000 GT VR4 (SOLD) Golf R, sold, Alfa Romeo 4C
      10-13-2011 06:15 PM #73
      Scott
      Scott, I had the same idea but with scion cement grey! Let me know what you think.
    24. Member .:RTime's Avatar
      Jun 1st, 2010
      Center Valley, PA
      Dumped Out Golf R, 2004 BMP R32
      10-14-2011 03:15 PM #74
      vmr 710 will look good but i think the 701 look amazing
    25. 10-14-2011 10:55 PM #75
      Quote Originally Posted by Gateway1 View Post
      19" RS6 reps might not be a bad idea:
      This makes me miss my black Avant S-Line. RIP - A drunk driver sideswiped the whole driver side.
