VWVortex.com - Jetta Timeline in Pictures...
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 90
    Thread: Jetta Timeline in Pictures...
    1. Member FourEyes's Avatar
      Jun 11th, 2010
      Ferndale, WA
      1996 2.0 Jetta
      09-30-2011 08:04 PM #1
      Update concerning wheels on page 2
      Hello, my name is Braeden. I'm a big time lurker and a fairly small time poster so far. This is my first meaningful thread so please go easy. I'm hesitant to post this in the Mk3 forums because TBH I think I'd get chewed alive for not having some hella-stance-waffled car like everyone else.
      I'm making this thread to serve as my timeline for the different thing's I've done with and to my Mk3 Jetta. Updates to this will be very slow and drawn out as I'm working as much as possible and don't have a disposable income. There's not much, and it's nothing spectacular but it's my baby and I adore it.
      I bought the 1996 ABA Jetta GL as my first car in October of '09 when I was 16 years old. I WAS searching for a 4 wheel mechanical steering early 90's Prelude (2nd Gen), which when done right doesn't look bad IMO. But I found this for the right price instead. To be honest I'm glad I went with this 'chick car' as my friends used to tease. The community based around these Volkswagens is so much nicer than the one built around Honda's.
      The things it had when I purchased it are 148k on the clock, two-tone black paint (I'll get to that later), a random cone filter sitting on the bottom half of the air box, a missing rub strip, broken sunroof motor, extremely dirty interior, leaky tails, ripped shift boot, nearly blown rear struts and a broken trunk that nobody knew how to open. Oh and ZERO rust thanks in part to it never being driven on salt up here.
      Immediately after purchasing my Jetta I found these forums and started lurking around. Caught on pretty quick to how things operate around here and after half a year I signed up as 'neon280'.
      And here's what she looked like on her good side:
      Not long after my purchase I realized that the tires were shot from sitting outside for 3 years. Evident by the couple flats I got:
      There's that missing rub strip. Both rub strips on the other side eventually fell off as well.
      Replaced the tires with the cheapest I could find and washed it:
      Very early modifications... I moved the license plate lower, because I think it makes the front bumper look cleaner. Also disabled the DRL's, removed the antenna and the dummy plates. Can't remember why though...
      Next up I put the antenna back on, got Hella smoked sidemarkers, in.pro smoked taillights, and unevenly smoked my dummy plates . Oh and new camera! Still missing the rubstrips:
      After fixing my rubstrip problems with 3m double sided mounting tape, I worked up the courage to have at it with the random orbital that the PO threw into the deal. Which means a full polish. Not bad at all for my first time:
      Before:
      After:
      Needless to say I felt awesome that it turned out so well. Still has quite a few deep scratches, but the only way to take care of those is a respray $$$ and in the end its just a daily. I also noticed around this time that half of my car doesn't have the original paint. The front end and the passenger side are a richer black than the drivers side, rear end, and roof. It's only noticeable in direct sunlight, has anybody seen this before
    2. Member FourEyes's Avatar
      Jun 11th, 2010
      Ferndale, WA
      1996 2.0 Jetta
      09-30-2011 08:05 PM #2
      Well few months later my rear struts finally blew so I took a chance and dumped some cash into a set of CXRacing coilovers. I never had heard of them before but from the looks of them they are assembled the same as K-Sports, and I found them cheap. I HIGHLY RECOMMEND THEM. Due to their design, I'm able to adjust my height and ride comfort separately. Which means lower but still comfortable!
      These coils:
      During the install:
      After the install:
      Also while it was up in the air I threw on a wheel from a set I snatched from Jason (punkracer). 15x7 et37 Centra Type 11's, spray-bombed black by someone up in Canada for use as their winter wheels. My plan with them is to strip them down and attempt refinish them back to silver on the cheap cheap:
      It's going to be a long time before these wheels get on my car. I have motivation issues and not a lot of free time. But it will get done eventually! Beginning to strip one:
      When I picked the wheels up from Jason he told me about the cruise up Mt. Baker that was coming up. So I made that my first cruise. Wanderlust 2011 was pretty fun, it started out kinda awkward for me since I didn't know anyone, but ended up being a sweet ride up there. And the weather was beautiful! (I'm missing my dummy plates in the following pics because I got fed up with my poor skills. Took them off to fix) Another thing to note is this is about the time I requested to change my username to 'FourEyes'.
      At the H&R Building in Bellingham:
      Found out later that I parked next to Joel (rootrider). Your car looked nice! Although the bees certainly liked whatever you wiped down the front end with.
      At the top: (Not my photo)
      I was parked next to the caddy's: (Also not my photo)
      As you can see here I talked with Chad (blue62) for a bit. He's cool.
      On the way down again:
      Ha I should put that one in TCL's bored ex-girlfriend thread...
      One of my favorites:
      I finally got around to replacing my antenna assembly with a new antenna grommet, ground strap, and antenna (a black one this time to match with everything else).
      And last but certainly not least(as it was a PITA to do): I sourced new turn signals that weren't leaky or cracked, shaved all the lettering off the turns and dummies, and polished them back to near OEM perfection:
      There's not a lot that I've done, but I pride myself in the little things I do. Like fixing the sunroof motor or getting a leather stitched shift boot. This is how she sits now, 2 years and 40k miles later. Maintainance so far has been a timing belt, water pump, theromostat, coolant bubble, coolant temp sensor, AC pressure switch, and the upper coolant hose.
      Questions, comments, and constructive criticizm are always welcome:
    3. Member FourEyes's Avatar
      Jun 11th, 2010
      Ferndale, WA
      1996 2.0 Jetta
      10-01-2011 01:21 AM #3
      If mod's feel like this should be moved to the Mk3 forums, go ahead. I won't mind
    4. Member boostedbastid's Avatar
      Aug 31st, 2009
      portland oregon
      few here, few there, big whoop wanna fight about it?
      10-01-2011 01:50 AM #4
      good job, but lower it
    5. Banned
      May 18th, 2011
      Oregon
      Wabbit and a pile of crap
      10-01-2011 02:07 AM #5
      and rust the hood
    6. Member blue62's Avatar
      Sep 25th, 2010
      Everett/Seattle
      '83 Caddy, '01 Jetta
      10-01-2011 03:25 AM #6
      Car is looking good dood, can't wait to see the Centras on it
    7. Member Naters10's Avatar
      May 3rd, 2011
      PNW
      02 Jetta 1.8t
      10-01-2011 01:24 PM #7
      looks clean im in bellingham, so im sure ill see you around sometime keep up the good work
    8. Member FourEyes's Avatar
      Jun 11th, 2010
      Ferndale, WA
      1996 2.0 Jetta
      10-01-2011 01:42 PM #8
      Yeah I know, it definitely needs to go lower! I'd just like to come up with the cash so I can roll my fenders the correct way. Probably at Meister Auto Werks. And then when I finally get the Centra's done it will be even lower.
      Quote Originally Posted by Naters10 View Post
      Thanks! I'm pretty sure I followed you for a few lights till we got to the H&R building for Wanderlust, before you left. Car looked clean and mean.
    9. Member Naters10's Avatar
      May 3rd, 2011
      PNW
      02 Jetta 1.8t
      10-01-2011 02:52 PM #9
      Quote Originally Posted by FourEyes View Post
      Yeah probably! I didn't go to the top. had to work:/ but thanks
    10. Member LieutenantShinySides's Avatar
      May 4th, 2007
      Earthquakeville, CA
      F31 328d xDrive, E39 M5, '54 3100 5 window
      10-03-2011 03:15 PM #10
      Looking good
      (Oo=[][]=oO)
      The art of trolling is easy. First, you must
      There are two types of people in this world who don't have beards - women and children.
    11. Member cabriosnap's Avatar
      Apr 24th, 2009
      Oregon City, OR
      98 Cabrio, 1983 302 RX-7, 1978 F250,02 Beetle TDI, 86 Ranger 4x4,83 16Vaba-T cabriolet project
      10-03-2011 07:36 PM #11
      car is looking good man. i would start searching for a trunk lid w/ spoiler and get some skirt's on it. how are those wheel's coming for you? i can see type 11's looking pretty good with a little more tuck
      Quote Originally Posted by PnwAviationNut View Post
      and rust the hood
      ^^^^please don't do this^^^^
      -VDUBN-
      Team Creampie
      My Car looks Dumped cuz theres Hookers in the Trunk
      Quote Originally Posted by 942drvento
      Instead of the Beer Avatar they need a Blunt
      Quote Originally Posted by uzi did it View Post
      4 doors more whores!
    12. Member MKIIIRobby's Avatar
      Jul 9th, 2007
      Covington, WA
      98 Jetta (show car), 2013 Fiat 500 Lounge (daily driver), 95 Corrado (project car)
      10-03-2011 09:03 PM #12
      Looks good! Nice and clean! Keep it up!
      I think my VW is broken. The check engine light is off!
    13. Member FourEyes's Avatar
      Jun 11th, 2010
      Ferndale, WA
      1996 2.0 Jetta
      10-03-2011 11:02 PM #13
      Quote Originally Posted by cabriosnap View Post
      No rusted hood for me!
      Also the wheels are coming slow as ever. Have one of them almost ready for paint. It's going to be a long time till they see my car. With Washington's rain and no garage space... But yeah I'm planning on tucking them a bit. I don't see flush looking well at all, especially since it's only a 7 inch and I'm not going to see any stretch on those without running skinny tires.
      Thanks guys!
    14. Member FourEyes's Avatar
      Jun 11th, 2010
      Ferndale, WA
      1996 2.0 Jetta
      10-11-2011 12:26 PM #14
      Seriously considering just getting the curbage polished out and then paying to get them stripped and powdercoated. Probably by Meister Auto Werks at the same time I come up with the money to roll my fenders. Although I still have to get a quote once I figure out what I want to do.
      If i go through with this I'd like some people's opinions:
      Should i stick with the original silver? Or should i try something else like gunmetal, white, or black? Maybe even gold? Idk! Lol
      Also what about the lip? It's going to be nice and shiny by the time all the curbage is out. Should I powdercoat the lip as well or keep it polished?
      Going to be tucking them on 195/45/r15's
      These wheels:
      And some curbage:
      Any ideas?
      I'm here for the thread about popcorn.
      | Jetta Timeline | 2011 Epic Thread Survivor | Nevar forget |
    15. Member blue62's Avatar
      Sep 25th, 2010
      Everett/Seattle
      10-11-2011 01:20 PM #15
      IMO, do the wheels whatever color you want that you think looks good. I think black or gold might look sweet on the car though no matter what you do there's always at least one person to hate what you do so might as well make a statement with it lol. Personally I'm getting ready to do some purple long beaches for the gf's car
    16. Member gettajetta13's Avatar
      Jun 22nd, 2008
      Bellevue , wa
      86 1.8 Jetta Sold, 96 2.0 Jetta Sold, 97 2.0 Jetta Sold, 01 vr6 Jetta Sold, 01 Passat b5 cuurent
      10-11-2011 01:58 PM #16
      Quote Originally Posted by blue62 View Post
      ^ dont do it you'll finish the car and she'll break up with you! i think a weird color choice on a basic wheel makes it look like your trying to hard.. imo i would just do a standard brushed aluminum look or they have wheel paint that matches pretty close to an oem wheels color at schucks
    17. Member FourEyes's Avatar
      Jun 11th, 2010
      Ferndale, WA
      1996 2.0 Jetta
      10-11-2011 02:17 PM #17
      Looks like i need to start playing around in photoshop. I'm too undecided.
      Tapatalkin'
    18. Member 86gti2fast's Avatar
      Apr 3rd, 2008
      Rainy City, WA
      10-11-2011 02:54 PM #18
      Good start, looks like you're headed in the right direction
    19. Member blue62's Avatar
      Sep 25th, 2010
      Everett/Seattle
      10-11-2011 03:50 PM #19
      Quote Originally Posted by gettajetta13 View Post
      Haha if she did I'd just swap the crappy 15's back on . Only doing purple because she loves purple and loves the long beach wheels plus she wants to be different. I said go for it because I'm a huge fan of going outside the lines
    20. Junior Member MR. TACOMPTON's Avatar
      Aug 5th, 2011
      tacoma
      2008 audi a3
      10-11-2011 08:30 PM #20
      Looks good so far. Do your thang.
      iTS HYBRID....BURNS GAS,OIL AND RUBBER
    21. Member FourEyes's Avatar
      Jun 11th, 2010
      Ferndale, WA
      1996 2.0 Jetta
      10-12-2011 09:01 PM #21
      Spent some time in Photoshop at work today, and here's what I came up with. I'm really liking the gold so far but thought I should post them all up just for the heck of it. I also took the liberty of lowering it a little more.
      White:
      Silver:
      Gunmetal:
      Black:
      And my favorite looking so far would be gold. I think it looks classy, plus it would probably hide brake dust better than white or silver...
      I'm also playing with the idea of getting some random machine shop to whip me up some generic flat caps which would be painted the same as the wheels.
      What do you all think?
    22. Member e1z1r1a's Avatar
      Jan 12th, 2011
      Washington
      10-12-2011 09:31 PM #22
      Gold looks nice
      JRM FABRICATION <------- link
    23. Member RowdyS4's Avatar
      Dec 12th, 2010
      Dubbya-town,Washington
      2001 Audi S4
      10-18-2011 12:50 PM #23
      I re did the Huff's on my S4 and they were pretty rashed up.. I sanded them down and then put a metal filler in/on the rash it worked out really well for me. Once it dries and you sand it down and primer you can't even tell it was rashed. It was like 5 bucks at o'reilly's you should check it out.
    24. Member FourEyes's Avatar
      Jun 11th, 2010
      Ferndale, WA
      1996 2.0 Jetta
      10-19-2011 01:55 PM #24
      ^^^ I was actually quite serious about trying this for the deeper gashes.. however I'm worried about if it will hold up during the powder coating process. Or if powder will adhere to it at all.
      The best option would be to fill them using a welder, but i don't have access to that or a grinder. Not to mention I've never welded in my life.
      Tapatalkin'
    25. Member FourEyes's Avatar
      Jun 11th, 2010
      Ferndale, WA
      1996 2.0 Jetta
      10-19-2011 10:25 PM #25
      I SPEND TOO MUCH MONEY.
      LED's from Super Bright LEDs came today. I also have brand new DJ Auto smoked E-codes on the way, with the pigtails and brackets, 4 brand new wheel bearings, a counterweight shift knob, and OSRAM Nightbreakers for said E-codes all in the mail heading my way.
      My bank is f**ked.
      OH well. On to the LED's. I should take a moment to say that the reverse lights and the LED's pictured are NOT PLUG AND PLAY, I had to reverse the polarity of the circuit in order to make them work. On to the pictures....
      Comparison!
      And here's how bright they are in the dark.
      Also put some on the inside...
      And one more picture to secure my place as a p0st wh0re. Don't worry, the tow hook will be gone within a few days, I'm re-polishing the passenger dummy plate and threw it on for ****z and giggles.
