You can't from the filler.
#1
From what I've read so far, it's not easy anymore. I've read descriptions of screens in the filler neck or at the tank that prevent a siphon tube getting down to the gas level.
So, who has siphoned gas from a newer car ? How did you do it ?
......... and no, I'm not asking for the purposes of ripping off the neighbors in the middle of the night. Thank you.
#2
-=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=- -=Camry Driver=-
#3
no, now when they wanna steal your gas, they just stab a hole in the bottom of your gas tank.
#5
#6
#7
#9
How modern are we talking here? I siphoned gas from my old '05 Nissan Quest. There were obviously a couple valves in the filler neck, but a relatively narrow and stiff tube got past them.
HAVE/HAD: Mercedes, Porsche, Cadillac, Land Rover, VW (x5), Buick, Mitsubishi, Chrysler, Dodge, Nissan, Ford, GMC
WANT: FIAT 500C Abarth, VW Scirocco Mk1, Alfa Romeo GTV, Lotus Esprit, Audi TT, 240Z, Lancer Evo VIII RS,
Hudson Hornet, Porsche 964, Mini Cooper, Caterham SV, M-B CLS63 AMG, DeTomaso Pantera
#11
I use the fuel pump to do it for me. Pull the supply hose off the engine and jump the pump at the fusebox![]()
Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
#14
#15
When I had fuel in the Focus I wanted to remove while working on it, I put a gas can in the engine bay and ran the fuel line into it, and then put a battery in the hatch and ran it directly to the fuel pump. Took several minutes, but it got the fuel out.
