VWVortex.com - slow shift when cold
    Results 1 to 6 of 6
    Thread: slow shift when cold
    1. 10-03-2011 02:53 PM #1
      i have a 98 jetta gl 2.0 and when its colder like yesterday it was low 50s it wont go into revers or drive untill its reved up then it jerks. it does this alot less when it warms up. is there anything i can do to fix this or is the trans shot... im trying to sell it and wanna get the selling value up i know noone wants a car with a bad trans
    2. 10-04-2011 06:37 PM #2
      anyone ever had this problem... any input on if i should flush n fill or just add lucas oil?
    3. Member deletedo1m's Avatar
      Jul 9th, 2007
      WC,PA
      97 TR jetta, 87 jetta, 81 caddy, 95 cbr600
      10-04-2011 07:34 PM #3
      Check your fluid level.
      Give wildlife a brake! 4TSQ. WV, Almost Heaven. Where are the moose? Save the Frogs!. Save the whales. I birds. Iron City
    4. 10-05-2011 02:25 AM #4
      how is the level checked exactly... from my understanding warm the car up then check through the drain plug... its a 98 jetta with the "sealed" transmission...
    5. 10-05-2011 02:31 AM #5
      ^ check while still running... i read one instruction that said bassically fill it till fluid comes out and then close her up...
    6. Member CoolAirVw's Avatar
      Mar 8th, 2007
      Kansas City Missouri
      85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
      10-06-2011 02:30 PM #6
      Here is "how to change fluid"... at the end is "fill procedure". Its discussing how to check fluid while filling it, but if you'll get the "gist" of it.
      http://www.kansascitytdi.com/01M%20Filter%20change.htm
      Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
      ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
      www.KansasCityTdi.com
