Page 2 of 2 FirstFirst 1 2
Results 36 to 47 of 47
Thread: B1 Dasher Project
  1. Member gravityjunkie's Avatar
    Sep 4th, 2010
    Denver, Colorado
    2003 w8 4motion, 87 QSW quantum, 02 allroad ko4's(SOLD), b5.5 4motion,slammed, 98 VR6-T Jetta
    02-02-2012 10:30 PM #36
  2. Member Helltime's Avatar
    Jun 3rd, 2009
    Iowa
    13 Jetta SE Conv/Sunroof 2.5 5spd manual
    02-22-2012 03:17 PM #37
    Anymore progress on this tj?
    13 Jetta SE with convience and sunroof, 2.5 5spd.
    2000 Range rover 4.0SE
    91 miata, hard top 5spd.
    Sold: mk2 gti 8v 5spd, mk5 gti tsi 6spd, mk4 gti 1.8T apr stg 3+, mk4 gti 1.8t uni stg2, 2- E30s.
  3. Member vwovw's Avatar
    Apr 1st, 2004
    IOWA
    02-23-2012 07:41 AM #38
  4. Junior Member Snarkle's Avatar
    Jan 21st, 2012
    Salem Oregon
    1986 QSW Syncro
    02-23-2012 05:16 PM #39
    Was that a cat paw in above photo of glow plugs ?
  5. Member 1FastB5's Avatar
    May 30th, 2005
    Apple Valley, MN
    MK1/L322/VZ/E24
    04-07-2012 07:52 PM #40
    Quote Originally Posted by Snarkle View Post
    yes it was. cat is also named dasher, she loves the car.
    small update on this little project, i put on a different set of wheels and tires for free that i picked up from a friend, giving it something to roll and drive on for the time being. if i can get this thing on the road reasonably i would like to run on the original hubcaps since i have all of them. so i'll keep the original wheels so if i choose to i can sandblast and paint them, and eventually put new tires on them if i choose.
    also picked up a new timing belt, tensioner, and a few other odds and ends to see if i can get it running under its own power. hopefully with a little bit of elbow grease i can enjoy it over the summer.
    MK1 Scirocco S | L322 Range Rover SC | E24 6 series | VZ Monaro CV8
    President of PKG
    "Oh, you're the Iowa guys!" ---> www.projektgerman.com
  6. Member 1FastB5's Avatar
    May 30th, 2005
    Apple Valley, MN
    MK1/L322/VZ/E24
    04-11-2012 10:33 PM #41
    today i installed a new timing belt, tensioner and a few other small odds and ends.
    so now its back in time, new glow plugs, clean glow plug wires, freshly lubricated injection pump, cleaned injectors and more. i was happy to find that while timing the engine it turns really smoothly and at least the top end of the engine, still looked really clean and in pretty good shape for this cars age.
    tired to fire it up, and she wants to go, but the weak battery won't. both alek and i ran out of time this afternoon, so its on the charger over night, we're going to bleed the injectors again and it SHOULD fire up, we can hear a lot of life ready to come back out of that engine. that familiar diesel knock was trying real hard to get out.
    so hopefully with a little bit of effort tomorrow, she just might roll out of the shop under her own power
    so provided that it is running in reasonable order, i'll address some of the other details that will need attention before being road worthy:
    -replace or rebuild the alternator
    -a/c delete -- the compressor is totally ceased and with A/C parts almost impossible to find, i doubt i'll get it in working order
    -brakes on all corners. new discs, pads, lines, and drums. master cylinder looks new so it should be fine.
    -suspension -- i MIGHT do air ride on this car if i can find something that will work for the front struts. thats the big thing i'd like to do to this car...i want nothing more than it to be low, and slow. with its patina status, i think it would turn a lot of heads with it being so rare on a nice set of wheels. otherwise standard suspension may be modified for it to sit lower. new shocks are readily available...springs less so.
    other problems i foresee:
    -wheel bearings? will see how these are on the first few drives. i can buy complete hubs cheap, so its an easy fix...
    -tie rods and other front end components need to be checked or replaced
    -clutch -- after sitting for years it may be dried out, and i'm anticipating replacement.
    President of PKG
  7. Member vwovw's Avatar
    Apr 1st, 2004
    IOWA
    04-12-2012 07:30 AM #42
    looking good
  8. Member bimrpwr's Avatar
    Jun 8th, 2008
    Gods Country
    85 Quantum Wagon, 06 Honda Pilot, 92 F350 Dually, 84 Rabbit Sport GTI
    04-12-2012 04:22 PM #43
    good luck with getting it going.
    Also i know of a TD from a quantum that will go right in the dash..
  9. Member 1FastB5's Avatar
    May 30th, 2005
    Apple Valley, MN
    MK1/L322/VZ/E24
    04-13-2012 12:27 AM #44
    Quote Originally Posted by bimrpwr View Post
    it runs, we know that for sure. just need to get the timing just right and she's ready to go
    President of PKG
  10. Member Moshua's Avatar
    Jul 20th, 2010
    Cincinnati OH
    1997 Audi A4 1,8tQ, 1999.5 VW Golf GLS, 1997 VW Cabrio, 1975 VW Passat L
    09-29-2012 02:19 AM #45
    any updates on this project. i have personal interest as i have a B1 also. Any good places to get parts that you have found?
  11. Member foxygrandpa's Avatar
    Jun 2nd, 2012
    Jacksonville, FL
    1987 VW Jetta GL, 1985 Audi 4000s, 1995 Celica GT
    10-02-2012 10:00 PM #46
    Awesome car man, a true unicorn ha. I would love to see one in person, maybe someday.
    Anyway, hope you're making good progress on it!
  12. Member dasherinoz's Avatar
    May 19th, 2011
    Melbourne, Australia
    1979 B1 Passat/Dasher - 1979 Golf - 1959 Beetle
    10-04-2012 07:16 AM #47
    Quote Originally Posted by Moshua View Post
    Looking for anything in particular? You could try the guys at Classic Parts in Germany if you have part numbers, otherwise have you thought about buying a second car to use for parts? It does help
