VWVortex.com - Daytime Running Lights
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 26
    Thread: Daytime Running Lights
    1. n00b
      Oct 9th, 2011
      Waterbury,VT
      2012 VW Passat
      10-09-2011 08:47 PM #1
      I have read previous posts regarding disabling the daytime running lights. I would rather not bend back the prong. Can you pull a fuse or is there another easy way to disable the DRL on a 2012 Passat? Thank you for your help.
    2. Member veedubcos's Avatar
      Jul 12th, 2006
      Atlanta
      2011 CW GTI MT
      10-09-2011 09:04 PM #2
      Quote Originally Posted by beezersfavorite View Post
      I would go with the euro switch route. You may be able to fit one from the previous year passats.. dont quote me on that.
    3. Member JWelty's Avatar
      Oct 7th, 2003
      Tampa, FL
      2006 MkV GTi
      10-09-2011 09:34 PM #3
      this has to be done with some recoding using a vagcom.
      UroTuning - OEM and Performance Parts Store - www.urotuning.com
      FixxFest #10 - Nov. 23rd, 2013 - THE Biggest EURO event in Florida - www.fixxfest.com
    4. Member
      May 10th, 2010
      North Jersey
      2016 Tiguan SE 4Motion
      10-09-2011 10:23 PM #4
      Quote Originally Posted by JWelty View Post
      may or may not be true
      the mk6 jetta went backwards in electronics.... the nms passat may be the same
      you can probably just take out the bulb
    5. 10-09-2011 11:04 PM #5
      Not to be a d**k, but leave them alone. Probably the cheapest safety device on the car. I'm sure you've had the same experience I have: poor weather conditions, dusk or early dawn light and consequent issues seeing oncoming traffic, particularly when turning to enter or leave a road, merging into traffic at ramps, etc.
      The whole point of DRLs is to ensure that your vehicle is visible and avoid these issues, and they work.
      Also, consider your liability if you're in an accident and the other party makes the case that your disabling the DRLs contributed to the accident.
      As an aside, on my MK3 Jetta the DRLs illuminated the taillights as well as the headlights, and I wish they'd put that on all cars. That's also why Euros have rear foglights.
    6. Member mreuro's Avatar
      Mar 10th, 2005
      Buford, GA
      07 GLI-F sold, 12 Passat VR6, 14 GLI, 16 GTI,17 A4
      10-10-2011 12:38 AM #6
      you can turn them off with Vag-com....
      did mine the other day....
    7. Member mreuro's Avatar
      Mar 10th, 2005
      Buford, GA
      10-10-2011 12:43 AM #7
      Vag-Com ONLY!!!
    8. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      10-10-2011 12:58 PM #8
      Quote Originally Posted by mreuro View Post
      Vag-Com ONLY!!!
      Indeed. FYI, most of this stuff seems to apply:
      http://wiki.ross-tech.com/wiki/index...6/AJ%29_Tweaks
      We'll make up a Passat-specific page shortly.
      Sep 22nd, 2011
      Southbay - Los Angeles, CA
      2012 VW Passat VR62002 Mercedes Benz E55 AMG
      10-10-2011 02:03 PM #9
      Funny, I was thinking that instead of disabling them, replace the yellowish bulbs with white ones to match my PIAA H7 Intense White.
      Any suggestions on white bulbs that might fit this application?
      Thanks for the input.
    10. Member cheapa55TDI's Avatar
      Sep 30th, 2011
      2012 Passat TDI SE
      10-10-2011 03:00 PM #10
      Quote Originally Posted by Andy@Ross-Tech.com View Post
      I'm looking forward to that. Hopefully it will be set up by the time I get my car.
    11. Member mreuro's Avatar
      Mar 10th, 2005
      Buford, GA
      10-10-2011 03:39 PM #11
      Sep 22nd, 2011
      10-11-2011 02:27 PM #12
      According to the 2012 Passat Owner's Manual:
      Turning off daytime running lights
      Press and hold the turn signal lever and high beam switch down and to the back (left turn signal and headlight flasher).
      Switch the ignition on for about 3 seconds and then off again.
    13. n00b
      Oct 9th, 2011
      Waterbury,VT
      2012 VW Passat
      10-11-2011 02:33 PM #13
      Thanks, I already tried that. When I took it to the dealer, the sales rep also tried doing it and it didn't work. The service technician was reluctant to turn off the DRL even though I was insisting I didn't want them. I was just looking for an easy fix, I appreciate all of the suggestions though.
    14. Member dachman1's Avatar
      Oct 2nd, 2011
      Oregon
      2012 Passat TDI SEL - White - Debadged, Tinted Windows, Euro Light Switch
      10-11-2011 03:49 PM #14
      Yep, I read and tried it too and it doens't seem to work for me either. Mine is an SEL though and I don't have a place to turn the key. I wonder if I'm just not doing the entire sequence right with the push button start.
    15. Member
      Apr 6th, 2002
      Pittsburgh, PA
      2012 Passat TDI SEL Premium
      10-11-2011 08:17 PM #15
      What are the negatives for having DRLs? I agree with the earlier stated safety advantages of DRLs and since they aren't using the main headlight bulb, why would I want them disabled?
      Current: 2012 Passat TDI SEL Premium - Tungsten Silver/Black Leather:
      Past Loves: 2007 GTI Pkg 1 - United Grey
      2002 Jetta 2.0T - Black
      1999 Passat V6 SEL - Silver
      1996 Jetta 2.slow - Purple
    16. Member
      Aug 30th, 2011
      NJ
      2003 Chev Trailblazer EXT, 2008 Buick Enclave, 2012 Passat TDI SEL
      10-11-2011 11:12 PM #16
      Quote Originally Posted by derreno View Post
      I agree what is the big deal. GM has had DRL for years now (my last 4 cars had it) . I would rather be seen instead of not seen. Canada has required them for quite a while now (that's how GM helped introduce them to the US). EU just began requiring them.
      http://en.wikipedia.org/wiki/Daytime_running_lamp
    17. Member
      May 10th, 2003
      Issaquah, WA
      2012 VW Passat TDI SEL, 2012 VW Touareg TDI Lux
      06-28-2012 08:09 PM #17
      Car looks better without them. Anybody figure this out?
      Current: 2012 Passat TDI SEL / 2012 Touareg TDI Lux
      Past VW: 2005 Touareg 3.2 / 1996 GTI-VR6
      Past Other: 2007 Audi Q7 4.2 / 2007 BMW 328xi / 2006 Porsche Cayenne / 2003 Audi A6 3.0Q / 2001 Audi A4 2.8Q / 1998 Jeep Wrangler Sahara / 1991 Honda Accord EX / 1989 Toyota Supra
    18. Member
      Oct 10th, 2011
      Mexiland
      2012 B7 Passat
      06-28-2012 08:12 PM #18
      You DON´T need a VAGCOM!!!!!!!!!!!!!!!!!!!!! it can be done via the steering wheel on the convenience menu
    19. Member
      May 10th, 2003
      Issaquah, WA
      06-28-2012 08:30 PM #19
      i noticed the manual referenced that but mine doesn't have the option in the menu. I tried the turn signal high beam ignition on thing and that didn't work either.
    20. Member TDI Brad's Avatar
      Nov 12th, 2011
      SC
      2012 Passat TDI SEL
      06-28-2012 09:47 PM #20
      By enabling Byte 15 bit 7 in the BCM I got this nice menu option in the MFD:
      You can also change the DRLs to only come on when the headlight switch is set to auto by checking Byte 26 Bit 3:
      Compu_85 posted this on TDIclub and this is how I enabled it my convenience settings.
      Euro switch, 30% 3M nano ceramic tint, Chinese BiXenon headlights and LED tail lights, H&R springs, paddle shifter steering from V6, 20" Giovanna Kilis wheels, 225/35ZR20 Conti DWS tires
    21. Member
      May 10th, 2003
      Issaquah, WA
      06-29-2012 12:13 AM #21
      Thanks. 6F isn't giving me the love. Cannot find it. Strange. Wondering if I should just do a euro-switch and wondering if that will get rid of them.
    22. Member JJS119's Avatar
      Aug 26th, 2008
      Brooklyn, New York
      13 Eos, 05 Outback, 86 LeBaron, 84 Subaru GL, 83 300D
      06-30-2012 01:37 PM #22
      This all seems amazing what you can do with these computers. What is Vag-Com? I have a Launch X431 if that means anything. I'm new to the B7. I've always had older cars that had no computers to screw but everything uses a ****ing computer now and its somewhat complicated. What do I need to do in order to this? And what else can I do with this Vag-Com and can my Launch do the same?
    23. Member
      May 10th, 2003
      Issaquah, WA
      06-30-2012 02:37 PM #23
      Quote Originally Posted by markitzero View Post
      Nevermind... I was looking in the wrong place. Got the DRL option in the MFI now. Thanks!
    24. Member TDI Brad's Avatar
      Nov 12th, 2011
      SC
      2012 Passat TDI SEL
      06-30-2012 02:59 PM #24
      NP
    25. Member
      Dec 24th, 2011
      Belleair, Florida
      2006 Volkswagen Passat
      06-30-2012 03:31 PM #25
      Quote Originally Posted by TOMPASS View Post
      Is there no Scandinavian DRL Option in vag-com for the B7? That'll have the tails on if I am correct. And I actually like DRLs, just not the ones that come stock in the B6, literally it's just your headlights on all the time. Not good for HID life. I am more for the OEM looking LED DRLs but I know there are people who don't care for it...a few pics of mine just for fun
      2006 Passat FSI 2.0T |Forge DV Spacer|Lowered on DG Springs|Electric Exhaust Cutout|Podi Stepper Boost Gauge|19" Gianelle Wheels|10" Kicker sub in custom box| iPad Mini Dash installed as headunit|5% Tint on sides, 30% on back window|Carbon fiber mirrors|Votex Roof Rack|Resonator Delete w/ Magnaflow tips|Colormatched Badgeless grill|OEM Audi S6 LED DRLs|Lip spoiler|Ceramic Brake Pads|Morimoto HIDs
