Page 1 of 26 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 889
Thread: FSAS07BOH's Exterior and Engine Bay Build Thread
  1. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    10-10-2011 09:32 PM #1
    Never made a "build thread" of sorts, and now is the time to start one up.
    I picked the car up in February of this year and it has gone through some changes since.
    Pick it up from my cousin, bone stock, on coilovers and audio system. Since then I have done multiple things, including: wheels, rear seat delete with custom false floor, joey modded headlights, MKIV manifold swap, etc etc.
    Starting within the next week. The bodywork is going to start. There are about 10 dings around the whole car that need to get pulled and filled. Some semi-serious rust on the drivers side rear fender and some shaved bits that are all going to get done before anything else. It wont be painted until spring time, but the main reason for starting the body work is so the rust doesnt go any further than it already is. Also, that way, when spring roles around, all thats needed is to fix some small things and then primer and paint the car.
    The engine bay has sorta kinda been started as far as shaving goes. I did a MKIV manifold swap on it, relocated the battery to the trunk, and took out some unneeded ****. Once the exterior gets done, then the seal sealer will get removed, holes will be filled, sheet metal will be laid, and some repainting of the engine bay will ensue.
    How it looked when i first got it:
    Edited GTI by RED2SLO4U, on Flickr
    Tint removed, kayne shadezzz, joey modded headlights, and some other small bits.
    _DSC0280 by RED2SLO4U, on Flickr
    Then came the wheels, rear seat delete, and the manifold swap
    Ginster3 by RED2SLO4U, on Flickr
    282167_1909540455242_1143774462_31701035_4979678_n by RED2SLO4U, on Flickr
    Ginster Canibeat 2 by RED2SLO4U, on Flickr
    I will update this thread with pictures of the rear seat delete and false floor, along with some engine bay pictures...
    BHC
    Instagram---> BHCGanshirt
  2. Member BARELY LEGAL's Avatar
    Jul 2nd, 2009
    Cincinnati, OH
    '81 Jetta Coupe | '04 .:R32 | '91 318i
    10-10-2011 10:18 PM #2
    Hello there. Good luck with the build. Let me know if I can help.
    Cin City
  3. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    10-10-2011 10:27 PM #3
    Quote Originally Posted by BARELY LEGAL View Post
    Oh im sure you will be getting a call here soon, as far as the wire tucking goes
    BHC
  4. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    10-26-2011 09:41 PM #4
    Ended up putting the rear seats back in, as i decided to reinstall my sub/amp into the trunk....
    Car as of tomorrow, is going to get the bodywork all sorted out tomorrow.
    List of things:
    -Shaved top cup on door handles
    -Shaved GTI rear emblem
    -Shaved rear wiper hole and emblem
    -Shaved rear license tub lock cylinder hole
    -Shaved wiper nozzles
    -Shaved NA front bumper (fog and side markers shaved, body line kept)
    -And fix some surface rust and a few dings
    Going to try and get it painted before the Import Alliance Fall Meet...we'll see though.
    BHC
  5. Member 95jetta17's Avatar
    Jan 20th, 2008
    York, PA
    95 2.0 turbo, 97 vr6
    10-26-2011 09:44 PM #5
    less talk...more work
    OG suede
    I survived epic thread 2011 never forget 11/11/11
    Quote Originally Posted by vastxpunk View Post
    You have a harness you forgot to plug back in, and you want to know where it goes? Back where you found it would be my guess..
  6. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    10-26-2011 09:46 PM #6
    ewerewrhth by RED2SLO4U, on Flickr
    Picture (sort of) of the engine bay.
    Havent gotten any pictures of it, because its not quite worthy yet.
    MASS pictures will be uploaded tomorrow once the work commences.
    BHC
  7. Member jbigs268's Avatar
    Nov 30th, 2009
    Rhode Island
    98 Ginster(sold) 01 Audi A4 avant QMT
    10-26-2011 10:43 PM #7
    Cant wait for this to be completed buddy
    Quote Originally Posted by 95jetta17 View Post
    not again 11/11/11 never forget
    Quote Originally Posted by vento86 View Post
    anyone got anymore pics of that yellow gti?
    Yellowlove
  8. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    10-27-2011 10:08 PM #8
    Update:
    Bodywork has started tonight for a couple hours.
    There was rust(bad surface rust) on the rear fender, some dings in a few places, and a crease on the front fender that had to get pushed out and fixed.
    Everything was pulled out as much as possible, then a very small amount of filler, more sanding, and some filler primer.
    All was done tonight, once i get access to a welder, the shaving of the hatch will commence. Most likely this weekend.
    Pictures: Some photos werent taken, as it was too dark.
    Drivers side rear fender rust. Looks alot worse than it was. Just some severe surface rust. Also, you can see the crease that is right next to the moulding, which was pin-hammered out.
    car before by RED2SLO4U, on Flickr
    Photo of the driver rear fender where the rust was, this was right when it was sanded down to remove rust, crease was removed as much as possible. Dont have pictures of the filler and primer stage.
    photo by RED2SLO4U, on Flickr
    More picture will be uploaded once my internet stops ****in up...
    BY THE WAY. It didnt take too long to sand down to the metal, literally about a second with a DA sander on the paint, and it was down to bare metal. Damn thats scary, **** you single stage.
    BHC
  9. Member mkIIIVDUB's Avatar
    Feb 23rd, 2004
    Ocean City, MD
    95 surf 20vt
    10-27-2011 11:36 PM #9
    Do mine next?
    *2011 MkIII Kickball Champions*/OCVW/DJR MK3 HELP PAGE/Never Forget/MkIII.net
  10. Member BHCgreene's Avatar
    Apr 5th, 2006
    Severn, MD
    Silver Arrow VR6, 04.5 GLI
    10-28-2011 02:55 PM #10
    Good luck!
    FS: 02M Swap with a peloquin
    BHC
    Instagram= mattgreeneva
  11. Senior Member reynolds9000's Avatar
    Oct 16th, 2003
    Chattanooga, TN
    MK3 VR6's
    10-28-2011 03:09 PM #11
    Your car is going to look wack at fall meet.
    Juuust kidding!
    I'm glad you're getting the exterior cleaned up! I saw that rust at H2O and was sad.
    SoWo
    BHC- It's not about who we are, it's just how we feel.
    Roll Tide.
  12. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    10-28-2011 06:32 PM #12
    Quote Originally Posted by reynolds9000 View Post
    Juuust kidding!
    Oh it won't look like **** for the fall meet, it'll be painted with freshly shaved bumpers and hatch
    BHC
  13. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    10-30-2011 12:35 PM #13
    Finally got the shaved bumper. Looks perfect.
    On friday, its going to my buddys house to get everything welded/shaved.
    BHC
  14. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    11-05-2011 03:40 PM #14
    UPDATE
    Everything has been welded up that needs to be welded:
    - Wiper Nozzles
    - Antenna
    - Rear Emblem
    - Rear Wiper Hole
    - Rear "Swag" Lines, under tailights
    - Hole from dent remover guy, there was a plug in the drivers door jam from where he drilled a hole and then put a plug in it afterwards, it started to rust also.
    On wednesday the plan is to get those things skim coated with filler, sanded smooth, and primered for now. Then that Friday(hopefully), it will be in the paint booth.
    Edit for some photos. FINALLY some Engine Bay pictures also
    Engine Bay 1 by RED2SLO4U, on Flickr
    Engine Bay 2 by RED2SLO4U, on Flickr
    Yes, plastic was cut to accomodate for filter. I wanted it to "hug" the manifold as must as possible.
    Engine Bay 3 by RED2SLO4U, on Flickr
    Passenger Door 1 by RED2SLO4U, on Flickr
    Passenger Rear Quarter 1 by RED2SLO4U, on Flickr
    Roof 1 by RED2SLO4U, on Flickr
    Yes, you can still see where everything was, just need to lay a skim coat of filler on those spots, and itll be good to go.
    Rear 1 by RED2SLO4U, on Flickr
    A little Euroskope.net love
    Euroskope 1 by RED2SLO4U, on Flickr
    Driver Rear Roofline 1 by RED2SLO4U, on Flickr
    A little more bodywork needs to be done to this rear quarter, its where it had some bad surface rust.
    Driver Rear Quarter 1 by RED2SLO4U, on Flickr
    Paintless dent remover spot, plug welded in and filled a little.
    Driver Door Jam 1 by RED2SLO4U, on Flickr
    Fender had a BAD crease by the headlight, fixed
    Driver Front Fender 1 by RED2SLO4U, on Flickr
    Still need to be skim coated.
    Hood 1 by RED2SLO4U, on Flickr
    Full Shot Passenger Side 1 by RED2SLO4U, on Flickr
    Full Driver Side 1 by RED2SLO4U, on Flickr
    BHC
  15. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    11-05-2011 04:14 PM #15
    doing work man
  16. Member Project Mayhem's Avatar
    Jun 11th, 2007
    Lehigh Valley PA / NJ
    00 avant 1.8T, 97 Jetta 2.8T
    11-05-2011 04:26 PM #16
    great so far
    loving the stance and wheels!
    fck vette wheels
    WTB: PZWO mirrors
    RIP
    Pring&Ed
  17. Senior Member reynolds9000's Avatar
    Oct 16th, 2003
    Chattanooga, TN
    MK3 VR6's
    11-05-2011 05:59 PM #17
    Good work! You have 3 weeks until IA. You better get to crackin'.
    SoWo
    Roll Tide.
  18. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    11-05-2011 06:08 PM #18
    Hoping to get the paint done before then, motor tucking MIGHT be done by then
    BHC
  19. Member andi_kg's Avatar
    Nov 2nd, 2004
    757 VA / 410 MD
    2 Candy White GTIs
    11-05-2011 06:54 PM #19
    Looking forward to this
    MKIII | BHC | BHCgreene
    IDM : You can't handle the truth!
  20. Member BARELY LEGAL's Avatar
    Jul 2nd, 2009
    Cincinnati, OH
    11-05-2011 08:44 PM #20
    She was a real gem to work on too. Looking good Ollie!
    Cin City
  21. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    11-05-2011 09:00 PM #21
    Mucho props for the welding! And surprising me with that intake being done! You da man
    BHC
  22. Member BARELY LEGAL's Avatar
    Jul 2nd, 2009
    Cincinnati, OH
    11-05-2011 09:12 PM #22
    Quote Originally Posted by FSAS07BOH View Post
    I do what I can to keep my people happy.
    Cin City
  23. Member make_it_rainn's Avatar
    Jan 7th, 2010
    Cincinnati
    Previous: a4 GLI & A5 GTI; Current: Chocolate 20th & Laser Blue Jetta
    11-05-2011 09:22 PM #23
    Looking so good man. You're gonna be bored for the rest of the winter. Props to Nick for that mad welding skill
    BAG RIDERS / 513 / Instagram: SWEATYSWEATER
    Condukt Co launching 2013 / Instagram: ConduktCo
  24. Member BHCgreene's Avatar
    Apr 5th, 2006
    Severn, MD
    11-05-2011 09:25 PM #24
    I like the way the shaved door cups look... BUT I wonder how much they will get scratched up opening the door over time
    BHC
  25. Member upoo2's Avatar
    Dec 6th, 2005
    Lexington, KY
    A1, A3
    11-05-2011 09:37 PM #25
    You should shave your rimz.
    |CHA BOI|KHROME|RIMZOS|
    |Instagram: DEMRIMZ|
    |my build|
  26. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    11-05-2011 10:02 PM #26
    Quote Originally Posted by mattgreeneva View Post
    Yeah ive thought it over, i was gonna shave the top half of the cup, but figured it would be a little tough getting that body line to look right. So, im just gonna color match the door handles and be done with it
    Quote Originally Posted by upoo2 View Post
    That ****s gettin KHROMED DIPPED after Import Alliance
    BHC
  27. Member 95jetta17's Avatar
    Jan 20th, 2008
    York, PA
    11-05-2011 10:10 PM #27
    looking good keep working
    OG suede
  28. Moderator vanaman's Avatar
    Aug 26th, 2003
    OhiO
    97 Jetta GLX, 99 Cabrio, 03 Sierra SLE, 90 XT600, 84 ATC200X, 78 CB750F, 66 S90
    11-05-2011 10:29 PM #28
    so you put your air filter right behind the radiator fan so it can suck all the hot air?
  29. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    11-05-2011 10:42 PM #29
    Quote Originally Posted by vanaman View Post
    Yep
    BHC
  30. Moderator vanaman's Avatar
    Aug 26th, 2003
    OhiO
    11-05-2011 11:03 PM #30
    ok
  31. Member mkIIIVDUB's Avatar
    Feb 23rd, 2004
    Ocean City, MD
    95 surf 20vt
    11-05-2011 11:18 PM #31
    You come to ocean city for a month when you are finished, stay with me, I will feed you and you can do mine.
  32. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    11-06-2011 12:13 AM #32
    Quote Originally Posted by mkIIIVDUB View Post
    Pay for my gas and im there
    BHC
  33. Banned vento86's Avatar
    Oct 13th, 2008
    11-06-2011 12:24 AM #33
    lookin good dude. cant wait to see the bay when your done
  34. Member BHCGanshirt's Avatar
    Feb 2nd, 2008
    Louisville, KY
    1998 Ginster GTI
    11-06-2011 12:50 AM #34
    Seeing the polished intake setup now, im rethinking the whole "blacked out" engine bay(plans were to paint/powdercoat everything black), but im kinda leaning toward polishing that manifold...
    BHC
  35. Member mkIIIVDUB's Avatar
    Feb 23rd, 2004
    Ocean City, MD
    95 surf 20vt
    11-06-2011 01:09 AM #35
    black khrome
