VWVortex.com - Duetto; Motivate me
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 73
    Thread: Duetto; Motivate me
    1. 10-11-2011 08:16 AM #1
      The Duetto has sat, accumulating dust and additional microns of rust for 12 months now, whilst i buy the odd shiny thing from Alfaholics & ClassicAlfa etc.
      It's not (really) a matter of money.. more a case of time management and me wanting to be involved in her (??) rebirth. I've sourced OEM panels to replace anything with a dent, rust or hysterical welding (all floors, nose, that arch, the boot).
      I stand at the crossroads of paint removal.
      Complete dip immersion (Alkaline) by Redistrip in NSW (est. $3K) or a professional sandblast for the chasssis and dip anything that bolts off here in Qld.. it's about twice as much for the redistrip ($not an issue), more a logistical get it to Sydney thing. Some people hate dipping, personally i like the idea of converting all rust in the seams to metal and etch coating the #uck out of anything that was joined.
      And then what colour.. i hate red.. somebody give me a 60's sky blue (maserati) metallic that will pop the curves (a bit like the BMW x5?!). Do i flick the original 1600 twin carb for a 2L twinspark (already bought).
      too may reds tonight
      should be doing the 2012 OP plan.
      or shagging a gradaute
    2. 10-11-2011 09:00 AM #2
      you like pinot?
    3. 10-11-2011 09:09 AM #3
      *L*.. it's a french Bordeaux.. no doubt something to do with me faffing about with the whilte balance on the camera (neon1)... see, still procrastinating !!
    4. 11-12-2011 10:40 AM #4
      Some progress. I pulled apart the drivers door as it had a large dent and kilograms of bog upsetting the delicate balance of the vehicle. I hand prepped the frame but was unhappy with the flash rust in the cavities I couldn't get into. I had the frame (alkaline) dipped then lightly blasted. The skin (new original tooling) was hand prepped before everything was epoxy primed.
      I'm chuffed to bits, looks great.
      I'm planning on using 3M epoxy to put this back together.. Just like a big airfix
      This is the paint I am working with... and the reason we're going back to metal for those of you who said "roll it as it is".. It's been rolled, passed to the left and smoked for far too long, trust me.
      Bonnet and scuttle are off for the same treatment as the door.
      The nose and wings are next although they're spot welded on.
      ... I need to update Ways "what have you bought thread" with an spanking new AEG sawzall
    5. Member mdt's Avatar
      Nov 22nd, 2001
      Melbourne
      M135i
      11-12-2011 03:12 PM #5
      Yes to the twinspark. You'll no doubt miss the 1600, but the electronic ignition will make the car much easier to live with.
      That door looks awesome. If you can finish the whole of the car to that standard, it's going to be a cracker.
    6. Senior Member Lima's Avatar
      Oct 26th, 2002
      Canberra, Australia
      MY10 Audi S3
      11-12-2011 07:52 PM #6
      Quote Originally Posted by mdt View Post
      I concur.
    7. Member mikinoz's Avatar
      Jun 20th, 2005
      Blue Mountains
      Ibiza Cupra 16v
      11-13-2011 04:15 AM #7
      Just keep plugging away at it. I've pulled the Imp out and will get it registered for the first time in 4 years, excited me just doing a shakedown around the block.
      It will improve your life to go for a drive now and then in this!
      I like your approach!
    8. 11-20-2011 05:30 AM #8
      Princess Amidala, your '66 Alfa Duetto awaits.
      Looks cool in polished metal.. Maybe I should go all Harrods Sheik and paint it in that Mercedes liquid metal (stuff).
      No damage in this door (yay)
      some damage above that wheel arch (yay)
      Kilograms of bog gone.. silicosis here I come
    9. 11-22-2011 08:59 AM #9
      More bits back from the dipper today, scuttle looks new
      Bonnet on the other hand appears to have been bump parked and/or shagged on for 46 years
      Looking to replace with new if I can find one.
    10. Member Aussie_Golfa's Avatar
      May 24th, 2005
      MKVI Golf GTI - MKVI Polo TSI
      11-25-2011 04:40 AM #10
      Quote Originally Posted by craig_m5 View Post
      You are wearing dust masks (or at least a hankie) aren't you
      And those lovely rims need to come off and go under the bed until all of the grinding, tool dropping, liquid splashing is finished, stick some old runners on it for the resto.
      Are you going to glue the door panels together?? Is that a new tequnique (for this car) or is it a modern improvisation????
      Lovely to see, keep the updates coming.
    11. 11-25-2011 06:14 AM #11
      Just as well you clarified, we could have become confused that it was a Peruvian Bordeaux instead...
    12. 11-25-2011 07:47 AM #12
      Yep, using a mask.. and glasses, of sorts. The thongs were a bad idea..
      Glueing (epoxying) panels on is a modern technique. Originally the car was held together with numerous spot welds, lead wiped between joints and of course factory rust in all box sections (no primer!).
      I've got some 3M epoxy for the skins and will seam weld everywhere for strength. The epoxy glues come in different strengths etc and can be stronger than welding in some cases (my welds for instance ). I'll probably do a mix with the wings and nose, pretty sure they're not (too) structural. In fact I was planning to epoxy in/on all panels, floors etc and the seam weld. Although this might affect front and rear crumple zones... Yes, this car is Alfas first car to be designed with crumple zones (on purpose )
      Yes I'm making it all up...
      Have ordered two new front wings and outer sills. Might as well do this properly
    13. 12-05-2011 08:07 AM #13
      Which have now arrived, lines so sharp i promptly cut my freakin finger (bastard)
      wonder if I can get this done before Lima gets his car back
      Oh, and I tracked down an original perfect boot/trunk lid, these are made of unobtanium..The most expensive bit yet (yay!)
      Merry Christmas - nobody tell Cathy
    14. 01-09-2012 02:13 AM #14
      .... and a new bonnet to replace the original which had been abused and slathered with bog by a bastard '70s panel beater, perhaps i could wrap it in carbon fibre
      Side by side shot - they changed the frame structure after mine. The OCD alfanazi purists will have a fit that i'm not reskining this with recylced original russian steel hand stretched by italian virgins... can't afford them - all this is getting out of hand (could have bought a Panerai by now).
      Did Liam get his car back yet - how much more time do i have
    15. Member mikinoz's Avatar
      Jun 20th, 2005
      Blue Mountains
      Ibiza Cupra 16v
      01-11-2012 06:54 AM #15
      I think this is progressing very nicely.
      Was the deadline Liam getting his car back or his house built. Either way, you probably will still have a bit of time up your sleeve.
      (BTW - Imp is registered! Only needed new brake lines and grease the kingpins)
    16. Geriatric Member J-Tim's Avatar
      May 26th, 2000
      Kangaroo-infested Austria
      German/American/Italian
      01-11-2012 07:20 AM #16
      Yes, because Chinese steel is soooo much better!
      Just kidding
      And now for something completley different...A Scotsman on a horse.
    17. 01-13-2012 05:02 AM #17
      Quote Originally Posted by J-Tim View Post
      Just kidding
      German steel actually.. they're the only people making good reproductions from the original dies.
      Opened up the nose.. found ancient damage hidden and never correctly repaired.
      Yay, more bits to find/buy/make
    18. Geriatric Member J-Tim's Avatar
      May 26th, 2000
      01-13-2012 05:11 AM #18
      Ughhh that's nasty!
      Good luck!
    19. 01-13-2012 05:14 AM #19
      will make getting the engine out easier
    20. 01-13-2012 05:31 AM #20
      lol i was pulling apart one of my minis for parts the other day and made more than one discovery like that, though less of the "bad repair" more a "feature" of british steel in just about every nook and cranny of the car Also random question to anyone who cares, clubman shell, rusted to ****, surely not worth fixing? i really couldnt be arsed but its gonna be hard seeing her leave my life 16 years and being my primary mode of transport during the "golden years" hah
      I know youre trying to save money/do it yourself for the love and all that but thats the best part about just taking it somewhere to be stripped and fixed properly, its sans the heartache of every reveal of something crappy you should have expected, but weren't
    21. Member sweatyworker's Avatar
      May 4th, 2005
      Melbourne, Australia
      01-13-2012 06:57 AM #21
      You can buy a brand new clubman shell from the UK. NFI what the cost is though... Actually it's 6000 pounds sterling plus shipping
    22. Member mikinoz's Avatar
      Jun 20th, 2005
      Blue Mountains
      Ibiza Cupra 16v
      01-14-2012 05:33 PM #22
      Quote Originally Posted by sweatyworker View Post
      Better off buying someone's car that they have done a full reto on at that point for 10-15k.
      Craig you should have found most of the surprises by now right?
    23. Member irsa76's Avatar
      Mar 28th, 2003
      Queanbeyan Australia
      2008 Mitsubishi Colt. 2012 Citroen C4 Grand Picasso
      01-14-2012 08:40 PM #23
      There's a bloke on another forum restoring a 105 and every time he thinks he's found all the horrors, more rust is uncovered. He joked that he might as well cut the car in half lengthways and replace the entire driver's side.
      But then again he daily drives a 164 and his mrs owns a Rover 75, not to mention has half a dozen motorbike "projects" so he's probably insane!
    24. 01-22-2012 06:51 AM #24
      Yep, there are no new surprises for me here. I've had this car (on & off) for over a decade, I know all her secrets. It's all just a bit ugly when it gets out in the air. Continuing a theme, the dodgy front end and unknown repairs to front sills forced me.. Hope I can weld as well as I can cut
      Somebody has been here before...
    25. 01-22-2012 07:18 AM #25
      Holy snapping duckshiiit Craig. I thought early model UK Fords were bad but I bow down to your perseverance.
      iPad Certified.
